My objective is to write a procedure that will read data from xml at different mentioned condition, read ICBO value at different condition of VGS i.e ICBO value at VGS=5V
BJT_ICBO := proc(parsedXML, VGS at condition )
can some one help me to write procedure
I inadvertently discovered that it was possible to create variables in a kind of dynamic way.
I wonder if the way i did  is something which is documented somewhere?
TIA
vars   := [a, b__c, t[1]];
[a, b__c, t[1]]
k := 1:
for i in vars do
  ``||i := k;
  k := k+1:
vars;
[1, 2, 3]
Download Assignement.mw
I have a 2nd order linear ODE that I solved firstly in a formal way.
The plot of the solution contains a "hole" which, in fact, corresponds to the range where the formal solution is not real.
This seemed strange to me as I expected a real solution.
So I solved this ODE numerically and this gave me a real solution.
Could you please explain that to me ?
PS : These results are obtained with Standard Worksheet Interface, Maple 2015.2, Mac OS X, December 21 2015 Build ID 1097895
perturbation := .9*(diff(epsilon(t), t, t)) = (-28.67085587*piecewise(0.2000000000e-1*t < 0.8e-1, 0., 0.2000000000e-1*t < .12, -0.8e-1+0.2000000000e-1*t, 0.2000000000e-1*t < .14, .16-0.2000000000e-1*t, 0.2e-1)-0.7645561571e-1*t-1.548363347)*(diff(epsilon(t), t))-0.7596363e-1*piecewise(0.2000000000e-1*t < 0.8e-1, 0., 0.2000000000e-1*t < .12, -0.8e-1+0.2000000000e-1*t, 0.2000000000e-1*t < .14, .16-0.2000000000e-1*t, 0.2e-1)-0.202569683e-3*t+0.26997403e-1-10.10*epsilon(t)
perturbation := .9*(diff(`&epsilon;`(t), t, t)) = (-28.67085587*piecewise(0.2000000000e-1*t < 0.8e-1, 0., 0.2000000000e-1*t < .12, -0.8e-1+0.2000000000e-1*t, 0.2000000000e-1*t < .14, .16-0.2000000000e-1*t, 0.2e-1)-0.7645561571e-1*t-1.548363347)*(diff(`&epsilon;`(t), t))-0.7596363e-1*piecewise(0.2000000000e-1*t < 0.8e-1, 0., 0.2000000000e-1*t < .12, -0.8e-1+0.2000000000e-1*t, 0.2000000000e-1*t < .14, .16-0.2000000000e-1*t, 0.2e-1)-0.202569683e-3*t+0.26997403e-1-10.10*`&epsilon;`(t)
Digits:=10:
EPS := rhs( dsolve({evalf(perturbation), epsilon(0)=0, D(epsilon)(0)=0}, epsilon(t)) ):
# a lengthy expression that involves Kummer's special functions
plot(EPS, t=0..10, gridlines=true);
Digits:=20:
evalf(eval(EPS, t=5));
Digits:=10:
-0.26529838913395427314e88+0.10340147081332027605e89*I
numsol := dsolve({perturbation, epsilon(0)=0, D(epsilon)(0)=0}, numeric):
odeplot(numsol, [t, epsilon(t)], t=0..10, gridlines=true, color=red)
Download dsolve_vs_numeric_dsolve.mw
kindly send me OHAM source code in Maple for PDEs. I need it.
I have the following set of coefficients
coef7 := [-1, 2, alpha[1, 2], alpha[2, 6], (17*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)+17)/(alpha[1, 2]*alpha[2, 6]), -17/alpha[2, 6], -33/(32*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)), -(163/32+RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)^2+5*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)*(1/4))/(alpha[1, 2]*alpha[2, 6]), -RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)-5/4, RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)]
Considering that alpha[1,2] and alpha[2,6] are always real, how can I extract only the real solution from coef7?
Many thanks.
Ed
Hello everyone!
Is it possible to find index of first non-negative or first positive Vector's (or Array's) element with the help of one Maple build-in comand (for example: use something from ArrayTools or ListTools)?
