Hi all, I have a linear equations 31 variables, I want to solve for m[i] >=0. Someone can help me, thank you very much.
L := {m[4]+4*m[7]+m[10]+m[13]+m[16]+m[19]+m[22] = 2*sqrt(2)+7, m[15]+3*m[18]+11*m[21]+m[6]+9*m[12]+2*m[3]-2*sqrt(2)*m[18]+6*sqrt(2)*m[21]-4*sqrt(2)*m[12]+m[24] = 2*sqrt(2)+61, -4*sqrt(2)*m[14]+6*m[14]+m[17]+11*m[20]+m[2]+4*m[5]+18*m[8]+6*sqrt(2)*m[20]-8*sqrt(2)*m[8]+m[23] = 2*sqrt(2)+34, m[27]-2*sqrt(2)*m[19]+4*sqrt(2)*m[7]+2*sqrt(2)*m[13]-2*m[16]+m[17]-6*m[19]-4*m[4]+m[5]+m[20]-16*m[7]+4*m[8]+m[11]-4*m[13]+m[14] = 6*sqrt(2)-6, m[28]+2*sqrt(2)*m[19]-4*sqrt(2)*m[10]-2*sqrt(2)*m[16]+m[15]+2*m[16]+m[18]+2*m[4]+m[6]+6*m[19]+m[21]+4*m[9]+2*m[10]+m[12]-2*m[13] = 6*sqrt(2)+21, m[25]+6*sqrt(2)*m[19]-2*sqrt(2)*m[20]-8*sqrt(2)*m[7]+4*sqrt(2)*m[8]-4*sqrt(2)*m[13]+2*sqrt(2)*m[14]+6*m[13]-4*m[14]+m[16]-2*m[17]+m[1]+4*m[4]+11*m[19]-6*m[20]-4*m[5]+18*m[7]-16*m[8] = 6*sqrt(2)-33, m[26]+6*sqrt(2)*m[19]+2*sqrt(2)*m[21]-4*sqrt(2)*m[10]-4*sqrt(2)*m[12]-2*sqrt(2)*m[16]-2*sqrt(2)*m[18]+m[13]-2*m[15]+3*m[16]+2*m[18]+2*m[1]+11*m[19]+6*m[21]+m[4]+2*m[6]+9*m[10]+2*m[12] = 6*sqrt(2)-33, m[29]+2*sqrt(2)*m[18]+6*sqrt(2)*m[20]-12*sqrt(2)*m[21]-2*sqrt(2)*m[3]-4*sqrt(2)*m[11]-2*sqrt(2)*m[15]-2*sqrt(2)*m[17]+m[14]+4*m[15]+3*m[17]-2*m[18]+2*m[2]+11*m[20]-22*m[21]+m[5]-4*m[6]+9*m[11] = 6*sqrt(2)-6, m[30]-12*sqrt(2)*m[20]+6*sqrt(2)*m[21]-2*sqrt(2)*m[2]-8*sqrt(2)*m[9]-2*sqrt(2)*m[14]-4*sqrt(2)*m[15]+2*sqrt(2)*m[17]+4*m[14]+6*m[15]-2*m[17]+m[18]+m[3]-22*m[20]+11*m[21]-4*m[5]+4*m[6]+18*m[9] = 6*sqrt(2)+21, -4*m[4]+2*m[5]+2*m[17]-2*m[18]-22*m[19]+6*m[20]-6*m[21]-2*m[16]-4*m[15]+m[31]-4*m[6]-16*m[9]+2*m[11]+4*m[13]-2*m[14]-2*sqrt(2)*m[1]+4*sqrt(2)*m[9]-2*sqrt(2)*m[17]-4*sqrt(2)*m[11]+2*sqrt(2)*m[15]+2*sqrt(2)*m[16]-12*sqrt(2)*m[19]-2*sqrt(2)*m[13]+2*sqrt(2)*m[20]-2*sqrt(2)*m[21] = 12*sqrt(2)-120}
In reference to the nice application: https://www.mapleprimes.com/posts/209845-Dataframes--Looking-For-A-New-Flashlight by @Christopher2222 ,  my question is:
is there a simple way to sort primarily by one column, but if two elements possess identical values, then using a second column to determine the order? For example, what if we wanted to sort the flashlight dataframe primarily by "B-type" but use a subsort by "Minutes".
