I unprotect the GAMMA, but still receives error:
Error, attempting to assign to `GAMMA` which is protected.  Try declaring `local GAMMA`; see ?protect for details.
II := 2
JJ := 2
N := 2:
unprotect(GAMMA):
q := max(II+1, JJ+1):
M := 5:
seq(seq(seq(assign(GAMMA[i, j, r], a*`#mover(mi("Γ",fontstyle = "normal"),mo("&uminus0;"))`[i, j, r]), i = 0 .. q), j = 0 .. q), r = 1 .. N):
a := .2:
RrProc := proc (i, m) local K, j, Q; if i <= m then 0 else K := 1; Q := Matrix(i, 1); for j by 2 to i do Q(j) := 2*i-K; K := 4+K end do; Q := FlipDimension(Q, 1); Q(m+1) end if end proc:
`#mover(mi("&Gamma;",fontstyle = "normal"),mo("&uminus0;"))` := Array(0 .. II, 0 .. JJ, 1 .. 6, 1 .. M):
f1 := RandomArray(II+1, JJ+1):
for m to M do `&Gamma;m`[1, m] := f1; `&Gamma;m`[2, m] := f2; `&Gamma;m`[3, m] := f3; `&Gamma;m`[4, m] := f4; `&Gamma;m`[5, m] := f5; `&Gamma;m`[6, m] := f6 end do:
unprotect(`#mover(mi("&Gamma;",fontstyle = "normal"),mo("&uminus0;"))`):
for m to M do `#mover(mi("&Gamma;",fontstyle = "normal"),mo("&uminus0;"))`[0 .. II, 0 .. JJ, 1, m] := ArrayTools:-Alias(`&Gamma;m`[1, m], [0 .. II, 0 .. JJ]); `#mover(mi("&Gamma;",fontstyle = "normal"),mo("&uminus0;"))`[0 .. II, 0 .. JJ, 2, m] := ArrayTools:-Alias(`&Gamma;m`[2, m], [0 .. II, 0 .. JJ]); `#mover(mi("&Gamma;",fontstyle = "normal"),mo("&uminus0;"))`[0 .. II, 0 .. JJ, 3, m] := ArrayTools:-Alias(`&Gamma;m`[3, m], [0 .. II, 0 .. JJ]); `#mover(mi("&Gamma;",fontstyle = "normal"),mo("&uminus0;"))`[0 .. II, 0 .. JJ, 4, m] := ArrayTools:-Alias(`&Gamma;m`[4, m], [0 .. II, 0 .. JJ]); `#mover(mi("&Gamma;",fontstyle = "normal"),mo("&uminus0;"))`[0 .. II, 0 .. JJ, 5, m] := ArrayTools:-Alias(`&Gamma;m`[5, m], [0 .. II, 0 .. JJ]); `#mover(mi("&Gamma;",fontstyle = "normal"),mo("&uminus0;"))`[0 .. II, 0 .. JJ, 6, m] := ArrayTools:-Alias(`&Gamma;m`[6, m], [0 .. II, 0 .. JJ]) end do:
UP := proc (s, GAMMA, N, M, a, b, II, JJ) local k; i, j, r, p, m, q, n, l; if s = 1 then add(add(add(add(add(add((2/3)*Rr[i, m]*Rr[k, m]*b*add(GAMMA[i, j, q, p]*GAMMA[k, j, q, r]*tau[p](t)*tau[r](t), q = 1 .. N)/((2*m+1)*(2*j+1)*a), i = 0 .. II), k = 0 .. II), m = 0 .. II), j = 0 .. JJ), p = 1 .. M), r = 1 .. M) elif s = 2 then add(add(add(add(add(add((1/2)*Rr[i, m]*Rr[k, m]*b*add(GAMMA[i, j, q, p]*GAMMA[k, j, q, r]*tau[p](t)*tau[r](t), q = 1 .. N)/((2*m+1)*(2*j+1)*a), i = 0 .. II), k = 0 .. II), m = 0 .. II), j = 0 .. JJ), p = 1 .. M), r = 1 .. M) end if end proc:
Grid:-Seq(UP(s, GAMMA, N, M, a, b, II, JJ), s = 1 .. 2)
UP(1, GAMMA, N, M, a, b, II, JJ), UP(2, GAMMA, N, M, a, b, II, JJ)
Download soal.mw
What is the problem?
