Why the performance of Maple GUI is bad. It is really hard to type anything in thew gui.
I have a relatively involved modeling application that tracks  a particle beam through a beam line for multiple passes. The beam is described by a Maple Record with a number of different entries; one of them being a table with a 6-vector of numbers for each particle in the beam.
Each pass this beam gets updated. I would like to be able to save the whole record into a filel (i.e. append the file each pass) and then be able to read it back in; regenerating the Record structures. Is this possible?
(I'd normally upload a mwe; except this code uses a large package that would have to be installed. This is something I do not consider reasonable to ask for.)
If there is an explicit answer like: call this function, give it your Record and it should work; and call this reading function to recreate the Record, that would be swell. Or maybe some pointers in the right direction...Maple has so many read, write, save and restore functions that a systematic test is daunting.
TIA,
Mac Dude
NULLrestart
Digits := 10:
with(CurveFitting):
with(plottools):
v := .7:
Disp := 20:
esp := 800000:
k := 0:
E := proc (x, t) options operator, arrow; int(exp((-esp*w^4+Disp*w^2+k)*t)*cos(w*(x+v*t))/Pi, w = 0. .. infinity) end proc;
f := proc (x) options operator, arrow; 20*exp(-(1/2000000)*(x-10000)^2)+15*exp(-(1/2000000)*(x-13800)^2) end proc:
u := proc (x, t) options operator, arrow; int(E(x-xi, t)*f(xi), xi = 0. .. 20000) end proc;
plot(u(x, t), x = 1500, t = 0 .. 60000, numpoints = 100)
Error, (in plot) unexpected options: [x = 1500, t = 0 .. 60000]
Download antegral.mw
I'm reading this book : Algebra and Trigonometry - Real Mathematics, Real People, 7th Edition
Chapter 1 Functions and Their Graphs, Example 7, Monthly Wage , Page 80.
I'm trying to plot for a monthly wage.
The inital equation is:
y = 2000 + 0.1*x
Then other changes:
a. Sales are $1480 in August. What are your wages for that month?
b. You receive $2225 for September. What are your sales for that month?
I'm lost. Which is better Numerical Solution or Graphical Solution?
Thanks in Advance,
Paul
I want to have the fractal of von koch as shown in the photo, and then animate it? the command Kochcurve does not give exactly the objective. some ideas?
VonKochFractal.mw
f := proc (a, b) options operator, arrow; (1/2)*b+(1/2)*arccos(sin(2*a-b)/tan(b)) end proc; dis := proc (A, B) options operator, arrow; sqrt(inner(A-B, A-B)) end proc; bisA := proc (A, B, C) local b, c, M; b, c := dis(A, C), dis(A, B); M := (b*B+C*c)/(b+c); x*(A[2]-M[2])+y*(M[1]-A[1])+A[1]*M[2]-A[2]*M[1] end proc; P := proc (a0, b0) local a, b, c, p1, p2, p3, p4, r, II; a := evalf(a0); b := evalf(b0); c := f(a, b); if b0-0.1e-2
The VectorCalculus package offers a convenient way to compute multivariate integral over a non-square geometry. See help("VectorCalculus/int"). Here is an example taken from this help page:
with(VectorCalculus):
int( x*y, [x,y] = Triangle( <0,0>, <1,0>, <0,1> ) );
The question is: is there a way to draw the area “Triangle( <0,0>, <1,0>, <0,1> )” in order to quickly check that it matches the expected region of integration that one needs?
I am trying to plot the solution of the DE in the interval [0.3,4]
  I have read the article attached in the following
I wrote the code mentioned in the article in order to find the Hirota formula This is the code that I wrote For Hirota Method But when running the program it does not work well
Could you help me to fix the mistake and run the program
restart; with(PDEtools); with(DEtools)
alias(u = u(x, t)); declare(u(x, t)); alias(f = f(x, t)); declare(f(x, t))
u, f
` u`(x, t)*`will now be displayed as`*u
u, f
` f`(x, t)*`will now be displayed as`*f
BD := proc (FF, DD) local f, g, x, m, opt; if nargs = 1 then return `*`(FF[]) end if; f, g := FF[]; x, m := DD[]; opt := args[3 .. -1]; if m = 0 then return procname(FF, opt) end if; procname([diff(f, x), g], [x, m-1], opt)-procname([f, diff(g, x)], [x, m-1], opt) end proc
BD([f(x, t), g(x, t)], [x, 1])
(diff(f(x, t), x))*g(x, t)-f(x, t)*(diff(g(x, t), x))
BD([f(x, t), g(x, t)], [t, 1])
(diff(f(x, t), t))*g(x, t)-f(x, t)*(diff(g(x, t), t))
BD([f(x, t), g(x, t)])
f(x, t)*g(x, t)
print_BD := proc (FF, DD) local f, g, x, m, i; f, g := FF[]; f := cat(f, '', g); g := product(D[args[i][1]]^args[i][2], i = 2 .. nargs); if g <> 1 then f := g*(`*`(f)) end if; f end proc
Typesetting:-mrow(Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("#", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("# collect(expr,f); first!", italic = "true", mathvariant = "italic"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("getFnumer", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo("proc", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic"), Typesetting:-mo("&Proportion;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("posint", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("local", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("fdenom", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("type", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("`+`", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("g", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("fdenom", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("map", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("denom", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("for", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("to", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("fdenom", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mi(""), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("while", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("fdenom", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo("&NotEqual;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-msup(Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mi("pow", italic = "true", mathvariant = "italic")), superscriptshift = "0"), Typesetting:-mo("do", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("od", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(">", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("nops", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("fdenom", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("lprint", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("fdenom", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("no term(s) or numer=0 when denom=%1"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mi("pow", italic = "true", mathvariant = "italic")), superscriptshift = "0"), Typesetting:-mi(""), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("g", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("numer", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("g", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("not", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("type", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("expand", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("g", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("`+`", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("lprint", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("g", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("Expected mor than 1 term about Hirota D-operator"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("return", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("g", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("lprint", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("expected 1 st argument be type `+`."), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"))
Typesetting:-mrow(Typesetting:-mi("getvarpow", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo("proc", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic"), Typesetting:-mo("&Proportion;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("function", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("local", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("var", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("dif", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo("&NotEqual;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("diff", italic = "true", mathvariant = "italic"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("lprint", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("expected diff function"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("convert", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("D", italic = "false", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("var", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("dif", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mn("0", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo("$", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("var", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("var", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("")), mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("for", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("to", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("var", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("dif", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("selectremove", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("member", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("dif", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "{", close = "}")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("nops", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("dif", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("dif", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("dif", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("2", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("od", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("zip", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("x", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("y", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo("&srarr;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("x", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("y", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("var", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("remove", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("has", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", mathvariant = "normal")), mathvariant = "normal", open = "{", close = "}")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("pow", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("")), mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"))
Typesetting:-mrow(Typesetting:-mo("#", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("convert to Hirota Bilinear Form", italic = "true", mathvariant = "italic"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("HBF", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo("proc", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("local", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("c", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("type", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("`+`", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("return", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("map", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("procname", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("type", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("`*`", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("selectremove", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("hasfun", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("diff", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("c", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("2", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo("&NotEqual;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1", mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("lprint", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("need only one diff function factor."), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("c", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("`*`", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("c", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("")), mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("getvarpow", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("c", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("return", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("op", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo("=", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("diff", italic = "true", mathvariant = "italic"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("getvarpow", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("return", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("lprint", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("df", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("unexpected type."), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"))
