Please, I need to use Maple to solve Euler-Bernoulli Beam on Pasternak Foundation using Homotopy Perturbation Method.
The governing equation is
initial conditions are
the boundary condition is
The governing equation represents Euler-Bernoulli beam on a generalized Pasternak viscoelastic foundation under an
arbitrary distributed dynamic load. in which E, I , ρ ,A are the parameters of the beam, representing Young’s modulus of elasticity, moment of inertia, density and area of cross section, respectively. K,C and Gp are spring stiffness, damping coefficient, and shear coefficient of the foundation. Moreover, y(x, t) and F(x, t) are defined as the vertical deflection of the beam and the generic arbitrary dynamic loads, respectively, where the loads distribute along the x-axis and t is time.
I will appreciate anyone who can help me with a Maple solution.
Would anybody be able to explain to me why I had to rewrite this one baby-procedure that has an if-statement inside my larger procedure, so that I could get a later on if-statement to work? As best I can tell, they mean exactly the same thing.
Information that may be pertinent:
 - The entire (overall) procedure worked without throwing any warnings prior to my adding this new if-statement.
 - The if-statement itself worked perfectly fine on another worksheet, though I hadn't tested it inside a procedure.
 - Commenting out the if-statement but retaining the interior commands led to the sheet compiling again, showing that it was in fact the presence of the if-statement causing the issue.
 - When I commented out the offending baby-procedure that started throwing the warning, the sheet once again compiled.
The added if statement:
if eval_size > 4 then Search(max(seq(eval_cont[i], i = 4 .. eval_size)), eval_cont); evals_pairlist := evals_pairlist[[1 .. 3, %]] fi:
The error I get, and its "positioning":
Error, invalid expression for inline function
How I can remove some problems in my code.
I wrote it before in  software, but in some lines, I have some problems with it.
How I can change it in maple to run well?
M := 2; B := 1; C := 3; K := 6; f := 2*exp(-t); q0 := 1; qd0 := -1; qd20 := 1; alpha := 1/2; beta := 1/12; gammaa := 1/4; h := .1; Tf := 2
"N:=size(M,1)  T:=0:h:Tf;  lt:=length(T);  F:=subs(f,t,T);  F:=subs(t=T,f);    qd30:=M\(F(1)-B*qd20-C*qd0-K*q0);   q:=zeros(N,lt)  qd:=zeros(N,lt)  qd2:=zeros(N,lt);  qd3:=zeros(N,lt);  q(:,1):=q0  qd(:,1):=qd0  qd2(:,1):=qd20  qd3(:,1):=qd30"
Error, invalid function arguments
"A:=M+alpha*h*B+gammaa*(h^2)*C+beta*(h^3)*K;  for n:=1:lt-1 do      D:=F(n+1)-B*(qd2(:,n)+(1-alpha)*h*qd3(:,n))-...          C*(qd(:,n)+h*qd2(:,n)+(0.5-gammaa)*(h^2)*qd3(:,n))-...          K*(q(:,n)+h*qd(:,n)+(h^2)/2*qd2(:,n)+(1/6-beta)*(h^3)*qd3(:,n));      qd3(:,n+1):=A\D;      qd2(:,n+1):=qd2(:,n)+(1-alpha)*h*qd3(:,n)+alpha*h*qd3(:,n+1);      qd(:,n+1):=qd(:,n)+h*qd2(:,n)+(0.5-gammaa)*(h^2)*qd3(:,n)+gammaa*(h^2)*qd3(:,n+1);      q(:,n+1):=q(:,n)+h*qd(:,n)+(h^2)/2*qd2(:,n)+(1/6-beta)*(h^3)*qd3(:,n)+...          beta*(h^3)*qd3(:,n+1);  end do"
plot(T, q, 'r-o', 'linewidth', 1.5)
Error, (in plot) unexpected options: [r-o, , 1.5]
Download
How should wirte a while loop for solve nonlinear equations by newton raphson method
 Hi guys,
I am trying write a code for homotopy perturbation, i have already generated the polynomial as you can see, i have also  solve for concentration equation since is not couple. But i have a lot of error massages for temperature, velocity and induced magnetic field. can some one please go through the code?
