Hello everyone!
Does anyone know if it is possible define a metric like the metric below?
Thanks in advance!
I would like to understand why the 'solve' command is unable to find any solution to the system of equation { x^2=2, x^3=2*sqrt(2) }  (which obviously has a unique solution x=sqrt(2) ). The syntax that I used is
> solve({x^2 = 2, x^3 = sqrt(2)^3}, [x]);
and the output is the empty list.
I suspect that this is related to the presence of the algebraic number sqrt(2). Does anyone have a better understanding ?
I am using Maple version 2018.0, build ID 1298750.
hi
how can i write the tittle on the plot exampe below pic
inequal({sqrt((1/2)*x) < y and sqrt(Pi/(2*x)) < y and y < sqrt(x) and y < sqrt(Pi/x)}, x = 1 .. 3, y = 0 .. 2);
I discovered incidentally that the command  Matrix(3, 3, `-`) (the number 3 is purely illustrative) returned the same result than the command Matrix(3, 3, (i,j) -> i-j).
In the same way `+` realizes (i,j) -> i+j), `*` realizes (i,j) -> i*j), ...
More surprisingly `.` realizes (i,j) -> i*j while I'm in worksheet mode, with "old" maple input style, and that the command 2.3 does not answer 6 but concatenates 2 and 3.
Is this a known behaviour or an undocumented feature?
I bassically have one problem with an integral of the type:
int(diff(f(s), s), s = l .. s)
and I want to change the integration variable. I've founded the IntegrationTools:-Change command, but it simply does not work.
Change(int(diff(f(s), s), s = l .. s), s = S*l, S)
givin the error:
Error, (in IntegrationTools:-Change) unable to determine new range for S
Any help is deeply appreciated.
I have noticed a few times now with Maple 2019. It looses kernel connection when it is sitting there idly. This time I observed it. Had saved a document after an intensive calculation. The memory used was about 30Gig. shortly after saving the cpu fan was running hard. I checked task manager and cpu was cycling to 100%, it was mserever. Then the memory usage droped to about 6gig and message as shown. During this time Maple screen down in the LH corner displayed "Ready", so it didn't think it was doing anything.
I am encountering problems solving a system of differential equations.
In the attached file, on the first try the boundary conditions are defined in H: = He, resulting in "Error, (in DEtools / convertsys) unable to compute coeff". On the second try, the boundary conditions are defined in H: = He + 0.00000000000000001 and this works.
What is the possible cause of the problem?
problem.mw
I am attempting to check solutions to a system of ODEs using odetest. However, odetest only appears to partially substitute the provided solution. Furthermore, it appears to be related to the alphabetical order of the functions.
For instance, here I have two functions, phiL and phiM, that satisfy Laplace's equation and are coupled through the boundary conditions, BCs.
laplace := {-phiL(z) + diff(phiL(z),z$2)=0, -phiM(z) + diff(phiM(z),z$2)=0}:
BCs := {phiL(d1)=0,phiM(-d1)=0,phiL(0)=phiM(0), D(phiL)(0)-D(phiM)(0)=-n}:
sol := {
phiM(z) = n/2/coth(d1)*(cosh(z)+coth(d1)*sinh(z)),
phiL(z) = n/2/coth(d1)*(cosh(z)-coth(d1)*sinh(z))
odetest(sol, laplace union BCs,{phiL(z),phiM(z)});
This returns
{0, 1/2*(2*phiL(0)*coth(d1)-n)/coth(d1), D(phiM)(0)-1/2*n}
Here, phiL(0) and phiM(0) are unevaluated even though the provided solutions are valid there.
Furthermore, while renaming phiL to an alphabetically earlier name (eg, phiJ) causes the corresponding change in the output. However, renaming it to something alphabetically after phiM (eg, phiN) causes the terms in the output to switch. That is, changing phiL to phiN in the above code results in
{0, 1/2*(2*phiM(0)*coth(d1)-n)/coth(d1), D(phiN)(0)+1/2*n}
Therefore, it seems to be related to the way Maple internally stores the list of variables.
