hi
i have an ode with its BCs,i defined those and tried to solve but it seems has problem,would you please see my code ?
plz see attached filesasa3.mw
Right now I am going through Bishop's ML book and as a part of the first exercise I need to define a polynomial that goes like this.
y(x,w) = w_0 + w_1 * x + w_2 * x^2 ... + w_m * x^m = sum (k=0 to m) w_k * x^k
Here is how I've written it out in Maple.
f := proc (x, w) options operator, arrow; sum(w[k]*x^k, k = 0 .. nops(w)) end proc
Sorry for the raw code, Maple Math won't accept the code I've written as a valid Maple expression for some reason. When I try to use this I get an error that says too many levels of recursion.
f(2, [a, b, c]);
Error, (in limit/mrv/limsimpl) too many levels of recursion
Where am I going wrong here?
I found that numerical integration of maple is a bit slow in many cases. Is there any external library for integration in maple. Please write how to use it as well. Thank you.
The following worksheet was run from my desktop and finds both currentdir() and interface(worksheetdir) to be "C:\Users\dharr\Desktop" (either from opening it within Maple 2017 or double-clicking on it). The startup code is
DocumentTools:-SetProperty("TextArea0",value,currentdir());
DocumentTools:-SetProperty("TextArea1",value,interface(worksheetdir));
But if I load it from Maple Player 2018, then both currentdir() and interface(worksheetdir) are "c:\program files\maple player".
It means an interactive application that runs in Maple won't run in Maple Player.
Is this a bug or deliberate strategy to make it harder to open datafiles within Maple Player?
(Can't load the worksheet contents right now)
Download Test.mw
I'm really after a simple workaround for a file open dialog with embedded components - any suggestions?
how can i construct this reccursive serie without loops or command proc :
for any n greater or equal 0 :u(n+1)=sin(u(n)) with u(0)=1.5
Please look at this codes!!!
i cant understand the idea of how maple works with parameters...
if u watch it exactly u can see that first maple understands that diff(a__1,t) is equall 1; but anfter that it couldnt load the value 1.
why?
what is hapening?
what can i do for this problem. its not the main code. i just send u an example of what  i want and what maple does. plz help me. tnx
i have a diff equation(in photo last one)ehich code coulde solve it?
Earlier smoothly working generation of normal distribution in v. 2019 unexpectedly shows the error:
RandV  := Statistics[RandomVariable](Normal(0, 1));
Statistics[Sample](RandV, 10);
Error, (in p) unable to convert Float(undefined) to an integer
When multiple request to DocumentTools:-Tabulate(...) are enclosed in the same group of commands (which typically happens when they are within a procedure), only the last one is displayed.
Is it possible to overcome this behaviour?
Hello, everyone: I have a question of drawing graph。
with(GraphTheory):
with(SpecialGraphs):
H := HypercubeGraph(3):
DrawGraph(H,
style = spring);
How  do I change  the vertex style   to polygon without line.
the aim graph  like figure below:
Thank you very much!
Greeting for all
 , How to plot gyroid surface by Maple where its equation is
Amr
How do I solve boundary layer equations with hmp (homotopy perturbation method) in Maple?
I can't understand how to solve. Can anybody help me please?
I have the following ODE perturbation problem which I want maple to solve for me:
q'(\tau)=f(p(eps*\tau)+eps*q(\tau),r(eps*\tau)+s(\tau))-f(p(eps*\tau,r(eps*\tau)+s(\tau))-f(p(eps*\tau),r(eps*\tau))
where q(\tau)=q_0(\tau)+eps*q_1(\tau)
p(eps*\tau)=p_0(eps*\tau)+eps*p_1(eps*\tau)
s(\tau)=s_0(\tau)+eps*s_1(\tau)
r(eps*\tau)=r_0(eps*\tau)+eps*r_1(eps*\tau)
I want maple to expand every function that depends on eps in its arguments by a Taylor series around eps=0, i.e h(eps)=h(0)+eps*h'(0)
and also expand the difference above the fs with an eps-expansion around eps=0.
I did all this manually now I want to check if my calculations are correct, eventaully I want to equate same powers of eps of the RHS and LHS of the first ODE I wrote above.
Then how to use maple for this?
Thnaks.
While using the RKF45 in MAPLE to solve ODE w.r.t. time, analysis results came out without any information regarding a total number of iterations or a total number of time steps used in the actual analysis.
I would like to know how can this information be checked in the MAPLE.
Thank you very much.
Does there exist a Maple command that on its own calculates the residual standard error of two regression lists?
First 702 703 704 705 706 707 708 Last Page 704 of 2428
