Can anyone correct me, what's wrong with it.
Help_solution.mw
Hello.
I have the ode
x' = 4 * lambda * x^4 - x^6
and I want to plot the phase portrait with x be the horizontal axis and lambda be the vertical axis.
Also, I want to plot the arrows showing the stability of the fixed points as lambda is changing values.
Thanks !
I have two functions, f1(x,y,z) and f2(x,y). I want to use Grid package to parallelize the runs of two functions. I have tried Grid:-Seq() but this way the maple does not seem to finish the computation.
Another thing I have tried so far was using Grid:-Run(), like so:
Grid:-Setup("local", numnodes=2):
Grid:-Run(0, f1, [x,y,z]):
Grid:-Run(1, f2, [x,y]):
It seems that this way i create background processes but I never see them finish. On their own the functions f1 and f2 work fine if used sequentially.
Is there any way to run time in parallel?
I'm experimenting the RSA encryption algorithm and in one example, I need to calculate (m^e) mod n where :
n=4142074788597595058238933087635402958555715420375128103710780511
m=65108105099101044032
e=3467995563410655813589059428902496618444213189544232426283402949
and I receive : Error, numeric exception: overflow
Even though these are large numbers, modular arithmetic algorithms should be able to deal with that.
Why is it not the case ?
NB : One of the mathApps in the category Computer Science is "RSA Encryption" and proves to be fairly comfortable with such large numbers, no overflow!
hi, why my dsolve command is not working
dsolve.mw
Here is a simple example which generates a loss of the connection to the kernel.
A few words to help you understand what this simplified code is aimed to do.
The inputs are:
  • a matrix (10 by 2 in the example given above),
  • a "slave" column p,
  • a "master" column q,
  • a list of rangesr.
Let nr the number of elements of r.
The goal is to separate the elements of M[.. ,p] in nr sorted lists L1, ..., Lnr according to the rule
  • M[n ,p] is in Lk  if M[n ,q] is in r[k]
A notional example is given in the snippet code below.
The variable num contains nr lists, the kth one contains the values of such that M[n ,q] is in r[k] .
As soon as one element of num is empty list the line S := ... generates the Connection to Kernel lost message.
I have made sure that this no longer happens by coding more carefully.
However, since some recent posts have mentioned this type of connection loss (usually difficult to trace), I thought it might be useful to publish this example (a census of connection loss situations might help make Maple more robust)
interface(version)
Standard Worksheet Interface, Maple 2015.2, Mac OS X, December 21 2015 Build ID 1097895
LTB := ListTools:-BinaryPlace:
M  := LinearAlgebra:-RandomMatrix(10, 2):
p  := 1:
q  := 2:
r  := [-100..-1, -1..1, 1..100]:
nr := numelems(r):
Y_x, Y_ix := sort(M[.., q] , output=[sorted, permutation]):
bounds    := map(u -> 1+LTB(Y_x, op(1, u))..LTB(Y_x, op(2, u)), r);
Y_nb      := map(u -> op(2, u)-op(1, u)+1, bounds);
            [2, 0, 8]
num       := [ seq(Y_ix[bounds[k]], k=1...nr) ];
            [[9, 1], [], [3, 2, 6, 7, 10, 4, 8, 5]]
S := [ seq(sort(convert(M[num[k], p], Vector)), k=1..nr) ];
KernelConnectionLost.mw
How can I expand exp(I x) to sin(x)+I*cos(x)
hi. how can i get this solution of eq
like this (just show not solving)
code
a := 3;
b := 5;
c := -1;
eq := exp(-c)/(a*b) + a^b*exp(c);
for a fixed x positive, I would like to find an asymptotic expansion of the following integral when n goes to infinity.
int(exp(-n*(x*cosh(t)+t)), t = 0 .. infinity)
Maybe we can define
f:=n->int(exp(-n*(x*cosh(t)+t)), t = 0 .. infinity);
Then
asympt(f(n), n,2)
But doesn't work
Many thanks for your help
Hi there!
I have a procedure that compares the (2n+1)-point Gauß-Kronrod-Quadrature to the (2n+1)-point Patterson-Quadratures for a range of n. I have plotted the results (the absolute and relative error if they "exist", meaning they need to posess certain features) in a graph, however they do not look very insightful. For the lowest n, the reader gets an impression for the different accuracy of the quadrature rules, however, for higher n's, the resulting points are basically just on the x-axis with no difference to see. Is it possible to also print a math table with Maple? Something like:
      GKQ   PZ+   PZ-   PY
1     1,04   1,03  1,02  1,02
2     1,09   1,04     -       -
3     1,02   1,01  1,01  1,01
4     1,03   1,02  1,01  1,01
with - meaning no existance for that particular n? I havent found anything about that on the internet, it's all about plotting.
