This code used to work OK in an earlier version of Maple 2018. I do not know what changed and if it some change in Physics package that caused it.
pde:=diff(u(r,theta),r$2)+1/r*diff(u(r,theta),r)+1/r^2*diff(u(r,theta),theta$2)=0;
bc:=u(r,0)=0,u(r,Pi)=0,u(0,theta)=0,u(1,theta)=f(theta);
sol:=pdsolve([pde,bc],u(r,theta),HINT = boundedseries(r = 0));
Now it gives the error
Error, (in assuming) when calling 'assume'. Received: 'invalid arguments'
Workaround is to remove the HINT above. So the following now works
sol:=pdsolve([pde,bc],u(r,theta));
Should this error message show up when using the HINT option?
Maple 2018.2 with Physics package cloud version 205.
Here is screen shot showing it was working in Physics 170
How can I calculate the Euler-Lagrange equation from the Lagrangian density from Gauged Baby Skyrme model in maple using the physics package? Here, the rules of the operation in the inner space are the same that of the vectors conventional: dot and cross products, etc...
Following below the Lagrangian density.
Errata:
Hello everyone!
Can you help me with my problem?
How can I automatically paste parts of denominator from one equations to another? Now I must do this manualy. Example of my problem is in file2.
File_2.mw
I have system of equations to solve. It has 118 equations and all variables have to be binary. I know for that system that the minial number for x=1 is 32 (I cheked it in solution chapter at the end of the book) but I always get 33 of ones. I changed MaxSols=500 and still got 33. If I change MaxSols to some bigger number the time for calculation is larger and I still don't get the correct solution. Is there any faster way to do this?
I'm thinking (but I don't know how to do in Maple): Is there any way to show solutions only with number of ones in interval, for example 30 to 33.
try1.mw
I have a question about Hilbert Series of the quotient of an algebra by a non-homogenous ideal.
In maple help: https://www.maplesoft.com/support/help/maple/view.aspx?path=Groebner%2FHilbertSeries, it is said that
The algorithms for HilbertSeries and HilbertPolynomial use the leading monomials of a total degree Groebner basis for J. Here J is an ideal.
I checked the following example. Let
J:= [(x[2]-x[1])*(x[2]-x[3]), (x[4]-x[1])*(-x[5]+x[4]), (x[4]-x[2])*(x[4]-x[6]), (-x[3]+x[5])*(x[5]-x[6]), x[1]^3-1, x[2]^3-1, x[3]^3-1, x[4]^3-1, x[5]^3-1, x[6]^3-1];
t1:=map(LeadingMonomial, l, grlex(x[1], x[2], x[3], x[4], x[5], x[6], x[7], x[8], x[9], x[10], x[11], x[12]));
Then t1 is the ideal generated by the following monomials.
t1 := [x[1]*x[2], x[1]*x[4], x[2]*x[4], x[3]*x[5], x[1]^3, x[2]^3, x[3]^3, x[4]^3, x[5]^3, x[6]^3]
Using the commands:
l2:={x[1],x[2],x[3],x[4],x[5],x[6],x[7],x[8],x[9],x[10],x[11],x[12]};
factor(HilbertSeries(J, l2, t));
factor(HilbertSeries(t1, l2, t));
We obtain Hilbert(J,t)=(t^2+t+1)*(5*t^4+11*t^3+11*t^2+5*t+1)
Hilbert(t1, t) = (t^2+t+1)*(3*t^2+3*t+1)*(2*t^2+2*t+1)
These two polynomials are not equal. How does maple compute Hilbert Series for the quotient of an algebra by a non-homogenous ideal? Thank you very much.
Is there any way to integrate this in maple?
lambda^2*t*(diff(theta(t), t, t)) = lambda^2*(diff(theta(t), t))-Pr*s*lambda*(diff(theta(t), t))+Pr*(diff(theta(t), t))-Pr*t*(diff(theta(t), t))
If I used factor, it didn't simplify to 0. As you may notice that this value should be 0.
I need help, because I can't find solution.
How can I export data from Bode Plot to Excel? Two below solutions don't work.
with(DynamicSystems);
T2 := TransferFunction((1.224867518*10^(-7)*s+2.259345677*10^(-6))/(s^2+11.83692270*s+238.3951363)):
BP2 := BodePlot(T2);
with(ExcelTools);
ExcelTools:-Export(op([1, 1], BP2));
Export(BP2, "Employees13.xls", "Payroll1", "B2");
File_1.mw
Never really used the writeto command but what's with all the typesetting gobbledygook in the text file?  It occurs with document and worksheet mode.  Perhaps it's only meant for classic or command line maple?
Is there a way to log the terminal output to a .txt file?
Trying to plot this expresion
f := epsilon-1.5+9.3*I = (a+I*b)*(26.+I*(-45.-1.0*Re(a+I*b)^2-1.0*Im(a+I*b)^2))
implicitplot (a^2+b^2) against epsilon
many thanks
I am trying to solve a linear system involving large number of equations with constant coefficients using Solve command from the LinearAlgebra package. The maple program is giving solutions for a smaller number of equations (T=10,Ne=20,Ng=15). But if I increase the number of equations to (T=20,Ne=30, Ng=25), then I got the error kernel connection has been lost. I need to increase the number of equations beyond this also. Any help to simplify the code or finding errors is appreciated.
solntosystem.mw
I would like to perform an implicit differentiation of the following:
eqn := 5*(x*y)^2+x/sqrt(y) = x^2+2*(3*x^3+y^2)^3
However implicitdiff(eqn, x, y); produces an output that expands the result.  Is there a way to not have it expand?
I tried something to the effect of...
eqn := 5*(x*y(x))^2+x/sqrt(y(x)) = x^2+2*(3*x^3+y(x)^2)^3;
diff(eqn, x);
but now what I need to to isolate d/dx y(x)...
Any suggestions are much appreciated.
 my question is
I am working on for loop and there are multi-line inside it and I only need to show a specific result, not all that occurs inside the loop . is there any commend to do that in maple?
with(Statistics):
LetList := [C, E, F, H, K, P, T, W, X, Y]; LetList[Sample()];
Error, invalid input: no implementation of Sample matches the arguments in call, 'Sample:-ModuleApply()'
Can any one help me with random sampling from LetList ?
Melvin
First 753 754 755 756 757 758 759 Last Page 755 of 2429
