I'm trying to Graph a Piecewise Defined Function.
j(x) = piecewise(x < 0, x^2 + 1, 0 <= x, x - 1);
It doesn't provide a plot option.
Download piecewisegraph.mw
Function Misrepresented
y^2-x = 1"(->)"[[y = (x+1)^(1/2)], [y = -(x+1)^(1/2)]]NULL
Expected output for y
y = `&+-`(sqrt(1+x))
Yes it's the same meaning but i would like less to look at.
Download funct_misrep.mw
data := [[0., 9.1300, 0.931e-1, 0.899e-1, .1000, 0.], [30.0000, 8.9300, .1270, .1230, .2270, 0.49e-2], [60.0000, 8.6000, .1510, .1390, .4920, 0.153e-1], [90.0000, 8.2800, .1540, .1490, .7780, 0.249e-1], [120.0000, 7.9700, .1540, .1570, 1.0700, 0.329e-1], [150.0000, 7.8600, .1540, .1600, 1.1700, 0.348e-1], [180.0000, 7.8100, .1530, .1530, 1.2100, 0.404e-1], [210.0000, 7.7700, .1400, .1420, 1.2800, 0.432e-1]];
des := [diff(y1(t), t) = -k1*y1(t)-k2*y1(t), diff(y2(t), t) = k2*y1(t)-k3*y2(t), diff(y3(t), t) = k1*y1(t)+k3*y2(t)-k4*y3(t), diff(y4(t), t) = k4*y3(t)-k5*y2(t)*y4(t)+k6*y5(t), diff(y5(t), t) = k5*y2(t)*y4(t)-k6*y5(t)];
ics := seq((y || i)(0) = data[1, i+1], i = 1 .. 5):
Error, unable to match delimiters
Typesetting:-mambiguous(Typesetting:-mambiguous(ics Assign seq
  lparlpary verbarverbar irpar(0) equals data(1comma i + 1)comma
  i equals 1 periodperiod 5rparcolon,
  Typesetting:-merror("unable to match delimiters")))
res := dsolve({ics, des[]}, numeric, parameters = [k1, k2, k3, k4, k5, k6]);
timeList := [0, 30, 60, 90, 120, 150, 180, 210];
sse := proc (k1, k2, k3, k4, k5, k6) res(parameters = [k1, k2, k3, k4, k5, k6]); add((rhs(select(has, res(timeList[i]), y1)[])-data[i, 2])^2+(rhs(select(has, res(timeList[i]), y2)[])-data[i, 3])^2+(rhs(select(has, res(timeList[i]), y3)[])-data[i, 4])^2+(rhs(select(has, res(timeList[i]), y4)[])-data[i, 5])^2+(rhs(select(has, res(timeList[i]), y5)[])-data[i, 6])^2, i = 2 .. 8) end proc;
proc(k1, k2, k3, k4, k5, k6)  ...  end;
c := GlobalOptimization:-GlobalSolve(('sse')(k1, k2, k3, k4, k5, k6), k1 = 0 .. 1, k2 = 0 .. 1, k3 = 0 .. 1, k4 = 0 .. 1, k5 = 0 .. 1, k6 = 0 .. 1, timelimit = 10); [.219132447080011505, [k1 = 0.852482740113834e-3, k2 = 0.52683998680924474e-4, k3 = 0., k4 = 0.5113239298267808e-1, k5 = 0.4363021255887466e-2, k6 = 0.]];
Error, `GlobalOptimization` does not evaluate to a module
[0.219132447080011505, [k1 = 0.000852482740113834,
  k2 = 0.000052683998680924474, k3 = 0.,
  k4 = 0.05113239298267808, k5 = 0.004363021255887466, k6 = 0.]]
res(parameters = c[2]):  p:=Array(1..5):  for n from 1 to 5 do     p[n]:=plots:-display(plots:-odeplot(res, [t, (y || n)(t)], t = 0 .. 210),plots:-pointplot([seq([data[i, 1], data[i, n+1]], i = 1 .. 8)]));  end do; plots:-display(p) ;
Typesetting:-mambiguous(Typesetting:-mambiguous(res(parameters
  equals c(2))colon  pAssignArray(1periodperiod5)colon  for n
  from 1 to 5 do     p(n)Assignplotscolon - displaylparplotscolon
   - odeplotlparrescomma lsqbtcomma lpary verbarverbar nrpar(t)
  rsqbcomma t equals 0 periodperiod 210rparcommaplotscolon -
  pointplot((seq((data(icomma 1)comma data(icomma n + 1))comma i
  equals 1 periodperiod 8)))rparsemi  end dosemi plotscolon -
  display(p) , Typesetting:-merror("unable to match delimiters")))
 I cannot solve this equation. Please help me
How can I use maple to get the numerical solution of this non-autonomous system
sys_ode := diff(x(t), t) = ax(t)-bx(t)y(t)+2sin(t), diff(y(t), t) = -cy(t)+dx(t)y(t)
where a,b,c,d is parameters, they can take any value.
