Can I make something like it using codegen (dinamically set parameters and default arguments freely)?
proc( a , b::integer , c:=0 , d::integer:=1 , { e:=2 , f::integer:=3 } ) return a, b, c, d, e, f end proc
eq1 := diff(h(t), [`$`(t, nu)])+(1/4)*h(t) = 8/3*(1/(sqrt(Pi)*t^(1/2))-(3/32)*t^2+(3/16)*exp(-t)-1);
with ics h^k (0)=0 for k=0..n
Dear Maple Users,
This particular question is example problem 8.4.1 in the textbook: "PDE & BVP with MAPLE", 2nd Edition by George A. Articolo.
I shall paraphrase the problem here and attach the Maple Worksheet solution as detailed in the textbook.
We seek the temperature distribution u(x,t) in a thin rod whose lateral surface is insulated over the interval I = {x | 0 <x<1}. The left end of the rod is held at a fixed temperature of 10, and the right end is held at the fixed temperature of 20. There is no internal heat source. The thermal diffusivity of the rod is k = 1/20, and the rod has an intitial temperature distribution u(x,0) = f(x) given as follows.
The nonhomogeneous diffusion equation is:
ut'(x,t) = k*ux"(x,t) +h(x,t)
The BCs are nonhomogeneous:
u(0,t) = 10
u(1,t) = 20
The IC is:
u(x,0) = 60x -50x2+10
The internal heat source term is:
h(x,t) = 0
I have typed in the MAPLE commands exactly as in the textbook (attached), but it does not execute in my Student 2020 version of MAPLE.
Could you please take a look at the attached MAPLE worksheet and let me know if something can be done to make it work.
Thank you for your help.
Joe Thodiyil
George_A_Articolo_2ndEdition_Ex_8.4.1_PDE.mw
I solve a given pde with some conditions given, but I get
unable to handle PDE problem subject to boundary conditions
solution_pdes.mw
many thanks for your help
I am trying to find one option so that  a sphere is tangent with every edge of a tetrahedron. Suppose tetrahedron OABC, here O(0,0,0), A(x1, y1, z1), B(x2, y2, z2), and C(x3, y3, z3).  How to find a sphere is tangent with every edge of a tetrahedron?
I know how to contruct an isoscele ABCD trapeze knowing the 2L length of AB and BC=CD=CD=a. But I don't know answer to that question : L being fixed together with points A and B , show that the place of C when a varies is a branch of hyberbola. Here is my code.
restart; unprotect(O, D);
Vdot := proc (U, V) add(U[i]*V[i], i = 1 .. 2) end:
dist := proc (M, N) sqrt(Vdot(expand(M-N), expand(M-N))) end:
_EnvHorizontalName := x: _EnvVerticalName := y:
O:=[0,0]:A:=[-L,0]:alpha:=arccos((2*L-a)^2/(2*a*(2*L-a))):h:=tan(alpha)*(2*L-a)/2:
B:=[L,0]:C:=[L-(2*L-a)/2,h]:D:=[-L+(2*L-a)/2,h]:
L := 6; a := 7;
poly := [A, B, C, D, A];tp := textplot([[A[], "A"], [B[], "B"], [C[], "C"], [D[], "D"]], color = black, 'align' = {'above', 'right'});
trapeze := polygonplot(poly, axes = normal, color = "DarkGreen", transparency = .9);
display([tp, trapeze], scaling = constrained); Thank you foryour help.
Hi everyone:
I want to write the below serie in Maple, how can I do it?
where: k = 0,.....,n
n is a Natural number.
tnx...
Dear Users!
I want to find the solution of the solution of PDEs as given bellow:
PDE1 := diff(u(y, t), t)+diff(u(y, t), t, t) = diff(u(y, t), y, y)-u(y, t);
PDE2 := v(y, t)+diff(tau(y, t), t) = diff(u(y, t), y);
ICandBC := {tau(y, 0) = 0, u(0, t) = 0, u(3, t) = 0, u(y, 0) = 0, (D[2](u))(y, 0) = 0};
pds := pdsolve({PDE1, PDE2}, ICandBC, numeric);
But got the following error
Error, (in pdsolve/numeric/process_PDEs) number of dependent variables and number of PDE must be the same
Kindly help me to fix this error. I shall be very thankful.