printHBF := proc (PL::list) local j, DD, f, C, tmp, gcdC; C := map2(op, 1, PL); gcdC := 1; if 1 < nops(C) then tmp := [seq(cat(_Z, i), i = 1 .. nops(C))]; gcdC := `~`[`*`](tmp, C); gcdC := `+`(gcdC[]); gcdC := factor(gcdC); tmp := selectremove(has, gcdC, tmp); gcdC := tmp[2]; if gcdC = 0 then gcdC := 1 end if; gcdC := gcdC*content(tmp[1]) end if; if gcdC <> 1 then C := `~`[`/`](C, gcdC) end if; DD := map2(op, 2, PL); f := op(0, DD[1][1][1]); DD := map(proc (z) options operator, arrow; product(D[z[i][1]]^z[i][2], i = 2 .. nops(z)) end proc, DD); DD := zip(`*`, C, DD); DD := `+`(DD[]); gcdC*"(DD)"*cat(f, '', f) end proc
printHBT := proc (uf, u, f, i, j, PL, alpha := 1) local DD, g, C, tmp, pl; pl := printHBF(PL); if 0 < j then print(u = 2*alpha*('diff')(ln(f), `$`(x, j))) else print(u = 2*alpha*ln(f)) end if; if 0 < i then print(('diff')(pl/f^2, `$`(x, i)) = 0) else print(pl/f^2 = 0) end if; NULL end proc
guessdifforder := proc (PL::list, x::name) local L, minorder, maxorder, tmp; L := map2(op, 2, PL); L := map(proc (z) options operator, arrow; z[2 .. -1] end proc, L); tmp := map(proc (z) options operator, arrow; map2(op, 2, z) end proc, L); tmp := map(proc (z) options operator, arrow; `+`(z[]) end proc, tmp); tmp := selectremove(type, tmp, even); minorder := 0; if nops(tmp[1]) < nops(tmp[2]) then minorder := 1 end if; tmp := map(proc (z) options operator, arrow; select(has, z, {x}) end proc, L); tmp := map(proc (z) options operator, arrow; map2(op, 2, z) end proc, tmp); if has(tmp, {[]}) then maxorder := 0 else tmp := map(op, tmp); maxorder := min(tmp[]) end if; if type(maxorder-minorder, odd) then maxorder := maxorder-1 end if; [minorder, maxorder] end proc
guessalpha := proc (Res, uf, u, f, i, j, PL, alpha) local tmp, res, pl, flag, k; flag := 1; tmp := [op(Res)]; tmp := map(numer, tmp); tmp := gcd(tmp[1], tmp[-1]); if type(tmp, `*`) then tmp := remove(has, tmp, f) end if; if tmp <> 0 and has(tmp, {alpha}) then tmp := solve(tmp/alpha^difforder(uf), {alpha}); if tmp <> NULL and has(tmp, {alpha}) then lprint(tmp); for k to nops([tmp]) while flag = 1 do res := collect(expand(subs(tmp[k], Res)), f, factor); if res = 0 then pl := subs(tmp[k], PL); printHBT(uf, u, f, i, j, pl, rhs(tmp[k])); flag := 0 end if end do end if end if; PL end proc
Typesetting:-mrow(Typesetting:-mi("Bilinear", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo("proc", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("uf", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("u", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("x", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("alpha", italic = "false", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("local", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("su", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("h", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("j", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g1", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("CB", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("PL", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("gdo", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("DD", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("Res", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("hasfun", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("uf", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("int", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("Do not support integral function yet.Please substitute int function."), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("for", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("j", italic = "true", mathvariant = "italic"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("from", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("to", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("2", mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("Res", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1", mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("su", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("u", italic = "true", mathvariant = "italic"), Typesetting:-mo("=", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("2", mathvariant = "normal"), Typesetting:-mo("*", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1666667em", rspace = "0.1666667em"), Typesetting:-mi("alpha", italic = "false", mathvariant = "normal"), Typesetting:-mo("*", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1666667em", rspace = "0.1666667em"), Typesetting:-mi("diff", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("ln", italic = "false", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("x", italic = "true", mathvariant = "italic"), Typesetting:-mo("$", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("j", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("h", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("collect", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("expand", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("dsubs", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("su", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("uf", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("factor", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("hasfun", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("h", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("ln", italic = "false", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("next", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("g1", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("getFnumer", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("h", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo("/", mathvariant = "normal", fence = "false", separator = "false", stretchy = "true", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1666667em", rspace = "0.1666667em"), Typesetting:-mn("2", mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("g1", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("expand", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("g1", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("CB", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("HBF", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("g1", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("gdo", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("guessdifforder", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("CB", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("x", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("for", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("from", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("gdo", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("by", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("2", mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("to", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("gdo", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("2", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo("=", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("PL", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("CB", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("else", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("PL", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("HBF", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("int", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("g1", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("x", italic = "true", mathvariant = "italic"), Typesetting:-mo("$", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("DD", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("add", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("PL", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo("*", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1666667em", rspace = "0.1666667em"), Typesetting:-mi("BD", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("PL", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("2", mathvariant = "normal")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("")), mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo("=", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1", mathvariant = "normal"), Typesetting:-mo("..", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("PL", italic = "true", mathvariant = "italic")), mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("Res", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("collect", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("expand", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("diff", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("DD", italic = "true", mathvariant = "italic"), Typesetting:-mo("/", mathvariant = "normal", fence = "false", separator = "false", stretchy = "true", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1666667em", rspace = "0.1666667em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo("^", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1111111em", rspace = "0.1111111em"), Typesetting:-mn("2", mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("x", italic = "true", mathvariant = "italic"), Typesetting:-mo("$", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic")), mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal"), Typesetting:-mo("&uminus0;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("h", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("factor", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("Res", italic = "true", mathvariant = "italic"), Typesetting:-mo("=", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("printHBT", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("uf", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("u", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("j", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("PL", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("alpha", italic = "false", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("break", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("elif", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("type", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("alpha", italic = "false", mathvariant = "normal"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("name", italic = "true", mathvariant = "italic")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("and", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("has", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("DD", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("alpha", italic = "false", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("Res", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("guessalpha", italic = "true", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("Res", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("uf", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("u", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("f", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("j", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("PL", italic = "true", mathvariant = "italic"), Typesetting:-mo(",", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("alpha", italic = "false", mathvariant = "normal")), mathvariant = "normal"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("od", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("if", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("Res", italic = "true", mathvariant = "italic"), Typesetting:-mo("=", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("0", mathvariant = "normal"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("break", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("od", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("PL", italic = "true", mathvariant = "italic"), Typesetting:-mo(";", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mo(" ", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"))
eq := diff(u(x, t), t, t)-(diff(u(x, t), x, x))-3*(diff(u(x, t), x, x))^2-(diff(u(x, t), x, x, x, x)) = 0
diff(diff(u(x, t), t), t)-(diff(diff(u(x, t), x), x))-3*(diff(diff(u(x, t), x), x))^2-(diff(diff(diff(diff(u(x, t), x), x), x), x)) = 0
Bilinear(eq, ln(f), f, x, 1)
Error, (in getFnumer) expected 1 st argument be type `+`.
