I find many tools about differential
i had some differential ideal
how to use these tools to research what application can be applied with differential ideals I discovered?
Given a list of numeric value lists, calculate the average of each sub-data list
### I am writing a code for an Optimal control using pontryagins maximum principle. I have supplied all neccessary boundary conditions yet it fails to detect one of the conditions. It gives an error message whenever I run it.
I need guidance. Thank you
r := 3; r[1] := 3; k := 10; a := 0.2e-1; b := 0.1e-1; c := 0.1e-1; beta := 0.3e-1; alpha := 0.3e-1; m := 0.5e-1;
z := 40; q := 5; p := 100; T := 3;
sigma := 0.1e-1; k[1] := 10; rho := 0.5e-1;
u[1] := min(max(0, z), 1); z := (a*m*k*lambda[2](t)*x(t)*y(t)-lambda[1](t)*r*(1+b*x(t)+c*y(t))*x(t)*x(t))/(z*k*(1+b*x(t)+c*y(t))); u[2] := min(max(0, q), 1); q := -lambda[1](t)*beta*x(t)*s(t)/q; u[3] := min(max(0, p), 1); p := -(r[1]*lambda[3](t)*s(t)*s(t))/(p*k[1]);
NULL;
sys := diff(x(t), t) = r*x(t)*(1-(1-u[1])*x(t)/k)-a*m*x(t)*y(t)/(1+b*x(t)+c*y(t))-beta*(1-u[2])*x(t)*s(t), diff(y(t), t) = -alpha*y(t)+a*m*x(t)*y(t)/(1+b*x(t)+c*y(t)), diff(s(t), t) = sigma*s(t)+r[1]*s(t)*(1-(1-u[3])*s(t)/k[1])-rho*s(t)*y(t), diff(lambda[1](t), t) = -lambda[1](t)*(r-2*r*(1-u[1])*x(t)/k-a*y(t)*(1+c*y(t))/((1+b*x(t)+c*y(t)) . (1+b*x(t)+c*y(t)))-beta*(1-u[2])*s(t))-lambda[2](t)*a*m*(1-u[1])*(1+c*y(t))*y(t)/((1+b*x(t)+c*y(t)) . (1+b*x(t)+c*y(t))), diff(lambda[2](t), t) = -lambda[1](t)*a*x(t)*(1+b*x(t))/((1+b*x(t)+c*y(t))*(1+b*x(t)+c*y(t)))+lambda[2](t) . (-alpha+(a*m*(1-u[1]) . (1+b*x(t)))*x(t)/((1+b*x(t)+c*y(t))*(1+b*x(t)+c*y(t))))+lambda[3](t)*rho*s(t), diff(lambda[3](t), t) = lambda[1](t)*beta*(1-u[2])*x(t)-lambda[1](t)*(r[1]-2*r[1]*(1-u[3])*s(t)/k[1]-sigma-rho*y(t)), x(0) = 10, y(0) = 20, s(0) = 10, lambda[1](T) = 0, lambda[2](T) = 0, lambda[3](T) = 0;
p1 := dsolve({sys}, type = numeric, method = bvp[midrich], abserr = .1);
Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 7, got 6
p2o := odeplot(p1, [t, y(t)], 0 .. 2, numpoints = 100, labels = ["Time (months)", " "*`badbiomass""spatina"""`], labeldirections = [horizontal, vertical], style = line, color = red, axes = boxed);
r := 3; r[1] := 3; k := 10; a := 0.2e-1; b := 0.1e-1; c := 0.1e-1; beta := 0.3e-1; alpha := 0.3e-1; m := 0.5e-1; sigma := 0.1e-1; k[1] := 10; rho := 0.5e-1;
fun := diff(x(t), t) = r*x(t)*(1-x(t)/k)-a*m*x(t)*y(t)/(1+b*x(t)+c*y(t))-beta*x(t)*s(t), diff(y(t), t) = -alpha*y(t)+a*m*x(t)*y(t)/(1+b*x(t)+c*y(t)), diff(s(t), t) = sigma*s(t)+r[1]*s(t)*(1-s(t)/k[1])-rho*s(t)*y(t), x(0) = 10, y(0) = 20, s(0) = 10;
p2 := dsolve({fun}, type = numeric);
Error, (in f) unable to store 'HFloat(10.0)*r*(1-HFloat(10.0)/k)-HFloat(3.1538461538461537)' when datatype=float[8]
p2i := odeplot(p2, [t, y(t)], 0 .. 2, numpoints = 100, labels = ["Time(months)", " bad biomass"], labeldirections = [horizontal, vertical], style = line, axes = boxed, color = blue);
plots[display](p2i, p2o);
Error, (in plots:-display) expecting plot structure but received: p2i
do math regex solver exist in this world?
