Alternating serie
sum((-1)^(n+1)/(2*n-1), n = 1 .. infinity)
(1/4)*Pi
sum((-1)^(n + 1)/(2*n - 1), n = 1 .. infinity):
sum((-1)^(n+1)/(2*n-1), n = 1 .. 4)
76/105
expand(sum((-1)^(n + 1)/(2*n - 1), n = 1 .. 4),symbolic);
76/105
?expand
series(sum((-1)^(n + 1)/(2*n - 1), n = 1 .. infinity),n=0,5);
series((1/4)*Pi,n)
Info series
How to get for n= 4  "for (∑)(((-1)^(n+1))/(2 n-1))  =   symbolic term 1+ symbolic term 2+... "
Download onderzoek_reeks_-hoe_krijg_ik_een_partieke_symbolische_som.mw
Input:
 a := x^2;
 whattype(x);
 b := x[1]^2;
 whattype(x[1]);
 CodeGeneration[C](a);
 CodeGeneration[C](b);
Output:
Do you know why cg0 =/= x[0]*x[0]?
Hello people in MaplePrimes,
I can't understand a code with PLOT3D using GRID in it.
I hope you will give me explanation about it.
k:=[[1,2,10],[1,1,8],[0,1,5],[0,0,6]];
PLOT3D(GRID(1..2,1..3,k),
       AXESLABELS(x,y,z));
I cannot understand the correspondence between points in the graph and lists in the code such as [1,2,10], [1,1,8].
 As two ranges in GRID augments in the code are 1..2 and 1..3, x takes value from 1 to 2, and
y from 1 to 3 in the picture.
And, as k is k:=[[1,2,10],[1,1,8],[0,1,5],[0,0,6]], which means this list of lists are 4 X 3, so in the picture
as for x the interval of 1 to 2 is divided to three sections with the points of value of 0, 1/3, 2/3 and 3/3, which total number is 4.
And, as for y the interval of 1 to 3 is devided to two sections with the points of value of 1, 2 and 3, which total number is 3.
And, I cannot understand why from the grid of [1,1,8] in the code, which I think is the coodinate of (1, 1) on x-y plane, does not mean that the value of z on that point on the graph is not 8, but 1.
graph.mw
sys:={-diff(v(x,t),t)+0.5*p*diff(u(x,t),x,x)+q*u(x,t)*(u(x,t)^2+v(x,t)^2)=0,diff(u(x,t),t)+0.5*p*diff(v(x,t),x,x)+q*v(x,t)*(u(x,t)^2+v(x,t)^2)=0};
        /                      /  2         \
        |/ d         \         | d          |
sys := < |--- u(x, t)| + 0.5 p |---- v(x, t)|
        |\ dt        /         |   2        |
        \                      \ dx         /
               /       2          2\       / d         \
   + q v(x, t) \u(x, t)  + v(x, t) / = 0, -|--- v(x, t)|
                                           \ dt        /
           /  2         \                                      \
           | d          |             /       2          2\    |
   + 0.5 p |---- u(x, t)| + q u(x, t) \u(x, t)  + v(x, t) / = 0 >
           |   2        |                                      |
           \ dx         /                                      /
eq1 := diff(u(x,t),t) = u__t(x,t):
eq2 := diff(v(x,t),t) = v__t(x,t):
sys_tmp := subs(eq1, eq2, sys):
sys_new := sys_tmp union {eq1, eq2}:
Boundary conditions:
bc :=
    u(0,t) = 2,
    v(0,t) = 0;
                 bc := u(0, t) = 2, v(0, t) = 0
Initial conditions:
ic :=
    u(x,0) = tanh(2*Pi),
    v(x,0) = tanh(2*Pi),
    u__t(x,0) = 0,
    v__t(x,0) = 0;
ic := u(x, 0) = tanh(2 Pi), v(x, 0) = tanh(2 Pi), u__t(x, 0) = 0,
  v__t(x, 0) = 0
Solve the system:
pdsol := pdsolve(subs(p=1, q=0.5, sys_new), {ic, bc}, numeric);
I want to change my variables. The coding below shows the influence of the Nb and Nt on the local Nusselt number (-theta') against the convection Bi.