PDEtools[declare](f(x),theta(x),u(x),w(x), prime=x):
f(x)*`will now be displayed as`*f
theta(x)*`will now be displayed as`*theta
u(x)*`will now be displayed as`*u
w(x)*`will now be displayed as`*w
`derivatives with respect to`*x*`of functions of one variable will now be displayed with '`
N := 4:
f(x):=sum((p^(i))*f[i](x),i=0..N);
f[0](x)+p*f[1](x)+p^2*f[2](x)+p^3*f[3](x)+p^4*f[4](x)
theta(x) := sum(p^i*theta[i](x), i = 0 .. N);
theta[0](x)+p*theta[1](x)+p^2*theta[2](x)+p^3*theta[3](x)+p^4*theta[4](x)
u(x) := sum(p^i*u[i](x), i = 0 .. N);
u[0](x)+p*u[1](x)+p^2*u[2](x)+p^3*u[3](x)+p^4*u[4](x)
w(x) := sum(p^i*w[i](x), i = 0 .. N);
w[0](x)+p*w[1](x)+p^2*w[2](x)+p^3*w[3](x)+p^4*w[4](x)
HPMEq := (1-p)*(diff(f(x), `$`(x, 2)))+p*(diff(f(x), `$`(x, 2))-k1*(diff(f(x), x))-k2*f(x));
(1-p)*(diff(diff(f[0](x), x), x)+p*(diff(diff(f[1](x), x), x))+p^2*(diff(diff(f[2](x), x), x))+p^3*(diff(diff(f[3](x), x), x))+p^4*(diff(diff(f[4](x), x), x)))+p*(diff(diff(f[0](x), x), x)+p*(diff(diff(f[1](x), x), x))+p^2*(diff(diff(f[2](x), x), x))+p^3*(diff(diff(f[3](x), x), x))+p^4*(diff(diff(f[4](x), x), x))-k1*(diff(f[0](x), x)+p*(diff(f[1](x), x))+p^2*(diff(f[2](x), x))+p^3*(diff(f[3](x), x))+p^4*(diff(f[4](x), x)))-k2*(f[0](x)+p*f[1](x)+p^2*f[2](x)+p^3*f[3](x)+p^4*f[4](x)))
HPMEr := (1-p)*(diff(theta(x), `$`(x, 2)))+p*(diff(theta(x), `$`(x, 2))-k11*(diff(theta(x), x))+k12*(diff(u(x), x))^2+k13*(diff(w(x), x))^2+k14*theta(x));
(1-p)*(diff(diff(theta[0](x), x), x)+p*(diff(diff(theta[1](x), x), x))+p^2*(diff(diff(theta[2](x), x), x))+p^3*(diff(diff(theta[3](x), x), x))+p^4*(diff(diff(theta[4](x), x), x)))+p*(diff(diff(theta[0](x), x), x)+p*(diff(diff(theta[1](x), x), x))+p^2*(diff(diff(theta[2](x), x), x))+p^3*(diff(diff(theta[3](x), x), x))+p^4*(diff(diff(theta[4](x), x), x))-k11*(diff(theta[0](x), x)+p*(diff(theta[1](x), x))+p^2*(diff(theta[2](x), x))+p^3*(diff(theta[3](x), x))+p^4*(diff(theta[4](x), x)))+k12*(diff(u[0](x), x)+p*(diff(u[1](x), x))+p^2*(diff(u[2](x), x))+p^3*(diff(u[3](x), x))+p^4*(diff(u[4](x), x)))^2+k13*(diff(w[0](x), x)+p*(diff(w[1](x), x))+p^2*(diff(w[2](x), x))+p^3*(diff(w[3](x), x))+p^4*(diff(w[4](x), x)))^2+k14*(theta[0](x)+p*theta[1](x)+p^2*theta[2](x)+p^3*theta[3](x)+p^4*theta[4](x)))
HPMEs := (1-p)*(diff(u(x), `$`(x, 2)))+p*(diff(u(x), `$`(x, 2))-R*(diff(u(x), x))-A-k8*w(x)-k7*u(x)+k5*theta(x)+k6*f(x));