expect to output a set of regex for pattern
and then use regex to generate condition or rules equations and then use sorting algorithm to find whether match all data
How can I print steps of ReducedRowEchelonForm when i got martix with dimensions 6x7(augmented)?
With command Expand Steps occurs an error:
ExpandSteps(ReducedRowEchelonForm(macierzA))
In Maple 2019 it is not possible to change to "1-D Math Input".
But it is possible to convert (right mouse->convert to-> 1D Math Input)
In this mode I get the following results:
> 6/2*(1 + 2);
                               9
> 6/2(1 + 2);
I have the feeling the 2nd result is wrong.
If I change to "Maple input", I get the following result:
> 6/2(1 + 2);
                               9
In this editor, where I write this post, it is possible to insert Maple Math.
If I enter there "6/2(1 + 2)", in the preview is written "3".
If I enter there "6/2(1 + 2+9)", in the preview is written "3".
The parser gives no error message, but a wrong result.
If I enter nonsense, there is the following message "You have entered an invalid Maple expression".
Are you aware of this?
Question 1)
Maximize A + B <= 60
A - B = prime or 2^n
A or B can be prime or 2^n  * prime
A or B at least one of them is prime
Solve system for A and B
Question 2)
Maximize A + B + C <= 60
B - C = prime or 2^n
A,B,C at least one of them is prime
A or B or C can be prime or 2^n * prime
Solve system for A and B and C
I have not touched Maple in about 10 years and I'm back but apparently my Maple skills got quite a bit it rusty. I'm trying to plot a function but keep getting this warning and a blank graph:
"Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct"
Here is what I'm trying to do (put and call formulas for Black 76 model):
> with(Statistics);
> X := RandomVariable(Normal(0, 1));
> K := 150;
> r := 0.25e-1;
> s := .75;
> t := .5;
> d1 := f-> (log(f/K)+.5*s^2*t)/(s*sqrt(t)):
> d2 := f-> d1(f)-s*sqrt(t):
> c := f-> exp(-r*t)*(f*([CDF])(X, d1(f))-K*([CDF])(X, d2(f))) :
p := ->exp(-r*t)*(K*([CDF])(X, -d2(f))-f*([CDF])(X, -d1(f))):
All of the above work as intented:
> evalf(c(100)), evalf(p(100));
return the correct values. But I can't plot c( ) or p( ):
plot(c(f), f = 50 .. 100)
What am I doing wrong here? I will appreciate any help.
Fsolve produces the correct solution.  solve followed by evalf produces a completely different solution.
What am I doing wrong?
## Ioannes Colla problem: "Divide 10 into three parts such that they
## shall be in continued proportion and that the product of the first
## two shall be 6"
eqs := [a+b+c=10, a/b=b/c, a*b=6];
fsolve(eqs); ## correct solution
evalf(solve(eqs)); ## different
Tom Dean
If A is an m × n matrix and B is a p × q matrix, then the Kronecker product C = A ⊗ B is the mp × nq block matrix. Assume I have matrix C and want to find matrix A and B. This problem has known solution called "Nearest Kronecker Product". So I just need a function like this: A,B:=NearestKroneckerProduct(C)  which minimizes ||C - A ⊗ B||F  where denotes frobenius norm.
Here is an Image that shows a mathematica code:
I took it from the link below:
https://mathematica.stackexchange.com/questions/91651/nearest-kronecker-product
Also there is a matlab code:
https://gist.github.com/tholden/58dd9a8991daa750ae36a633fe7060a4/revisions
can you convert mathematica code to maple?