But now I want it to be  the influence of the Bi on the local Nusselt number (-theta') against the Nb and Nt.
Can anyone help me?
with(plots)
DE1 := diff(f(eta), `$`(eta, 3))+f(eta)*(diff(f(eta), `$`(eta, 2)))-(diff(f(eta), eta))^2 = 0
diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))-(diff(f(eta), eta))^2 = 0
DE2 := diff(theta(eta), `$`(eta, 2))+Pr*f(eta)*(diff(theta(eta), eta))+Pr*Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Pr*Nt*(diff(theta(eta), eta))^2 = 0
diff(diff(theta(eta), eta), eta)+Pr*f(eta)*(diff(theta(eta), eta))+Pr*Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Pr*Nt*(diff(theta(eta), eta))^2 = 0
DE3 := diff(phi(eta), `$`(eta, 2))+Le*(diff(phi(eta), eta))+Nt*(diff(theta(eta), `$`(eta, 2)))/Nb
diff(diff(phi(eta), eta), eta)+Le*(diff(phi(eta), eta))+Nt*(diff(diff(theta(eta), eta), eta))/Nb
BC1 := f(0) = 0, (D(f))(0) = 1, (D(f))(10) = 0
BC2 := theta(10) = 0, (D(theta))(0) = -Bi*(1-theta(0))
BC3 := phi(0) = 1, phi(10) = 0
  getRes:= proc(a, x);
                local sol;
                if   type(x, numeric)
                then sol:= dsolve
                           ( eval
                             ( {BC1, BC2, BC3, DE1, DE2, DE3},
                               [Nt = a, Nb = a, Pr = 2, Le = 5, Bi = x]
                             numeric,
                             output = listprocedure,
                             abserr = 0.0001,
                             maxmesh = 1024,
                             initmesh = 512
                else return 'procname(a,x)';
                fi;
                return -eval(diff(theta(eta), eta), sol)(0)
  cl:=[red, green, blue, yellow, black]:
  L:=[0.2, 0.4, 0.6,0.8,1.0]:
  display
  ( [ seq
      ( plot
        ( getRes( L[k], x),
          x=0..5,color = colorList[k], legend = ["Nb=Nt" = L[k]], legendstyle = [location = top],
          color=cl[k]
        k=1..5
Download odeProb2.mw
Contour integration notation
" (&int;)[+infinity]^(+infinity)((-x)^(z))/((e)^(x)-1). (&DifferentialD;x)/(x)"
The limits of integration are intented to indicate a path of integration which begins at + ∞, moves to th e left down the positive real axis, circles the orign once in positive ( counterclockwise) direction, and returns up to the positive real axis to  +∞
-How does this contour look like  in a  graph ?
- the "(&DifferentialD;x)/(x)" notation  ?
- calculating this complexe contour integral?
Seems that the concept of the contour integration is similar wit a line integral in real calculus ?
Some more information needed about singularities ( first en second order ..more?)
Nieuwe pagina 1 (hhofstede.nl)
Download contourintegraal_vraag1.mw
I have just come across this curious but really boring problem.
In the code snippet below, expr1 and expr2 are identical.
data := [a=1, b=2]:
convert(
  piecewise(And(x(t) > a, x(t) < b), 1, 0),
  Heaviside
expr1 := eval(eval(%, data),  x(t)=z):
plot(expr1, z=0..3);
convert(
  piecewise(And(z > a, z< b), 1, 0),
  Heaviside
expr2 := eval(%, data),:
plot(expr2, z=0..3);
But if I change the parameterization of the problem, expr2 is still correct but expr1 is not
data := [d=1.5, a=0.5]:
convert(
  piecewise(And(x(t) > d-a, x(t) < d+a), 1, 0),
  Heaviside
convert(
  piecewise(And(z > d-a, z< d+a), 1, 0),
  Heaviside
Where does this come from?
PS: I'm sorry not to be able loading the mw file
I would like to write to a file the output of the command CodeGeneration[Matlab]. I couldn't find a way to write the output.
