Seems to me informative to see a earth-like surface on a sphere and in particular from the zeta function.
Another simple complex function will do it also.
Note: i saw a  3D picture with a colored sphere , where you can see zeroes and poles on the surface of the sphere
A colored complex function is that hard to make with Maple too?: it are all polar coordinates as complex points in the complex plane.
The angle is standing for hue and the magnitude is standing for the lightness
I am trying to get a family of curves on one graph. Each curve a different colour and labeled
P=2, Q=0 , P=2,Q=1 , etc
mmcdara 's proposal for inspiration?
https://www.mapleprimes.com/questions/233088-How-Do-I-Plot-A-Function-Of-Two-Variables
Family_of_curves_plot.mw
I looked at combinat package but it is too large and could not find what I want.
I'll explain with example to make it easy. Given n=2 I want to generate all possible arrangements of sets of length n where each element can be either +1 or -1. So it will be 2^n=4 possible arrangements
And for n=3 then want to generate all possible sets of length 3 where each element can be either +1 or -1 so it will be  2^n=2^3=8 possible sets
And for n=4 it will be 2^n=16 possible arrangements
And so on. I picked [+1,-1] in the above as an example.
Is there a command to do this in Maple?  I can ofcourse program it using using loops and if's and so on. But thought there might be a command in Maple package which will generate all these possibles sets. Either as list of lists or Matrix or any other format.
K := proc (x, t) options operator, arrow; 5*x+3*t end proc; 1; f := proc (x, t) options operator, arrow; 2*x+3*t^2 end proc
"g(x,t):=f(x,t)+(∫)[0]^(t)K(x,t-u) ⅆW(u)  "
where W(u) is wiener process
how to solve this integeral at t=.5sec and plot sample paths for x=0..5
Download stochastic_integral.mw
Hello there,
When I tried to write an expression with the '1d' subscript, I found that it was automatically translated as '1.'. The following worksheet shows an example. Is there any chance to preserve the expression as I intended to see?
eq3_130:= Psi[fd] = L[ffd]*i[fd]+L[f1d]*i[1d]-L[ad]*i[d];
Psi[fd] = -L[ad]*i[d]+L[f1d]*i[1.]+L[ffd]*i[fd]
Download Q20220121.mw
Really , the complex plotting possibilities in Maple are difficult to decipher.
I tried something, but  in general the visualizing for me is not that easy
Now i must look at the complexplot where i got a circle for  the complexplot(sin(x + I), x = -Pi .. Pi) example ?
     Can you enter debug in a worksheet vs a proc?
    I have a for loop that is crashing in the middle with a bad calculated number to provide to a thermoprops function.   Is there a way to single step through a for loop (1500 iterations) to see which line is getting tripped up?  I can not post the worksheet as it's private development.   The question is generic to any "for loop".
   I have also tried "porting" into a code edit region, but still can not enter the debugger mode.   Is proper debugger only available if I turn the "for loop" into a proc?   If yes, what is the availability of packages called right after restart for the worksheet for a proc, or do all the pre-calcs developed in the worksheet and the packages to be variables fed into the proc or packages re-declared insde a new proc ???
  Sorry if this is a trival question.
Thanks in advance,
Bill
I solve numerically a DAE system whose independent variable is named t and the dependent variables are d[1](t), ..., d[n](t).
I would like to to 2D or 3D plots of the solutions and color the resulting curve using a function f(...) of the remaining dependent variables.
