hi , I want to solve a problem of structural analysis (slope deflection) in maple but .... ?
convert(...,Int) in Maple 2018.2 works for fourier, invfourier, laplace, but does not work for invlaplace.
Why is that? Is there a workaround?
expr:=fourier(f(x), x, w):
convert(expr,Int);
expr:=invfourier(f(w), w, x):
convert(expr,Int);
expr:=laplace(f(s),s,t):
convert(expr,Int)
expr:=invlaplace(f(s),s,t):
convert(expr,Int)
Was expecting to see the Mellin's inverse formula.
Maple 2018.2 on windows 10
In the snip from Maple help: please expaln (a) the meaning, (b) how do I enter e1..-1,2 in the last statement?
Hi I am trying to solve the following system of equation. I could solve it for approximate value of s(0)=0.9999 using middefer method of bvp, but as soon as I give the b.c. as s(0)=1, Maple gives me an error that there is an numeric exception. Can someone explain it what is going wrong with s(0)=1? Any sugesstion to solve the equation?
error.mw
b := 1;
r := .1;
l := 3;
a := 10; p := 1.5; ds := 100; dk := 1;
sol3 := dsolve({ds*(diff(i(x), x)) = exp(eta(x)), s(x)^3*i(x)*b*r+(1-s(x))^3*a*l*(diff(s(x), x))/s(x)^1.5 = (1-s(x))^3, diff(eta(x), x) = dk*(i(x)-1)/s(x)^p, i(0) = 0, i(1) = 1, s(0) = 1}, {eta(x), i(x), s(x)}, approxsoln = [eta(x) = .5, i(x) = .5, s(x) = 1], initmesh = 100000, type = numeric, maxmesh = 100000, range = 0 .. 1, output = listprocedure, method = bvp[middefer], abserr = 0.1e-3, adaptive = true);
Error, (in dsolve/numeric/bvp) numeric exception: division by zero
plots[odeplot](sol3, [[x, s(x)]], 0 .. 1, color = ["Green"]);
Thanks and regards,
 write a programe for fractional calculus and it shows subscript error plzz help me with that
Using Latest Physics updates (I am not sure when this started), pdsolve gives Error, (in PDEtools/eval/2) numeric exception: division by zero on the following problem from a HW from text book.
PackageTools:-IsPackageInstalled("Physics Updates");
                             "220"
pde:=diff(w(x,t),t)+3*t*diff(w(x,t),x)=w(x,t);
ic:=w(x,0)=f(x);
sol:=pdsolve([pde,ic],w(x,t));
Mathematica answer btw is
pde = D[w[x, t], t] + 3 t D[w[x, t], x] == w[x, t];
ic = w[x, 0] == f[x];
sol = Simplify[DSolve[{pde, ic}, w[x, t], {x, t}]]
This is on Maple 2018.2 on windows 10 64 bit.
Any idea what is causing this and any workaround? Do others get the same exception?
hai,
greetings,
I require help to plot graphs by changing differernt parameters. i am enclosing my codes and sample codes,
 my_codes.mw
nanofluid_sample.mw
Thanks in advance.
Let us consider L be the following list of 6 lists of polynomials which all of their polynomials are linear combination of B=[x^2,x*y,z^2,1].
L:=[[a*x^2+b*x*y-1, -(a*b-b)*x*y/a-z^2+(a-1)/a, -a*c*z^2/(b*(a-1))+(b+c)/b], [a*x^2+b*x*y-1, -(a*b-b)*x*y/a-z^2+(a-1)/a, 1],
[a*x^2+b*x*y-1, -z^2+(a-1)/a, c*x*y+1], [b*x*y-1, -x^2-z^2, (b+c)/b], [-1, -x^2-z^2, c*x*y], [-1, -x^2-z^2]].
Now, I need the matrix coefficients of any member of L (please note that any matrix has 4 columns according to the list B) . Is there any command for this?
Thank you in advanced.
Ok so when a module is loaded, there is a .dll file that loads a list of symbols into maple.exe, what can be done if an error occurs for which the debugging output declares that the PDB file for the module could not be found?
I have read that the program database file stores debugging information related to the locating symbols, how can i fix this if my computer isn't finding theres files for a list of .dll it attempts to load into maple.exe, or is there a way for which i can make these files for each corresponding module?
u(vu)+ uvvuu - 2vvu = 0
using maple show that the ode has an eighth dimensional lie symmetry group
For some reason the Maple software is not evaluating the last bounds for a triple integral.
But the evalf command works.
I have Maple through the school where I teach math, and the IT-guy gave us Maple 2018.1 to install.
But after a while even though I have Maple 2018.1 installed on my computer Windows 10 pc, then Maple 2018.1 surgests that I upgrade to 2018.1?? Any idea why?
I could not find a command that splits a polynomial in parts based on leading integer coefficients, so I wrote a procedure. It works well, but I still wonder if there is no simpler way of doing this?