What I am trying to do is to generate complex symbolic equations and expressions and write them as either a function or variables in matlab.
As an example:
exp := [sin(theta(1)), cos(theta(1))];
func := unapply(exp,[theta]);
CodeGeneration:-Matlab(func)
If i can write the output of the above command in a matlab file, it will generate a matlab function file.
I was using the command 'writeto' but this one basically outputs every line a command written to a file instead of the terminal, which is not what I want (it will output even the warnings, I know I can silent them!).
can you please help.. thanks.
Hello guys,
I want to plot two functions such as x(t) and y(t) in a unique diagram as a function of each other. In a routine way, one needs to solve one of these functions as t and then input its results in others. for example, solving x(t) to find t and then input this t(x) into y(t) to have y(x). but here problem is that I cannot solve x(t) to find t and so this routine solution is not accelssible.
x(t):=1 + (3*n*(v - 1)^2*A*(t^v)^2*(1 + alpha*(v - 1)^2*A^2*(t^v)^2*ln(m^2*t^2/((v - 1)^2*A^2*(t^v)^2))/(3*n^2*m^2*t^2) + A^2*beta*(v - 1)^2*(t^v)^2/(3*n^2*m^2*t^2))*((4*A^2*alpha*t^v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + 6*t^(-v + 2)*m^2*n^2 + 4*t^v*(beta - alpha/2)*A^2*(v - 1)^2)*sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2) - 3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2))*(1 + ((4*A^2*alpha*t^v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + 6*t^(-v + 2)*m^2*n^2 + 4*t^v*(beta - alpha/2)*A^2*(v - 1)^2)*sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2) - 3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2))/(3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2))))/(2*v^2*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2)) - (3*n^2*(v - 1)^2*A^2*(t^v)^2*(1 + alpha*(v - 1)^2*A^2*(t^v)^2*ln(m^2*t^2/((v - 1)^2*A^2*(t^v)^2))/(3*n^2*m^2*t^2) + A^2*beta*(v - 1)^2*(t^v)^2/(3*n^2*m^2*t^2))*(((4*A^2*alpha*t^v*v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2))/t + 4*A^2*alpha*t^v*(v - 1)^2*(2 - 2*v)/t + 6*t^(-v + 2)*(-v + 2)*m^2*n^2/t + 4*t^v*v*(beta - alpha/2)*A^2*(v - 1)^2/t)*sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2) + (4*A^2*alpha*t^v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + 6*t^(-v + 2)*m^2*n^2 + 4*t^v*(beta - alpha/2)*A^2*(v - 1)^2)*n^2*(v - 1)^2*A^2*t^(2*v)/(sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2)*v*t) - 3*n*A*(2*A^2*alpha*t^(2*v)*v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2))/t + A^2*alpha*t^(2*v)*(v - 1)^2*(2 - 2*v)/t + 2*A^2*beta*(v - 1)^2*t^(2*v)*v/t + 6*n^2*m^2*t))/(3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2)) - (((4*A^2*alpha*t^v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + 6*t^(-v + 2)*m^2*n^2 + 4*t^v*(beta - alpha/2)*A^2*(v - 1)^2)*sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2) - 3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2))*(2*A^2*alpha*t^(2*v)*v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2))/t + A^2*alpha*t^(2*v)*(v - 1)^2*(2 - 2*v)/t + 2*A^2*beta*(v - 1)^2*t^(2*v)*v/t + 6*n^2*m^2*t))/(3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2)^2)))/(2*v^2):
