In DifferentialGeometry package, let P be the output of Prolong applied to a Transformation.
How to extract each identity/equation from P?
Is there a way to convert P to an array of equations?
I am learning how to use dchange in Maple. I can do  something as dchange(x=t^2) OK, but I need to do dchange(x=t^n) where "n" is meant to be a parameter that I can later use subs on to set it to any number I want.  But I do not know how to tell Maple that "t" is the new variable and that "n" is meant to be used as constant or parameter.
As an example, this works
n:=2;
ode:=x^2*diff(z(x),x)=0;
PDEtools:-dchange({x=t^n},ode,{t})
But this does not work
n:='n';
PDEtools:-dchange({x=t^n},ode,{t});
subs(n=2,%)
It used "n" above as new variable. So the dependent variable which was z(x) became z(t,n).
So I need to tell Maple that "t" is the new variable only and not "n" as well.
Is it possible to do this in Maple?
Maple 2019 on windows.
I compute a double integral, and I would like to change the order of integration ( of course we take into account the domain of integration, that must be changed), but unfortunately I have two different values instead the same value.
order_integration.mw
Note that I the code if I put t_0=0, I get the same value. Bur for other values of t_0, i havent the same value.
Many thanks for your help
Maple gives me the incorrect answer to the hundredth place. (arithmetic.mw)
>15000*(1+.06/365)^(10*365)
>                        27330.47804
I tried using an exact fraction 15000*(1+(6/100)/365)^(10*365) as well.
How can I draw together the function f(x,y)=(x.y^2)+1 and its tangent plane at the point (2,1,f(1,2)) in each of the following rectangles?
(Note that the equation of the tangent plane at the given point is z=x+4y-3)
a. 2<=x<=3 and 1<=y<=3
b. 2<=x<=2.1 and 1<=y<=1.2
c. 2<=x<=2.01 and 1<=y<=1.02
I can  this equation.
CV.mw
restart; c__v := 1.2; `&tau;__q` := 8.5*10^(-12); `&tau;__T` := 90.0*10^(-12); rho := 1000; k := 10
1.2
0.8500000000e-11
0.9000000000e-10
k*(diff(T(x, t), x, x))+k*`&tau;__T`*(diff(T(x, t), t, x, x)) = rho*c__v*(diff(T(x, t), t))+(diff(T(x, t), t, t))*c__v*rho*`&tau;__q`+(1/2)*c__v*rho*`&tau;__q`^2*(diff(T(x, t), t, t, t))
10*(diff(diff(T(x, t), x), x))+0.9000000000e-9*(diff(diff(diff(T(x, t), t), x), x)) = 1200.0*(diff(T(x, t), t))+0.1020000000e-7*(diff(diff(T(x, t), t), t))+0.4335000000e-19*(diff(diff(diff(T(x, t), t), t), t))
Boundary condition:
T(0, t) = 300; T(10, t) = 300
INITIAL CONDITIONS:
T(x, 0) = 300; (D[1](T))(x, 0) = 0, (D[2](T))(x, 0) = 0
Download CV.mw
Greetings everybody!
I am facing a strange problem. Dissolve/numeric seems to provide a solution and gives no error. However, when I try to plot the solution, Maple gives an error. Please guide me how to get rid of this error and how to plot the graph?
Please see the attatched file.
Thanking in anticipation.
fracmprime.mw
with(Groebner);
Jugdement := proc (F, P)
local f, N1, N2, i, j, k, q, LTF, LTPj;
N1 := nops(F); N2 := numelems(P);
for i to N1 do
LTF := LeadingTerm(F, plex(w, t, s, x, y, z));
for j to N2 do
LTPj := LeadingTerm(P[j], plex(w, t, s, x, y, z));
f := divide(LTF[2], LTPj[2], 'q');
if f = true then
k := j;
break
end if
if f = true then
break
if f = false then
F := F-LTF[1]*LTF[2]
end if
return k, f, q, P[k], LTF[1]
F := x^2+y^2+z^2;
                             2    2    2
                       F := x  + y  + z
P := {z, x*z, y*x};
                       P := {z, x z, y x}
Jugdement(F, P);
Error, (in Jugdement) illegal use of a formal parameter
I want to know what is the problem?
i) D(X,Y) , D(X,Z) ,D(Y,Z) COVARİANT DERİVATİVE ?
İİ) [X,Y] LİE OPERATOR ?
İİİ) R(X,Y)Z = D DZ - DDZ - D[X,Y] Z
How to improve menu speed in Maple 2016?
I am using Maple 2016, when I right click the equation, it really takes a long time to show the menu. It seems that the CPU usage and Memory usage is low, it should be fast as it is only a showing menu action, what's wrong with that?
The help page TimeSeriesAnalysis, ExponentialSmoothingModel contains an error.
The command that generates the output (7) should be
esm2 := ExponentialSmoothingModel(seasonal={"A","M"},constraints=admissible)
instead of
esm2 := ExponentialSmoothingModel(seasonal={A,M},constraints=admissible)
PS : there is no tag relative to TimeSeriesAnalysys
Hello! How would I do the following question using the maple program? I am not sure about the syntax. Thank you!
Express (cos^6)*t in terms of cosines and sines of multiples of t for
(cos^6)*t = a*cos(6*t) + b*cos(4*t) + c*cos(2*t) + 5/16
Where a = ?, b = ?, and c = ?
  As we  known, in Graphtheory , a loop is an edge that joins a vertex to itself (for example  fig1 vertex1) and multiple edges (for example Fig2)are two or more edges that join the same two vertices.  But in Maple,  G := Graph({{a, b}, {a, c}, {b, c}}). The Edges(G) function returns a set  (not list )of the edges of G.  So, for example I can't create loop{1,1} by G:=Graph({{1,1},{1,2},{1,5},{2,5},{2,3},{5,4},{3,4},{4,6}})   . But in my research, I consider a graph which exist loops or multiple edges. I want to create  it  .How should I do?  Thanks in advance.
my code like this
with(GraphTheory):
G:=Graph({{1,2},{1,5},{2,5},{2,3},{5,4},{3,4},{4,6}}):
G:=Graph({{1,1},{1,2},{1,5},{2,5},{2,3},{5,4},{3,4},{4,6}}):DrawGraph(G,style=spring);
G2:=Graph({{1,2}}):
DrawGraph(G2);
G3:=Graph({{1,2},{1,2}}):
DrawGraph(G3);
This may be a stupid question, but I am having elementary trouble with pdsolve.
I have the following pde system:
PDE:=[diff(f(x,xp),x)=-(1/2)*(L*xp+2*x)*kl,diff(f(x,xp),xp)=-(1/4)*kl*L*(L*xp+2*x)];
Trying to solve it:
pdsolve(PDE)
I get this error message:
Error, (in pdsolve/sys) too many arguments; some or all of the following are wrong: [{f(x, xp)}, handlenonrationalfunctionsofdependentvariables = false]
I don't understand any of this; can someone enlighten me?
TIA
M.D.
pde.mw
how can I solve triple integral below in maple, thanks
First 700 701 702 703 704 705 706 Last Page 702 of 2428