In maple, how to change strings style? Thanks!
In Mathematica , we can choose Style to change strings style.
Style["A", Blue, Italic, 24]
source of the  problem : I make an User Interface.
the color of   "mass "  may consider be changed to  red .
"with(LinearAlgebra):  T := proc(n::integer)  local t0, tn, i, t, t1;  if (n>0) then t0 := Matrix(1, 1, 1); tn := Matrix(1,1,0);  for i from 1 to n do local z := 2^i;  t := Matrix([[Add(t0, tn), x .~ t0], [t0, ZeroMatrix(z/(2))]]);  t1 := Matrix([[y .~ t0, ZeroMatrix(z/(2))], [ZeroMatrix(z/(2)), ZeroMatrix(z/(2))]]);  t0 := t; tn := t1;  end do;  else 'T'(n) end if; t0; end proc;"
Error, unterminated loop
"with(LinearAlgebra):  T := proc(n::integer)  local t0, tn, i, t, t1;  if (n>0) then t0 := Matrix(1, 1, 1); tn := Matrix(1,1,0);  for i from 1 to n do local z := 2^i;  t := Matrix([[Add(t0, tn), x .~ t0], [t0, ZeroMatrix(z/2)]]);  t1 := Matrix([[y .~ t0, ZeroMatrix(z/2)], [ZeroMatrix(z/2), ZeroMatrix(z/2)]]);  t0 := t; tn := t1;  end do;  else 'T'(n) end if; t0; end proc;"
T(2)
T(2)
Download G2.mw
Hello everyone. I was trying to code the recurrence relation given in the image below (without taking the mth power):
But, as I run the program, I am getting an "unterminated loop" error. Can someone please point out the mistake(s)?
Is there any way to write the expression into the ratio of simple determinants? i..e,
How do we remove the module name functions that massively pollute the output after using with(Units[Standard]):
So that I can have something presentable like this :
Dear sir, I request to suggest the method for the following posted question.
How to find a rational function with give real roots 1,2,3  and oblique asymptote y=2-x?
Based on an answer to a question posted on MaplePrimes, which I am I able to locate through the search system, but that I know it is recent, I am trying to calculate the parameters of a function which minimizes the result of a numerical integral. The function, f1(x), is well defined. The function f2(x) has two parameters, K and r. The integral of the square of the difference between the two function cannot be solved symbolically. Hence my plan is to use the Minimization function in Optimization to determine the values of K and r.
The attached worksheet includes two examples - a practice example for me to become familiar with using Optimization:-Minimization for an integral and the actual problem I am attempting to solve. Note: it was only through MaplePrimes that I learned the function must be defined through a procedure. Here is what I discovered in my experiments:
* the command to perform the numerical integration requires the small "i" verion of int, not Int, i.e evalf( int( function, limits )), not evalf(Int(..)).  This seems to be inconsistent with the documentation. Can someone explain why it is this way?
* The function must be defined locally. If I try to use a globally defined function, non-numeric results are encountered. Is there a way to integrate a global function?
* For the practice problem, it works as long as I abide by the conditions in the previous 2 bullet points.
* When I try to solve the real problem, which appears to be solvable by eyeballing some graphs (included), the kernal is lost.  This is repeatable for me. Do others experience this problem?
Thank you for your attention.
Aside: It would be useful if the output of a search in MaplePrimes could be sorted by date.
 MaplePrimes_Minimization.mw
Hi, can someone explain me why CodeGeneration in C throws the error : Error, (in Print) improper op or subscript selector ? Interestingly, CodeGeneration in Python or Matlab works. Source code is attached. Thanks in advance!