(1-p)*(diff(diff(u[0](x), x), x)+p*(diff(diff(u[1](x), x), x))+p^2*(diff(diff(u[2](x), x), x))+p^3*(diff(diff(u[3](x), x), x))+p^4*(diff(diff(u[4](x), x), x)))+p*(diff(diff(u[0](x), x), x)+p*(diff(diff(u[1](x), x), x))+p^2*(diff(diff(u[2](x), x), x))+p^3*(diff(diff(u[3](x), x), x))+p^4*(diff(diff(u[4](x), x), x))-R*(diff(u[0](x), x)+p*(diff(u[1](x), x))+p^2*(diff(u[2](x), x))+p^3*(diff(u[3](x), x))+p^4*(diff(u[4](x), x)))-A-k8*(w[0](x)+p*w[1](x)+p^2*w[2](x)+p^3*w[3](x)+p^4*w[4](x))-k7*(u[0](x)+p*u[1](x)+p^2*u[2](x)+p^3*u[3](x)+p^4*u[4](x))+k5*(theta[0](x)+p*theta[1](x)+p^2*theta[2](x)+p^3*theta[3](x)+p^4*theta[4](x))+k6*(f[0](x)+p*f[1](x)+p^2*f[2](x)+p^3*f[3](x)+p^4*f[4](x)))
HPMEt := (1-p)*(diff(w(x), `$`(x, 2)))+p*(diff(w(x), `$`(x, 2))-R*(diff(w(x), x))+k9*u(x)-k10*w(x))
(1-p)*(diff(diff(w[0](x), x), x)+p*(diff(diff(w[1](x), x), x))+p^2*(diff(diff(w[2](x), x), x))+p^3*(diff(diff(w[3](x), x), x))+p^4*(diff(diff(w[4](x), x), x)))+p*(diff(diff(w[0](x), x), x)+p*(diff(diff(w[1](x), x), x))+p^2*(diff(diff(w[2](x), x), x))+p^3*(diff(diff(w[3](x), x), x))+p^4*(diff(diff(w[4](x), x), x))-R*(diff(w[0](x), x)+p*(diff(w[1](x), x))+p^2*(diff(w[2](x), x))+p^3*(diff(w[3](x), x))+p^4*(diff(w[4](x), x)))+k9*(u[0](x)+p*u[1](x)+p^2*u[2](x)+p^3*u[3](x)+p^4*u[4](x))-k10*(w[0](x)+p*w[1](x)+p^2*w[2](x)+p^3*w[3](x)+p^4*w[4](x)))
for i from 0 to N do equ[1][i] := coeff(HPMEq, p, i) = 0 end do;
diff(diff(f[0](x), x), x) = 0
diff(diff(f[1](x), x), x)-k1*(diff(f[0](x), x))-k2*f[0](x) = 0
diff(diff(f[2](x), x), x)-k2*f[1](x)-k1*(diff(f[1](x), x)) = 0
diff(diff(f[3](x), x), x)-k2*f[2](x)-k1*(diff(f[2](x), x)) = 0
diff(diff(f[4](x), x), x)-k1*(diff(f[3](x), x))-k2*f[3](x) = 0
for i from 0 to N do equa[1][i] := coeff(HPMEr, p, i) = 0 end do;
diff(diff(theta[0](x), x), x) = 0
diff(diff(theta[1](x), x), x)-k11*(diff(theta[0](x), x))+k12*(diff(u[0](x), x))^2+k13*(diff(w[0](x), x))^2+k14*theta[0](x) = 0
diff(diff(theta[2](x), x), x)+2*k13*(diff(w[0](x), x))*(diff(w[1](x), x))-k11*(diff(theta[1](x), x))+2*k12*(diff(u[0](x), x))*(diff(u[1](x), x))+k14*theta[1](x) = 0
diff(diff(theta[3](x), x), x)+k12*(2*(diff(u[0](x), x))*(diff(u[2](x), x))+(diff(u[1](x), x))^2)+k14*theta[2](x)+k13*(2*(diff(w[0](x), x))*(diff(w[2](x), x))+(diff(w[1](x), x))^2)-k11*(diff(theta[2](x), x)) = 0
