Can one hope that next version of Maple will be able to solve the standard convection-diffusion pde in 1D?
pde:=diff(u(x,t),t)=d*diff(u(x,t),x$2)+c*diff(u(x,t),x);
in 1D. Even the most simple form with zero boundary conditions can't be solved.
bc:=u(0,t)=0,u(L,t)=0;
ic:=u(x,0)=f(x);
sol:=pdsolve([pde,ic,bc],u(x,t)) assuming d>0,c>0,L>0
              sol := NULL
I tried some HINT's also but not all of them.
FYI, Mathematica 12.1 is now able to solve the above PDE
ClearAll["Global`*"];
pde=D[u[x,t],t]==d*D[u[x,t],{x,2}]+c*D[u[x,t],x];
bc={u[0,t]==0,u[L,t]==0};
ic=u[x,0]==f[x];
DSolve[{pde,bc,ic},u[x,t],{x,t},Assumptions->{d>0,c>0,L>0}]
Gives
Is it possible I am overlooking some other option or a trick to obtain solution for the above using pdsolve? Only reason I am asking is that Maple can solve much more complicated PDE's and the above is one of the basic diffusion based PDE's. So I am surprised why Maple still can't solve this as it is just a seperation of variables method.
Maple 2020 on windows 10. Physics version 631
Why is my figure not smooth? How can I make it smooth?
with(plots, implicitplot); with(plots)
pp1 := implicitplot(mu*x-ln(1+x) = 0, mu = -10 .. 5, x = -5 .. 5, color = black)
Download mm.mw
 I have a problem about extremal function.
The function is shown below with restricted condition of x and a:  x>=2 and -1 < a <0.
(x-3/2)^a-(x-1)^a+(1-2^(a-1))*((x-3/2)^a-(x-1/2)^a)-x*((x-3/2)^a+x^a-(x-1/2)^a-(x-1)^a)
I guess that  it's minimum value is greater than 0.  In other words,  I want prove that  (x-3/2)^a-(x-1)^a+(1-2^(a-1))*((x-3/2)^a-(x-1/2)^a)-x*((x-3/2)^a+x^a-(x-1/2)^a-(x-1)^a)>0
when I use Minimize function,
Optimization:-Minimize((x-3/2)^a-(x-1)^a+(1-2^(a-1))*((x-3/2)^a-(x-1/2)^a)-x*((x-3/2)^a+x^a-(x-1/2)^a-(x-1)^a),{x>=2, -1<a, a<0})
I 'm not seeing but Error, (in Optimization:-NLPSolve) strict inequalities are not valid constraints. I cannot but add the condition of equality of a : -1<=a, a<=0.
Optimization:-Minimize((x-3/2)^a-(x-1)^a+(1-2^(a-1))*((x-3/2)^a-(x-1/2)^a)-x*((x-3/2)^a+x^a-(x-1/2)^a-(x-1)^a),{x>=2, -1<=a, a<=0})
A result is returned with a warning:
Warning, no iterations performed as initial point satisfies first-order conditions
[0.000000, [a = -2.225074*10^(-308), x = 2.000000]]
Local or Global ?
When I read recent question post
https://www.mapleprimes.com/questions/229132-Maximize-Function-Does-Not-Work?ref=Feed:MaplePrimes:New%20Questions
 I'm worrying  that Maple only returns local  extremun. So I use the freely  maple package DirectSearch. We can get it from  https://www.maplesoft.com/applications/view.aspx?SID=101333.
DirectSearch:-GlobalOptima(-((x-3/2)^a-(x-1)^a+(1-2^(a-1))*((x-3/2)^a-(x-1/2)^a)-x*((x-3/2)^a+x^a-(x-1/2)^a-(x-1)^a)),{x>=2, -1<a, a<0},maximize);
 Note: I add a  minus sign to find maximize value .
It returns: [0.002264, [a = -0.000203, x = 1.019590*10^13], 605]
But I substitute the value of a and x  into the function,it returns strange result:   4078.360000 not  -0.002264.