My (long) code is this:
with(ListTools):
with(PolynomialTools):
with(CurveFitting):
Plotting:=proc(Unten,Oben,f,g,nUnten,nOben)::plot;
local SpeicherlisteX, SpeichervektorX, #speichert die Stützstellen
SpeichervektorXGekürzt, #streicht nicht existierende Quaraturformeln.
SpeicherlisteYAbs, SpeichervektorYAbs,  #speichert die Stützwerte des späteren Splines aus dem absoluten Quadraturfehler
SpeicherlisteYRel, SpeichervektorYRel,  #speichert die Stützwerte des späteren Splines aus den relativen Quadraturfehler
î, #Laufvariable
InterpolationsfunktionAbs, #speichert den Spline aus dem absoluten Interpolationsfehler
InterpolationsfunktionRel, #speichert den Spline aus den relativen Fehlern von f
GraphAbsGK, GraphAbsPY, GraphAbsPZP, GraphAbsPZM, #speichert den Graphen aus dem Spline aus dem absoluten Interpolationsfehler          GraphRelGK, GraphRelPY, GraphRelPZP, GraphRelPZM, #speichert den Graphen aus dem Spline aus den relativen Fehlern  von f
PunkteAbsGK, PunkteAbsPY, PunkteAbsPZP, PunkteAbsPZM,#speichert den Punktgraphen aus dem absoluten Interpolationsfehler
PunkteRelGK, PunkteRelPY, PunkteRelPZP, PunkteRelPZM, #speichert den Punktgraphen aus dem absoluten Interpolationsfehler
NichtexistenzGK, NichtexistenzPY, NichtexistenzPZP, NichtexistenzPZM, #speichert die Häufigkeit der Nichtexistenz
p,i,c,d,e,Hn,Koeffizienten,s,j,M,V,S,K,nNeu,Em,Hnm,KnotenHnm,KoeffizientenHnm,h0,b,gxi,Gewichte,Delta,Ergebnis,
Endergebnis,Koeffizient,Rest,a,VorgegebeneKnoten,TatsächlicherWert, DoppelterKnoten, KomplexerKnoten,
Text:= proc() #Prozedur zum Schreiben der Ausgabe
uses T= Typesetting;
     T:-mrow(seq(`if`(e::string, T:-mn(e), T:-Typeset(T:-EV(e))), e= [args]))
end proc,
OrtPol:= proc(G,N)::list; #Prozedur zum Berechnen der benötigten orthogonalen Polynome
  local q,r,R;
  q[-1]:=0;
  q[0]:=1;
  for r from 1 to N do
  q[r]:=(x^r-add(evalf(Int(x^r*q[R]*G,x=(-1)..1))*q[R]/evalf(Int(q[R]^2*G,x=(-1)..1)),R=0..r-1));
  return(fsolve(q[N]));
end proc,
BasenwechselNormiert:=proc(Dividend, m)::list; #stellt ein gegebenes Polynom über eine Linearkombination der orthogonalen Polynome #dar.
   local BasenwechselNormiert;
  Koeffizient:=quo(Dividend, p[m],x);
  Rest:=rem(Dividend, p[m],x);
  if m=0 then
    BasenwechselNormiert:=[Koeffizient*evalf(Int(g*p[m]^2,x=Unten..Oben))];
    BasenwechselNormiert:=[Koeffizient*evalf(Int(g*p[m]^2,x=Unten..Oben)),op(procname(Rest,m-1))];
  end proc,
    Basenwechsel:=proc(Dividend, m)::list; #stellt ein gegebenes Polynom über eine Linearkombination der orthogonalen Polynome dar.
   local Basenwechsel;
  if m=0 then
    Basenwechsel:=[Koeffizient];
    Basenwechsel:=[Koeffizient,op(procname(Rest,m-1))];
  end proc,
Erweiterung:= proc(Unten, Oben, f,g,Liste,n)::real; #Prozedur zur Berechnung der optimalen Erweiterung nach Knotenvorgabe
  #Unten:= Untere Intervallgrenze; Oben:= Obere Intervallgrenze; f:= zu integrierende Funktion;
  #g:= Gewicht; Liste:= Liste der alten Knoten, n:= Anzahl hinzuzufügender Knoten;
Hn:=mul(x-Liste[i],i=1..numelems(Liste));
 Koeffizienten:=FromCoefficientList(BasenwechselNormiert(Hn,numelems(Liste)+1),x,termorder=reverse); #Die Koeffizienten der orthogonalen Polynome werden hier als Koeffizienten der Monome gespeichert.