Download Hirota_to_send.mw
HI
I am using a simple piece of code to generate Lie derivatives, and I am interested in adapting it so that I can use it with vector Fields where that include RootOf expressions.
LieDer_with_rootof.mw
The above includes an example where it works, and an example where RootOf appears in the vector field and it does not work.
i want solve error of PDE2
with(plottools):
with(CurveFitting):
with(ExcelTools):
Digits := 10:
PDE1 := diff(C(x, t), t) = -.7*(diff(C(x, t), x))+20*(diff(C(x, t), x, x)):
g := proc (t) options operator, arrow; 20*exp(-(1/2000000)*(t-10000)^2)+15*exp(-(1/2000000)*(t-13800)^2) end proc:
plot(g(t), t = 0 .. 60000)
IBC := C(x, 0) = 0, C(0, t) = g(t), (D[1](C))(20000, t) = 0:
pds1 := pdsolve(PDE1, [IBC], time = t, range = 0 .. 20000, timestep = 10, numeric, spacestep = 10)
k := pds1:-plot(x = 1500, t = 0 .. 60000, numpoints = 60000)
`[Length of output exceeds limit of 1000000]`
k;
T := ExcelTools:-Import("E:/er.xls", "sheet1"):
PLOT(CURVES(Matrix(7, 2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = 10000.0, (2, 2) = 1.0, (3, 1) = 20000.0, (3, 2) = 5.0, (4, 1) = 30000.0, (4, 2) = 10.0, (5, 1) = 40000.0, (5, 2) = 5.0, (6, 1) = 50000.0, (6, 2) = 1.0, (7, 1) = 60000.0, (7, 2) = .0}, datatype = float[8]), COLOUR(RGB, .47058824, 0., 0.54901961e-1, _ATTRIBUTE("source" = "mathdefault"))), AXESLABELS("", ""), VIEW(DEFAULT, DEFAULT))
A := unapply(Spline(getdata(m)[3][() .. (), 1], getdata(m)[3][() .. (), 2], 't', degree = 2), t):
PDE2 := diff(C(x, t), t) = -.7*(diff(C(x, t), x))+20*(diff(C(x, t), x, x))
Error, unsupported type of index, x
IBC := C(x, 0) = 0, C(0, t) = A(t), (D[1](C))(18500, t) = 0:
pds2 := pdsolve(PDE2, [IBC], time = t, range = 0 .. 18500, timestep = 10, numeric, spacestep = 10)
p01 := pds2:-plot(t = 30000, numpoints = 250, color = red); plots[display]({p01})
Error, (in pdsolve/numeric/plot) unable to compute solution for t>INFO["failtime"]:
unable to store A(10.) when datatype=float[8]
Error, (in plots:-display) expecting plot structures but received: {p01}
Typesetting:-mrow(Typesetting:-mi("pts", italic = "true", mathvariant = "italic"), Typesetting:-mo("&coloneq;", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi(""), Typesetting:-mtable(Typesetting:-mtr(Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1000", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1500", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1574.297189", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1648.594378", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1722.891566", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1797.188755", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1871.485944", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1945.783133", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2020.080321", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2094.37751", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2168.674699", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2242.971888", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2317.269076", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2391.566265", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2465.863454", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2540.160643", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2614.457831", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2688.75502", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2763.052209", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2837.349398", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2911.646586", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2985.943775", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3060.240964", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3134.538153", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3208.835341", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3283.13253", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3357.429719", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3431.726908", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3506.024096", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3580.321285", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3654.618474", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3728.915663", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3803.212851", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3877.51004", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3951.807229", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4026.104418", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4100.401606", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4174.698795", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4248.995984", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4323.293173", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4397.590361", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4471.88755", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4546.184739", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4620.481928", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4694.779116", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4769.076305", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4843.373494", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4917.670683", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4991.967871", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5066.26506", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5140.562249", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5214.859438", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5289.156627", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5363.453815", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5437.751004", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5512.048193", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5586.345382", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5660.64257", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5734.939759", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5809.236948", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5883.534137", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5957.831325", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6032.128514", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6106.425703", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6180.722892", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6255.02008", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6329.317269", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6403.614458", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6477.911647", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6552.208835", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6626.506024", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6700.803213", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6775.100402", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6849.39759", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6923.694779", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6997.991968", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7072.289157", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7146.586345", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7220.883534", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7295.180723", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7369.477912", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7443.7751", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7518.072289", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7592.369478", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7666.666667", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7740.963855", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7815.261044", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7889.558233", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7963.855422", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8038.15261", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8112.449799", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8186.746988", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8261.044177", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8335.341365", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8409.638554", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8483.935743", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8558.232932", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8632.53012", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8706.827309", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8781.124498", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8855.421687", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8929.718876", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9004.016064", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9078.313253", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9152.610442", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9226.907631", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9301.204819", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9375.502008", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9449.799197", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9524.096386", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9598.393574", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9672.690763", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9746.987952", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9