just a quick question: Is it possible to customize the default worksheet with my own settings/styles, such that my settings are loaded automically when I create a new worksheet? I've tried to change my settings/styles and apply that globally but, once I leave MF and re-launch it, my settings/styles are not loaded.
Thanks very much in advance.
Hello, I have a question regarding finding two vectors that result in a resulting vector with only the directions of the two needed vectors.
Given:
- Vector F_RC1
- Unit Vector of F_RC1Y (called EV_C1Y)
- Unit Vector of F_RC1_ST (called EV_C1_ST)
Needed
- F_RC1_ST
- F_RC1Y
The picture below and the file should make it clear.
vector_question.mw
How do I approach this? Best regards,
I knowI can use a loop but I would like something neater. igcd can be applied to a list. Is there a way to map or use @ to apply gcd to a list?
lst:= [4, 2, 8, 4];
lst1 := [a^3/10, -a^2/2, a, a^4/4]
                      lst := [4, 2, 8, 4]
                        [1   3    1  2     1  4]
                lst1 := [-- a , - - a , a, - a ]
                        [10       2        4   ]
gd:=igcd(lst);
                            gd := 2
gd1=(gcd@op)(lst1);
Maple's Student:-ODEs:-ODESteps solves an ode by doing change of variable on the independent variable, but the resulting ode is wrong and final answer is wrong.
Here is one such example
ode:=diff(diff(y(x),x),x)*sin(x)^2 = 2*y(x);
Student:-ODEs:-ODESteps(ode):
But this result is wrong. First of all, we can not have both x and t  in the same ode. This is what dchange gives
ode:=diff(y(x),x$2)*sin(x)^2-2*y(x)=0;
tr:={PDEtools:-Solve(t=ln(x),x)};
simplify(PDEtools:-dchange(tr,ode,[t]))
It looks like Student:-ODEs:-ODESteps is trying to solve  sin(x)^2*y'' + 2 y=0 as EULER type ode.
But Euler type ode will look like  x^2*y'' +2 y=0
It seems to have confused sin(x)^2 with x^2. This change of variable it used only works for EULER type ode with polynomial coefficient, not trig coefficients.
Maple 2024.2 on Windows 10
Let x be some name:
x := asdf;
asdf
I wish to make a new name, y, whose value is the first character in x:
convert(x, string):
y := convert(%[1], name);
a
That works but seems too convoluted.  Is there a better way of doing that?
i already use this method for a lot of equation but this time something not normal hapening what is problem?
with(PDEtools)
with(LinearAlgebra)
with(Physics)
with(SolveTools)
eq0 := -4*alpha*k^2*m^2*n^2*A[0]^2+4*beta*k*m*n^2*A[0]^3-4*gamma*k*m*n^2*A[0]^3+4*delta^2*m*n^2*A[0]^2-4*n^2*sigma*A[0]^4-4*m*n^2*w*A[0]^2 = 0
eq1 := -8*alpha*k^2*m^2*n^2*A[0]*A[1]+12*beta*k*m*n^2*A[0]^2*A[1]-12*gamma*k*m*n^2*A[0]^2*A[1]+8*delta^2*m*n^2*A[0]*A[1]-16*n^2*sigma*A[0]^3*A[1]+2*a*alpha*m*n*A[0]*A[1]-8*m*n^2*w*A[0]*A[1] = 0
eq2 := -4*alpha*k^2*m^2*n^2*A[1]^2+12*beta*k*m*n^2*A[0]*A[1]^2-12*gamma*k*m*n^2*A[0]*A[1]^2+4*delta^2*m*n^2*A[1]^2-24*n^2*sigma*A[0]^2*A[1]^2+a*alpha*m^2*A[1]^2+3*alpha*b*m*n*A[0]*A[1]-4*m*n^2*w*A[1]^2 = 0
eq3 := 4*beta*k*m*n^2*A[1]^3-4*gamma*k*m*n^2*A[1]^3-16*n^2*sigma*A[0]*A[1]^3+alpha*b*m^2*A[1]^2+alpha*b*m*n*A[1]^2+4*alpha*c*m*n*A[0]*A[1] = 0
eq4 := -4*n^2*sigma*A[1]^4+alpha*c*m^2*A[1]^2+2*alpha*c*m*n*A[1]^2 = 0
C := solve({eq0, eq1, eq2, eq3, eq4}, {a, b, c, `__ `*A[0]})
Download problem.mw
Can someone tell me how to calculate the Christoffel symbols in spherical coordinates in Euclidean three dimensional space?