membrane_energy.mw
Membrane Energy
restart; with(VectorCalculus); with(LinearAlgebra); with(CodeGeneration)
Define variables
Vectors for vertices of current position
v1 := Vector(3, symbol = v1_i) = Vector[column]([[v1_i[1]], [v1_i[2]], [v1_i[3]]], ["x", "y", "z"])
v2 := Vector(3, symbol = v2_i) = Vector[column]([[v2_i[1]], [v2_i[2]], [v2_i[3]]], ["x", "y", "z"])NULL
v3 := Vector(3, symbol = v3_i) = Vector[column]([[v3_i[1]], [v3_i[2]], [v3_i[3]]], ["x", "y", "z"])NULL
n := `&x`(v2-v1, v3-v1)
v4 := v1+n/norm(n, 2)^.5
Vector for vertices of next position
v1n := Vector(3, symbol = v1n_i) = Vector[column]([[v1n_i[1]], [v1n_i[2]], [v1n_i[3]]], ["x", "y", "z"])NULL
v2n := Vector(3, symbol = v2n_i) = Vector[column]([[v2n_i[1]], [v2n_i[2]], [v2n_i[3]]], ["x", "y", "z"])NULL
v3n := Vector(3, symbol = v3n_i) = Vector[column]([[v3n_i[1]], [v3n_i[2]], [v3n_i[3]]], ["x", "y", "z"])NULL
nn := `&x`(v2n-v1n, v3n-v1n)
v4n := v1n+nn/norm(nn, 2)^.5``
Define Transformation
V := LinearAlgebra:-Transpose(Matrix([v2-v1, v3-v1, v4-v1]))
Dimension(V) = 3, 3
Vn := LinearAlgebra:-Transpose(Matrix([v2n-v1n, v3n-v1n, v4n-v1n]))
Dimension(Vn) = 3, 3NULL
Note we have Vn = T*V and if the current triangle is not degenerate, then T = Vn/V. As we can pre-compute 1/V we define a new matrix for it:
Vinv := Matrix(3, 3, symbol = Vinv_ij) =
Matrix(%id = 18446746713267339006)
(1.2.1)
T := MatrixMatrixMultiply(Vn, Vinv)
Dimension(T) = 3, 3``
Define Energy
E := Trace(MatrixMatrixMultiply(T, LinearAlgebra:-Transpose(T)))``
Gradient and Hessian
gradE := Gradient(E, [v1n[1], v1n[2], v1n[3], v2n[1], v2n[2], v2n[3], v3n[1], v3n[2], v3n[3]])
Dimension(gradE) = 9NULL
CodeGeneration[C](gradE, defaulttype = numeric, optimize = tryhard, functionprecision = double, precision = double, deducetypes = false, resultname = 'gradE')t1 = v2n_i[0] - v1n_i[0];
t2 = v2n_i[1] - v1n_i[1];
t3 = v2n_i[2] - v1n_i[2];
t4 = t1 * Vinv_ij[0][0] + t2 * Vinv_ij[1][0] + t3 * Vinv_ij[2][0];
t5 = t1 * Vinv_ij[0][1] + t2 * Vinv_ij[1][1] + t3 * Vinv_ij[2][1];
t6 = t1 * Vinv_ij[0][2] + t2 * Vinv_ij[1][2] + t3 * Vinv_ij[2][2];
t7 = v3n_i[0] - v1n_i[0];
t8 = v3n_i[1] - v1n_i[1];
t9 = v3n_i[2] - v1n_i[2];
t10 = t7 * Vinv_ij[0][0] + t8 * Vinv_ij[1][0] + t9 * Vinv_ij[2][0];
t11 = t7 * Vinv_ij[0][1] + t8 * Vinv_ij[1][1] + t9 * Vinv_ij[2][1];
t12 = t7 * Vinv_ij[0][2] + t8 * Vinv_ij[1][2] + t9 * Vinv_ij[2][2];
t13 = t2 * t9 - t3 * t8;
t14 = fabs(t13);
t15 = t1 * t9 - t3 * t7;
