A few times ago a trainee asked me this question
         "given a matrix formula, can Maple find the transpose of this formula?"
More precisely, let's say E, A, B and C are four (abstract) matrices (let's say symbols) with consistent dimensions such that E = A+B*C, can Maple "find" that ET = AT + CT * BT (where  ET represents the transpose of E)?
I come back to this problem regularly because the trainee was quite frustrated by my negative answer (note she had the same request form the inverse of a matrix formula).
The best I'm capable to do is given in the attached file (transposition only).
This seems to work correctly even if did not do intensive testing.
Do you have any ideas on how to implement the transposition and inversion computation rules in Maple?
For example, given
E := A &* B^(-1))
Maple would return
Transpose(E);
      (B^(-1))^T &* A^T
# or better   E^(T) = (B^T)^(-1) &* A^T
# and
Inverse(E);
   B &* A^(-1)
Thanks in advance for you involvement
Transpose := proc(e)
  local tr, t:
  tr := `#mo("т")`:
  define(
    t,
    t(`&*`(a::anything, b::anything)) = &*(b^tr, a^tr),
    t(a::anything+b::anything)=a^tr+b^tr,
    t(a^tr)=a,
    'linear', 'flat'
  t(expand(e));
  return eval(%, map(u -> (u^tr)^tr = u, indets(e, name)));
end proc
proc (e) local tr, t; tr := `#mo("т")`; define(t, t(`&*`(a::anything, b::anything)) = `&*`(b^tr, a^tr), t(a::anything+b::anything) = a^tr+b^tr, t(a^tr) = a, 'linear', 'flat'); t(expand(e)); return eval(%, map(proc (u) options operator, arrow; (u^tr)^tr = u end proc, indets(e, name))) end proc
Transpose(A+B)
B^`#mo("т")`+A^`#mo("т")`
Transpose(2*A + B &* C)
2*A^`#mo("т")`+`&*`(C^`#mo("т")`, B^`#mo("т")`)
Transpose((A + B) &* (A + B))
`&*`(A^`#mo("т")`, A^`#mo("т")`)+`&*`(B^`#mo("т")`, A^`#mo("т")`)+`&*`(A^`#mo("т")`, B^`#mo("т")`)+`&*`(B^`#mo("т")`, B^`#mo("т")`)
Transpose((A + B) &* Transpose(A + B) + Transpose(Transpose(A)) )
`&*`(B, A^`#mo("т")`)+`&*`(A, A^`#mo("т")`)+`&*`(B, B^`#mo("т")`)+`&*`(A, B^`#mo("т")`)+A^`#mo("т")`
Download transposition.mw
Hi and Welcome Everyone here.
It is my first post and I am happy to have Maple 2020 Personal Edition. It is great tool and I am still learning.
Durng first weeks I solved many things with help and forums but I can't solve this simple one below:
How to force maple to divide a sqrtof (4*n^2 + 5*n - 7) by n to have each expression divided separately and all still inside of sqrt?
sqrt(4*n^2 + 5*n - 7)/n to get:sqrt(4 + 5/n - 7/n^2) by collect or expand function or anything else. I was able to do it by rewriting combine(((4*n^2 + 5*n - 7)/n^2)^0.5, radical) in such form but it is not what I want to have since I need to rewriting it manually.
Can any "wizard of maple" help me to find an answer? Or at least give a hint in what direction to go, I will dig later myself.
Marcin
At the moment t=0, we place a body at 100 ° C in a room at 25°C; we designate by q(t) the temperature at the moment t. The differential equation is.q'(t)+k*(q(t)-25)=t, with k cooling coefficient equal to 2.
Determine the solution that checks the initial condition.
What is the body temperature after 30 minutes.
After how long the temperature drops to 50°C. Thank you for the help.
Using InertfForm, I found this strange result:
e := (A+B)*(A+C);
ife  := InertForm:-Parse(convert(e, string));
InertForm:-Display(ife);
(A+B)*(A+C)
`%*`(`%+`(A, B), `%+`(A, C))
Download Precedence.mw
Why doesn't Display(..) return (A+B)*(A+C) ?
Can anyone assist with Heat Map plotting questions?
I am interested in specifically formating axis.  i.e., can an axis be labels such as RPM range text =  "0-100, 101-200, 201-300", etc.  for each bin and rotated vertical to fit.   I tried most of the plot options with no success including labeldirections=[x, y].
Also, can I invert the data so the 1,1 bin is lower left corner vs upper left? tried to reverse the indices and errored with "inverted index" without resolution.
Lastly, I noted that I couldn't stack a frame Text plot of same size by assigning a plot to a variable and using display to overlay them.   The heat map is always on top and transparency option doesn't let the text come through.