Thank you very much in advance!
I am working on my vector file and have another question:
1. How do I display any vectors in a matrix notation next to each other or above each other (like: [1;2;3])
Find attached the file:question_vector_.mw
I really appreciate any help you can provide.
At the end of this link - (2.14) and (2.15) - the problem and the solution have the same maple code, so I don't understand how to solve the problem.
https://www.maplesoft.com/support/help/Maple/view.aspx?path=isimplicitlydeclaredlocal
Is it possible to have a variable in a filename ?
as an example if I save a file by
save M, "Result(Variable).txt";
So If Variable is e.g. set to
Variable:=10;
then the filename saved should be
Result(10).txt
It is not that this a terribly difficult to work out, but I feel I am probably missing something. I need to check if a 3D point lies on a 3D line. What is a good approach here. I started of with the idea all alpha's are equal. but there are exceptions. See P3 and P4
l := `<,>`(3+2*alpha, 1+6*alpha, 4-5*alpha)
Vector[column](%id = 36893489809910741940)
P := [9, 19, -11]
[9, 19, -11]
seq(solve({l[i] = P[i]}, alpha), i = 1 .. 3)
{alpha = 3}, {alpha = 3}, {alpha = 3}
l1 := `<,>`(3+2*alpha, 1+0*alpha, 4-5*alpha)
Vector[column](%id = 36893489809910721460)
P1 := [9, 1, -11]
[9, 1, -11]
seq(solve({l1[i] = P1[i]}, alpha), i = 1 .. 3)
{alpha = 3}, {alpha = alpha}, {alpha = 3}
l2 := `<,>`(3+2*alpha, 1+0*alpha, 4-0*alpha)
Vector[column](%id = 36893489809910705556)
P2 := [9, 1, 4]
[9, 1, 4]
seq(solve({l2[i] = P2[i]}, alpha), i = 1 .. 3)
{alpha = 3}, {alpha = alpha}, {alpha = alpha}
l3 := `<,>`(3+2*alpha, 0+0*alpha, 4-0*alpha)
Vector[column](%id = 36893489809963852012)
P3 := [9, 0, 4]
[9, 0, 4]
seq(solve({l3[i] = P3[i]}, alpha), i = 1 .. 3)
P4 := [9, 0, -2]
[9, 0, -2]
seq(solve({l3[i] = P4[i]}, alpha), i = 1 .. 3)
(14)
Download 2024-12-21_Q_3D_point_lies_on_3D_line.mw
I don't know what that line above the question is. Thanks in Advance.
I'm quite new to Maple Flow and I really like it. However, since the 2024.2 update, Flow sometimes does not let me save a worksheet. Just nothing happens when I click Save or Save As or press Ctrl+S. Same thing when I click "Yes" in the dialogue (which asks me if I want to save the changes) after I close the worksheet.
As a workaround in these cases, I copy the whole content of the worksheet, close Flow altogether and open a new worksheet into which I paste the previously copied contents. Am I the only one experiencing this behaviour? Am I doing something wrong?
NULLComplex Numbers
Key Skills 11-48
NULLc11 := 2-3*i+(6+8*i)"(=)"8+5*i
c12 := 4+5*i-8+2*i"(=)"-4+7*i
c13 := -3+2*i-4+4*i"(=)"-7+6*i
c14 := 3-4*i+(3+4*i) = 6NULL
c15 := 2-5*i-8-6*i"(=)"-6-11*i
c16 := -8+4*i-2+2*i"(=)"-10+6*i
c17 := 3*(2-6*i)"(=)"6-18*i
c18 := -4*(2+8*i)"(=)"-8-32*i
NULLc19 := 2*i(2-3*i) = 2*i(2-3*i)NULL
c20 := 3*i*(-3+4*i) = 3*i*(-3+4*i)
c21 := (3-4*i)*(2+i) = (3-4*i)*(2+i)NULL
c22 := (5+3*i)*(2-i) = (5+3*i)*(2-i)
Download 1.3-Complex_Numbers_bad.mw
I'm trying to get my problems in standard form  a + bi . Questions 19 - 22 are wrong.
How can I display the symbol (blue solid circle) and the line (blue line) together in the legend box (( from   to ))?
plot(sin(x), x = -3 .. 3, colour = [blue], style = pointline, symbol = [solidcircle], numpoints = 20, legend = ["sin(x)"])
Download Plot1.mw
First 44 45 46 47 48 49 50 Last Page 46 of 2425