I’m confused..
I try to use  Mathematica,
NMinimize[{(x - 3/2)^a - (x - 1)^
    a + (1 - 2^(a - 1))*((x - 3/2)^a - (x - 1/2)^a) -
   x*((x - 3/2)^a + x^a - (x - 1/2)^a - (x - 1)^a),
  x >= 2 && a > -1 && a <= 0}, {x, a}]
It retruns {0., {x -> 13.256, a -> 0.}}  May be well.
mimimize.mw
i need to create a table with information from plots like how many times x become 0
this is the way to make an null oscillation
please help!
I am trying to calculate the following integra
r*rr*g1^2*h1^2*f1^2*fh1^2*exp(-2*t)/t
here g1 is a kummerM functin in s, and also h1 is another kummerM function  in ss, and f1 and fh1 are the HeunB functions with complex arguments in r and rr. and t=sqrt((r-rr)^2+(s-ss)^2).I would like to integte over dr drr ds dss
restart; F := rsolve({16*s(n+1) = 2+12*s(n)-2*s(n-1), s(1) = 1, s(2) = 5/8}, s); Error, (in s) cannot determine if this expression is true or false: n
solve({sigma*E-(mu+alpha+gamma)*I = 0, gamma*E+Lambda*N*P-(mu+alpha)*R = 0, Beta__1*S*E+Beta__2*S*I/(I*M+1)-(mu+sigma)*E = 0, Lambda(1-p)*N-mu*S-Beta__1*S*E-Beta__2*S*I/(I*M+1) = 0}, {E, I, R, S}, explicit)
I'm not sure if there's something on the page I'm not seeing but even  https://www.maplesoft.com/support/help/Maple/view.aspx?path=Optimization/Minimize#examples
Maximize(2*x^2 + 2*y^2 + y, {2*x + y <= 6, y^2 - x <= 2})
a literal copy-paste of the posted example maple just repeats what I posted Idk whats wrong. btw is there some way to read the maple documentation pages?
Wis_BS2_Taak2_2019-2020_20200323-1.mw
I have some huge troubble with making sure all formula's wont be forgotten by Maple.
For example:
f(x):=a+b;
a:=5;
b:=2;
f(x):=f(x);  --> gives me f(x):=f(x) instead of saying f(x):=7
In my document the naming is a bit more complex.
I have a variable named "M_Inwendig2[y]" in the uploaded document. When i name it "M_Inwendig2(y)" (notice [-->( )
maple refuses to use the previous filled/calculated variables.
Due to this error i have copy and pasted the answer to a new formula to continue my work, therefor it becomes quite messy... Now i am trying to fix this.
Ideal all names will be M[inwendig2](y). So the first letter will tell the kind of variable (Moment) the subscript will tell the part (inside) and the depending variable will be between ().
In the document i have marked all error's and copy's RED.
Anyone can advice me? i have named variables the same way in the past, but now it doesnt work.
I had difficulty in making my latest post.  It would fail at Submit.
I had success when I saved a draft post.  I was able to edit the draft to submit.
Lee
I am interested in how easy it is to work with formulae in the Maple language.  For example, you can easily add two equations together with '+'.
e1:=x^2+1=2*x;
x^2+1 = 2*x
e2:=x^3+x=5;
x^3+x = 5
e1+e2;
x^3+x^2+x+1 = 2*x+5
I was pleased when the following example added (x+1) to both sides of an equation,
e3:=x+1;
x+1
e1+e3;
x^2+x+2 = 3*x+1
Some other algebraic operations work.
e1-e3;
x^2-x = x-1
e1*e3;
(x+1)*(x^2+1) = 2*(x+1)*x
e1/e3;
(x^2+1)/(x+1) = 2*x/(x+1)
e1^(1/2);
(x^2+1)^(1/2) = 2^(1/2)*x^(1/2)
Build-in functions do not work, though, but there is a simple solution.