821.285141", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9895.582329", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9969.879518", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10044.17671", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10118.4739", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10192.77108", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10267.06827", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10341.36546", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10415.66265", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10489.95984", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10564.25703", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10638.55422", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10712.85141", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10787.14859", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10861.44578", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10935.74297", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11010.04016", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11084.33735", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11158.63454", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11232.93173", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11307.22892", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11381.5261", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11455.82329", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11530.12048", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11604.41767", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11678.71486", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11753.01205", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11827.30924", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11901.60643", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11975.90361", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12050.2008", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12124.49799", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12198.79518", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12273.09237", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12347.38956", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12421.68675", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12495.98394", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12570.28112", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12644.57831", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12718.8755", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12793.17269", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12867.46988", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12941.76707", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13016.06426", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13090.36145", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13164.65863", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13238.95582", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13313.25301", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13387.5502", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13461.84739", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13536.14458", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13610.44177", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13684.73896", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13759.03614", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13833.33333", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13907.63052", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("13981.92771", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14056.2249", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14130.52209", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14204.81928", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14279.11647", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14353.41365", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14427.71084", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14502.00803", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14576.30522", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14650.60241", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14724.8996", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14799.19679", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14873.49398", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("14947.79116", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15022.08835", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15096.38554", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15170.68273", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15244.97992", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15319.27711", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15393.5743", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15467.87149", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15542.16867", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15616.46586", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15690.76305", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15765.06024", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15839.35743", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15913.65462", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("15987.95181", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16062.249", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16136.54618", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16210.84337", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16285.14056", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16359.43775", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16433.73494", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16508.03213", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16582.32932", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16656.62651", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16730.92369", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16805.22088", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16879.51807", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("16953.81526", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17028.11245", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17102.40964", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17176.70683", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17251.00402", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17325.3012", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17399.59839", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17473.89558", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17548.19277", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17622.48996", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17696.78715", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17771.08434", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17845.38153", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17919.67871", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("17993.9759", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18068.27309", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18142.57028", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18216.86747", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18291.16466", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18365.46185", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18439.75904", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18514.05622", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18588.35341", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18662.6506", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18736.94779", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18811.24498", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18885.54217", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("18959.83936", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19034.13655", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19108.43373", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19182.73092", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19257.02811", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19331.3253", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19405.62249", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19479.91968", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19554.21687", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19628.51406", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19702.81124", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19777.10843", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19851.40562", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("19925.70281", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("20000", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), rowalign = "", columnalign = "", groupalign = ""), align = "axis", rowalign = "baseline", columnalign = "center", groupalign = "{left}", alignmentscope = "true", columnwidth = "auto", width = "auto", rowspacing = "1.0ex", columnspacing = "0.8em", rowlines = "none", columnlines = "none", frame = "none", framespacing = "0.4em 0.5ex", equalrows = "false", equalcolumns = "false", displaystyle = "false", side = "right", minlabelspacing = "0.8em"), Typesetting:-mi("")), executable = "false", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", executable = "false", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi(""), Typesetting:-mtable(Typesetting:-mtr(Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.66511E-25", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.34215E-24", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.87399E-24", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.10862E-23", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.11384E-23", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.59634E-23", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.33959E-22", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6.27976E-22", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.66174E-21", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.3355E-21", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.11569E-20", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.83323E-20", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.10262E-20", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.7583E-19", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.29949E-19", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.03864E-18", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.4791E-18", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.84724E-18", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.36293E-17", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.13977E-17", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.14926E-17", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.6092E-16", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.58086E-16", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.87859E-16", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.71413E-15", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.68835E-15", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.85006E-15", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.65282E-14", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.44311E-14", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.09757E-14", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.44798E-13", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.9239E-13", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.84479E-13", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.15673E-12", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.26673E-12", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.39866E-12", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.45348E-12", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.60912E-11", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.03401E-11", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.66709E-11", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.04871E-10", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.92281E-10", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.49336E-10", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6.28941E-10", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.12221E-09", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.98457E-09", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.47878E-09", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6.04489E-09", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.04133E-08", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.77851E-08", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.01181E-08", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.0575E-08", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.42191E-08", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.39086E-07", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.27815E-07", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.70117E-07", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.96458E-07", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.53528E-07", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.51226E-06", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.37952E-06", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.71489E-06", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.75475E-06", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.84619E-06", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.34947E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.04305E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.06993E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.57868E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6.77865E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.96243E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000145357", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000210562", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.00030285", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000432517", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000613389", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000863871", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.001208279", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.001678474", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.002315868", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.00317385", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.004320695", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.00584299", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.007849649", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.010476524", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.013891649", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.018301092", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.023955396", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.031156525", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.040265187", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.05170839", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.065986974", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.083682864", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.105465676", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.132098276", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.164440843", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.203452918", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.250192924", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.305814596", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.371559803", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.44874728", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.538756839", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.64300878", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.762938322", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.89996508", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.055457828", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.230695007", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.4268217", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.644804066", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.885382451", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.149024682", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.43588115", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.745743574", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.078009252", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.431652744", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.805206773", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.196753939", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.603930677", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.023944341", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.453604145", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.88936592", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6.327390353", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6.763613724", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.19382965", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.613779894", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.019251823", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.406179757", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.770747208", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.10948683", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.41937487", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.697917029", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.943222698", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.1540651", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.32992485", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.47101543", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.5782891", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.65342272", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.69878349", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.71737491", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.71276457", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.68899503", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.65048052", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.60189181", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.54803268", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.49371117", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.44360935", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.4021553", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.37340083", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.36090861", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.36765187", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.39592969", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.44730016", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