i have a task who is like this:
let h(x)=2/f(x)
and the function f meets the following criteria
f(-1)=4 and f '(-1)=2
what is h'(-1)
how to i solve this, i am thinking of ordinary differential equations (ODEs)
and dsolve funktion in maple. but how do i do this.
or is there another way to solve it
 Hello , I need to plot the following on the same axes of implicit plot where discrete wavenumbers k1, k2, k3 on the same set of axes (the wavenumbers are points [k1,0], [k2,0], [k3,0], ...) , where k_{n}=2*n*Pi/L and the domain [0,L]
Could you please help , I couldn't do. Thank you
with(plots, implicitplot);
alpha := 0.1;
beta := 0.1;
mu := 0.5;
u := 0.5;
v := 1;
gamma = 0.1;
                          alpha := 0.1
                          beta := 0.1
                           mu := 0.5
                            u := 0.5
                             v := 1
                          gamma = 0.1
Eq := -2*sigma*alpha*beta*mu*u - sigma*alpha*beta^2*u*v - 2.0*mu*alpha*beta^2*u*v - gamma^2*k^2*alpha*beta*u + beta*sigma^2*v + sigma^3 + 2*mu*sigma^2 - alpha*beta*sigma^2*u + sigma*beta^2*u*v + gamma^2*k^2*sigma + 2.0*mu*beta*sigma*v + 2.0*mu*beta^2*u*v;
                                            2  2              2
 Eq := 0.0995 sigma + 0.004500 - 0.005 gamma  k  + 1.095 sigma
           3        2  2
    + sigma  + gamma  k  sigma
implicitplot(Eq, k = 0 .. 10, sigma = -0.1 .. 0.1);
Please can someone help me out, have been trying for a very long time now on how to differentiate the lines on the graph.......please find attachment below and correct..................................................................
# Define the ODE system
  odeSys:= { (diff(F(eta), eta, eta, eta))*(1+epsilon-alpha((diff(F(eta), eta, eta))^2))+F(eta)*(diff(F(eta), eta, eta))+S*(diff(F(eta), eta))-(1/2)*S*eta*(diff(F(eta), eta, eta))-(diff(F(eta), eta))^2-M*(diff(F(eta), eta)), (diff(theta(eta), eta, eta))*(1+R)-delta*(diff(F(eta), eta))^2-Pr((3/2)*S*theta(eta)+(1/2)*S*eta*(diff(theta(eta), eta))-2*(diff(F(eta), eta))*theta(eta)+F*(diff(theta(eta), eta)))};
# Define the first set of boundary conditions
  bcs1:= { F(0) = 0, (D(F))(0) = 1, (D(F))(inf) = 0, theta(0) = 1, theta(inf) = 0
  RVals:=[0.1, 0.5, 1]:
  for k from 1 by 1 to numelems(RVals) do
      pList:=[ epsilon = 0.18, M = 0.5, S = 1.5, delta = 0.3, Pr = 1.5, alpha = 0.4, R = RVals[k],inf=1
      sol1[k]:= dsolve( eval
                        ( `union`( odeSys, bcs1),
                           pList
                       numeric
  display
  ( [ seq
      ( odeplot
        ( sol1[i],
          [eta, theta(eta)],
          eta=0..2
        i=1..numelems(RVals)
    color = [red, green, blue],
    title = typeset( theta(eta), " versus ", eta),
    titlefont = [times, bold, 20]
I want to do a organised introduction in Maple  with the student and main vectorcalculus package
Is there some studymatrial to find for this ?
I am using Maple to solve a system of ODEs numerically. Right now, I want to find the integration of the output of the system of ODEs. How it is possible to do this?
F := dsolve(ODESys union ICs, {y0(t), y1(t), y2(t), y3(t)}, type = numeric)
Y0 := t -> rhs(op(2, F(t)))
Now, I want to find int(Y0,t=0..1).