I wrote a function which used recursion. It worked fine for small dataframes, but was painfully slow with a multi-thousand element spreadsheet.
I have a nonhomogeneous heat conduction problem, where the thermal conductivity, the density, and the specific heat of the
material are piecewise functions.
The thermal conductivity derivative has a discontinuity that causes a problem in the pdsolve command (see the first test).
To avoid this problem, I did a second test where the product rule was calculated directly.
Is there a better way to deal with this problem?
thank you
problem.mw
Dear Maple community,
I am trying to import from a .csv (or .xls) a matrix, whose symbolic elements have subscripts of a type "a[1, 2, 3, 4]" (i.e., datatype=indexed). However, when I enter "ImportMatrix(csvFile, datatype = indexed)", I receive an error message "Error, (in ImportMatrix) unable to store '0' when datatype=indexed". I would highly appreciate your help with importing an indexed matrix. Thank you.
Are there any established (or not established but cool) methods to exchange data between different worksheets or workbooks?
Actually there are 2 questions.
  1. If I have 2 different worksheets or workbooks open in Maple, and want to exchange data between them.
  2. One workbook, but different worksheets in the same workbook.
I am currently working on a project that generates a set of matrices and I want to find their eigenvalues, but using the inbuilt Maple engine takes too long. The problem is that whenever I try to use the Matlab[eig] command I get the error:
Error, (in Matlab:-setvar) unable to store '-3.*Re(X)' when datatype=float[8]
I found out that solving symbolic matrices in MATLAB requires first defining symbols with the "sym" command but I've been unable to do that in Maple.
why   print(lastexception);  gives `[Length of output exceeds limit of 1000000]` while just doing lastexception; gives no problem?
eq:=x*y*p = y^2+x*(4*x^2+y^2)^(1/2);
try
   sol:= timelimit(20,`assuming`([solve(eq,y)],[real]));
catch:
end try;
lastexception
I know one should use something like
print(StringTools:-FormatMessage( lastexception ))
But I do not know why print(lastexception) gives the length exceeds error.
whattype(lastexception) gives exprseq
Maple 2020.1
In this post https://math.stackexchange.com/questions/1196194/asymptotic-behaviour-of-frac1x-1-frac1x2-1-frac1x3-1-cdots
this sum is evaluated in the answer to be
I cannot see how to use eularmac to get this answer as x approaches 1.
Maybe using
ge := `assuming`([sum(1/(x^k-1), k = 1 .. infinity)], [k::integer])then something like
eulermac(ge, limit(ge, x = 1), 3)
Could anyone help me to numerically solve this ode?
I've tried almost all the methods Maple proposes, trying to adjust stepsizes, tolerances and so on;, always without success.
I give also the exact solution of this ode in order to compare the numerical solution to.
interface(version)
# Source term
F := t*(-600*t/(100*t^2+1)^2+80000*t^3/(100*t^2+1)^3)/(100*t^2+1)-(1/(100*t^2+1)-200*t^2/(100*t^2+1)^2)/(1+(1/(100*t^2+1)-200*t^2/(100*t^2+1)^2)^2);
plot(F, t=0..0.5);
# Ode
ode := X(t)*diff(X(t), t$2)-diff(X(t),t)/(1+diff(X(t),t)^2) - 'F'
X(t)*(diff(diff(X(t), t), t))-(diff(X(t), t))/(1+(diff(X(t), t))^2)-F
# Initial conditions
ics := X(0) = 0, D(X)(0) = 1
X(0) = 0, (D(X))(0) = 1
# I used alot methods with allways either failure or either a HFloat(undefined)
printf("rkf45\n");
sol := dsolve({ode, ics}, numeric):
sol(1e-8);
printf("\n\nrosenbrock\n");
sol := dsolve({ode, ics}, numeric, method=rosenbrock):
sol(1e-8);
printf("\n\ngear\n");
sol := dsolve({ode, ics}, numeric, method=gear):
sol(1e-8);
sol := dsolve({ode, ics}, numeric, method=classical[heunform]):
sol(1e-8);
rkf45
Error, (in sol) cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
rosenbrock
Error, (in dsolve/numeric/SC/firststep) unable to evaluate the partial derivatives of f(x,y) for stiff solution
gear
[t = 0.1e-7, X(t) = HFloat(HFloat(undefined)), diff(X(t), t) = HFloat(HFloat(undefined))]
gear
# The solution must be this one
U := t -> t/((t*10)^2+1)
proc (t) options operator, arrow; t/(100*t^2+1) end proc
# Check ode and ics
eval(ode, X(t)=U(t));
U(0);
D(U)(0);
# Plots when a solution is obtained
display(
  plot(U(t), t=0..1, color=blue),
  odeplot(sol, [t, x(t)], t=0..1, color=red, linestyle=3)
Download Unsuccessful_dsolve.mw
xE.mw
I integrate the expression maple but the result is large. How to furtherxE.mw reduce the size of the result? Also, what is dilog on maple?