.52253359", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.62158687", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.74359995", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.88691422", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11.04911243", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11.2270788", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11.41707747", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11.61484704", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11.81570826", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.0146818", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.20661265", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.38629757", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.54861207", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.68863342", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.80175632", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.88379847", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.93109316", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.94056699", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.9098009", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.83707361", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.72138678", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.56247191", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.36077974", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("12.11745279", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11.83428291", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11.51365535", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("11.15848158", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.7721232", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("10.35830928", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.921049733", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.464547077", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.993108951", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.51106359", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("8.022680152", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.532095603", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.043249522", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6.559827833", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("6.085216253", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.622463745", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.174256134", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.742899602", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.330313611", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.938032568", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.567215301", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("3.218661419", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.892833351", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.589883031", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.309681975", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("2.051853713", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.815807483", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.600772226", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.405830061", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.229948463", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("1.072010592", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.930843275", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.805242313", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.693994894", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.595899009", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.509779847", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.434503266", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.368986452", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.312205983", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.26320352", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.221089376", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.185044253", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.154319386", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.1282354", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.106180095", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.087605421", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.072023841", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.059004283", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.048167828", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.039183298", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.031762834", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.025657574", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.020653497", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.01656749", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.013243667", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.010549974", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.008375083", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.00662559", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.005223486", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.004103928", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.003213255", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.002507261", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.001949691", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.001510937", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.001166928", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000898178", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000688975", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000526708", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000401297", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000304715", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000230599", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000173924", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("0.000130739", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("9.79481E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("7.31487E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("5.46612E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), Typesetting:-mtd(Typesetting:-mrow(Typesetting:-mn("4.46927E-05", executable = "false", mathvariant = "normal")), rowalign = "", columnalign = "", groupalign = "", rowspan = "1", columnspan = "1"), rowalign = "", columnalign = "", groupalign = ""), align = "axis", rowalign = "baseline", columnalign = "center", groupalign = "{left}", alignmentscope = "true", columnwidth = "auto", width = "auto", rowspacing = "1.0ex", columnspacing = "0.8em", rowlines = "none", columnlines = "none", frame = "none", framespacing = "0.4em 0.5ex", equalrows = "false", equalcolumns = "false", displaystyle = "false", side = "right", minlabelspacing = "0.8em"), Typesetting:-mi("")), executable = "false", mathvariant = "normal", open = "[", close = "]")), mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(":", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"))
f := unapply(Spline(pts[1], pts[2], x, degree = 2), x):
plot(f(x), x = 0 .. 20000, labels = ["x", "concentration"])
v := .7:
Disp := 20:
esp := 800000:
k := 0:
"E(x,t):=(&int;)[0.0]^(infinity)1/(Pi)*(e)^((-esp*w^(4)+Disp*w^(2)+k)*t)*cos(w*(x+v*t)) &DifferentialD;w;"
E(4000, 3600);
E(4000, 3600)
simplify(int(exp(-2880000000*w^4+54000*w^2)*cos(6520.0*w)/Pi, w = 0 .. infinity));
0.6340566241e-11
"u(x,t):=(&int;)[0.0]^(20000)E(x-xi,t)*f(xi) &DifferentialD;xi;"
uu1 := [seq(evalf(Int(E(i-xi, 1)*f(xi), xi = 0 .. 20000, method = _NCrule, epsilon = 10^(-6))), i = 0 .. 20000, 100)];
uu5000 := [seq(evalf(Int(E(i-xi, 5000)*f(xi), xi = 0 .. 20000, method = _NCrule, epsilon = 10^(-6))), i = 0 .. 20000, 100)]
[HFloat(-2.1992851380000959e-7), HFloat(-1.4989226916812487e-7), HFloat(1.1410806624540552e-7), HFloat(-7.410689072344523e-11), HFloat(3.005799292702046e-10), HFloat(9.85200498671503e-7), HFloat(7.66402271489397e-9), HFloat(1.4944589525699508e-9), HFloat(1.0909345347265328e-9), HFloat(-1.347400153841658e-10), HFloat(-3.3002245572182045e-9), HFloat(-6.469790742663034e-10), HFloat(6.666140227067126e-9), HFloat(-3.138040719031061e-9), HFloat(2.447894346686553e-8), HFloat(3.290412144789029e-8), HFloat(2.7715876722785253e-8), HFloat(3.743104982870806e-9), HFloat(-1.711761110503056e-8), HFloat(-6.953769222206797e-8), HFloat(-1.8096994014761858e-7), HFloat(-2.924897676092406e-7), HFloat(-4.592332772791863e-7), HFloat(-5.215015444966435e-7), HFloat(-4.7399576012451554e-7), HFloat(-1.3540108524111875e-7), HFloat(9.425076798876926e-7), HFloat(2.8764801628344496e-6), HFloat(6.024495781387309e-6), HFloat(1.0474833315300292e-5), HFloat(1.585982875179663e-5), HFloat(2.1023912595690784e-5), HFloat(2.2774809493421695e-5), HFloat(1.6479587729796864e-5), HFloat(-5.245576382315365e-6), HFloat(-5.2558166892293585e-5), HFloat(-1.380624402754629e-4), HFloat(-2.7574576571570003e-4), HFloat(-4.7569555736198853e-4), HFloat(-7.394255978755631e-4), HFloat(-0.0010482153736026704), HFloat(-0.001350218271812716), HFloat(-0.0015268864800545134), HFloat(-0.0013860822630267539), HFloat(-5.90390037822208e-4), HFloat(0.0013612729015365624), HFloat(0.005196755592921281), HFloat(0.011958115495006439), HFloat(0.023024884366977645), HFloat(0.04021742818287536), HFloat(0.06583792860781386), HFloat(0.10271290504564239), HFloat(0.15424165474904508), HFloat(0.22437186446906676), HFloat(0.3175073612404071), HFloat(0.4385035483336921), HFloat(0.5924