M:=Matrix(n,n); #Beginn der Erstellung eines linearen Gleichungssystems, dessen Lösung die Koeffizienten der orthogonalen Polynome sind, deren Summe Em die hinzuzufügenden Knoten als Nullstellen hat.
V:=Vector(n);
  for s from 0 to n-1 do
    for j from 0 to s do
      M(s+1,j+1):=add(coeff(a[s][j],x,k)*coeff(Koeffizienten,x,k),k=0..n);
      if s<>j then
        M(j+1,s+1):=M(s+1,j+1);
    M(s+1,n+1):=add(coeff(a[n][s],x,k)*coeff(Koeffizienten,x,k),k=0..n);
S:=LinearSolve(M,V);
K:=evalindets(S,name,()->2);
Em:=add(p[i]*K[i+1],i=0..n); #Erstellen von Em, dessen Nullstellen die hinzuzufügenden Knoten sind
Hnm:=Hn*Em; #Erstellen von Hnm, welches alle Knoten als Nullstelle besitzt
KnotenHnm:=fsolve(Hnm,complex); #Knotenberechnung
if (KnotenHnm[1]<-1-10^(-10)) or (KnotenHnm[n+numelems(Liste)]>1+10^(-10)) then
  return(false)
KomplexerKnoten:=false;
for i from 1 to n+numelems(Liste) do
 if(Im(KnotenHnm[i])>10^(-10)) then
  KomplexerKnoten:=true
if KomplexerKnoten=true then
  return(false)
DoppelterKnoten:=false;
for i from 1 to n+numelems(Liste)-1 do
 if (KnotenHnm[i+1]-KnotenHnm[i]<10^(-10)) then
   DoppelterKnoten:=true
if DoppelterKnoten=true then
 return(false)
KoeffizientenHnm:=Reverse(Basenwechsel(Hnm,n+numelems(Liste)));  #Das Polynom Hnm wird über die orthogonalen Polynome dargestellt.
h0:=evalf(Int(g,x=Unten..Oben)); #Beginn der Berechnung der Gewichte
b[n+numelems(Liste)+2]:=0;
b[n+numelems(Liste)+1]:=0;
  for i from 1 to nops([KnotenHnm]) do
    for j from n+numelems(Liste) by -1 to 1 do
      b[j]:=KoeffizientenHnm[j+1]+(d[j]+KnotenHnm[i]*c[j])*b[j+1]+e[j+1]*b[j+2];
    gxi:=quo(Hnm,x-KnotenHnm[i],x);
    Gewichte[i]:=c[0]*b[1]*h0/eval(gxi,x=KnotenHnm[i]);
    Delta[i]:=c[0]*b[1];
Ergebnis:=add(eval(f,x=KnotenHnm[k])*Gewichte[k],k=1..nops([KnotenHnm]));
Endergebnis:=Re(evalf(Ergebnis))
p[-1]:=0;
p[0]:=1;
for i from 1 to (2*nOben+1)*2 do
  p[i]:=(x^i-add(evalf(Int(x^i*p[j]*g,x=Unten..Oben))*p[j]/evalf(Int(p[j]^2*g,x=Unten..Oben)),j=0..i-1)); #Berechnung einer Folge orthogonaler Polynome bezüglich der gegebenen Gewichtsfunktion und des gegebenes Intervalles
c[i-1]:=coeff(p[i],x,i)/coeff(p[i-1],x,i-1); #Berechnung der dreigliedrigen Rekursion der errechneten orthogonalen Polynome
d[i-1]:=(coeff(p[i],x,(i-1))-c[i-1]*coeff(p[i-1],x,(i-2)))/coeff(p[i-1],x,(i-1));
if i <> 1 then
  e[i-1]:=coeff(p[i]-(c[i-1]*x+d[i-1])*p[i-1],x,i-2)/coeff(p[i-2],x,i-2);
  e[i-1]:=0;
a[0][0]:=1; #Beginn der Berechnung der orthogonalen Produkterweiterungen, die Koeffizienten der orthogonalen Polynome werden wieder über die Monome gespeichert (2*x^2+2 bedeutet bspw. [2,0,2,0,0...] für die Koeffizienten)
a[1][0]:=x;
a[1][1]:=-e[1]*c[0]/c[1]+(d[0]-d[1]*c[0]/c[1])*x+c[0]/c[1]*x^2;
for s from 2 to 2*nOben+1 do
  a[s][0]:=x^s;
  a[s][1]:=-e[s]*c[0]/c[s]*x^(s-1)+(d[0]-d[s]*c[0]/c[s])*x^s+c[0]/c[s]*x^(s+1);
    pprint (coeff(a[s][1],x,s),as1s);
  for j from 2 to s do