t16 = fabs(t15);
t17 = t1 * t8 - t2 * t7;
t18 = fabs(t17);
t19 = pow(t14, 0.2e1) + pow(t16, 0.2e1) + pow(t18, 0.2e1);
t20 = pow(t19, -0.5e1 / 0.4e1);
t19 = t19 * t20;
t21 = Vinv_ij[0][0] * t13;
t22 = Vinv_ij[1][0] * t15;
t23 = Vinv_ij[2][0] * t17;
t24 = (t23 + t21 - t22) * t19;
t25 = -v2n_i[2] + v3n_i[2];
t26 = fabs(t15) / t15;
t27 = -v2n_i[1] + v3n_i[1];
t28 = fabs(t17) / t17;
t21 = t23 + t21 - t22;
t22 = (t16 * t25 * t26 + t18 * t27 * t28) * t20;
t23 = 0.1e1 / 0.2e1;
t29 = Vinv_ij[0][1] * t13;
t30 = Vinv_ij[1][1] * t15;
t31 = Vinv_ij[2][1] * t17;
t32 = (t31 + t29 - t30) * t19;
t29 = t31 + t29 - t30;
t30 = Vinv_ij[0][2] * t13;
t15 = Vinv_ij[1][2] * t15;
t17 = Vinv_ij[2][2] * t17;
t31 = (t17 + t30 - t15) * t19;
t15 = t17 + t30 - t15;
t17 = t6 + t12;
t30 = t5 + t11;
t33 = t4 + t10;
t13 = fabs(t13) / t13;
t34 = -v2n_i[0] + v3n_i[0];
t35 = (t14 * t25 * t13 - t18 * t34 * t28) * t20;
t35 = t17 * Vinv_ij[1][2] - t24 * (t23 * t35 * t21 - t19 * (t25 * Vinv_ij[0][0] - t34 * Vinv_ij[2][0])) + t30 * Vinv_ij[1][1] - t31 * (t23 * t35 * t15 - t19 * (t25 * Vinv_ij[0][2] - t34 * Vinv_ij[2][2])) - t32 * (t23 * t35 * t29 - t19 * (t25 * Vinv_ij[0][1] - t34 * Vinv_ij[2][1])) + t33 * Vinv_ij[1][0];
t36 = (t14 * t27 * t13 + t16 * t34 * t26) * t20;
t34 = Vinv_ij[2][2] * t17 - t24 * (-t23 * t36 * t21 + t19 * (t27 * Vinv_ij[0][0] - t34 * Vinv_ij[1][0])) + t30 * Vinv_ij[2][1] - t31 * (-t23 * t36 * t15 + t19 * (t27 * Vinv_ij[0][2] - t34 * Vinv_ij[1][2])) - t32 * (-t23 * t36 * t29 + t19 * (t27 * Vinv_ij[0][1] - t34 * Vinv_ij[1][1])) + t33 * Vinv_ij[2][0];
t36 = (t16 * t9 * t26 + t18 * t8 * t28) * t20;
t36 = t24 * (-t23 * t36 * t21 - t19 * (-t8 * Vinv_ij[2][0] + t9 * Vinv_ij[1][0])) + t31 * (-t23 * t36 * t15 - t19 * (-t8 * Vinv_ij[2][2] + t9 * Vinv_ij[1][2])) + t32 * (-t23 * t36 * t29 - t19 * (-t8 * Vinv_ij[2][1] + t9 * Vinv_ij[1][1])) + t4 * Vinv_ij[0][0] + t5 * Vinv_ij[0][1] + t6 * Vinv_ij[0][2];
t37 = (t14 * t9 * t13 - t18 * t7 * t28) * t20;
t9 = t24 * (-t23 * t37 * t21 + t19 * (-t7 * Vinv_ij[2][0] + t9 * Vinv_ij[0][0])) + t31 * (-t15 * t23 * t37 + t19 * (-t7 * Vinv_ij[2][2] + t9 * Vinv_ij[0][2])) + t32 * (-t23 * t29 * t37 + t19 * (-t7 * Vinv_ij[2][1] + t9 * Vinv_ij[0][1])) + t4 * Vinv_ij[1][0] + t5 * Vinv_ij[1][1] + t6 * Vinv_ij[1][2];
t37 = (t14 * t8 * t13 + t16 * t7 * t26) * t20;