Is this a bug? Or is there something I'm missing?
My code below works but I an looking to speed it up to apply to large arrays. I have large integers and I want to store the exponent and first and last few digits.
nelems := 10;  ~ takes about 50mins when n=100,000,000
n := 374894756873546859847556;
op(n);
A := Array(1 .. 4, 1 .. nelems);
length(n);
st := time();
for i to nelems do
    A[1, i] := i^10*n;
    A[2, i] := length(A[1, i]) - 1;
    b := convert(A[1, i], string);
    A[3, i] := parse(b[1 .. 3]);
    A[4, i] := parse(b[-3 .. -1]);
time() - st;
A;
A[1, -2];
A[2, -2];
A[3, -2];
A[4, -2];
I am trying to implement a Squarefree Factorization Algo in Maple.
For several algorithms (like the one in Victor Shoup- A computational Introduction to Number Theory and Algebra) one is in need of computing the pth root (F_q is the finite field with q=p^k) of a polynomial. I tried stuff like pol^(1/p), root[p](pol), proot(pol,p), but either I get NOROOT as output or just the polynomial with the exponent 1/p, like e.g.
(x^6+(2*tau+1)*x^3+2)^(1/3)
(tau my RootOf for the field extension, F_q with q=3^2)
But that doesnt help me, because I will need a polynomial without any exponent so that i can get the derivate pol'=dpol/dx, and that doenst work if there is any exponent...
cTest := `mod`(root[p](c), p);
cStrich := `mod`(diff(cTest, x), p);
          Error, the modular inverse does not exist
Does anybody know how I can calculate the pth root of a polynomial? (At the moment I am following the Algo that is mentioned on wiki for Squarefree Factorization...)
Or, does anybody know a better Algo for a squarefree Factorization?
Thanks for any help and any answers!
In dark matter cosmology the following integral in x  does not yet have an analytical solution. I report the integral in
Maple 2018 notation
int(1/sqrt((1+x)^3*a+(1-a)*(1+x)^(3+3*b)), x)
If someone has some smart idea is welcome
Dear Community,
I run a MapleSim model from Maple. The simulation runs fine giving me the correct graphical plots, but I wonder how could I obtain also the numerical values of the probes vs. time? Sorry I could not figure it out. A matrix format would be perfect: 1st column time, the other columns probe 1 .. n values vs. time. (Files attached)
Tx for the kind help in advance,
best regards
Andras
RunMapleSim.mw , RCNetwork.msim
with(Physics)
Setup(Coordinatesystem = (X = [x1, x2, x3, x4]), metric = -dx3^2*u22+2*dx3*dx4*u12-dx4^2*u11+dx1*dx3+dx2*dx4)
`* Partial match of  'Coordinatesystem' against keyword 'coordinatesystems'`
`Default differentiation variables for d_, D_ and dAlembertian are: `*{X = (x1, x2, x3, x4)}
`Systems of spacetime Coordinates are: `*{X = (x1, x2, x3, x4)}
[coordinatesystems = {X}, metric = {(1, 3) = 1/2, (2, 4) = 1/2, (3, 3) = -(diff(diff(u(X), x2), x2)), (3, 4) = Physics:-diff(diff(u(X), x1), x2), (4, 4) = -(diff(diff(u(X), x1), x1))}]