     a[s][j]:=c[j-1]*add(coeff(a[s][j-1],x,k-1)/c[k-1]*x^k,k=abs(s-j)+2..s+j)+add((d[j-1]-c[j-1]*d[k]/c[k])*coeff(a[s][j-1],x,k)*x^k,k=abs(s-j)+1..s+j-1)-c[j-1]*add(e[k+1]*coeff(a[s][j-1],x,k+1)/c[k+1]*x^k,k=abs(s-j)..s+j-2)+e[j-1]*add(coeff(a[s][j-2],x,k)*x^k,k=abs(s-j)+2..s+j-2);
for î from nUnten to nOben do
  VorgegebeneKnoten[î]:=OrtPol(g,î);
TatsächlicherWert:=evalf(Int(f*g,x= Unten..Oben));
GraphAbsGK:=plot([]); PunkteAbsGK:=plot([]); GraphAbsPZP:=plot([]); PunkteAbsPZP:=plot([]); GraphAbsPZM:=plot([]); PunkteAbsPZM:=plot([]); GraphAbsPY:=plot([]); PunkteAbsPY:=plot([]);
GraphRelGK:=plot([]); PunkteRelGK:=plot([]); GraphRelPZP:=plot([]); PunkteRelPZP:=plot([]); GraphRelPZM:=plot([]); PunkteRelPZM:=plot([]); GraphRelPY:=plot([]); PunkteRelPY:=plot([]);
SpeicherlisteX:=[];
SpeicherlisteYAbs:=[];
SpeicherlisteYRel:=[];
  if Erweiterung(Unten,Oben,f,g,[VorgegebeneKnoten[î]],î+1) <> false then
    SpeicherlisteX:=[op(SpeicherlisteX),î]; #Stützstellen definieren
    SpeicherlisteYAbs:=[op(SpeicherlisteYAbs),Erweiterung(Unten,Oben,f,g,[VorgegebeneKnoten[î]],î+1)-evalf(Int(f*g,   x=Unten..Oben))]; #Bestimmen des absoluten Fehlers von f für n=î
      if abs(TatsächlicherWert) > 10^(-10) then #Bestimmen des relativen Fehlers von f1 falls                                                          #dieser definiert ist
      SpeicherlisteYRel:=[op(SpeicherlisteYRel),abs(SpeicherlisteYAbs[-1]/TatsächlicherWert)];
if numelems(SpeicherlisteX)>0 then
  SpeichervektorX:=Vector[row](numelems(SpeicherlisteX),SpeicherlisteX);
  SpeichervektorYAbs:=Vector[row](numelems(SpeicherlisteYAbs),SpeicherlisteYAbs);
  PunkteAbsGK:= plot(SpeichervektorX,SpeichervektorYAbs,style = point, color=red, legend = ["GK"]);
    #  Generierung des Punktgraphen, der sich aus den absoluten Fehlern von f ergibt
  if numelems(SpeicherlisteX)>1 then
    InterpolationsfunktionAbs:=Spline(SpeichervektorX,SpeichervektorYAbs,n);
      #  Splines aus Stützpunkten, die sich aus den absoluten Fehlern von f ergeben
    GraphAbsGK:= plot(InterpolationsfunktionAbs, n=nUnten..nOben, color=red);
      #  Generierung des Graphen, der sich aus dem Spline aus den absoluten Fehlern von f ergibt
  # falls der relative Fehler definiert ist analoges Vorgehen für die relativen Fehler
    SpeichervektorYRel:=Vector[row](numelems(SpeicherlisteYRel),SpeicherlisteYRel);
    PunkteRelGK:= plot(SpeichervektorX,SpeichervektorYRel,style = point, color=red, legend = ["GK"]);
    if numelems (SpeicherlisteX)>1 then
      InterpolationsfunktionRel:=Spline(SpeichervektorX,SpeichervektorYRel,n);
      GraphRelGK:= plot(InterpolationsfunktionRel, n=nUnten..nOben, color=red);
NichtexistenzGK:=nOben-nUnten+1-numelems(SpeicherlisteX);
SpeicherlisteX:=[]; # analoges Vorgehen für PZP
  if Erweiterung(Unten,Oben,f,g,[-1,VorgegebeneKnoten[î]],î) <> false then