exp(e1);
Error, invalid input: exp expects its 1st argument, x, to be of type algebraic, but received x^2+1 = 2*x
exp(rhs(e1))=exp(lhs(e1));
exp(2*x) = exp(x^2+1)
map(exp,e1);
exp(x^2+1) = exp(2*x)
The methods also apply to inequality formulae.  I'm not as pleased about how it does '*' and '/' for inequalities.  You can get more control using rhs and lhs functions.  Here are some examples:
e4:=x^3<5*(x+1);
x^3 < 5*x+5
e4+e3;
x^3+x < 6*x+5
e4-e3;
x^3-x < 4*x+5
(14)
e4*e3;
(x^3 < 5*x+5)*(x+1)
(15)
e4/e3;
(x^3 < 5*x+5)*(1/(x+1))
(16)
eval(%,x=4);
64/5 < 5
(17)
evalb(%);
(18)
(16)/x^2;
((x^3 < 5*x+5)*(1/(x+1)))/x^2
(19)
simplify(%);
(20)
lhs(e4)/e3/x^2 < rhs(e4)/e3/x^2;
x/(x+1) < (5*x+5)/((x+1)*x^2)
(21)
simplify(%);
x/(x+1) < 5/x^2
(22)
Download equations.mw
Any  idea is good for me !
According to Wikipedia  https://www.wikidata.org/wiki/Q3115604 ,
Outerplanar graph  is a graph that can be drawn without crossings in the plane (means it is planar graph) with all vertices on the outer face.
For example
Recently  in my project, I  need to judge whether a planar graph is a  outerplanar graph.
I tried to find some algorithms but failed.
Maple  only considers how to test wheather a graph is  planar.
like following:
with(GraphTheory):
with(SpecialGraphs)
K4 := CompleteGraph(4)
IsPlanar(K4, 'F')
   Dear friends,on the left I created two Tasks named a and aa.However,I do not know how to delete these two Tasks.Then I refer to the help pages below.
The text I marked says I should enter full filename.I do not know the fullfile name of customized Tasks.So does anyone know how to delete them?
I am exploring the idea of porting some of my functions to Maple from Mathematica. But I just found a big problem in importing comma delimited data that contains a string within a string. This is not a problem being imported in Mathematica, but I need help to do same thing in Maple.
I tried ImportMatrix (as suggested in https://www.mapleprimes.com/questions/221509-How-To-Read-Lines-From-File-With-Quoted-Strings and also tried Import then convert and in both cases Maple does not read the full string in the field. I will show simple example
This file, called data.txt
1,2,3,"x+y, algorithm=["123"]","OK",5
It has 6 fields (since comma seperated.
But when importing it, Maple reads the 4th field above as "x+y, algorithm=[" and drops the rest 123"]"
Here is the code
#currentdir("C:\\bug"); #change as needed
data:=ImportMatrix("data.txt", source=csv);
print(data(4));
print(data(5));
This is the output
I also tried
data := Import("data.txt",format="CSV");
data := convert(data,Matrix):
print(data(4));
print(data(5));
Same output as above.
Compare the output in Mathematica. Using the same file as input. It automatically escapes the embedded strings and reads the full field OK
SetDirectory[NotebookDirectory[]];
data = First@Import["data.txt", "Table", "FieldSeparators" -> {","}, "Numeric" -> True]
               {1, 2, 3, "x+y, algorithm=[\"123\"]", "OK", 5}
data[[4]]
What would be the right way in Maple to import such files without losing part of the field?
The file has mixed strings and non strings, just like this example shows, and each file fields are seperated by comma, but I need to be able to read fields that can contain embedded strings in them automatically.
I am using Maple 2020. I think I might have to forget about import and try to do it using lower level code using scanf, or may be there is better method using Filetools package? but thought to check first if I am overlooking some option.
First 584 585 586 587 588 589 590 Last Page 586 of 2434