y(t):=1 + ((4*A^2*alpha*t^v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + 6*t^(-v + 2)*m^2*n^2 + 4*t^v*(beta - alpha/2)*A^2*(v - 1)^2)*sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2) - 3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2))/(3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2)) - (((4*A^2*alpha*t^v*v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2))/t + 4*A^2*alpha*t^v*(v - 1)^2*(2 - 2*v)/t + 6*t^(-v + 2)*(-v + 2)*m^2*n^2/t + 4*t^v*v*(beta - alpha/2)*A^2*(v - 1)^2/t)*sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2) + (4*A^2*alpha*t^v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + 6*t^(-v + 2)*m^2*n^2 + 4*t^v*(beta - alpha/2)*A^2*(v - 1)^2)*n^2*(v - 1)^2*A^2*t^(2*v)/(sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2)*v*t) - 3*n*A*(2*A^2*alpha*t^(2*v)*v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2))/t + A^2*alpha*t^(2*v)*(v - 1)^2*(2 - 2*v)/t + 2*A^2*beta*(v - 1)^2*t^(2*v)*v/t + 6*n^2*m^2*t))/(3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2)) - (((4*A^2*alpha*t^v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + 6*t^(-v + 2)*m^2*n^2 + 4*t^v*(beta - alpha/2)*A^2*(v - 1)^2)*sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2) - 3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2))*(2*A^2*alpha*t^(2*v)*v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2))/t + A^2*alpha*t^(2*v)*(v - 1)^2*(2 - 2*v)/t + 2*A^2*beta*(v - 1)^2*t^(2*v)*v/t + 6*n^2*m^2*t))/(3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2)^2))*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2)/((4*A^2*alpha*t^v*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + 6*t^(-v + 2)*m^2*n^2 + 4*t^v*(beta - alpha/2)*A^2*(v - 1)^2)*sqrt(n^2*(v - 1)^2*A^2*t^(2*v)/v^2) - 3*n*A*(A^2*alpha*t^(2*v)*(v - 1)^2*ln(m^2*t^(2 - 2*v)/((v - 1)^2*A^2)) + A^2*beta*(v - 1)^2*t^(2*v) + 3*n^2*m^2*t^2)):
there are x(t) and y(t). I want to plot y as x, not t. so please help me.
with best
Hello people in Mapleprimes,
I haven't written in this site for a long time.
I have a question in the below program, which is to write ribbons.
For the implementation of this program,
I wrote this.
ribbonplot5([cos, sin, cos + sin], -Pi .. Pi,numpoints=20);
In the part of pattern matching, as -Pi .. Pi above is a range, so it is OK.
But, when I changed this part to x=-Pi..Pi, an error message appears.
ribbonplot5([cos, sin, cos + sin],x=-Pi .. Pi,numpoints=20);
brings error messages:
"Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct"
In the code of ribbonplot5,  x=-Pi..Pi which is the type of name=range shoud satisfy the pattern matching, as I wrote in the first part of the program as
ribbonplot5 := proc(Flist, r1::{range,name=range})
I cannot know why the part of the program:
" else
       newFlist := map(unapply, Flist, lhs(r1));
     opts := ['labels'=[lhs(r1), " "," "],
                 args[3 .. nargs]];
    ribbonplot5(newFlist,rhs(r1),op(opts)):
wouldn't work well.
I wish I could get an answer to this.
This is a program in maple9 Advanced Programming Gude p. 253
graphic_ribbonplot.mw
extend := proc(f)
     local x, y;
     unapply(f(x), x, y);
p:=x->cos(2*x):
q:=extend(p);
     local i, m, p, n, opts,newFlist;
     opts := [args[3 .. nargs]];
     if type(r1, range) then
         if not hasoption(opts, 'numpoints', 'n', 'opts')
         then n := 25
         m := nops(Flist);
         p := seq(plot3d(extend(Flist[i]), r1, (i-1) .. i,
                                  grid=[n, 2], op(opts)),
                       i = 1 .. m):
         plots[display](p):
                 args[3 .. nargs]];
   end if:
I'd like to get the simplest possible expression when using simplify. The problem is that this is all done in a program, without having the benifit of looking at the expression on the screen and trying things. So I need a method that works for large set of input all the time.
I noticed in this example that simplify did not do what I think it should have.
Given the expression -2*(x^3 + 2)/(x*(x + 1)*(sqrt(3)*I + 2*x - 1)*(sqrt(3)*I - 2*x + 1)) it can be simplified to (x^3 + 2)/(2*x^4 + 2*x) but  I had to go into many tries in order to get this final result.