    SpeicherlisteYAbs:=[op(SpeicherlisteYAbs),Erweiterung(Unten,Oben,f,g,[-1,VorgegebeneKnoten[î]],î)-TatsächlicherWert]; #Bestimmen des absoluten Fehlers von f für n=î
  PunkteAbsPZP:= plot(SpeichervektorX,SpeichervektorYAbs,style = point, color=orange);
    GraphAbsPZP:= plot(InterpolationsfunktionAbs, n=nUnten..nOben, color=orange);
    PunkteRelPZP:= plot(SpeichervektorX,SpeichervektorYRel,style = point, color=orange, legend = ["PZP"]);
      GraphRelPZP:= plot(InterpolationsfunktionRel, n=nUnten..nOben, color=orange);
NichtexistenzPZP:=nOben-nUnten+1-numelems(SpeicherlisteX);
SpeicherlisteX:=[];# analoges Vorgehen für PZM
  if Erweiterung(Unten,Oben,f,g,[VorgegebeneKnoten[î],1],î) <> false then
    SpeicherlisteYAbs:=[op(SpeicherlisteYAbs),Erweiterung(Unten,Oben,f,g,[VorgegebeneKnoten[î],1],î)-TatsächlicherWert]; #Bestimmen des absoluten Fehlers von f für n=î
  PunkteAbsPZM:= plot(SpeichervektorX,SpeichervektorYAbs,style = point, color=blue, legend = ["PZM"]);
    GraphAbsPZM:= plot(InterpolationsfunktionAbs, n=nUnten..nOben, color=blue);
    PunkteRelPZM:= plot(SpeichervektorX,SpeichervektorYRel,style = point, color=blue, legend = ["PZM"]);
      GraphRelPZM:= plot(InterpolationsfunktionRel, n=nUnten..nOben, color=blue);
NichtexistenzPZM:=nOben-nUnten+1-numelems(SpeicherlisteX);
SpeicherlisteX:=[]; #analoges Vorgehen für PY
  if Erweiterung(Unten,Oben,f,g,[-1,VorgegebeneKnoten[î],1],î-1) <> false then
    SpeicherlisteYAbs:=[op(SpeicherlisteYAbs),Erweiterung(Unten,Oben,f,g,[-1,VorgegebeneKnoten[î],1],î-1)-TatsächlicherWert]; #Bestimmen des absoluten Fehlers von f für n=î
  PunkteAbsPY:= plot(SpeichervektorX,SpeichervektorYAbs,style = point, color=purple, legend = ["PY"]);
    GraphAbsPY:= plot(InterpolationsfunktionAbs, n=nUnten..nOben, color=purple);
    PunkteRelPY:= plot(SpeichervektorX,SpeichervektorYRel,style = point, color=purple, legend = ["PY"]);
      GraphRelPY:= plot(InterpolationsfunktionRel, n=nUnten..nOben, color=purple);
NichtexistenzPY:=nOben-nUnten+1-numelems(SpeicherlisteX);
print(display({GraphAbsGK,PunkteAbsGK,GraphAbsPZP,PunkteAbsPZP, GraphAbsPZM,PunkteAbsPZM, GraphAbsPY,PunkteAbsPY}, title= "Absoluter Fehler", titlefont=["ROMAN",18]));
  print(display({GraphRelGK,PunkteRelGK,GraphRelPZP,PunkteRelPZP, GraphRelPZM,PunkteRelPZM, GraphRelPY,PunkteRelPY}, title= "Relativer Fehler", titlefont=["ROMAN",18]));
Text("Häufigkeit der Nichtexistenz: GK ",NichtexistenzGK, ", PZP ",NichtexistenzPZP, ", PZM ", NichtexistenzPZM, ", PY ", NichtexistenzPY);
 end proc
An example of how it should not look like is this:
Plotting(-1,1,2*x^2+2,1,3,10)
On a side note, Maple's return is
Warning, `GraphRelGK` is implicitly declared local to procedure `Plotting`
Warning, `GraphRelPZP` is implicitly declared local to procedure `Plotting`
Warning, `GraphRelPZM` is implicitly declared local to procedure `Plotting`
Warning, `GraphRelPY` is implicitly declared local to procedure `Plotting`
even though I did declare them.