Plt1 := HeatMap(Array3[2 .. 101, 2 .. 31], color = C_List, size = [750, 450], transparency = 0.5)
Thanks in advance,
Bill
I'm trying to solve the problem which is published in the research article. The paper is attached.
This work done with the help of shooting technique in maple 18
1.Is it possible to solve in maple 17
2. How to obtain the triple soln
3. How to implement Shooting technique
Please anyone help me to get this
eq1 := (1+K)*(diff(f(eta), `$`(eta, 3)))+f(eta)*(diff(f(eta), `$`(eta, 2)))+K*(diff(g(eta), eta))-2*(diff(f(eta), eta))^2-M*(diff(f(eta), eta)) = 0;
(1+K)*(diff(diff(diff(f(eta), eta), eta), eta))+f(eta)*(diff(diff(f(eta), eta), eta))+K*(diff(g(eta), eta))-2*(diff(f(eta), eta))^2-M*(diff(f(eta), eta)) = 0
eq2 := (1+(1/2)*K)*(diff(g(eta), `$`(eta, 2)))+f(eta)*(diff(g(eta), eta))-3*g(eta)*(diff(f(eta), eta))-2*K*g(eta)-K*(diff(f(eta), `$`(eta, 2))) = 0;
(1+(1/2)*K)*(diff(diff(g(eta), eta), eta))+f(eta)*(diff(g(eta), eta))-3*g(eta)*(diff(f(eta), eta))-2*K*g(eta)-K*(diff(diff(f(eta), eta), eta)) = 0
eq3 := (1+(4/3)*Rd)*(diff(theta(eta), `$`(eta, 2)))/Pr+f(eta)*(diff(theta(eta), eta))+Nb*(diff(chi(eta), eta))*(diff(theta(eta), eta))+Nt*(diff(theta(eta), eta))^2 = 0;
(1+(4/3)*Rd)*(diff(diff(theta(eta), eta), eta))/Pr+f(eta)*(diff(theta(eta), eta))+Nb*(diff(chi(eta), eta))*(diff(theta(eta), eta))+Nt*(diff(theta(eta), eta))^2 = 0
eq4 := diff(chi(eta), `$`(eta, 2))+Sc*f(eta)*(diff(chi(eta), eta))+Nt*(diff(theta(eta), `$`(eta, 2)))/Nb = 0;
diff(diff(chi(eta), eta), eta)+Sc*f(eta)*(diff(chi(eta), eta))+Nt*(diff(diff(theta(eta), eta), eta))/Nb = 0
bcs := f(0) = S, (D(f))(0) = -1, g(0) = -m*((D^2)(f))(0), (D(theta))(0) = -A*(1-theta(0)), chi(0) = 1+delta*(D(chi))(0), (D(f))(10) = 0, g(10) = 0, theta(10) = 0, chi(10) = 0;
f(0) = S, (D(f))(0) = -1, g(0) = -m*(D(f))(0)^2, (D(theta))(0) = -A*(1-theta(0)), chi(0) = 1+delta*(D(chi))(0), (D(f))(10) = 0, g(10) = 0, theta(10) = 0, chi(10) = 0
params := [K = .1, S = 2.1257, m = .5, Pr = 2, Nb = .3, Nt = .5, Sc = 2, Rd = .5, delta = .1, A = 5];
sol := dsolve(eval([eq1, eq2, eq3, eq4, bcs], params), numeric, output = listprocedure, maxmesh = 5000)
Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 10, got 9
Download Triple.mw
Dear Community,
I try to solve a simple flow problem between two fluid tanks. They are connected with a pipe and a pump. Simulation runs from 0s to 3000s. Fluid levels are H1(t), H2(t), and flow rate between the tanks is Q1(t). I operate the pump between 500s and 2000s, with a constant head, and after that I would like to shut down the system from 2000s to 2500s (i.e. for 500s Q1(t) should be 0, and consequently H1, H2 remain constant) and then reopen it again, so tanks can equilibrate. I've attached the worksheet (FlowProblem.mw).
I tried to achieve this in the event section of dsolve (indicated in red), but it seemingly did not work out. So my question is: how to correctly specify it in dsolve, so flow (Q1) remains 0. between 2000s and 2500s, and can flow again afterwards? Am I right to do it in dsolve, or is there any other way to do it?
Your kind help is appreciated in advance,
best regards
Andras
FlowProblem.mw
How do I retrieve data table from Numbers (apple) Worksheet to use in Maple Document (for fit analysis)? Information for Excel exists (not useful) pathway for me), but I could  not locate corresponding information for Numbers
I want to find fundamental matrix of the system: X(t).
Actually I need A=X(T) where T is 2*Pi.