360770204598), HFloat(0.7844565731490415), HFloat(1.019575386892244), HFloat(1.302213754453327), HFloat(1.6360395729372545), HFloat(2.0235874322882688), HFloat(2.465964308060876), HFloat(2.9623917866661063), HFloat(3.510172795187464), HFloat(4.104442909537644), HFloat(4.738163759600416), HFloat(5.402077208261823), HFloat(6.085003939824813), HFloat(6.774273818965306), HFloat(7.455950334190702), HFloat(8.115503419953518), HFloat(8.73850814681547), HFloat(9.311025236581445), HFloat(9.820725339218527), HFloat(10.2573149622096), HFloat(10.613078798784128), HFloat(10.883255307633352), HFloat(10.856359411035413), HFloat(11.16522416855706), HFloat(11.184962917921158), HFloat(11.134803691368438), HFloat(11.026657679243602), HFloat(10.87578966233986), HFloat(10.697895657317185), HFloat(10.510256612444557), HFloat(10.32991368673935), HFloat(10.173581456155178), HFloat(10.056171410218234), HFloat(9.990228902921526), HFloat(9.968230116417578), HFloat(10.047707495157132), HFloat(10.179679424716957), HFloat(10.378745760438791), HFloat(10.644656442368278), HFloat(10.961440457423619), HFloat(11.317321786625449), HFloat(11.695936489699424), HFloat(12.088535985231788), HFloat(12.470666708207581), HFloat(12.826818669062217), HFloat(13.139345691015317), HFloat(13.391799614225496), HFloat(13.569738986357798), HFloat(13.661431230863538), HFloat(13.658264356618345), HFloat(13.555070069836518), HFloat(13.350036213326835), HFloat(13.04483013270294), HFloat(12.64421008954875), HFloat(12.155858058862474), HFloat(11.58972560800692), HFloat(10.957678358136778), HFloat(10.27293454622325), HFloat(9.549517810345792), HFloat(8.801563442807502), HFloat(8.04297857108484), HFloat(7.2868723610605075), HFloat(6.545216626809865), HFloat(5.828447698995182), HFloat(5.145409735520372), HFloat(4.503137438015899), HFloat(3.906897454790606), HFloat(3.3601455817574575), HFloat(2.8647391746565836), HFloat(2.421031757395161), HFloat(2.028139352410935), HFloat(1.6840780596555522), HFloat(1.3860436211999592), HFloat(1.13066755932939), HFloat(0.9141803943307134), HFloat(0.7325379816140354), HFloat(0.5817114166353163), HFloat(0.45778482189190894), HFloat(0.3569917848488745), HFloat(0.2758426219320803), HFloat(0.2111748625411637), HFloat(0.16016747842604875), HFloat(0.12033556155892848), HFloat(0.08955002369092911), HFloat(0.06599326950189098), HFloat(0.04815810951427795), HFloat(0.034789168452562476), HFloat(0.024873727159344283), HFloat(0.017598916262082077), HFloat(0.01231069831969616), HFloat(0.008524199459054327), HFloat(0.005831440170893582), HFloat(0.003941490667084899), HFloat(0.002630675051787171), HFloat(0.001735001443530577), HFloat(0.0011256488644413724), HFloat(7.207690785057685e-4), HFloat(4.5494021337731883e-4), HFloat(2.830708074208877e-4), HFloat(1.7387894938060964e-4), HFloat(1.0687128532492048e-4), HFloat(6.553528358344664e-5), HFloat(4.03830805764973e-5), HFloat(2.476823627006392e-5), HFloat(1.432651811874368e-5), HFloat(6.369128385711481e-6), HFloat(-3.758513152748625e-7), HFloat(-6.403599557992656e-6), HFloat(-1.166859405924552e-5), HFloat(-1.5868845363728307e-5), HFloat(-1.8554886048879536e-5), HFloat(-1.9393938611608052e-5), HFloat(-1.8427186533743853e-5), HFloat(-1.6088752417953466e-5), HFloat(-1.193680041350809e-5), HFloat(-7.555478307437356e-6), HFloat(-3.2911085564722923e-6), HFloat(3.356749716461853e-7), HFloat(2.8998828963327384e-6), HFloat(4.238379176054762e-6), HFloat(4.4848478120653275e-6), HFloat(3.866316967870751e-6), HFloat(2.7107300340368345e-6), HFloat(1.4355045861462792e-6), HFloat(2.850676346931986e-7), HFloat(-5.374079342625969e-7), HFloat(-9.471125330562209e-7), HFloat(-1.0509770482664845e-6), HFloat(-8.777313747111306e-7), HFloat(-5.691104546691238e-7), HFloat(-2.2568651591974698e-7), HFloat(3.926326058286941e-8), HFloat(1.93863475127399e-7), HFloat(2.3999508470850535e-7), HFloat(2.0781442173898844e-7), HFloat(1.3254743334241917e-7), HFloat(5.292614948809493e-8), HFloat(-8.91306618652483e-9), HFloat(-4.3255435750577205e-8), HFloat(-5.106709687555605e-8), HFloat(-4.157521021362038e-8), HFloat(-2.4265545292546804e-8), HFloat(2.2172177464260928e-7), HFloat(-3.232228499340677e-7), HFloat(-3.574877979173867e-7)]
uu14000 := [seq(evalf(Int(E(i-xi, 14000)*f(xi), xi = 0 .. 20000, method = _NCrule, epsilon = 10^(-6))), i = 0 .. 20000, 100)]
[HFloat(1.8984460429666323), HFloat(2.542203448187856), HFloat(3.278815214073577), HFloat(4.099762802653735), HFloat(4.991514106675378), HFloat(5.9363031344932855), HFloat(6.911978477696919), HFloat(7.893211726573761), HFloat(8.852443165892987), HFloat(9.761228808949022), HFloat(10.591356908962199), HFloat(11.31702396211637), HFloat(11.9157330168993), HFloat(12.369923813109331), HFloat(12.667892142536154), HFloat(12.804627019860604), HFloat(12.783022041256418), HFloat(12.612611015103397), HFloat(12.310450714322979), HFloat(11.899878999111325), HFloat(11.40955461661877), HFloat(10.871941152681682), HFloat(10.322091183028114), HFloat(9.794944028027414), HFloat(9.324625087452905), HFloat(8.94186966928496), HFloat(8.673155680929145), HFloat(8.538404006472692), HFloat(8.550410616728419), HFloat(8.717085037843194), HFloat(9.02731946246416), HFloat(9.478136058266164), HFloat(10.048633425916135), HFloat(10.714344495297375), HFloat(11.445455095057982), HFloat(12.208607206328521), HFloat(12.967106771143273), HFloat(13.716075623814897), HFloat(14.372832293087027), HFloat(14.917820375566151), HFloat(15.327836070199165), HFloat(15.585834093956311), HFloat(15.680549959663027), HFloat(15.606626699209665), HFloat(15.364297956589061), HFloat(14.959250739611827), HFloat(14.402294402596562), HFloat(13.709191733116185), HFloat(12.899536192497393), HFloat(11.996159621112872), HFloat(11.023936524697616), HFloat(10.008669178463672), HFloat(8.975650531818998), HFloat(7.948871050818295), HFloat(6.949767852098431), HFloat(5.996812372845334), HFloat(5.104581046389905), HFloat(4.284319984086291), HFloat(3.5433223456935528), HFloat(2.8854656435430406), HFloat(2.3113843263296276), HFloat(1.8191051825492703), HFloat(1.4046205500595659), HFloat(1.0619718079409348), HFloat(0.784243700235652), HFloat(0.5637546424021248), HFloat(0.39261402841609716), HFloat(0.26300727696967563), HFloat(0.1676022451729217), HFloat(0.09950501456835244), HFloat(0.05276898931820286), HFloat(0.022208685153363765), HFloat(0.0034979160857172642), HFloat(-0.0068657700037872615), HFloat(-0.011620118830512255), HFloat(-0.012831176493821891), HFloat(-0.01199975128469045), HFloat(-0.010159616971257486), HFloat(-0.007989896808169333), HFloat(-0.00589456051995726), HFloat(-0.00408474277870436), HFloat(-0.002644602606291918), HFloat(-0.0015737857562143872), HFloat(-8.286217546599032e-4), HFloat(-3.4592329134206765e-4), HFloat(-5.849834612465939e-5), HFloat(8.924183025638507e-5), HFloat(1.5001094320898133e-4), HFloat(1.5998805414824002e-4), HFloat(1.4437616090641532e-4), HFloat(1.1948838247294166e-4), HFloat(9.438032839543576e-5), HFloat(7.316838034449886e-5), HFloat(5.6591323759713274e-5), HFloat(4.4264905556369225e-5), HFloat(3.42186876063437e-5), HFloat(2.5021556314654777e-5), HFloat(1.5583664857464896e-5), HFloat(5.6385757712731825e-6), HFloat(-5.3275793443416805e-6), HFloat(-1.6045293693179578e-5), HFloat(-2.5817725426274037e-5), HFloat(-3.352726981393149e-5), HFloat(-3.8385952061904546e-5), HFloat(-3.965560700306478e-5), HFloat(-3.7243140663913855e-5), HFloat(-3.155030157464335e-5), HFloat(-2.337313732953488e-5), HFloat(-1.3320560937865262e-5), HFloat(-3.50418234648856e-6), HFloat(5.540028908243629e-6), HFloat(1.2524770007189394e-5), HFloat(1.7073457116507357e-5), HFloat(1.8708225133371985e-5), HFloat(1.7701653217757437e-5), HFloat(1.4623865597543186e-5), HFloat(1.0175560668185901e-5), HFloat(5.214167123621291e-6), HFloat(4.797650792676976e-7), HFloat(-3.2919454969322776e-6), HFloat(-5.7436329729945125e-6), HFloat(-6.838751417646233e-6), HFloat(-6.6093927912591425e-6), HFloat(-5.4885037553175774e-6), HFloat(-3.746109768848459e-6), HFloat(-1.8257548729270171e-6), HFloat(-6.669823964428799e-8), HFloat(1.252092158217382e-6), HFloat(2.0074350746210378e-6), HFloat(2.2377694266974552e-6), HFloat(2.02006168692389e-6), HFloat(1.504764981773835e-6), HFloat(8.601728543038608e-7), HFloat(2.3894588944372517e-7), HFloat(-2.5160448936342736e-7), HFloat(-5.561018667238092e-7), HFloat(-6.696078700258816e-7), HFloat(-6.213845272228045e-7), HFloat(-4.68538082641874e-7), HFloat(-2.69994919902449e-7), HFloat(-7.800211168313004e-8), HFloat(1.4052446014541566e-8), HFloat(1.5750721583688112e-7), HFloat(1.8877386994167574e-7), HFloat(1.6961438290291193e-7), HFloat(1.2128521424624616e-7), HFloat(8.774226604463782e-8), HFloat(6.642970657423184e-9), HFloat(-4.566438822213199e-8), HFloat(-6.992151925716301e-8), HFloat(-6.745325366085338e-8), HFloat(-4.959282338574516e-8), HFloat(-2.6443615148317168e-8), HFloat(-6.041131124902863e-9), HFloat(8.329679821070189e-9), HFloat(1.4943663548620636e-8), HFloat(1.55070180285137e-8), HFloat(1.247076547701608e-8), HFloat(7.432139790580089e-9), HFloat(2.5770510607048068e-9), HFloat(-1.0161333699501456e-9), HFloat(-2.987930555580264e-9), HFloat(-2.4306746069083186e-8), HFloat(-2.9934400562245605e-9), HFloat(-1.9751069539745235e-9), HFloat(-8.777846107070544e-10), HFloat(2.3380121237654402e-7), HFloat(8.30791125367846e-8), HFloat(-2.972322167749468e-8), HFloat(-8.728995933444071e-8), HFloat(-9.545935109738457e-8), HFloat(-7.217057651414578e-8), HFloat(-3.7286535678145796e-8), HFloat(-5.943853021904159e-9), HFloat(1.4009194287973976e-8), HFloat(2.1366019628235056e-8), HFloat(1.9195068065111276e-8), HFloat(1.2153590287401112e-8), HFloat(4.423641475609614e-9), HFloat(-1.3550835012940617e-9), HFloat(-4.247800804847201e-9), HFloat(-4.595431218053097e-9), HFloat(-3.37785728176737e-9), HFloat(-1.6408199896045958e-9), HFloat(-1.470963993346052e-10), HFloat(7.435726927689552e-10), HFloat(1.0141718404732006e-9), HFloat(8.483109366941543e-10), HFloat(4.868447488763738e-10), HFloat(1.3044852753670129e-10), HFloat(-1.1058454778456778e-10), HFloat(-2.101848180300784e-10), HFloat(-1.9821786201223902e-10), HFloat(-1.2834313846846617e-10), HFloat(-4.738629156115246e-11), HFloat(1.2798544031600627e-11), HFloat(4.14702177578367e-11), HFloat(4.399736945552101e-11), HFloat(3.0426918677352054e-11), HFloat(1.3231113142805841e-11), HFloat(-2.0196512501386664e-13)]