Hi, I'm investigating an equation of motion, and I'm attempting to plot t against different values of thetabn. I have acquired a list of my data points (in the real domain) of the form [thetabn1, t1], [thetabn2, t2] ... etc. But I am struggling to figure out how to plot it. Using dataplot gives me a graph but it is incorrect. I would like a scatterplot, ideally once I have refined my range of thetabn I would like to be able to join it up with a line to create a nice looking plot. Also any improvements to my method would be appreciated. v[i], thetavn and omegac are set variables and s[n] is my function which I am setting equal to zero, and solving for t.
with(RealDomain);
v[i] := 145000;
thetavn := (1/6)*Pi;
omegac := .1;
s[n] := v[i]*cos(thetavn)*(cos(2*thetabn)*tan(thetabn)+sin(2*thetabn)*sin(omegac*t)/omegac);
for thetabn from evalf((1/100)*Pi) by evalf((1/100)*Pi) to evalf(Pi) do assign('result', [op(result), [thetabn, solve(v[i]*cos(thetavn)*(cos(2*thetabn)*tan(thetabn)+sin(2*thetabn)*sin(omegac*t)/omegac) = 0, t)]]) end do;
dataplot(result);
Hello, I need to figure out what theta is through this matrix:
https://imgur.com/RldbcJD
Should I use a solve command for this?
MY worksheet have more than 100 parameters, now I want to use all of the parameters within a procedure, is there any easy way to introduce all these paramaters to proc without mentioning them in parentheses one by one proc(x,y,z,...)?
hello everyone,
I am trying to optimize expressions symbolically. I need to find out the maximum value possible for an variable, so that the expressoin still have a valid solution.
For Example:
expr:=a-b/b-a^3;  # a=(0,10), b=(0,10)
In this eypression b=a^3 is the only case where undefined solution is possible, for a given interval of variables
This looks fine for simple expression. But in reality there are complex equations to solve with more than 2 varibles.
1) first thing is to find out all values of a variable resulting in undeifined output(or infinite)
2) assign a symbolic value(variable < or > some value) to the variable so that the undefined result can be eliminated.
 I need to optimize the given expression so that it does not have any undefined cases when solving. I understood that when optimizing, there always be a condition on variables(in this case variable max is the condition, maximum value the variable can take). output of an expression is always a real value
OptimizedExpr:=a-b[max]/b[max]-a^3 --> b[max]>a^3 or b[max]<a^3
(it is easy to to say b[max] is not equal to a^3 , also a^3 is the limiting value. In some case it is more resonable to just ignore other part of limiting value. Hence, I would like to optimize using greaterthan or lessthan of limiting value).
I would be very glad to know how I can find Optimized expressions. I tried using the solve function but observed that expressions are equalled to zero and solving. which is completely opposite to what I was looking. I really do not know is there any way to find out undefined cases in expressions and on what varibale at what values.
I tried to explain the situation at my best and I welcome for any suggested edits or furthur information required.
how I can determied  this integral in figure below or compute area in figure which adressed in the following website?
https://en.m.wikipedia.org/wiki/Spherical_cap
Hello everyone !
 when I use  the command   ''G1:=NonIsomorphicGraphs(5, output = graphs, outputform = adjacency)''  , I want to compute the   rank of   adjacent  matrices of
every graph in  G1,. I try to do , but maple  retutn false:
Rank(G1);
Error, invalid input: too many and/or wrong type of arguments passed to LinearAlgebra:-Rank; first unused argument is Matrix(5, 5, {(1, 1) = 0, (1, 2) = 1, (1, 3) = 1, (1, 4) = 1, (1, 5) = 1, (2, 2) = 0, (2, 3) = 1, (2, 4) = 1, (2, 5) = 1, (3, 3) = 0, (3, 4) = 1, (3, 5) = 1, (4, 4) = 0, (4, 5) = 1, (5, 5) = 0}, datatype = integer[1], storage = triangular[upper], shape = [symmetric])
  How to achieve it , I do not konw to  invoke these adjacent matrices . Would someboby
give me a hand.
Thanks very much!
how I can write taylor function for following example.