Setup(spacetimeindices = lowercaselatin)
u22 := diff(u(x1, x2, x3, x4), x2, x2)
Physics:-diff(Physics:-diff(u(X), x2), x2)
u12 := diff(u(x1, x2, x3, x4), x1, x2)
Physics:-diff(Physics:-diff(u(X), x1), x2)
u11 := diff(u(x1, x2, x3, x4), x1, x1)
Physics:-diff(Physics:-diff(u(X), x1), x1)
u24 := diff(u(x1, x2, x3, x4), x2, x4)
Physics:-diff(Physics:-diff(u(X), x2), x4)
u13 := diff(u(x1, x2, x3, x4), x1, x3)
Physics:-diff(Physics:-diff(u(X), x1), x3)
g_[]
Physics:-g_[a, b] = Matrix(%id = 18446745064427858870)
Define(W, quiet)
"W[~i,j,k,l]=1/(2)sqrt('g_[determinant]')g_[~i,~a]g_[~b,~c]LeviCivita[a,j,b,d]Weyl[~d,c,k,l]"
W[`~i`, j, k, l] = (1/2)*Physics:-g_[determinant]^(1/2)*Physics:-g_[`~a`, `~i`]*Physics:-g_[`~b`, `~c`]*Physics:-LeviCivita[a, b, d, j]*Physics:-Weyl[`~d`, c, k, l]
Define(W[`~i`, j, k, l] = (1/2)*Physics[g_][determinant]^(1/2)*Physics[g_][`~a`, `~i`]*Physics[g_][`~b`, `~c`]*Physics[LeviCivita][a, b, d, j]*Physics[Weyl][`~d`, c, k, l])
`Defined objects with tensor properties`
{Physics:-D_[a], Physics:-Dgamma[a], Physics:-Psigma[a], Physics:-Ricci[a, b], Physics:-Riemann[a, b, c, d], W[`~i`, j, k, l], Physics:-Weyl[a, b, c, d], Physics:-d_[a], Physics:-g_[a, b], Physics:-Christoffel[a, b, c], Physics:-Einstein[a, b], Physics:-KroneckerDelta[a, b], Physics:-LeviCivita[a, b, c, d], Physics:-SpaceTimeVector[a](X)}
W[definition]
W[`~e`, f, g, h] = (1/32)*16^(1/2)*Physics:-g_[`~a`, `~e`]*Physics:-g_[`~b`, `~c`]*Physics:-LeviCivita[a, b, d, f]*Physics:-Weyl[`~d`, c, g, h]
u11*u22-u12^2+u13+u24 = 0
diff(diff(u(X), x1), x3)+diff(diff(u(X), x2), x4)+(diff(diff(u(X), x2), x2))*(diff(diff(u(X), x1), x1))-(diff(diff(u(X), x1), x2))^2 = 0
u113 := diff(-u11*u22+u12^2-u24, x1)
-(diff(diff(diff(u(X), x1), x2), x4))-(diff(diff(u(X), x1), x1))*(diff(diff(diff(u(X), x1), x2), x2))-(diff(diff(u(X), x2), x2))*(diff(diff(diff(u(X), x1), x1), x1))+2*(diff(diff(u(X), x1), x2))*(diff(diff(diff(u(X), x1), x1), x2))
u123 := diff(-u11*u22+u12^2-u24, x2)
-(diff(diff(diff(u(X), x2), x2), x4))-(diff(diff(u(X), x1), x1))*(diff(diff(diff(u(X), x2), x2), x2))-(diff(diff(u(X), x2), x2))*(diff(diff(diff(u(X), x1), x1), x2))+2*(diff(diff(u(X), x1), x2))*(diff(diff(diff(u(X), x1), x2), x2))
u133 := diff(-u11*u22+u12^2-u24, x3)
-(diff(diff(diff(u(X), x2), x3), x4))-(diff(diff(diff(u(X), x2), x2), x3))*(diff(diff(u(X), x1), x1))-(diff(diff(u(X), x2), x2))*(diff(diff(diff(u(X), x1), x1), x3))+2*(diff(diff(u(X), x1), x2))*(diff(diff(diff(u(X), x1), x2), x3))
(14)
u134 := diff(-u11*u22+u12^2-u24, x4)
-(diff(diff(diff(u(X), x2), x4), x4))-(diff(diff(diff(u(X), x2), x2), x4))*(diff(diff(u(X), x1), x1))-(diff(diff(u(X), x2), x2))*(diff(diff(diff(u(X), x1), x1), x4))+2*(diff(diff(u(X), x1), x2))*(diff(diff(diff(u(X), x1), x2), x4))