diff(diff(theta[4](x), x), x)+k12*(2*(diff(u[0](x), x))*(diff(u[3](x), x))+2*(diff(u[1](x), x))*(diff(u[2](x), x)))-k11*(diff(theta[3](x), x))+k14*theta[3](x)+k13*(2*(diff(w[0](x), x))*(diff(w[3](x), x))+2*(diff(w[1](x), x))*(diff(w[2](x), x))) = 0
for i from 0 to N do equat[1][i] := coeff(HPMEs, p, i) = 0 end do;
diff(diff(u[0](x), x), x) = 0
diff(diff(u[1](x), x), x)-R*(diff(u[0](x), x))-A-k7*u[0](x)+k5*theta[0](x)+k6*f[0](x)-k8*w[0](x) = 0
diff(diff(u[2](x), x), x)-R*(diff(u[1](x), x))-k7*u[1](x)+k6*f[1](x)-k8*w[1](x)+k5*theta[1](x) = 0
diff(diff(u[3](x), x), x)-R*(diff(u[2](x), x))+k6*f[2](x)-k7*u[2](x)+k5*theta[2](x)-k8*w[2](x) = 0
diff(diff(u[4](x), x), x)-R*(diff(u[3](x), x))+k5*theta[3](x)+k6*f[3](x)-k7*u[3](x)-k8*w[3](x) = 0
for i from 0 to N do equati[1][i] := coeff(HPMEt, p, i) = 0 end do;
diff(diff(w[0](x), x), x) = 0
diff(diff(w[1](x), x), x)-R*(diff(w[0](x), x))-k10*w[0](x)+k9*u[0](x) = 0
diff(diff(w[2](x), x), x)-k10*w[1](x)+k9*u[1](x)-R*(diff(w[1](x), x)) = 0
diff(diff(w[3](x), x), x)-k10*w[2](x)+k9*u[2](x)-R*(diff(w[2](x), x)) = 0
diff(diff(w[4](x), x), x)+k9*u[3](x)-R*(diff(w[3](x), x))-k10*w[3](x) = 0
con[1][0] := f[0](-1) = 1, f[0](1) = 1:
-.5000000000*k2+0.3435019841e-1*k2^4+.5000000000*k2*x^2-.2500000000*k2^2*x^2+.2083333333*k2^2+0.4166666667e-1*k2^2*x^4-0.2083333333e-1*k2^3*x^4+.1041666667*k2^3*x^2+0.4166666667e-1*k1^2*k2+0.5952380952e-3*k2^3*k1*x^7-0.8472222222e-1*k2^3+0.2480158730e-4*k2^4*x^8+0.4166666667e-2*x^6*k1^2*k2^2+0.8333333333e-2*k2*x^5*k1^3-0.9722222222e-2*k1*k2^3*x^5-0.3472222222e-1*k1^2*k2^2*x^4-0.2777777778e-1*k2*x^3*k1^3+0.5046296296e-1*k1*k2^3*x^3+0.6805555556e-1*k2^2*k1^2*x^2-0.4133597884e-1*k1*k2^3*x+0.1944444444e-1*k2*k1^3*x+1.+0.1388888889e-2*k2^3*x^6+0.1666666667e-1*k1*k2^2*x^5+0.4166666667e-1*k2*x^4*k1^2-.1111111111*k2^2*k1*x^3+0.9444444444e-1*k1*k2^2*x-0.8333333333e-1*k2*k1^2*x^2+.1666666667*k2*k1*x^3-0.3750000000e-1*k1^2*k2^2-0.6944444444e-3*k2^4*x^6+0.8680555556e-2*k2^4*x^4-0.4236111111e-1*k2^4*x^2-.1666666667*k1*k2*x
1-(1/2)*k2+(277/8064)*k2^4+(1/2)*k2*x^2-(1/4)*k2^2*x^2+(5/24)*k2^2+(1/24)*k2^2*x^4-(1/48)*k2^3*x^4+(5/48)*k2^3*x^2+(1/24)*k1^2*k2+(1/1680)*k2^3*k1*x^7-(61/720)*k2^3+(1/40320)*k2^4*x^8+(1/240)*x^6*k1^2*k2^2+(1/120)*k2*x^5*k1^3-(7/720)*k1*k2^3*x^5-(5/144)*k1^2*k2^2*x^4-(1/36)*k2*x^3*k1^3+(109/2160)*k1*k2^3*x^3+(49/720)*k2^2*k1^2*x^2-(125/3024)*k1*k2^3*x+(7/360)*k2*k1^3*x+(1/720)*k2^3*x^6+(1/60)*k1*k2^2*x^5+(1/24)*k2*x^4*k1^2-(1/9)*k2^2*k1*x^3+(17/180)*k1*k2^2*x-(1/12)*k2*k1^2*x^2+(1/6)*k2*k1*x^3-(3/80)*k1^2*k2^2-(1/1440)*k2^4*x^6+(5/576)*k2^4*x^4-(61/1440)*k2^4*x^2-(1/6)*k1*k2*x