I'm having a weird issue. :(
DEplot command worked when I initially ran the executed it, but then when I executed the entire worksheet, it didn't plot. Instead I just get this output.
This is the entire worksheet so far without the output.
If someone could please help me, I would greatly appreciate it!!!!!
with(DEtools);
eq1 := diff(y(x), x) = 3*x*y(x);
dsolve(eq1, y(x));
ini1 := y(0) = 3;
dsolve({eq1, ini1}, y(x));
ini2 := y(1) = -3;
dsolve({eq1, ini2}, y(x));
eq2 := y(x)*diff(y(x), x) = -x;
dsolve(eq2, y(x));
dsolve({eq2, ini1}, y(x));
eq := diff(y(x), x) = 3*x*y(x);
ini := y(0) = 5;
dsolve({eq, ini}, y(x));
sol := rhs(%);
plot(sol, x = -2 .. 2, y = 0 .. 10);
DEplot(eq, y(x), x = -2 .. 2, y = 0 .. 10, [[ini]]);
Does anyone use MTM toobox and why?
I discovered this through the eig help search and found the MATLAB format of [V, D] = eig(Matrix) for eigenvectors and eigenvalues as a single function call with output a nice shortcut vs two calls to LinearAlgebra[Eigenvalues], LinearAlegebra[Eigenvectors]
But, is the overhead and overmapping of standard maple functions worth it?   I find very little descriptions about the Maple Toolbox, specifically the MTM package.
Hi everyone:
how can I obtain the B from A?
A:=u[1, 0](t)*v[1, 3](t)+u[1, 1](t)*v[1, 2](t)+u[1, 2](t)*v[1, 1](t)+u[1, 3](t)*v[1, 0](t)
B:=u[1, 0](t)*v[1, 3](tau)+u[1, 1](t)*v[1, 2](tau)+u[1, 2](t)*v[1, 1](tau)+u[1, 3](t)*v[1, 0](tau)
tnx...
Good day house.
Please I don't know why the solve command does not display any results in the following code. Kindly assist. Thank you in anticipation.
omega := v/h;
t := sum(a[j]*x^j, j = 0 .. 6)+a[7]*cos(omega*x)+a[8]*sin(omega*x);
r1 := diff(t, x$2);
r2 := diff(t, x$4);
c1 := eval(t, x = q+2*h) = y[n+2];
c2 := eval(r1, x = q) = f[n];
c3 := eval(r1, x = q+h) = f[n+1];
c4 := eval(r1, x = q+2*h) = f[n+2];
c5 := eval(r1, x = q+3*h) = f[n+3];
c6 := eval(r2, x = q) = g[n];
c7 := eval(r2, x = q+h) = g[n+1];
c8 := eval(r2, x = q+2*h) = g[n+2];
c9 := eval(r2, x = q+3*h) = g[n+3];
b1 := seq(a[i], i = 0 .. 8);
`k&Assign;solve`({c1, c2, c3, c4, c5, c6, c7, c8, c9}, {a[0], a[1], a[2], a[3], a[4], a[5], a[6], a[7], a[8]});
Please I found out that the MatrixInverse on the assignment statement P3 does not run for about three days now. Please kindly help to simplify the code. Thank you and kind regards.
