I have created a custom port in my MapleSim file and when I try to add the port to a Custom Component I keep getting an error that the connector cannot be found.
The custom port appears in the components pane of my MapleSim model.
I am guessing that I am missing something to fully qualify the port name.
I would like to create a custom component with thermal fluid flow ports but I don't see that type of port as an option in the DAE Custom Component Template.  Can anyone help me with now I would go about doing this?
Maple does not simplify the expression A*[sin(x)]^2+A*[cos(x)]^2=A, where A is any expression.
How can I make it do so?
Maple 17 64-bit on Windows 8
Hello. How to connect 2 point of segment with animation? I know only one way to do this. We need connect P and Q. We need to create intermediate points like:
for i from 1 to 100
q[i]:=i/100*P+(1-i/100)*Q
It seems to me that this option consumes a lot of resources.
Is there another way to do this with the Maple?
I have thought that   D(y)(0)=C1  and  eval(diff(y(t),t),t=0)=C1  mean exactly the same thing which is derivative of y wr.t. "t" evaluated at specific point t=0 is C1.
If you agree they are exactly the same thing, then why dsolve works with both forms used for initial conditions if the option 'series' is not used.
When using the 'series' option, dsolve stops working when using  eval(diff(y(t),t),t=0) form? All else is the same.
ode:=diff(y(t),t$2)+3*diff(y(t),t)+2*y(t)=0;
bc_form_1:=y(0)=C1,eval(diff(y(t),t),t=0)=C2;
bc_form_2:=y(0)=C1,D(y)(0)=C2;
sol1:=dsolve([ode,bc_form_1],y(t));
sol2:=dsolve([ode,bc_form_2],y(t))
Both the above work
But now when I use the 'series' option, the first form stops working!
sol1:=dsolve([ode,bc_form_1],y(t),'series');
sol2:=dsolve([ode,bc_form_2],y(t),'series')
Is this a bug?
Just updated to Maple 2019.1  on windows 10.
The code is from the book(SDE). I think P.n := evalm( P.(n-1)&*P0) causes the problem. I have never seen this kind of the structure before ( I did some coding with C and Java). Could you explain that? P0, P1, P2,,,, using for n from 1 to 10. Is "." between P and n the dot (period)? Thank you in advance.
N := 2; A := -N; B := N
q := .3; p := .5; sa := .9; sb := .1; r := 1-p-q
with(linalg)
dimP := 2*N+1
P := matrix(dimP, dimP, [`$`(0, dimP*dimP)])
P[1, 1] := sa; P[1, 2] := 1-sa; P[dimP, dimP] := sb; P[dimP, dimP-1] := 1-sb
for i from 2 to dimP-1 do P[i, i-1] := q; P[i, i] := r; P[i, i+1] := p end do
P0 := P
for n to 10 do P.n := evalm(`&*`(P.(n-1), P0)) end do
print(P10)
P10
Download TransitionMatix.mw
I have this very ugly ODE system which I solve with "dsolve, numeric, complex=true". It works ok but I'd really like to be able to use events. The problem is that the solution of the system has very small (~10^(-Digits)) imaginary part and as we know "events" works only for real ODEs.
My question is does anyone know a way to force dsolve to solve the ODE as a real system? In Mathematica, there is the function "chop" which does the trick. In Maple, I tried with fnormal and also by forcing some terms to be real but that makes it hit a singularity at 0.01 which doesn't exist when it integrates it as a complex system. In Mathematica, it integrates ok with "chop" without any random singularities.
I'm currently trying separating the system into real and imaginary parts, but considering how ugly the system is, it may not be so simple (and so far, it doesn't work). So something to trick dsolve would come handy.
How can plot two  and bipolar figures as attached and extract their data.
Thank You.
I have reinstalled Maple 2019 several times, including its latest update. But when trying to graph the following:
plot(sin(x), x = -2*Pi .. 2*Pi)
But I get this:
Error, (in plot) expected a range but received x = -2*Pi .. 2*Pi
And if I enter:
sin(x)
The result is:
2.73949338633639*10-116 + 2.73949338633639*10-116*I
When trying this:
plot3d(x*exp(-x^2 - y^2), x = -2 .. 2, y = -2 .. 2, color = x)
I get this:
And if I try it with Graph Theory:
with(GraphTheory);
G := Graph({{a, b}, {a, c}, {b, c}});
G := Graph 1: an undirected unweighted graph with 3 vertices and 3 edge(s)
DrawGraph(G)
Error, (in GraphTheory:-DrawGraph) invalid input: modp received I, which is not valid for its 2nd argument, m
I do not know what is the reason for this anomalous behavior of Maple 2019, it will be some software bug or it will be an error caused by my computer...