2.400000000*k2+0.3589208394e-1*k2^4+1.104000000*k2^2+2.713333334*k1*k2+1.904000000*k1^2*k2+0.115520003e-1*k2^3+.939244445*k1*k2^2+.3973226666*k1^2*k2^2+0.1412642116e-1*k1*k2^3+.9218444444*k1^3*k2
(14)
"cond[1][0]:=theta[0](-1)=0.1, theta[0](1)=1,w[0](-1)=0, w[0](1)=0,u[0](-1)=0, u[0](1)=0:  for j from 1 to N do:  cond[1][j]:=theta[j](-1)=0, theta[j](1)=0,w[j](-1)=0, w[j](1)=0,u[j](-1)=0, u[j](1)=0:  end do:    for i from 0 to N do:  dsolve({equa[1][i],cond[1][i]},theta[i](x));  theta[i](x):=rhs(`%`):    end do:    theta(x):=evalf(simplify(sum(theta[n](x),n=0..N)));  convert(theta(x),'rational'); "
Error, (in dsolve) found the following equations not depending on the unknowns of the input system: {u[0](-1) = 0, u[0](1) = 0, w[0](-1) = 0, w[0](1) = 0}
theta[0](x)+theta[1](x)+theta[2](x)+theta[3](x)+theta[4](x)
(15)
"condi[1][0]:=theta[0](-1)=0.1, theta[0](1)=1,w[0](-1)=0, w[0](1)=0,u[0](-1)=0, u[0](1)=0,f[0](-1)=1, f[0](1)=1:  for j from 1 to N do:  condi[1][j]:=theta[j](-1)=0, theta[j](1)=0,w[j](-1)=0, w[j](1)=0,u[j](-1)=0, u[j](1)=0, f[j](-1)=0, f[j](1)=0:  end do:    for i from 0 to N do:  dsolve({equat[1][i],condi[1][i]},u[i](x));  u[i](x):=rhs(`%`):    end do:    u(x):=evalf(simplify(sum(u[n](x),n=0..N)))"
Error, (in dsolve) found the following equations not depending on the unknowns of the input system: {f[0](-1) = 1, f[0](1) = 1, w[0](-1) = 0, w[0](1) = 0, theta[0](-1) = 1/10, theta[0](1) = 1}
u[0](x)+u[1](x)+u[2](x)+u[3](x)+u[4](x)
(16)
"condit[1][0]:=theta[0](-1)=0.1, theta[0](1)=1,w[0](-1)=0, w[0](1)=0,u[0](-1)=0, u[0](1)=0,f[0](-1)=1, f[0](1)=1:  for j from 1 to N do:  condit[1][j]:=theta[j](-1)=0, theta[j](1)=0,w[j](-1)=0, w[j](1)=0,u[j](-1)=0, u[j](1)=0, f[j](-1)=0, f[j](1)=0:  end do:    for i from 0 to N do:  dsolve({equati[1][i],condit[1][i]},w[i](x));  w[i](x):=rhs(`%`):    end do:    w(x):=evalf(simplify(sum(w[n](x),n=0..N)))"
Error, (in dsolve) found the following equations not depending on the unknowns of the input system: {f[0](-1) = 1, f[0](1) = 1, u[0](-1) = 0, u[0](1) = 0, theta[0](-1) = 1/10, theta[0](1) = 1}
w[0](x)+w[1](x)+w[2](x)+w[3](x)+w[4](x)
(17)
Download completecode.mw
I got some problems with command solve .