Why this simple case cannot be simplified to Complete Square form
EQ := 1/4*n[1]^4 - 1/2*n[1]^2 + 1/4
simplify(1/4*n[1]^4 - 1/2*n[1]^2 + 1/4, 'size')
with(Student[Precalculus])
CompleteSquare(EQ);
Would you tell me a way to apply the identity relationship in Maple, to rewrite 'subexp' below to 'subexp2'?
subexp := M__a*sin(omega*t + alpha)*I__a*sin(omega*t + phi);
M__a*sin(omega*t+alpha)*I__a*sin(omega*t+phi)
subexp2 := M__a * I__a * (-1/2*(cos(2*omega*t + alpha + phi)-cos(alpha - phi)));
M__a*I__a*(-(1/2)*cos(2*omega*t+alpha+phi)+(1/2)*cos(alpha-phi))
is(subexp = subexp2);
Download Q20200901.mw
In the plane, an ABC triangle is considered for the vertices B and C are fixed, A being variable so that b +c remains constant and equal to a given length l. (b=distance(A,C), (c=distance(A,B)
How to show that the product tan(B/2=*tan(C/2) remains constant ?
I would like to solve this equation and keep the parameters a and eta unknown and assign them a value later on. Is it possible ?
I know I can solve this equation numerically, it works, but I want to change the parameters to fit experimental data.
I tried this :
ode:=diff(y(t),t)=-(4/3)*(a/eta)*(y(t)^3+1):
lambdaE:=dsolve({ode,y(0)=1},y(t),explicit);
But the solution appears with RootOf expression and I can't get a numerical solution afterwards.
lambdaE := y(t) = RootOf(6*eta*sqrt(3)*arctan(((2*_Z - 1)*sqrt(3))/3) - eta*sqrt(3)*Pi - 3*eta*ln(_Z^2 - _Z + 1) + 6*eta*ln(_Z + 1) - 6*eta*ln(2) + 24*t*a)
I tried some things from forums but nothing works.
Do you have any leads on how to do it please ?
Thank you in advance
Manon
is there easy way to simulate lines rotation like robotic arm following point P moving by adjusting angle q1 and q2?
i feel point two lines and simulate static two lines in animate is also not easy.
with(geometry):
#Joint at (5,5)
#length a  2, y=7, x, solve(subs(y=7,2^2 = (y-5)^2+(x-5)^2), x)[1];
#length b 2, y=1, x, solve(subs(y=4,2^2 = (y-5)^2+(x-5)^2), x)[1];
point(A, 5, 5), point(B, solve(subs(y=7,2^2 = (y-5)^2+(x-5)^2), x)[1], 7):
point(C, 5, 5), point(D, solve(subs(y=4,2^2 = (y-5)^2+(x-5)^2), x)[1], 4):
line(L1, [A, B]);
line(L2, [C, D]);
_EnvHorizontalName := x;
_EnvVerticalName := y;
Equation(L1);
Equation(L2);
solve(Equation(L1), y);
solve(Equation(L2), y);
plot([solve(Equation(L1), y),solve(Equation(L2), y)], x = 1 .. 2);
animate(plot, [Equation(L1),Equation(L2), x = 0 .. 2], A = -3 .. 3);
Angle Reference from below
angle of L2 , q1a
angle of L1,  q2a
p1 := vector([a*cos(q1), a*sin(q1)]);
P := evalm(p1 + b*vector([cos(q1+q2), sin(q1+q2)]));
Pe := map(expand, P);
A := {cos(q1) = c1, sin(q1) =s1, cos(q2)=c2, sin(q2)=s2};
P := subs(A, op(Pe));
F1 := [x - P[1], y - P[2], s1^2+c1^2-1, s2^2+c2^2-1 ];
F2 := subs({a=1, b=1}, F1);
with(Groebner):
g1 := Basis(F2, plex(c2, s2, c1, s1, y, x));
g1 := [-4*x^2+x^4+2*x^2*y^2+y^4-4*y*x^2*s1-4*y^3*s1+4*s1^2*x^2+4*s1^2*y^2, 2*y*s1+2*x*c1-x^2-y^2, 4*x-x^3-y^2*x+2*y*x*s1-2*y^2*c1-4*s1^2*x+4*y*s1*c1, s1^2+c1^2-1, x*s1-y*c1+s2, -y^2+2-x^2+2*c2];
map(indets, g1);
g2 := Basis(F2, plex(c2, s2, c1, s1));