(15)
u234 := diff(u(x1, x2, x3, x4), x2, x3, x4)
Physics:-diff(Physics:-diff(Physics:-diff(u(X), x2), x3), x4)
(16)
u223 := diff(u(x1, x2, x3, x4), x2, x2, x3)
Physics:-diff(Physics:-diff(Physics:-diff(u(X), x2), x2), x3)
(17)
u133 = -u11*u223-u113*u22+2*u12*u123-u234
-(diff(diff(diff(u(X), x2), x3), x4))-(diff(diff(diff(u(X), x2), x2), x3))*(diff(diff(u(X), x1), x1))-(diff(diff(u(X), x2), x2))*(diff(diff(diff(u(X), x1), x1), x3))+2*(diff(diff(u(X), x1), x2))*(diff(diff(diff(u(X), x1), x2), x3)) = -(diff(diff(diff(u(X), x2), x3), x4))-(-(diff(diff(diff(u(X), x1), x2), x4))-(diff(diff(u(X), x1), x1))*(diff(diff(diff(u(X), x1), x2), x2))-(diff(diff(u(X), x2), x2))*(diff(diff(diff(u(X), x1), x1), x1))+2*(diff(diff(u(X), x1), x2))*(diff(diff(diff(u(X), x1), x1), x2)))*(diff(diff(u(X), x2), x2))-(diff(diff(diff(u(X), x2), x2), x3))*(diff(diff(u(X), x1), x1))+2*(diff(diff(u(X), x1), x2))*(-(diff(diff(diff(u(X), x2), x2), x4))-(diff(diff(u(X), x1), x1))*(diff(diff(diff(u(X), x2), x2), x2))-(diff(diff(u(X), x2), x2))*(diff(diff(diff(u(X), x1), x1), x2))+2*(diff(diff(u(X), x1), x2))*(diff(diff(diff(u(X), x1), x2), x2)))
(18)
Weyl[`~i`, j, k, l, nonzero]+W[`~i`, j, k, l, nonzero]
Weyl[`~i`, j, k, l, nonzero]-W[`~i`, j, k, l, nonzero]
(19)
`in`(half*flat*metrics, 4*D)
I require one of these Weyl + W or Weyl - W (where W is Weyl tensor with hodge star operator, the equation may be found in my code) to be identically equal to zero. The computer will not recognise that it is identally equal unless i input the original p.d.e which I have, and I have also added some partial differentials up to the third order, maybe I need to include up to the fourth order? I am unsure what to add can someone please help me make this identically equal to zero! Thanks in advance for any help!
(I have put colon's after the equations Weyl+W and Weyl-W as the output was too long, but rest assured its not looking identically equal to zero!)
Download NEED_11.mw
ddesys := {diff(pred(t), t) = pred(t)*[prey(t)/(prey(t)+10)-2/3], diff(prey(t), t) = prey(t)*[2-(1/20)*prey(t-tau)]-prey(t)*[pred(t)/(prey(t)+10)]-10, pred(0) = 1, prey(0) = 1};
dsn := dsolve[eval(ddesys, tau = 0)];
plots[odeplot](dsn, [[t, prey(t), color = red], [t, pred(t), color = blue]], 0 .. 300, legend = [prey, pred], labels = [t, ""]);
I do not understand what i mistake, please help me regarding this issue, thanks in advance
This is a question out of curiosity only ...
I can easily import a matrix from an Excel spreadsheet / source. Maple then displays matrix dimensions, data type, storage and order ... which is fine. Now - suppose I wished to import the standard matrix in question, with all entries displayed - can this be done?
First 708 709 710 711 712 713 714 Last Page 710 of 2428