I would like to know if this problem happens to other people or just to me. Any help or guidance on this problem will be greatly appreciated.
Best regards
Hello everyone!
I have a naive question...
I'm traying to construct an array such entries are derivatives of a particular function. In my original problem, the elements of the array are numerous, so build it manual is not an option... A simplification of my task is :
So, as you can see, for some reason Maple doen't chanche the index "i" in my derivative while the cycle is runnin. So all i want to do  is construct an array of the form
using a cycle.
Thanks for yout help!
Hello everybody
can anybody help me solve this differential equation please?
d^2y(t)/dt^2-dy(t)/dt*1/y(t)=a*y(t)^2
I am really not good at writing the code. The code was from the book (Stochastic process with maple).
It does not seem to generate the different plots when I run the code.
Also the last added code was from the book but it shows error.
Thank you for the help in advance. (My English also is not good.)
with(stats)
with(plots)
RandWalk := proc (N, p, q, sa, sb, M) local A, B, r, PA, PC, PB, state, step, path; A := -N; B := N; r := 1-p-q; PA := empirical[0., sa, 1-sa]; PC := empirical[q, r, p]; PB := empirical[1-sb, sb, 0.]; state := 0; path := state; to M do if A < state and state < B then step := trunc(stats[random, PC](1))-2 elif state = A then step := trunc(stats[random, PA](1))-2 elif state = B then step := trunc(stats[random, PB](1))-2 end if; state := state+step; path := path, state end do; plots[pointplot]([seq([i, path[i]], i = 1 .. nops([path]))], axes = BOXED) end proc
RandWalk(3, .5, .5, .8, .8, 20)
plots[display]([seq(RandomWalk(10, .45, .5, .8, 300), k = 1 .. 4)], insequence = true); plots[display](%)
Error, (in plots:-display) cannot make plot structure from object with name RandomWalk
Download randomWalk.mw
with(stats)
with(plots)
Could you help me?
with(stats)
with(plots)
"RandWalk :=proc(N,p,q,sa,sb,M)  local A,B,r,PA,PC,PB, state,step,path:  A:=-N: B:=N: r:=1-p-q:  PA:=empirical[0.,sa,1-sa]:  PC:= empirical[q,r,p]:  PB := empirical[1-sb,sb,0.]:  state:=0: path:=state:  from 1 to M do  if (A< state and state <B) then step:=trunc(stats[random, PC](1))-2:  else if state =A then step:= trunc(stats[random,PA](1))-2:  else if state =B then step:= trunc(stats[random,PB](1))-2:  end if:  state := state + step:  path := path,state:  end do:  plots[pointplot]([seq([i,path[i]],i=1..nops([path]))],axes=BOXED):  end proc:"
Error, unterminated procedure
with(stats)
with(plots)
restart; with(stats); with(plots); RandWalk :=proc(N,p,q,sa,sb,M) local A,B,r,PA,PC,PB, state,step,path: A:=-N: B:=N: r:=1-p-q: PA:=empirical[0.,sa,1-sa]: PC:= empirical[q,r,p]: PB := empirical[1-sb,sb,0.]: state:=0: path:=state: from 1 to M do if (A< state and state
assign(seq(U || i = `<,>`(x[i], y[i]), i = 1 .. 3));
U || 4 := U || 1; r := (1/6)*sqrt(3);
assign(seq(V || i = (U || i+U || (i+1))*(1/2)+(`<,>`(`<|>`(0, 1), `<|>`(-1, 0)) . (U || (i+1)-U || i))*r, i = 1 .. 3)); Norm(V || 3-V || 1, 2); is(Norm(V || 3-V || 1, 2) = Norm(V || 3-V || 2, 2)); is(Norm(V || 2-V || 1, 2) = Norm(V || 3-V || 2, 2));
Starting from 3 points of a base, then got 3 lines equations.
If having 3 lines equations of a cone surface, how to find the surface equation of a cone?
First 683 684 685 686 687 688 689 Last Page 685 of 2428