I have to solve 6 equations with 6 unknowns. The problem is that Maple solves this system in a wrong way - the values calculated by the command are bad. I would like to ask if there is any command in Maple while solving the equations that are responsible for possible approximations when solving equations.
In the attachment I will insert the code I used.
https://www.pastiebin.com/5ce6a1943f548
Hi freind,
Anybody knows what happen to this coding?
why this error happens? how can i fix it?
thank you!
Hi everyone,
I was wondering how I could modify the thickness of edges in a graph displayed as a Maple plot through DrawGraph. The point is, the graph comprises 100 vertices and 1000 edges. By default, edge thickness is set as 2 but due to the high number of edges I would like to set edge thickness to1 or even 0. How can I do so?
Here is an example with a random graph:
with(GraphTheory) : with(RandomGraphs) : G := RandomGraph(100, 1000) : DrawGraph(G)
Thank you very much
Good day,
I was recently using Maple 2019 for work on a project, and ran into an error. This error (which will be copied and pasted below for others to test) occurs when making assumptions across multiple lines (whether using the additionally function or not) while using IntegrationTools[Change]. It seems that, if during the process a variable that was within both the assumptions is subtracted from itself, the subtraction fails to happen and leaves what effectively equals 0 in the workings, making further workings impossible.
I'm wondering if anyone else is able to reproduce this error? I know the fix for it is to not disjoint the assumptions, but I am curious if others can easily reproduce it or if others have experiences with it!
As promised, below you will find my workings in order to reproduce this error!
Base Error:
assume(a>0,b>0,b>a,c>0,t>0);
interface(showassumed=0);
F := Int(sqrt(d-a*c^2*t),d=0...infinity);
assume(b>a);
IntegrationTools[Change](F,-a*t*c^2+d=-y,y)
Simple Fix:
Error Without Interface Change:
assume(a>0,b>a,c>0,t>0);
assume(b>a);
Error When Using Additionally:
additionally(b>a);
lambda := 1;
mu := 1;
alpha := 1;
v := 2;
delta := 1;
m := 1;
d := 3;
l := 1;
omega := -(1/2)*a*lambda^2-a*m^2+2*a*mu*v-delta*l*m-(1/2)*delta*lambda^2+2*delta*mu*v-l^2*mu-(1/2)*lambda^2*mu+2*mu^2*v-2*a*mu-2*delta*mu-2*mu^2;
                            - a + 1
a[0] := ((2*d*v-2*d-lambda)*(1/2))*sqrt(2)*sqrt(gamma*(a+delta+mu))/gamma;
                    (1/2)                (1/2)
                 5 2      (gamma (a + 2))
                            2 gamma
a[1] := 0;
a[2] := -(2*(1/2))*sqrt(2)*sqrt(gamma*(a+delta+mu))*(d^2*v-d^2-d*lambda+mu)/gamma;
                     (1/2)                (1/2)
                  7 2      (gamma (a + 2))
                              gamma
Omega := lambda^2-4*mu*v+4*mu;
                               -3
H := (-lambda+sqrt(-Omega)*tan((1/2)*sqrt(-Omega)*xi))/(2*(v-1));
                  1   1  (1/2)    /1  (1/2)   \
                - - + - 3      tan|- 3      xi|
                  2   2           \2          /
u := a[0]+a[1]*(d+H)+a[2]/(d+H);
              (1/2)                (1/2)
           5 2      (gamma (a + 2))
                      2 gamma
                       (1/2)                (1/2)
                    7 2      (gamma (a + 2))
                      /5   1  (1/2)    /1  (1/2)   \\
                gamma |- + - 3      tan|- 3      xi||
                      \2   2           \2          //
eta := -l*y-m*x+omega*t;
                               /1      \
                      -y - x + |- a + 1| t
                               \2      /
              (1/2)                (1/2)
           5 2      (gamma (a + 2))
                      2 gamma