My aim is to investigate whether there is some way of factoring this and other polynomials.
kind regards,
Harry Garst
restart; with(ListTools); with(LinearAlgebra)
p := 2*x^3*y+2*x^3*z+4*x^2*y^2+24*x^2*y*z+4*x^2*z^2+2*x*y^3+24*x*y^2*z+24*x*y*z^2+2*x*z^3+2*y^3*z+4*y^2*z^2+2*y*z^3-40*x^2*y-40*x^2*z-40*x*y^2-40*x*z^2-40*y^2*z-40*y*z^2+108*x*y+108*x*z+108*y*z-9*x-9*y-9*z+36
p1 := 2*x^3*y+2*x^3*z+2*x*y^3+2*x*z^3+2*y^3*z+2*y*z^3
p2 := 24*x^2*y*z+24*x*y^2*z+24*x*y*z^2
p3 := 4*x^2*y^2+4*x^2*z^2+4*y^2*z^2
p4 := -40*x^2*y-40*x^2*z-40*x*y^2-40*x*z^2-40*y^2*z-40*y*z^2
p5 := 108*x*y+108*x*z+108*y*z
p6 := -9*x-9*y-9*z
-9*x-9*y-9*z
p7 := 36
36
simplify(p-p1-p2-p3-p4-p5-p6-p7)
Knip := proc (p) local g, h, i, j, N, X, Q; g := sort(ListTools:-MakeUnique([seq(lcoeff([op(p)][j]), j = 1 .. nops([op(p)]))])); h := 0; N := Matrix(nops([op(p)]), 1); X := Matrix(nops([op(g)]), 1); Q := convert([op(p)], Matrix); for j in g do h := h+1; N[h, 1] := convert([seq(ifelse(has(lcoeff([op(p)][i]), j), 1, 0), i = 1 .. nops([op(p)]))], Matrix); X[h, 1] := LinearAlgebra:-Trace(Q.N[h, 1]^%T) end do; return X end proc
proc (p) local g, h, i, j, N, X, Q; g := sort(ListTools:-MakeUnique([seq(lcoeff([op(p)][j]), j = 1 .. nops([op(p)]))])); h := 0; N := Matrix(nops([op(p)]), 1); X := Matrix(nops([op(g)]), 1); Q := convert([op(p)], Matrix); for j in g do h := h+1; N[h, 1] := convert([seq(ifelse(has(lcoeff([op(p)][i]), j), 1, 0), i = 1 .. nops([op(p)]))], Matrix); X[h, 1] := LinearAlgebra:-Trace(Typesetting:-delayDotProduct(Q, N[h, 1]^%T)) end do; return X end proc
Knip(p)
Matrix(%id = 18446747088530918086)
simplify(p-Trace(Matrix(1, 7, 1).Knip(p)))
Download knip.mw
Greeting!
I am a new user of Maple. I want to perform a simple (to me, it is very difficult) integration  defined as follows
range from 0 to omega (frequency). alpha^2F (omega) is constant function with set of values (already calculated) for the corresponding frequency. I have calculated the frequencies ranging from 54 to 900 cm-1. Suppose I have alpha^2F(omega)=0, 0.5,0.6,0.7......0.1 for omega=58, 80, 110, 190,.....800, how can I perform this integration  in Maple? Please help me how can I cope with this problem.
Thanks a lot.
Best Regards,
Trying Maple on a textbook problem to verify my hand solution.
But Maple pdsolve hangs with the mserver.exe tallomg almost 100% CPU and over 10 GB of RAM!
I waited for almost 20 minutes. Tried another time, same thing.
It is no problem if Maple can't solve this, but Maple seems to suffer from too many hangs when it is not able to solve a problem. I've had similar problems with dsolve also.
This is on windows 10, 64 bit with Maple 2018.2 With Physics updates version 218
218
interface(showassumed=0);
infolevel[pdsolve]:=2;
pde :=  diff(u(x,t),t)=k*diff(u(x,t),x$2)+Q(x,t);
ic  :=  u(x,0)=f(x);
bc  :=  eval(diff(u(x,t),x),x=0)=A(t),eval(diff(u(x,t),x),x=1)=B(t);
sol:=pdsolve({pde,ic,bc},u(x,t)) assuming t>0,k>0;
then
* trying method "_Fn" for 2nd order PDEs
   -> trying "linear_in_xt"
   -> trying "BC_equal_0"
* trying method "_Cn_cn" for 2nd order PDEs
Trying travelling wave solutions as power series in tanh ...
Trying travelling wave solutions as power series in ln ...
* trying method "Wave" for 2nd order PDEs
   -> trying "Cauchy"
   -> trying "SemiInfiniteDomain"
   -> trying "WithSourceTerm"
* trying method "Heat" for 2nd order PDEs
* trying method "Series" for 2nd order PDEs
   -> trying "ThreeBCsincos"
   -> trying "FourBC"
   -> trying "ThreeBC"
   -> trying "ThreeBCPeriodic"
And here is hangs. Notice that because both ends are Neumann, there is no unique solution to this problem.  So the solution will contain arbitrary constant. May be this is what made pdsolve hang?
No it is not. Trying with only one end nonhomogeneous  Neumann, and the other end Dirichlet, it still hangs. The problem seems to be with one end is nonhomogeneous  Neumann, which is a function of time. So this hangs also (same place)
ic  :=  u(x,0)=f(x);
bc  :=  eval(diff(u(x,t),x),x=0)=A(t),eval(diff(u(x,t),x),x=1)=0;
And this also
ic  :=  u(x,0)=f(x);
bc  :=  eval(diff(u(x,t),x),x=0)=sin(t),eval(diff(u(x,t),x),x=1)=0;
But this does not hang
ic  :=  u(x,0)=f(x);
bc  :=  eval(diff(u(x,t),x),x=0)=1,eval(u(x,t),x=1)=0;
The issue seems to be when one end is nonhomogeneous  Neumann which is function of time.
Is there a workaround so it does not hang? The complaint is that Maple hangs, and not that Maple unable to solve the PDE.
First 749 750 751 752 753 754 755 Last Page 751 of 2428