Just wondering why
x:=2*{};
has(x,{})
Clearly {} is special. But is there a way to make it return true?
Warning, cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
p := 10; omega := 0.3e-2; q := 0.234e-1; phi := .2; beta := .1; alpha := .2; sigma := 0.4e-2; tau := 0.2e-1; theta := .13; Omega := 0.23e-1; mu := 0.2e-1; k := 0.18e-1; eta := 0.2e-1; delta := 0.1e-1; unprotect(gamma); gamma := 0.2e-1; rho := 0.2e-1; PI := 0.4e-1; xi := 0.57e-1; a := 0.11e-1; l := 0.73e-1; chi := 0.95e-1; nu := 0.8e-1; unprotect(Zeta); Zeta := 0.26e-1; varphi := 0.2e-1;
funcs := diff(S(t), t) = delta*V(t)+PI*C__Sy(t)+xi*C__Asy(t)+varphi*R(t)+(1-p)*omega-(mu+(q+(1-q)*lambda)*phi+chi*lambda+nu)*S(t), diff(V(t), t) = p*omega-rho*lambda*V(t)+nu*S(t)-(delta+mu+kappa*lambda*eta+(1-kappa)*lambda*eta)*V(t), diff(C__Sy(t), t) = q*phi*S(t)+Omega*C__Sy(t)+eta*kappa*lambda*V(t)+l*i(t)-(PI+theta+mu+beta+sigma)*C__Sy(t), diff(C__Asy(t), t) = (1-q)*phi*S(t)+theta*C__Sy(t)+eta*lambda*(1-kappa)*V(t)+alpha*i(t)-(xi+Omega+mu+alpha+tau)*C__Asy(t), diff(i(t), t) = rho*lambda*V(t)+alpha*C__Asy(t)+beta*C__Sy(t)+chi*lambda*S(t)-(mu+Zeta+gamma+a+l)*i(t), diff(R(t), t) = gamma*i(t)+tau*C__Asy(t)+sigma*C__Sy(t)-(mu+varphi)*R(t), S(0) = 200, V(0) = 100, C__Sy(0) = 80, C__Asy(0) = 50, i(0) = 70, R(0) = 40;
p1 := dsolve({funcs}, type = numeric, abserr = 2.4);
p1i := odeplot(p1, [t, S(t)], 0 .. 120, numpoints = 100, labels = ["Time(Days)", "Susceptible  population"], labeldirections = [horizontal, vertical], style = line, axes = boxed, color = red);
Apparently the return value of a GetProperty check is not a boolean variable, but something else.
Why?
boolean.mw
I am creating Maple figures that are being used to create camera-ready figures in Adobe Illustrator. The graphic artist doing the Adobe Illustrator has asked me if there is a way to have the text information in the figure (tickmarks, axis labels, ...) saved as text and not created as an image?
I know that other EPS files have text stored this way, but it appears Maple does not do this. I can't find any documentation about this. Does anybody have any knowledge or experience about this?
Thanks in advance,
Doug
First 519 520 521 522 523 524 525 Last Page 521 of 2434