                       (1/2)                (1/2)
                    7 2      (gamma (a + 2))
                      \2   2           \2          //
f := diff(u, xi);
                                  /                      2\
       (1/2)                (1/2) |3   3    /1  (1/2)   \ |
    7 2      (gamma (a + 2))      |- + - tan|- 3      xi| |
                                  \4   4    \2          / /
                  \2   2           \2          //
S := diff(u, xi);
                                  /                      2\
                                  \4   4    \2          / /
                  \2   2           \2          //
xi := x+y-(-2*alpha*m-delta*l-delta*m-2*l*mu)*t;
                          x + y + 6 t
eq := (-omega-a*m*m-delta*l*m-mu*l*l)*u-(gamma*u*u)*u+(a+delta+mu)*S;
            /   (1/2)                (1/2)
/  3      \ |5 2      (gamma (a + 2))
|- - a - 3| |-----------------------------
\  2      / |           2 gamma
                 (1/2)                (1/2)          \         /
              7 2      (gamma (a + 2))               |         |
   - ------------------------------------------------| - gamma |
           /5   1  (1/2)    /1  (1/2)              \\|         |
     gamma |- + - 3      tan|- 3      (x + y + 6 t)|||         |
           \2   2           \2                     ///         \
     (1/2)                (1/2)
  5 2      (gamma (a + 2))
             2 gamma
                 (1/2)                (1/2)          \
   - ------------------------------------------------|^3 +
           \2   2           \2                     ///
                          1                         |
  ------------------------------------------------- |7 (a + 2)
                                                  2 \
        \2   2           \2                     //
                              /                                 2
  2      (gamma (a + 2))      |- + - tan|- 3      (x + y + 6 t)|
                              \4   4    \2                     /
value(%);
            /   (1/2)                (1/2)
\  2      / |           2 gamma
                 (1/2)                (1/2)          \         /
           \2   2           \2                     ///         \
     (1/2)                (1/2)
  5 2      (gamma (a + 2))
             2 gamma
                 (1/2)                (1/2)          \
           \2   2           \2                     ///
                          1                         |
                                                  2 \
        \2   2           \2                     //
                              /                                 2
                              \4   4    \2                     /
simplify(%);
Error, (in simplify/tools/_zn) too many levels of recursion
Q := exp(I*(-y-x+((1/2)*a+1)*t))*((5/2)*sqrt(2)*sqrt(gamma*(a+2))/gamma-7*sqrt(2)*sqrt(gamma*(a+2))/(gamma*(5/2+(1/2)*sqrt(3)*tan((1/2)*sqrt(3)*(x+y+6*t)))));
                                /   (1/2)                (1/2)
     /  /         /1      \  \\ |5 2      (gamma (a + 2))
  exp|I |-y - x + |- a + 1| t|| |-----------------------------
     \  \         \2      /  // |           2 gamma
                   (1/2)                (1/2)          \
             \2   2           \2                     ///
                                /   (1/2)                (1/2)
                   (1/2)                (1/2)          \
             \2   2           \2                     ///
plot3d(Re(Q), x = -40 .. -37, y = -40 .. -37, t = -10 .. 10);
Dear Maple friends~
Recently I am thinking a question about how to use Maple to prove an equation based on a known partial differential equationand its boundary conditions.