assume point x = 1, y = 0.5
g2spec := subs({x=1, y=1/2}, [g2[1],g2[3]]);
S1 := [solve(g2spec[1])];
q1a := evalf(arcsin(S1[1]));
q1b := evalf(arcsin(S1[2]));
S2 := [solve(subs(s1=S1[1], g2spec[2])), solve(subs(s1=S1[2], g2spec[2])) ];
q2a := evalf(arcsin(S2[1]));
q2b := evalf(arcsin(S2[2]));
q2a := subs({a=2,b=2}, q2a);
if q2a < 0 then
 q2a_pi := evalf(eval(-q2a-Pi));
 q2a_pi := evalf(eval(Pi-q2a));
end if:
q2a_pi;
q2b := subs({a=2,b=2}, q2b);
if q2b < 0 then
 q2b_pi := evalf(eval(-q2b-Pi));
 q2b_pi := evalf(eval(Pi-q2b));
end if:
q2b_pi;
I've been using Physics:-Latex in my large program, and checking the output visually. I noticed this small issue on one page.
When asking Physics:-Latex to generate Latex for this expression
It gives
While when using standard latex() command, the result is
Below is the worksheet attached. Using Latest Physics and Maple.
interface(version)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 784 and is the same as the version installed in this computer, created 2020, August 31, 0:51 hours Pacific Time.`
expr:=1/2*int(exp(-t)*f(t),t)*exp(t)-1/2*exp(-t)*int(exp(t)*f(t),t)
(1/2)*(int(exp(-t)*f(t), t))*exp(t)-(1/2)*exp(-t)*(int(exp(t)*f(t), t))
Physics:-Latex(expr)
\frac{\left(\int {\rm e}^{-t} f \left(t \right)d t \right) {\rm e}^{t}}{2}+-\frac{1}{2} {\rm e}^{-t} \left(\int {\rm e}^{t} f \left(t \right)d t \right)
latex(expr)
{\frac {\int \!{{\rm e}^{-t}}f \left( t \right) \,{\rm d}t{{\rm e}^{t}
}}{2}}-{\frac {{{\rm e}^{-t}}\int \!{{\rm e}^{t}}f \left( t \right)
\,{\rm d}t}{2}}
THe latex file used to compile the Maple output Latex using TeXLive distribution on Linux is
\documentclass[12pt]{article}
\usepackage{amsmath}
%\usepackage{maplestd2e} %not needed for this example
\begin{document}
%output of Physics:-Latex()
%output of maple latex()
{\frac {\int \!{{\rm e}^{-t}}f \left( t \right) \,{\rm d}t{{\rm e}^{t}}}{2}}-{\frac {{{\rm e}^{-t}}\int \!{{\rm e}^{t}}f \left( t \right) \,{\rm d}t}{2}}
\end{document}
Download latex_issue_5.mw
Hello everyone, my computer installed Maple 2016, 2020 and set Maple 2016 as default opening files .mw, .mws. How to change default to Maple 2020 . I tried searching on Google but not found.
Thank you very much.
How to calculate the residual sum of squares of a Nonlinear Fitting?
I tried but was unsuccessful.
How I can prove the following equation in red box.
Also, Pn(v) and qn(v) are the real combinations of half-integer Legendre functions.
For more details please see
https://math.stackexchange.com/questions/2746660/potential-flow-around-a-torus-laplace-equation-in-toroidal-coordinates/3809487#3809487
I did already some programmingexercises , but this sort of programming example i did not encounter in the programmingbook
How it is programmed in general lines ?
I do have a lot of small procedures to learn from
But it is too much asked here on the forum to explain all ins and outs for this procedure, because it is not that simple.
Download Basisgrid_procedure.mw
First 506 507 508 509 510 511 512 Last Page 508 of 2428
