Here is an example where (f@g)(..) cannot be written f(g(..)): When is @ necessary?
with(Statistics):
interface(displayprecision=4):
S := Sample(Uniform(-1, 1), 10):
((max-min)/Mean)(S);  # correctly evaluated
abs(Mean(S)); # correctly evaluated
((max-min)/abs(Mean))(S);  # unevaluated value: abs(Mean) appears as  |Statistics:-Mean|
((max-min)/(abs@Mean))(S);  # correctly evaluated
I have defined a piecewise function, and then i derive that function and take the arctan of it. However for x=5, which is the maximum x value for the piecewise function, it shows "Float(undefined)".I have attached images at the bottom. I havent been able to figure out why this happens and i would appreciate any help. Also, does somebody know why the following error appears when i try to upload the .mw file?
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/crimp_versuch_tagentenstetig.mw .
Download crimp_versuch_tagentenstetig.mw
Why does  1e-(Digits) return 1. and 1e-Digits generate an error?
1e-Digits;
1e(-Digits);
                               1.
type(Digits, posint)
A function ta(x) is defined
Testing it indicates  that everything seems ok.
ta(2010);                 0.2212273448
ta(2050);               4.440420849
But printing goes totally wrong :
plot(ta(x), x = 2000 .. 2030);
The code consists of 13 constants and 4 equations.
Am I overlooking something?  Any idea?
na := 8.069439677916595*10^5;
nb := -1.777065899098942*10^3;
nc := 1.467451715287991;
nd := -5.383733471268420*10^(-4);
ne := 7.404613067985871*10^(-8);
am := 0.77317633747818500000;
bm := -0.00626025741156560000;
cm := 0.00002185947833342660;
ap := 471.909671218139000000000000;
bp := -7.368938071612570000000000;
cp := 0.041111235018593800000000;
dp := -0.000098963929768727000000;
ep := 0.88147417256725300*10^(-7);
c_y := y -> na + nb*y + nc*y^2 + nd*y^3 + ne*y^4;
to_c := ppm -> ap + bp*ppm + cp*ppm^2 + dp*ppm^3 + ep*ppm^4;
to_y := y -> tpn(c_y(y));
ta := x -> 0.0014*int(to_y(y), y = 2000 .. x);
Ok, I think I am starting to get the hang of this. So in Maple, structured types is like a pattern in Mathematica. To find some subexpression one needs to first define a structured type which match that subexpression, and then use  select(type,.....).
This works well so far (but it is not as easy as setting up a pattern).
But one small problem is that select() starts looking at the operands of the expression to look for a match.
So if the whole expression itself matches the structured type, it will not detect the whole expression, since select goes over each operand, missing that the whole thing actually matches the type.
May be an example helps shows what I mean. I want to find if an expression has cos(anything)*sin(anything) so I made a structured type for this
mytype_3 :=  ''`*`'( {'specfunc'(cos),'specfunc'(sin)})';
btw, I do not know if I should use `&*` or '`*`' but that is a side point, I'll try to find this out.
Now I want to use the above to check if expression has the same "structured type", or "pattern". The expression is expr:=cos(x)*sin(x); clearly it matches it. But since select looks at the operands, it will only see cos(x) by itself, and then sin(x) by itself and hence not find the structured type.
type(expr,mytype_3);  # true
select(type, expr, mytype_3); # does not work, does not find it.
Since I am doing this in code, and I do not know what the expression is, I think I have to now do the following
if type(expr,mytype_3) then
   print("The whole expression is a match! nothing to do. no need to use select");
fi;
Which is OK. I can do this, But it will be nice if there was a way to have select (or another function like it) starts at the top level before looking at the operands?
How do others handle such cases? does the above sound like an OK solution to this?
I am a research scholar in mathematics
I am currently working on fluid mechanics
I wish to obtain the solution given in the research article
I am uploading the pdf containing problem.
In the paper they mentioned that " Shooting method" is used.
Please anyone help me regarding this topic
File : 1.pdf
I am learning how to use select with my own types defined, to find parts of expression. This is instead of using patmach.
For example, given   3+x^2*sin(x) and then I want to find any POLYNIMAL*sin function, if present. So I did the following
expr_1:=3+x^2*sin(x):
mytype_1 := `&*`( polynom(And(algebraic, satisfies(u -> not has(u, I))),x),specfunc('sin')):
select( z->type(z,mytype_1),expr_1);
Which works. Maple returned
The problem is that if I change the order of multiplication, and also at same time change the polynomial by adding one more term, it no longer works!