restart; omega := v/h;
r := a[0]+a[1]*x+a[2]*sinh(omega*x)+a[3]*cosh(omega*x)+a[4]*cos(omega*x)+a[5]*sin(omega*x);
b := diff(r, x);
c := eval(b, x = q) = f[n];
d := eval(r, x = q+3*h) = y[n+3]; e := eval(b, x = q+3*h) = f[n+3];
g := eval(b, x = q+2*h) = f[n+2];
i := eval(b, x = q+h) = f[n+1];
j := eval(b, x = q+4*h) = f[n+4];
k := solve({c, d, e, g, i, j}, {a[0], a[1], a[2], a[3], a[4], a[5]});
Warning,  computation interrupted
assign(k);
cf := r;
s4 := y[n+4] = simplify(eval(cf, x = q+4*h));
s3 := y[n+2] = simplify(eval(cf, x = q+2*h));
s2 := y[n+1] = simplify(eval(cf, x = q+h));
s1 := y[n] = simplify(eval(cf, x = q));
with(LinearAlgebra);
h := 1;
YN_1 := seq(y[n+k], k = 1 .. 4);
A1, a0 := GenerateMatrix([s1, s2, s3, s4], [YN_1]);
eval(A1);
YN := seq(y[n-k], k = 3 .. 0, -1);
A0, b1 := GenerateMatrix([s1, s2, s3, s4], [YN]);
eval(A0);
FN_1 := seq(f[n+k], k = 1 .. 4);
B1, b2 := GenerateMatrix([s1, s2, s3, s4], [FN_1]);
eval(B1);
FN := seq(f[n-k], k = 3 .. 0, -1);
B0, b3 := GenerateMatrix([s1, s2, s3, s4], [FN]);
eval(B0);
ScalarMultiply(R, A1)-A0;
det := Determinant(ScalarMultiply(R, A1)-A0);
P1 := A1-ScalarMultiply(B1, z);
P2 := combine(simplify(P1, size), trig);
P3 := MatrixInverse(P2);
P4 := A0-ScalarMultiply(B0, z);
P5 := MatrixMatrixMultiply(P3, P4);
P6 := Eigenvalues(P5);
f := P6[4];
T := unapply(f, z);
implicitplot(f, z = -5 .. 5, v = -5 .. 5, filled = true, grid = [5, 5], gridrefine = 8, labels = [z, v], coloring = [blue, white]);
The equation
(x3−13x2+55x−73)/(x−1)=0
has at least one real solution. Give an interval on which the Intermediate Value Theorem assures that there is a solution to this equation.
Note: Enter your interval in the form [a,b].
can I get help please? I cant seem to do this.
Dear Helpers
I have a RootOf such as below. My question is how can I obtain a simple answer for it, or how can I simplify it? Also, what's the difference between the case "index=1" and the cases "index=2" and "index=3"?
" RootOf(6*_Z^3+(27+3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2))*_Z^2+(3*sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2)*l^4*RootOf(_Z^2*l^2+3*_Z^4-3)^2-9*sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2)*l^2+90*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2-18*l^4+6*l^6*RootOf(_Z^2*l^2+3*_Z^4-3)^2-81+45*RootOf(_Z^2*l^2+3*_Z^4-3)^2*sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2))*_Z-324-3*l^8+l^10*RootOf(_Z^2*l^2+3*_Z^4-3)^2+108*RootOf(_Z^2*l^2+3*_Z^4-3)^2*sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2)-3*sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2)*l^6+sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2)*l^8*RootOf(_Z^2*l^2+3*_Z^4-3)^2-63*sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2)*l^2+30*sqrt(9-3*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2)*l^4*RootOf(_Z^2*l^2+3*_Z^4-3)^2+45*l^6*RootOf(_Z^2*l^2+3*_Z^4-3)^2+351*RootOf(_Z^2*l^2+3*_Z^4-3)^2*l^2-108*l^4, index = 1) "
Thank you so much!
We are in the very beginning of implementation of Maple in our office, and are trying to write the first programs.
For the moment we are building a material database, starting from Excel, and generating a Maple library out of that. Afterwards we are going to pull the data from the library, and show it in a nice output.
We've so far managed to write the library, but we are running into problems with variable names.
In Maple 2D notation a variable with indexes including a comma is no problem. My specific problem is, how can I use those variables in a program in Maple 1D notation.
Here are some examples of variables which are relevant.
I'm trying to be able to add bullet points to this Plot as well as where they cross. Download provided below. Thanks in Advance.
Example 7: Equations of Perpendicular Lines
NULLy = -(3/2)*x+2
2*x-3*y = 5; "_noterminate"
2, -1; "_noterminate"and m = 2/3; "_noterminate"
y = -5/3+(2/3)*x
Download mp.mw
Why the performance of Maple GUI is bad. It is really hard to type anything in thew gui.
First 585 586 587 588 589 590 591 Last Page 587 of 2428