Here is a simple example.
sys := {
   diff(x(t), t) = v(t)
  ,diff(v(t), t) = cos(t)
  ,x(0) = -1
  ,v(0) = 0
  ,px(t) = piecewise(x(t) >=0, 1, -1)
  ,pv(t) = piecewise(v(t) >=0, 1, -1)
sol := dsolve(sys, numeric):
odeplot(sol, [t, x(t), v(t)], t=0..4*Pi)
# I would like to color this space curve depending on the signs of x(t) and y(t)
# for instance, f being a "color function"
f := proc(s)
  local a, b:
  if s::numeric then
    a := round(eval(px(t), sol(s))):
    b := round(eval(pv(t), sol(s))):
    return piecewise(a+b = 2, "Green", a = 1, "Red", b = 1, "Blue", "Gold")
  end if:
SOL := proc(s)
  if s::numeric then
    eval([t, x(t), v(t)], sol(s))
  end if:
# I would like to make something like this to work
plot3d(SOL(s), s=0..4*Pi, colorfunc=f(s)):  #... which generates a void plot
# In some sense a continuous version of this
opts := symbol=solidbox, symbolsize=20:
display( seq(pointplot3d({SOL(s)}, opts, color=f(s)), s in [seq](0..6, 0.1)) );
Download coloring.mw
How can I fix (if possible) the syntax in the command
Has someone tried to connect Grasshopper with Maple yet?
Grasshopper is a visual programming environment on Rhino.
https://en.wikipedia.org/wiki/Grasshopper_3D
Try to calculate the values for the Zeta(z) on the critical line in symbolic form and also as a plot
Both i did not yet succeed in
f:=z->Zeta(z);
complexplot3d(f,-1-1*I..1+1*I);
solve(f = 1/2 , z )
Hello;
I am facing "Error, too many levels of recursion" in loops. kindly guide me. Thanks
1D1P.mw
restart; printlevel := 3
restart; with(LinearAlgebra); with(linalg); with(CodeGeneration); with(plots); Digits := 30; `ε` := 0.1e-1; k := .5; m := 1; c := 1; q := 1
L[time] := 1:
.200000000000000000000000000000
ICff := 1.0*exp(-p^2/(2.0))*(1.0+epsilon*cos(1.0*k*x))/sqrt(2.0*Pi):
for i from 0 while i <= N[x] do for j from 0 while j <= N[p] do f[0, i, j] := eval(ICff, [x = i*`&Delta;x`, p = j*`&Delta;p`]) end do end do:
for n from 0 while n <= T do for j from 0 while j <= N[p] do f[n, 0, j] := 0; f[n, N[x], j] := 0 end do end do:
for n from 0 while n <= T do for i from 0 while i <= N[x] do f[n, i, 0] := 0; f[n, i, N[p]] := 0 end do end do:
for n1 from 0 while n1 <= T-1 do for i1 while i1 <= N[x] do for j1 while j1 <= N[p] do f[n1+1, i1, j1] := f[n1, i1, j1]-`&Delta;t`*j1*`&Delta;p`*(f[n1+1, i1+1, j1]-f[n1+1, i1-1, j1]+f[n1, i1+1, j1]-f[n1, i1-1, j1])/((4*`&Delta;x`)*(1.0)) end do end do end do
Dear esteem Colleagues,
Please how do I modify the following two files (though similar) to get consistent errors? I am not sure where I made the mistake.
Any modifications would be appreciated.
Thank you all for your time and mentorship. Best regard
Biratu_Mapleprimes.mw
DDE_2_Mapleprime.mw
I would like to emphasize a particular region of my plot by shading the whole strip between x=0 and x=1. I learned of the command shadebetween, but the functions it takes as arguments for the boundaries of the region to shade must be functions of x.
Does someone know how to shade between two vertical lines?
I am a new user to Maple, but have used PTC's Mathcad and Prime.
I have several matrices that I need to combine both vertically and horizontally.  The command augment will combine the matrices horizontally.  I was unable to find a command to combine the matrices vertically.  I tried the stack command (Prime command).  The Maple stack command appears to have a different functionality.  Could you suggest which command would do the job?  The matrices are large and I would like to limit the number of rows and columns shown in the document.
The next step will be sorting the data. I am researching this at this time.
Thank you for the support,
David Tietje
First 376 377 378 379 380 381 382 Last Page 378 of 2458