Special request to:
@acer @Carl Love @Kitonum @Preben Alsholm
I have created a set of help files using the example templates. After I create the .help file and install it with my package, I can view the help pages in the help viewer. However, when I click on any link within a help page, the target page opens as a worksheet in Maple. I understand this is because I created the hyperlink with a worksheet as the target. However, I don't know where to obtain the help topic name for a help page before it has been created.  I have searched help, but can't find any applicable guidance.  Can anyone tell me how to determine the help topic name when first creating the help pages.
I have attached one of my help file worksheets.     Hlpdiracmatrices.mw
I defined a vector (in cartesian coordinates) with Physics[Vectors] as
q_:=3 _i + 5 _j + 2 _k
Then I wanted do a transformation on this vector by multiplying it with matrix
M:=<3,4,2|5,6,2|2,1,4>
M.q_
However, I am getting a result where every element of the matrix is multiplied by the vector.
If I define q as <3,5,2> then matrix multiplication works as one would expect.
So, my question is how can I have a matrix multiplication with a vector defined with Physics[Vectors] package?
Dear Maple community,
I would really appreciate it if you could tell me how I can solve numerically in Maple the following system of equations (the Maple file containing these equations can be found here: Mapleprime_Q.mw):
Thank you very much in advance for you help!
When I create a vector in spherical coordinates and map it to cartesian coordinates with Physics[Vectors] package as follows,
restart:with(Physics[Vectors]):
q_:=a _r + b _theta + c _phi
ChangeBasis(q_,cartesian)
I get the answer:
(a*cos(phi)*sin(theta)+b*cos(phi)*cos(theta)-c*sin(phi)) i + (a*sin(theta)*sin(phi)+b*cos(theta)*sin(phi)+c*cos(phi)) j + (-b*sin(theta)+a*cos(theta)) k
which is what I would expect.
But if I try to do that with VectorCalculus package as follows,
q := SetCoordinates(<a, b, c>, spherical)
MapToBasis(q, cartesian)
This gives
(a*sin(b)*cos(c)) ex + (a*sin(b)*sin(c)) ey + (a*cos(b)) ez
I am confused about this!
The SetCoordinates(<a, b, c>, spherical) command outputs
q:=(a) er  + (b) ephi + (c) etheta
here, a,b, and c are  depicted as the components of the vector q in spherical coordinates, but when I map to cartesian coordinates, a,b, and c are treated as if they were the coordinates in spherical coordinates rather than components-- unlike ChangeBasis in Physics[Vectors] package.
Why are these two different?
Good evening,
is it possible to construct a math table with Maple just with Code? Something like
      test_1    test_2
a       9,6        5,6
b     pending  8,4
to be able to print it? There is
https://de.maplesoft.com/support/help/Maple/view.aspx?path=worksheet/documenting/table            and
https://de.maplesoft.com/support/help/Maple/view.aspx?path=worksheet%2freference%2ftableproperties
, however, I do not understand how to just get any table going and assign calculated values within a procedure as is possible with a matrix for example. Thank you in advance! :)
Hello, I am trying to plot this one and I did not get the graph, I don't know where the problem. Could you please help. thank you
alpha := 0.005;
beta := 0.01;
                          beta := 0.01
mu := 0.005;
                          mu := 0.005
m := 0.003;
                           m := 0.003
u := 0.3;
                            u := 0.3
w := 0.3;
                            w := 0.3
v := 1;
                             v := 1
gamma = 0.1;