Although I can Prove it with hand computation ,it still has some difficulty and it will be really hard if its partial differential equation become more complex(As a matter of fact, it will happen).So I think of Maple and want to take advantage of computer.However,I get few ideas how to realize it .The details are as follows:
alias(u=u(x,t)):
pde:=diff(u,t)-diff(u,x$2,t)+4*u^2*diff(u,x)=3*u*diff(u,x)*diff(u,x$2)+u^2*diff(u,x$3);
N:=5;#actually N can be any positive integer!
bcs:=eval(u,x=-infinity)=0,seq(eval(diff(u,x$ha),x=-infinity)=0,ha=1..N),eval(u,x=infinity)=0,seq(eval(diff(u,x$ha),x=infinity)=0,ha=1..N);
E:=Int(u^4+2*u^2*diff(u,x)^2-diff(u,x)^4/3,x=-infinity..infinity);
#try to prove the following equation
diff(E,t)=0
The written proof is as follows:
Therfore,I submit such a problem and look forward your solutions and suggestions sincerely~
Hy everyone,
i'm writing a code wich ends with an Explore including multiple parameters (8) ; my problem is that if i want to change every parameter, elaborating time becames too long, because Maple evaluates every variation of every parameter every time.
I'm looking for something like a button, which works like this: when i change parameters in explore maple doesn't evaluate the function, and when i click the button maple evaluates one time all the changed parameters.
Any suggestion?
Please help me for removing an error in my code.
"   restart:     NL:=960:    LL:=4:      BB:=0.6 :  T:=16:    MM:=NL*(LL+1):          for  NC  from 0 by 1 to MM-1  do       S:=BB+(2*Pi*NC/T)*I;          powerFactor := 0.05 * (sqrt(2.0) - 1.202081528);     powerTerm := sqrt(S)*sqrt(49*S^(2)+280*S+800)/sqrt(S+4);       preFactor := 1/((exp(sqrt(2.0)*powerTerm/10.0)-1.0)*S);       XS(NC+1):= preFactor * ((-exp(-powerFactor*powerTerm) + exp(powerFactor*powerTerm)) * exp(sqrt(2.0)*powerTerm/20.0));    end  do;    for  timeCounter from 0 by 1 to  NL-1  do     totalTerm:=0;     for KK from 0 to NL-1 do        for L from 0 to LL do           Term1:=Re(XS(KK+L*NL+1))+I*(Im(XS(KK+L*NL+1)));           Term2:=exp((timeCounter*KK*2*Pi/NL)*I);           totalTerm:=totalTerm+Term1*Term2;        end do     end do     XT(timeCounter+1):=((2.0/T)*exp(BB*timeCounter*T/NL)*(-0.5*Re(XS(1))+Re(totalTerm)));     TT(timeCounter+1):=(timeCounter*T)/NL;         end do    "
Error, invalid loop statement termination
"   restart:    NL:=960:  LL:=4:  BB:=0.6 :  T:=16:    MM:=NL*(LL+1):       for NC  from 0 by 1 to MM-1  do     S:=BB+(2*Pi*NC/T)*I;    powerFactor := 0.05 * (sqrt(2.0) - 1.202081528);   powerTerm := sqrt(S)*sqrt(49*S^2+280*S+800)/sqrt(S+4);    preFactor := 1/((exp(sqrt(2.0)*powerTerm/10.0)-1.0)*S);     XS(NC+1):= preFactor * ((-exp(-powerFactor*powerTerm) + exp(powerFactor*powerTerm)) * exp(sqrt(2.0)*powerTerm/20.0));    end  do;    for timeCounter from 0 by 1 to NL-1  do  totalTerm:=0;     for KK from 0 to NL-1 do        for L from 0 to LL do  Term1:=Re(XS(KK+L*NL+1))+I*(Im(XS(KK+L*NL+1)));  Term2:=exp((timeCounter*KK*2*Pi/NL)*I);  totalTerm:=totalTerm+Term1*Term2;        end do     end do   XT(timeCounter+1):=((2.0/T)*exp(BB*timeCounter*T/NL)*(-0.5*Re(XS(1))+Re(totalTerm)));   TT(timeCounter+1):=(timeCounter*T)/NL;      end do    "
Download
How I can write a code for the determination of Laplacian in a new form that is introduced in the maple code (First line).
FOR
Maple Worksheet - Error
Failed to load the worksheet //convert/FOR
Download FOR
First 686 687 688 689 690 691 692 Last Page 688 of 2428