If I do:
df:=DataFrame(Matrix(3,4,[seq(1..12)]), rows=[a,b,c],columns=[A,B,C,D]);Tabulate(df, width=100)
The font that Maple uses for the Tablulate is much larger than the font used to display the Dataframe. How does one choose the font size that Tabluate() uses?
Peter
When I type this into Maple
(i mod 3)*(i mod 4)
Maple gives the answer i^2
That doesn't seem right to me.  Is that a bug?
I have been given the assigment to plot at sphere in maple, with a spherical triangel. I know how to plot the sphere:
restart; with(geom3d); with(plots); with(Plot); with(plottools);
display(sphere([0, 0, 0], 1), axes = Framed)
But i do not know how to mape the spherical triangels on the sphere.
The koordinates are:
A(1,0,0)
B(0,1,0)
C(0,0,1)
Hope somone can help
Hi, i want to plot an ode plot with respect to a parameter (E) in range [0,4] instead of time.
I start with unassign variable E and tried to change 't' for 'E' directly, but its give me error
did I use the incorrect syntax/ step?
restart; with(linalg); with(VectorCalculus); with(DEtools); with(plots)
r := .9; K := 10; beta := .5; g := 0.3e-1; alpha[1] := .4; alpha[2] := 2.2; alpha[3] := 4; d[1] := .1; d[2] := .1; q := 1; E := 2.5; s := .46; delta := 1.5; b := 1.2; p := 1; c := 0.1e-1; mu := 0.25e-1; P0 := 4; M0 := 5; N0 := 3; L0 := 2; T := 20
> dP := VectorCalculus[`+`](VectorCalculus[`+`](VectorCalculus[`*`](VectorCalculus[`*`](r, P(t)), VectorCalculus[`+`](1, VectorCalculus[`-`](VectorCalculus[`*`](P(t), 1/K)))), VectorCalculus[`*`](g, P(t))), VectorCalculus[`-`](VectorCalculus[`*`](beta, P(t)))); dM := VectorCalculus[`+`](VectorCalculus[`+`](VectorCalculus[`*`](beta, P(t)), VectorCalculus[`-`](VectorCalculus[`*`](VectorCalculus[`*`](q, E), M(t)))), VectorCalculus[`-`](VectorCalculus[`*`](d[1], M(t)))); dN := VectorCalculus[`+`](VectorCalculus[`-`](VectorCalculus[`*`](s, N(t))), VectorCalculus[`*`](VectorCalculus[`*`](VectorCalculus[`*`](delta, N(t)), M(t)), 1/VectorCalculus[`+`](M(t), VectorCalculus[`*`](b, N(t))))); dL := VectorCalculus[`+`](VectorCalculus[`*`](VectorCalculus[`+`](alpha[1], VectorCalculus[`-`](VectorCalculus[`*`](VectorCalculus[`*`](alpha[2], L(t)), 1/VectorCalculus[`+`](alpha[3], M(t))))), L(t)), VectorCalculus[`-`](VectorCalculus[`*`](d[2], L(t))));
> satu := diff(P(t), t) = dP; dua := diff(M(t), t) = dM; tiga := diff(N(t), t) = dN; empat := diff(L(t), t) = dL;
> pdb := satu, dua, tiga, empat; fcns := {L(t), M(t), N(t), P(t)};
> Q := dsolve({pdb, L(0) = L0, M(0) = M0, N(0) = N0, P(0) = P0}, fcns, type = numeric, method = rkf45, maxfun = 500000);
> odeplot(Q, [[t, P(t), color = blue], [t, M(t), color = green], [t, N(t), color = red], [t, L(t), color = gold]], t = 0 .. T, numpoints = 100000, thickness = 2);
its work fine if i plot with respect to time (t), but when i tried to change it for a parameter like E its doesnt work
unassign('E');
odeplot(Q, [[E, P(t), color = blue]], E = 0 .. 4, numpoints = 100000, thickness = 2)
Error, (in plots/odeplot) curve is not fully specified in terms of the ODE solution, found additional unknowns {E}
following the output that I expected
attached: captive_breeding.mw
I can use plot3d() command. But when I want to use contourplot() or densityplot() commands, Maple diaplays no plots.
Can you please guide me?
First 684 685 686 687 688 689 690 Last Page 686 of 2428