So then I can find whether the solution is stable.
The problem is, I don't understand how to find X(t) in Maple.
Tried to solve numerically with dsolve at t=T but the next step is not obvious.
Eq=z"(t)+3z'(t)+2z(t)=24*(exp(-3t)-exp(-4t)) how to find the gereral solution of this equation. Thank you.
If I have some similar functions, say sin(x), sin(2x)..., what approach is better:
f(i,x):=(i,x)->sin(i*x)
or
f[i](x):=x->sin(i*x)
Or maybe there is another way?
The second one seems more natural for me but  I've stucked with an error:
divide5.mw
NULLNULL
restart; divide5 := proc (f) local x, r; r := unapply((1/5)*f(x), x); eval(r) end proc; f := proc (x) options operator, arrow; x^2 end proc; f := divide5(f); f(3)
9/5
restart; divide5 := proc (f) local i, x, r; r := unapply((1/5)*f(i, x), i, x); eval(r) end proc; f := proc (i, x) options operator, arrow; x^2+i end proc; f := divide5(f); f(5, 3)
14/5
restart; divide5 := proc (f) local x, r; r := unapply((1/5)*f(x), x); eval(r) end proc; f[i] := proc (x) options operator, arrow; x^2+i end proc; f[5] := divide5(f[5]); f[5](3)
Error, (in f[5]) too many levels of recursion
Download divide5.mw
What's the matter?
Thank you for your answers.
I know it is not hard to write such a function, but can be tricky for all options. For 1D and uniform grid, it is straight forward to code it. The formula is here  https://en.wikipedia.org/wiki/Trapezoidal_rule#Uniform_grid
I was looking to see if Maple has this build-in. This is the equivalent of Matlab's trapz
I know about Student:-Calculus1:-ApproximateInt with option trapezoid. But this is not exactly the same. Matlab's trapz can accept just a list of numbers directly (the y values), or a a matrix of numbers (2D function), and applies trapezoidal rule. The default is unit spacing.
It is a simplified version of Student:-Calculus1:-ApproximateInt in a way, but I found trapz easier to use, if one has list of numbers generated before, (i.e. function values) and want to applies trapezoidal rule on it as is. It is more more convenient that way.
Here is an example from Matlab's help. Given
Y = [1 4 9 16 25];
Q = trapz(Y)
it gives 42.
One does not need to define f(x) or x=from..to  as in the case with Maple's ApproximateInt.
Matlab's trapz also supports Matrix as input not just 1D list of numbers.
Does Maple have something similar?
I want to write this system and solve it by picard iteration method
but I don't know how to write a system of ODE in maple
x'=cos (x)    x(0)=1
y'= sin (z)    y(0)=-1
z'= zy           z(0)=2
I have to copy and paset c(n), and my final results are the square root of what they should be.
f:=(x-1)/(x+2)
                               -1 + x
                          f := ------
                               x + 2
plot(f,x=-3..3)
sum(k -> 1/k^2, k=1..1000)
                             1000 f
series(f,x=0);
          1   3     3  2   3   3   3   4   3   5    / 6\
        - - + - x - - x  + -- x  - -- x  + -- x  + O\x /
          2   4     8      16      32      64
s:=convert(f,FormalPowerSeries)
                          /infinity           \
                          |  \     /      k  \|
                          |   )    |   3 x   ||
                 s := 1 + |  /     |- -------||
                          | -----  |        k||
                          \ k = 0  \  2 (-2) //
simplify(s,symbolic)
                 /infinity                       \
                 |   )    /       k  (-k - 1)  k\|
             1 + |  /     \-3 (-1)  2         x /|
                 \ k = 0                         /
                             c := c
c:=k->-(3 *x^k)/((2 (-2)^k))
c(k)
                                  k
                               3 x
                                k
                               2  x
abs( ((c(k+1)*(x^(k+1)))) / ((c(k)*x^k)));
                               2 |    k   |
                     | (k + 1)|  |   2    |
                     |x       |  |--------|
                                 | (k + 1)|
                                 |2       |
                             | k|
                             |x |
simplify( % );
                          | (k + 1)|
                          |x       |
                              | k|
                            2 |x |
L:= limit( %, k=infinity );
                               1    2
                          L := - |x|
solve( L<1, x);
with(plots)
witth(plottools)
f:=(x-1)/(x+2)
p1:=plot(f,x=-3..3):
p2≔circle([0,0],1,color=blue); #add a circle to plot, would like to figure out how to do automatically
           p2&Assign;circle([0, 0], 1, color = blue)
display(p1,p2);
I'm able to plot f(x), but not plot the circle.
First 472 473 474 475 476 477 478 Last Page 474 of 2434