                          gamma = 0.1
Gamma := 0.01;
                         Gamma := 0.01
Eq := sigma^4 + sigma^3*[2*(mu*v + mu) + 2*alpha - beta*(u + w) + 2*beta*v] + sigma^2*[4*mu*m + 2*alpha*(2*mu + m) + alpha^2 - 2*beta*v(mu - 2*m) - 2*beta*(u + w)*(mu + m) + alpha*beta*(4*beta + (-u - w)) - beta^2*v*(u + w - v) + k^2*(Gamma^2 + gamma^2)] + sigma*[2*alpha*mu*(2*m - beta*(u + w)) + 2*alpha^2*(beta*v + mu) - 4*beta*mu*m*(u + w + v) + 4*alpha*beta*v*(mu + m) - 2*beta^2*v*(u + w) + 2*beta^2*v^2*(m + alpha) - alpha*beta^2*v*(u + w) + 2*Gamma^2*beta*v*k^2 + 2*k^2*(Gamma^2*mu + gamma^2*m) + gamma^2*k^2*(2*alpha - beta*(u + w))] + [Gamma^2*k^2*(2*beta*mu*v + gamma^2) + Gamma^2*beta^2*k^2*v*(Gamma*v - gamma*(u + w)) - beta*gamma^2*k^2*(u + w)*(alpha + 2*m) + alpha^2*(beta^2*v^2 + gamma^2*k^2) + 2*alpha*beta^2*v*(v*m - mu*(u + w)) + 4*beta*mu*m*v*(alpha - beta*(u + w))];
p1 := implicitplot(Eq, k = 0 .. 10, sigma = -0.1 .. 0.1);
           4
Eq := sigma
   + sigma  [2 mu v + 2 alpha + 2 mu - beta (u + w) + 2 beta v] +
       2 [                                   2
  sigma  [4 mu m + 2 alpha (2 mu + m) + alpha
   - 2 beta v(mu - 2 m) - 2 beta (u + w) (mu + m)
   + alpha beta (4 beta - u - w) - beta  v (u + w - v)
      2 /     2        2\]         [
   + k  \Gamma  + gamma /] + sigma [2 alpha mu (2 m
   - beta (u + w)) + 2 alpha  (beta v + mu)
   - 4 beta mu m (u + w + v) + 4 alpha beta v (mu + m)
           2                   2  2
   - 2 beta  v (u + w) + 2 beta  v  (m + alpha)
               2                    2         2
   - alpha beta  v (u + w) + 2 Gamma  beta v k
        2 /     2           2  \
   + 2 k  \Gamma  mu + gamma  m/
          2  2                         ]   [     2  2 /
   + gamma  k  (2 alpha - beta (u + w))] + [Gamma  k  \2 beta mu v
          2\        2     2  2
   + gamma / + Gamma  beta  k  v (Gamma v - gamma (u + w))
               2  2
   - beta gamma  k  (u + w) (alpha + 2 m)
          2 /    2  2        2  2\
   + alpha  \beta  v  + gamma  k /
   + 2 alpha beta  v (v m - mu (u + w))
   + 4 beta mu m v (alpha - beta (u + w))]
[k1,0], [k2,0], [k3,0], ...) , where k_{n}=2*n*Pi/L and the domain [0,L]
L:=10.0;
p2:=pointplot([seq([2*n*Pi/L,0],n=0..10)],color=red,symbolsize=15):
display(p1,p2);
                           L := 10.0
       /            /     4
display\implicitplot\sigma
       2 [                                   2
      2 /     2        2\]         [
           2                   2  2
               2                    2         2
        2 /     2           2  \
          2  2                         ]   [     2  2 /
          2\        2     2  2
               2  2
          2 /    2  2        2  2\
   + 4 beta mu m v (alpha - beta (u + w))], k = 0 .. 10,
  sigma = -0.1 .. 0.1/, pointplot([[0., 0], [0.6283185308, 0],
  [1.256637062, 0], [1.884955592, 0], [2.513274124, 0],
  [3.141592654, 0], [3.769911184, 0], [4.398229716, 0],
  [5.026548246, 0], [5.654866778, 0], [6.283185308, 0]],
  color = red, symbolsize = 15)/
Hello.
I plot  F1:=1/(x + μ) + x - 1 and on the graph i get the line x = -μ. How can I get rid of it? I try the discont option but I get an error. Do I need, maybe, a specific with command?
The command I use is the next one:
diagd1_1 := implicitplot(F1 = 0, mu = -8 .. 8, x = -4 .. 4, gridrefine = 5, crossingrefine = 15, rational, color = blue, thickness = 2, numpoints = 100000, resolution = 3000, rangeasview)
The error I get:
Error, (in plot/options2d) unexpected option: discont = True
Thanks a lot !!!
First 477 478 479 480 481 482 483 Last Page 479 of 2459