uu18000 := [seq(evalf(Int(E(i-xi, 18000)*f(xi), xi = 0 .. 20000, method = _NCrule, epsilon = 10^(-6))), i = 0 .. 20000, 100)]
[HFloat(7.409509418160813), HFloat(7.595059847681534), HFloat(7.992113526121652), HFloat(8.57518284010406), HFloat(9.329524598894817), HFloat(10.217390519263928), HFloat(11.19798923534698), HFloat(12.2253864661297), HFloat(13.252011379529215), HFloat(14.228035600747651), HFloat(15.10873796661343), HFloat(15.928306880789524), HFloat(16.50909223938234), HFloat(16.879261949948738), HFloat(17.027101643551294), HFloat(16.934536283737913), HFloat(16.660457038703544), HFloat(16.17264642976531), HFloat(15.468901461155456), HFloat(14.61916560864992), HFloat(13.6337690796214), HFloat(12.54301260021309), HFloat(11.379068648385934), HFloat(10.174383852974936), HFloat(8.961113738740105), HFloat(7.7691034122590406), HFloat(6.6250465815945585), HFloat(5.54621611984644), HFloat(4.564001713323817), HFloat(3.6768047115314864), HFloat(2.8960811065620335), HFloat(2.2239117808521556), HFloat(1.6581171483741708), HFloat(1.1931512054245996), HFloat(0.820804903652921), HFloat(0.5309226184525386), HFloat(0.3127347087209871), HFloat(0.15480307255474524), HFloat(0.04618543021962802), HFloat(-0.023390810685535716), HFloat(-0.06317513410920489), HFloat(-0.08130139046340634), HFloat(-0.08452908968714502), HFloat(-0.07832436295542394), HFloat(-0.06689227264820587), HFloat(-0.05336426946955139), HFloat(-0.03987490010746672), HFloat(-0.02775140359419409), HFloat(-0.017687158552281923), HFloat(-0.009906894287553753), HFloat(-0.004322400129422728), HFloat(-6.343682266780555e-4), HFloat(0.0015197673306707878), HFloat(0.0025368519731222092), HFloat(0.002781037866365493), HFloat(0.002555248299068407), HFloat(0.002091754224621768), HFloat(0.0015554926391638543), HFloat(0.00104944261656644), HFloat(6.299674375428231e-4), HFloat(3.163257635968789e-4), HFloat(1.0692242195814104e-4), HFloat(-1.4682096270099988e-5), HFloat(-7.020183987922623e-5), HFloat(-8.139785333180154e-5), HFloat(-6.773855838636202e-5), HFloat(-4.3878953331669875e-5), HFloat(-2.0134170468864147e-5), HFloat(-2.9778389046638165e-6), HFloat(4.859865606967784e-6), HFloat(4.426680936424721e-6), HFloat(-4.076457754723723e-6), HFloat(-1.6649469936260864e-5), HFloat(-3.0315584028964042e-5), HFloat(-4.2813609850970516e-5), HFloat(-5.129605307813786e-5), HFloat(-5.4537089044370886e-5), HFloat(-5.1993545923725376e-5), HFloat(-4.4138457837053646e-5), HFloat(-3.229569339375092e-5), HFloat(-1.7672864371638124e-5), HFloat(-2.6073560261864707e-6), HFloat(1.1097166538272856e-5), HFloat(2.1974367775710724e-5), HFloat(2.874650721630383e-5), HFloat(3.145780755068448e-5), HFloat(2.9812577905438363e-5), HFloat(2.4905760708078658e-5), HFloat(1.759804784988322e-5), HFloat(9.16017076530884e-6), HFloat(1.0541983777672445e-6), HFloat(-5.675869533939248e-6), HFloat(-1.0469181703583092e-5), HFloat(-1.2886408184006528e-5), HFloat(-1.298955579846072e-5), HFloat(-1.1340058392063555e-5), HFloat(-8.26558853324741e-6), HFloat(-4.718167487741519e-6), HFloat(-1.1979773925744327e-6), HFloat(1.728296755733973e-6), HFloat(3.707714367798811e-6), HFloat(4.6754581492807254e-6), HFloat(4.666681190695684e-6), HFloat(3.918025783827286e-6), HFloat(2.715485174422845e-6), HFloat(1.3597049889685049e-6), HFloat(1.1321481014467643e-7), HFloat(-8.523092901966158e-7), HFloat(-1.4154515756456405e-6), HFloat(-1.5882880279368063e-6), HFloat(-1.4383498400492715e-6), HFloat(-1.0744156221858616e-6), HFloat(-6.16773101137574e-7), HFloat(-1.7253915922647237e-7), HFloat(1.8083545351203652e-7), HFloat(4.026132753252526e-7), HFloat(4.872073588302888e-7), HFloat(4.563149194507083e-7), HFloat(3.481120903038017e-7), HFloat(2.040466712264077e-7), HFloat(6.284345372316295e-8), HFloat(-4.905405413167501e-8), HFloat(-1.1809113715233529e-7), HFloat(-1.4149814339337468e-7), HFloat(-1.3178269431693502e-7), HFloat(-9.713101022037339e-8), HFloat(-5.335863052590509e-8), HFloat(-1.2175928133867007e-8), HFloat(-7.580138951268074e-9), HFloat(3.26688921369612e-8), HFloat(5.2964525190902256e-8), HFloat(5.302439497119996e-8), HFloat(3.981137006945887e-8), HFloat(2.0793273444005258e-8), HFloat(3.3588733739810424e-9), HFloat(-8.836883716040163e-9), HFloat(-1.4942798952101338e-8), HFloat(-1.5193433202642635e-8), HFloat(-1.1565432064799109e-8), HFloat(-6.343527253139991e-9), HFloat(-1.4132035451038641e-9), HFloat(2.0836345814511634e-9), HFloat(3.784755156699577e-9), HFloat(1.723798436684402e-7), HFloat(-2.5790829031594663e-7), HFloat(1.713125842617808e-9), HFloat(4.659566023216503e-10), HFloat(-3.2760310807868565e-7), HFloat(-1.628869086864372e-7), HFloat(-1.7876140021860788e-8), HFloat(7.533503988795572e-8), HFloat(1.112367369329852e-7), HFloat(1.0225827740024424e-7), HFloat(6.84440798974735e-8), HFloat(2.894996085227409e-8), HFloat(-2.9518551976072232e-9), HFloat(-2.1313245911587584e-8), HFloat(-2.6327828671265363e-8), HFloat(-2.1882240401087846e-8), HFloat(-1.3007525599512765e-8), HFloat(-4.002452912218396e-9), HFloat(2.506148895850859e-9), HFloat(5.655877370358561e-9), HFloat(5.8920960347118725e-9), HFloat(4.32681909858327e-9), HFloat(2.144696894945916e-9), HFloat(2.338795733477704e-10), HFloat(-9.599803561210672e-10), HFloat(-1.3798759544432389e-9), HFloat(-1.2198879424870417e-9), HFloat(-7.661783927072736e-10), HFloat(-2.7245738448279275e-10), HFloat(9.592528687270006e-11), HFloat(2.826919036843557e-10), HFloat(3.0627023427261033e-10), HFloat(2.2732588977774642e-10), HFloat(1.128272083797884e-10), HFloat(1.1662482202270612e-11), HFloat(-4.8921391216900934e-11), HFloat(-6.949592201876554e-11), HFloat(-5.96493821722168e-11), HFloat(-3.5627919267687115e-11), HFloat(-1.2085657608372612e-11), HFloat(5.85906793877762e-12), HFloat(1.440554016777574e-11), HFloat(1.4823700647799498e-11), HFloat(1.0632837567752218e-11), HFloat(5.027622274677454e-12), HFloat(-3.9812600630158934e-13), HFloat(-3.3886345270870547e-12), HFloat(-4.049181293661401e-12), HFloat(-2.7927956342052716e-12), HFloat(-1.5823963888778041e-12), HFloat(7.028152814608126e-14), HFloat(3.681496828628412e-13), HFloat(4.0798107191893156e-13), HFloat(6.462582417387677e-13), HFloat(5.197168034653561e-13), HFloat(2.4345526773453285e-13), HFloat(3.1401339323304314e-14), HFloat(-1.27380542074307e-13)]
xx := [seq(i, i = 0 .. 20000, 100)]
p1 := pds1:-plot(t = 29999, numpoints = 100, color = blue, legend = ["direct,t=19499"], labels = ["x", "concentration"])
p2 := plot(xx, uu1, color = red, legend = [''inverse, t = 1''])
p3 := pds1:-plot(t = 25000, numpoints = 100, color = blue, legend = ["direct,t=16000"], labels = ["x", "concentration"])
p4 := plot(xx, uu5000, color = red, legend = [''inverse, t = 1''])
p7 := pds1:-plot(t = 16000, numpoints = 100, color = blue, legend = ["direct,t=9000"], labels = ["x", "concentration"])
p8 := plot(xx, uu14000, color = green, legend = [''inverse''])
p9 := pds1:-plot(t = 12000, numpoints = 100, color = blue, legend = ["direct,t=9000"], labels = ["x", "concentration"])
p10 := plot(xx, uu18000, color = green, legend = [''inverse''])
plots[display]({p1, p2})
plots[display]({p3, p4})
plots[display]({p5, p6})
Error, (in plots:-display) expecting plot structures but received: {p5, p6}
plots[display]({p7, p8})
plots[display]({p10, p9})
Download Error10%.mw
Error10%.mw
er.xls
my"+cy'+ky=F(t)      y(0)=y_0    and y'(0) =y'_0    (1)
Where F(t) is an external force, m, c and k are positive constants, y is a function of t and cy' is the damping term. Use equation (1) for your topic and F(t) = 0.
Task 2 : Assume that m = 1 unit in equation (1). For each of the following cases (all with m = 1), perform 5 steps of the modified Euler method applied to the coupled first order system you obtained in part (i), taking the step size h = 0.02 and working to 5 decimal places at each stage :
c = 0,  k = 4  , y(0)=1   and y'(0) =0;
c = 2,  k = 0,   y(0)=1   and y'(0) =0;
c = 2,  k = 1,   y(0)=1   and y'(0) =0;
c = 4, k = 6.25,  y(0)=1   and y'(0) =0.
Summarise your step-by-step results for each example in a table like the blank template below.
c = (Value),  k = (Value), h = 0.02,
t
 (Predicted)
 (Corrected)
   (Predicted)
 (Corrected)
0.00
1.00000
1.00000
0.00000
0.00000
0.02
0.04
0.06
0.08
0.10
This is a question based on rewriting the equation as a pair of coupled(simultaneous) first order ODEs of the general form.
If anyone could please help to proceed with this question, as I am not quiet sure how to approach this differential equation. I will really appreciate your help please.
I am solving some system of linear equations using fsolve(), I will like to obtain my answers without the attached label, i.e. instead of saying {x=2, y = 3} I need my result to be {2,3} because I need reuse the result. Please, help. Thanks.
I seem to be getting false solutions with Maple 2019.2 from solve and cannot figure out why.
Example :
f := x -> x*sqrt(4*x^2 + 1) + arcsinh(2*x);
sol := solve(f(x) = 5., x);
sol := 1.247747277, -1.839602523, 0.2519279800 - 1.361107684 I,
  0.2519279800 + 1.361107684 I
f(sol[1]); =    4.999999999
f(sol[2]); =   -9.027641618
Thus the second reported solution is not a solution after all.
Any ideas are most welcome.
First 586 587 588 589 590 591 592 Last Page 588 of 2428