Any suggestions on that minor issue? And on how to construct a math table which allows for a symbol like - for nonexistence?
Thank you in advance!
V1 := [1.666666667, 1.983050847, 2.372881356, 2.768361582,
    3.380681818, 3.977272727, 4.767045455, 5.755681818,
    6.937500000, 8.244318182, 9.801136364, 0.2971428571,
    0.6914285714, 1.085714286, 0.3942857143]
dV1 := [0.03315280331, 0.03866282527, 0.04508264551,
   0.05165406892, 0.06212371278, 0.07219635124, 0.08557994498,
   0.1023815798, 0.1225076192, 0.1447933406, 0.1713677762,
   0.01380612592, 0.01872473080, 0.02454205309, 0.01488350319]
V2 := [17/10, 2, 12/5, 14/5, 17/5, 4, 24/5, 29/5, 7, 42/5, 10, 3/10, 7/10, 11/10, 2/5]
dV2 := [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
Hey,
i have trouble adding error bars to my plots despite experimenting with it for hours. I tried using ErrorBars but i never get close to what i need. What i have is V1 (values for y) and V2 (values for x) to produce a ScatterPlot which works alright. What i need is something like this: .
For the errors in x and y-direction i have 2 lists dV1 (y errors) and dV2 (x errors).
This is my first post and i´m a bit in a rush so please excuse me for any mistakes i may have made.
how are please I want to help In some graphs in maple
the graph in the picture
thank you
I have created a robot ar with p starting position X, Y, Z and a spring that connects to the robot end effector with a spring that is L long. I have exported this simulink model to an FMU inorder to use it in python.
Is it posible to change the value of X, Y, Z and L using pyfmi before using it in pythuon and if it is, then how?
Thanks again for youre time and help. I know that this is not exaclyt inside the expertise of this fine comunity but have no were else to go.
Eric R
I will start off with the programming already accomplished. The first part of programming was salvaged from mathexchange whereby I am able to perform combinations with repititions.
>with(combinat):
choosing:=proc(n,m,k:=1)
local duplicated:=[seq(op(n),i=1..k)]:
return combinat:-choose(duplicated,m):
>choosing([w,b,g],4,4);
[[b, b, b, b], [b, b, b, g], [b, b, b, w], [b, b, g, g], [b, b, g, w], [b, b, w, w], [b, g, g, g], [b, g, g, w], [b, g, w, w], [b, w, w, w], [g, g, g, g], [g, g, g, w], [g, g, w, w], [g, w, w, w], [w, w, w, w]]
the next step I'm hoping to accomplish is to receive a list giving me a count of each value from each set of combinations. For example, in the first set i have 4 counts of black (b), 0 counts of white (w) and 0 counts of grey (g).  the second set tells me i have 3 counts of b, 0 counts of w and 1 count of g, etc.
the purpose of this is to apply a formula to each set of values.
So I recently bought a new desktop with Windows 10 installed. The problem is hard to describe so I put a picture. This problem occurs randomly (Mostly occurs after I click the right button, when browsing the option in the pop-up toolbar).
When this problem happens, if I move my mouse to any toolbar which suppose to pop-up a toolbar, the pop-up toolbar wont disspear. And ultmately leads to the picture I showned above.
Sorry for the bad explaintion but it is just like I said, it is hard to describe the problem. This PC arrives around Christmas and I downloaded Maple last week. And it never have been normal. This issue also happens to NetLogo (A model simulation software).
I asked DELL's technique services and they did a remote control to help me fix the issue. However, the problem doesn't solved (They worked on this for about 3 hours). It seems the only choice I have is to reinstall the Windows.
Does anyone have met this problem or know who met it before? Please let me know and I'm really appreciate it.
First 448 449 450 451 452 453 454 Last Page 450 of 2427