I have no idea why. It seems Maple rememebrs something.  Here is a screen shot, followed by plain text code.
code
expr_1:=3+(1+x)*sin(x):
expr_1:=3+sin(x)*(1+x):
#change polynomial but keep same order, it works
expr_2:=3+(1+x+x^2)*sin(x):
select( z->type(z,mytype_1),expr_2);
#change order BUT keep same polynomial, it works
expr_3:=3+sin(x)*(1+x+x^2):
select(z->type(z, mytype_1),expr_3);
#keep same order as above, but change polynomial, now it does not works
expr_4:=3+sin(x)*(1+x+x^2+x^4):
select(z->type(z, mytype_1),expr_4);
#keep same order as first one  but change polynomial, it does not work
expr_5:=3+(1+x+x^2+x^4)*sin(x):
select(z->type(z, mytype_1),expr_5);
#keep same order as first one but change polynomial back to what it was, now it works
expr_6:=3+(1+x)*sin(x):
select(z->type(z, mytype_1),expr_6);
What Am I doing wrong?
Maple 2021.1
I have  an expression made of a sum of different terms from which I want to extract all terms of a specific form.
A typical expression and the functions I want to extract is given in the attached file.
You will see in the example that the terms in the expression can be
  • a constant
  • a continuous function of t
  • a piecewise function like
    something*piecewise(a(t) < 0, A(t), a(t) < 1, B(t), ...)
    something*piecewise(t < 0, A(t), t < 1, B(t), ...)
The functions I want to extract are only those of this latter form .
MyExpr.mw
PS: all the situations I have to manage contain expressions of the form of the prototype expression given in the attached file.
       Nothing more general than this.
This worksheet displays an ellipsoid internally tangent to the four sides of a tetrahedron.
The tetrahedron is a special case: it has a horizontal base with vertices A,B and C and its fourth vertex E is on the z axis.
However I have failed when trying to display an internally tangent ellipsoid in any other tetrahedron.
Will any tetrahedron support one or more internally tangent ellipsoids?
If so, are there conditions restricting the location of the mutual points of tangency?
Ellipsoid_in_a_tetrahedron.mw
How to obtain a dual branch solution in Maple.
Is there any specific method is there to get these type of solutions.
I have attached the document.
Link [copyright material removed by moderator]
I'm trying to construct an iterative procedure al1(f,x0) where f is a function, x0 is an initial estimate.
Now for example by defining f:= x-> 4*x^4-4*x^2 and inputting x0=0.75 and N=10 i should be able to check that my procedure calculates 1 correctly.
f := x -> 4*x^4 - 4*x^2;
f1 := D(f);
f2 := D(f1);
x0 := 0.75;
Digits := 100;
tol := 10.^(-15);
al1:= proc(f,x0)
local y, z, s, i, fs, a, de;
s := x0:
a[0]:=x0;
for i from 1 to 10
while abs(fs)>tol and de>tol do
y := evalf(s- f(s)/f1(s)):
s:=evalf(y-f(y)/f1(y)):
fs:=evalf(f(s)):
a[i]:=s:
de:=abs(evalf(a[i]-a[i-1])):
return n, s, fs, de;
> n, s, fs, de := al1(f, 0.75);
Error, (in al1) cannot determine if this expression is true or false: 0.1000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000e-14 < abs(fs) and 0.1000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000e-14 < de
The code i've written so far is incorrect but i'm not sure where i'm going wrong. Would you be able to give me some pointers?
Hi !
Sorry but there is a bug in the "combine" command when combining double summations.
 Maple 2017,2018 and 2020 all give me a wrong answer. I have an old version of Maple which gives the correct answer.
I have put an example in the attached file.
bugcombine.mw
Best regards
Réjean
Hello. looking for the numerical or analytical solution of the attached file and at the needed expression or value of lambda for different values of the involved parameter?
Help_numerically_solution.mw
I need the non-dimensional form of PDE with given non-dimensional variables. I have attached a worksheet please check it.
Thank you nondimensional.mw
Failed to load the worksheet /maplenet/convert/nondimensional.mw .
Download nondimensional.mw
First 392 393 394 395 396 397 398 Last Page 394 of 2427