I want to gain an answer similar to the image result by using taylor function.
tylor.mw
P27 := f(x+fNx/`&Delta;x`, y+(`&Delta;y`-fNy)/`&Delta;y`, z+fNz/`&Delta;z`)
f(x+fNy/`&Delta;x`, y+(`&Delta;y`-fNy)/`&Delta;y`, z+fNz/`&Delta;z`)
with(MultiSeries)
taylor(P27, x = 0)
series(f(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`)+(D[1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`)*x+((1/2)*(D[1, 1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`))*x^2+((1/6)*(D[1, 1, 1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`))*x^3+((1/24)*(D[1, 1, 1, 1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`))*x^4+((1/120)*(D[1, 1, 1, 1, 1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`))*x^5+O(x^6),x,6)
Download tylor.mw
I am trying the following command:
restart; with(IntegrationTools):
simplify(int(f(x), x = 0 .. L*Ts)-Split(int(f(x), x = 0 .. L*Ts), [i*Ts, i = 0 .. L]))
Clearly the output should be 0. However, maple is not able to output the correct result. Any ideas?
I have 26 equations  and 26 variables and I want to solve them numerically. fsolve function returns whole equations as a solution.
Any advice ?
What command in Maple runs specific worksheets within other worksheet?
Actually I want to know how is it possible to comminucate and control multiple worksheets within one specific worksheet?
I want to store the matrix m2 representing a system m2*x=b with vectors as given by the command "CompressedSparseForm" and solve the system using those vectors and b without using m2 and b.
vectors.mw
restart; with(LinearAlgebra)
m2 := Matrix([[102, 0, 0, .1, 1], [0, 3, 0, 0, 1], [1, 3.1, 7, 0, 0], [1, 33, 0, .5, 0], [1, 0, 0, 0, 1]], 'datatype = float')
Matrix([[102., 0., 0., .100000000000000, 1.], [0., 3., 0., 0., 1.], [1., 3.10000000000000, 7., 0., 0.], [1., 33., 0., .500000000000000, 0.], [1., 0., 0., 0., 1.]])
cm, rm, values := CompressedSparseForm(m2)
Vector(6, {(1) = 1, (2) = 5, (3) = 8, (4) = 9, (5) = 11, (6) = 14}, datatype = integer[8]), Vector(4, {(1) = ` 1 .. 13 `*Vector[column], (2) = `Data Type: `*integer[8], (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order}), Vector(4, {(1) = ` 1 .. 13 `*Vector[column], (2) = `Data Type: `*float[8], (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
b := `<,>`(1.1, 2, 5, .5, 5)
Vector(5, {(1) = 1.1, (2) = 2, (3) = 5, (4) = .5, (5) = 5})
LinearSolve(m2, b)
Vector(5, {(1) = -.107505070993915, (2) = -1.03583502366464, (3) = 1.18837052062204, (4) = 69.5801217038540, (5) = 5.10750507099392})
NULL b
Download vectors.mw
Digits := 15;
b := -I;
a := sqrt(2);
epsilon := 1;
f := proc (t) options operator, arrow; evalf(Int(exp(I*k*t)/((1+a^2*sin(k)^2)*(k-b)^epsilon), k = -infinity .. infinity)) end proc;
f(1.3)
I tried different methods like _d01amc, but either I have this error:
Error, (in evalf/int) NE_QUAD_NO_CONV:
  The integral is probably divergent or slowly convergent.
or it takes forever.
I also tried to map the interval to some finite length (k=tan(u)), but then I get
Error, (in evalf/int) NE_QUAD_BAD_SUBDIV:
  Extremely bad integrand behaviour occurs around the
  sub-interval (-1,5707963e+000, -1,5707963e+000 ).
disgusting integrand?
I hope to enter something like
5^(x-1)=5^x/5
And get "true". Mathematica and some other softwares do this but Maple returns my exact input (I'm new to Maple).
I tried using evalb and verify, but they all return false or FAIL. Is there a straightforward to verify equality and get a result of True or False in Maple?
Is there any way with integer programming function "LPSolve" to get all optimal solutions, because I know there is more than one, and in case if there is a lot of optimal solutions, how to show only the number of optimal solutions?
Thanks in advance!
First 746 747 748 749 750 751 752 Last Page 748 of 2428