Is there a better way to do this? I end up now   doing simplify(expand(numer(expr))/expand(denom(expr))) in the hope to get better simplification.  Here is an example
w:=-2*(x^3+2)/x/(x+1)/(I*3^(1/2)+2*x-1)/(I*3^(1/2)-2*x+1);
-2*(x^3+2)/(x*(x+1)*(I*3^(1/2)+2*x-1)*(I*3^(1/2)-2*x+1))
simplify(w)
(-2*x^3-4)/(x*(x+1)*(I*3^(1/2)+2*x-1)*(I*3^(1/2)-2*x+1))
simplify(evalc(w))
(1/2)*(x^3+2)/((x^2-x+1)*(x+1)*x)
simplify(w) assuming x::real
simplify(w,size)
simplify(w,symbolic)
simplify(w,sqrt)
simplify(expand(numer(w))/expand(denom(w)))
(x^3+2)/(2*x^4+2*x)
It would be nice if Maple simplify would just do it directly as follows in Mathematica. May be there is a an  option I am overlooking
Download simplify.mw
I drew a methane molecula and display three times because I wanted to get two-fold and three-fold symmetry axis. ,I would is that I would like to get a more exact output and doing it without clicking, it's say, using code. Can someone help me?tareaclase6.mw
University of Costa Rica
Course: SP-1493
Student: Lic. Marcus Vinicio Mora Salas
Instructor: Dr. Erick Castellón Elizondo
Assigment5
Description
In this assigment exercises e2.113,  e2.114, e2.115 and e2.117 was solved.
***e2.113
Download tareaclase6.mw
Suppose I have a real function which is defined on these intervals [x0,x1],...[x1,xn], and on each interval it's defined differently, for example f(x):=sqrt(x) if x>=0; f(x):=1/x if x<0.
For the last example I tried my last resort to use the assuming operator the following way:
f := ((x -> sqrt(x)) assuming (0 <= x)) or ((x -> 1/x) assuming (x < 0)) plot(f, x)
But it doesn't seem to be working, how do you propose to define this function? perhaps proc?
I tried looking for an example in maple's help, but didn't find any.
Your help is appreciated.
I read that abs(v) should find the magnitude of complex number. But I find cases where it does not.
Should one then use sqrt( Re(v)^2 + Im(v)^2 ) instead or is there different command to use?  Here is an example
interface(version)
v:=1/16*(I*5^(1/2)+I-4*sin(1/5*Pi))*2^(3/10)*(5-5^(1/2))^(1/2)-1/8*2^(4/5)*((I*5^(1/2)+I)*sin(1/5*Pi)+1/2*5^(1/2)+3/2)
(1/16)*(I*5^(1/2)+I-4*sin((1/5)*Pi))*2^(3/10)*(5-5^(1/2))^(1/2)-(1/8)*2^(4/5)*((I*5^(1/2)+I)*sin((1/5)*Pi)+(1/2)*5^(1/2)+3/2)
abs(v)
-(1/16)*(I*5^(1/2)+I-4*sin((1/5)*Pi))*2^(3/10)*(5-5^(1/2))^(1/2)+(1/8)*2^(4/5)*((I*5^(1/2)+I)*sin((1/5)*Pi)+(1/2)*5^(1/2)+3/2)
sqrt( Re(v)^2 + Im(v)^2 );
((-(1/4)*2^(3/10)*(5-5^(1/2))^(1/2)*sin((1/5)*Pi)-(1/8)*2^(4/5)*((1/2)*5^(1/2)+3/2))^2+((1/16)*2^(3/10)*(5-5^(1/2))^(1/2)*(5^(1/2)+1)-(1/8)*2^(4/5)*(5^(1/2)+1)*sin((1/5)*Pi))^2)^(1/2)
Download complex.mw
Here is the same thing in Mathematica:
I searched help for modulus but could not find one.
Maple 2021.2
Can someone confirm, that autosave is not implemented for workbooks?
The only thing I can restore form a workbook session are specific worksheets of the workbook that I was working on.
None of the Maple codes are saved for example.
This is a major issue, folks. If you haven't implemented it, you need to tell us about it in the help document.
IN CAPITAL LETTERS!
First 377 378 379 380 381 382 383 Last Page 379 of 2458