t4 = t24 * (t23 * t37 * t21 - t19 * (-t7 * Vinv_ij[1][0] + t8 * Vinv_ij[0][0])) + t31 * (t15 * t23 * t37 - t19 * (-t7 * Vinv_ij[1][2] + t8 * Vinv_ij[0][2])) + t32 * (t23 * t29 * t37 - t19 * (-t7 * Vinv_ij[1][1] + t8 * Vinv_ij[0][1])) + t4 * Vinv_ij[2][0] + t5 * Vinv_ij[2][1] + t6 * Vinv_ij[2][2];
t5 = (t16 * t3 * t26 + t18 * t2 * t28) * t20;
t5 = t10 * Vinv_ij[0][0] + t11 * Vinv_ij[0][1] + t12 * Vinv_ij[0][2] + t24 * (t21 * t23 * t5 + t19 * (-t2 * Vinv_ij[2][0] + t3 * Vinv_ij[1][0])) + t31 * (t15 * t23 * t5 + t19 * (-t2 * Vinv_ij[2][2] + t3 * Vinv_ij[1][2])) + t32 * (t23 * t29 * t5 + t19 * (-t2 * Vinv_ij[2][1] + t3 * Vinv_ij[1][1]));
t6 = (-t18 * t1 * t28 + t14 * t3 * t13) * t20;
t3 = t10 * Vinv_ij[1][0] + t11 * Vinv_ij[1][1] + t12 * Vinv_ij[1][2] + t24 * (t21 * t23 * t6 - t19 * (-t1 * Vinv_ij[2][0] + t3 * Vinv_ij[0][0])) + t31 * (t15 * t23 * t6 - t19 * (-t1 * Vinv_ij[2][2] + t3 * Vinv_ij[0][2])) + t32 * (t23 * t29 * t6 - t19 * (-t1 * Vinv_ij[2][1] + t3 * Vinv_ij[0][1]));
t6 = (t16 * t1 * t26 + t14 * t2 * t13) * t20;
t1 = t10 * Vinv_ij[2][0] + t11 * Vinv_ij[2][1] + t12 * Vinv_ij[2][2] + t24 * (-t21 * t23 * t6 + t19 * (-t1 * Vinv_ij[1][0] + t2 * Vinv_ij[0][0])) + t31 * (-t15 * t23 * t6 + t19 * (-t1 * Vinv_ij[1][2] + t2 * Vinv_ij[0][2])) + t32 * (-t23 * t29 * t6 + t19 * (-t1 * Vinv_ij[1][1] + t2 * Vinv_ij[0][1]));
t2 = 0.2e1;
gradE[0] = -t2 * (-t24 * (t23 * t22 * t21 + t19 * (t25 * Vinv_ij[1][0] - t27 * Vinv_ij[2][0])) + t33 * Vinv_ij[0][0] + t30 * Vinv_ij[0][1] + t17 * Vinv_ij[0][2] - t32 * (t23 * t22 * t29 + t19 * (t25 * Vinv_ij[1][1] - t27 * Vinv_ij[2][1])) - t31 * (t23 * t22 * t15 + t19 * (t25 * Vinv_ij[1][2] - t27 * Vinv_ij[2][2])));
gradE[1] = -t2 * t35;
gradE[2] = -t2 * t34;
gradE[3] = t2 * t36;
gradE[4] = t2 * t9;
gradE[5] = t2 * t4;
gradE[6] = t2 * t5;
gradE[7] = t2 * t3;
gradE[8] = t2 * t1;
Hessian
hessE := Hessian(E, [v1n[1], v1n[2], v1n[3], v2n[1], v2n[2], v2n[3], v3n[1], v3n[2], v3n[3]])
Dimension(hessE)
9, 9
(1.5.1)
CodeGeneration[C](hessE, optimize = tryhard, deducetypes = false, resultname = 'hessE')
Download membrane_energy.mw
Dear Experts,
Please how do I carry out the differentiation of
y[1](t)*y[2](t)*(y[1](t)+y[2](t))^3
with respect to y[1] using maple? I know how to use maple if the derivative is with respect to t.
Thank you in anticipation
I would like to solve a linear system A X=b whee A is a matrix n times n
If A is a tri-diagonal matrix, how can we write simple code to make A upper-triangular and then we solve the system using backward substitution
many thanks
First 578 579 580 581 582 583 584 Last Page 580 of 2434
