How can we solve the following pde by Maple?
where v is velocity, v with dot is acceleration. (So, I think we will assume that acceleration is fixed.) And \delta is Dirac distribution.  E,I,m, M , g are fixed numbers.
Boundary conditions are:
Initial conditions are:
You can find the equation in the code: question.mw
this "sum(1/(1+x)^t, t=1..infinity)" is (in my opionon) one of the most standard infinity summation and has the closed form 1/x.
i used maple 18 and it was executed and i got the closed form 1/x.
with maple 2018 i get the non executed form, also the same inert form as "Sum(1/(1+x)^t, t=1..infinity)".
if i try "sum(1/(1+2)^t, t=1..infinity)" i get 1/2 as result.
why does the version above not working? any ideas?
thank you.
Dear friends,
I'm trying to solve a linear system of PDEs. After applying the casesplit command Maple returns:
diff(U, z, y, x, x) = 0; diff(G, y,y,z) = diff(U,x,y,z);  diff(G,x,y,z) = diff(U,x,x,z)
(with U(x,y,z), G(x,y,z))
The solution to the first equation is U = F4(x, y)+ F3(x, z) + F2(y, z) + x*F1(y, z).
However, given this solution, I cannot satisfy diff(G,x,y,z) = diff(U,x,x,z).  What could I be doing wrong?
Many thanks for your help.
I have a problem with my maple.
corrupt file
Is there anybody who can help me solve this problem.
Casper
sys:={x+y=10,x^2-y^2+z^2=1};
{x+y = 10, x^2-y^2+z^2 = 1}
isolve(sys, n);
{x = -(1/20)*(1+20*n)^2+101/20, y = (1/20)*(1+20*n)^2+99/20, z = 1+20*n}
_SolutionsMayBeLost;  # It was set in Maple 10 or so!  E.g. x=5,y=5,z=-1 is not found.
_SolutionsMayBeLost
# Workaround
yz:=eliminate(sys,x);
[{x = -y+10}, {z^2-20*y+99}]
S:=isolve(yz[2], n);
{y = 20*n^2-38*n+23, z = 19-20*n}, {y = 20*n^2-22*n+11, z = 11-20*n}, {y = 20*n^2-18*n+9, z = 9-20*n}, {y = 20*n^2-2*n+5, z = 1-20*n}
map(u -> ( u union eval(yz[1],u) ), [S])[];  # The correct solution
{x = -20*n^2+38*n-13, y = 20*n^2-38*n+23, z = 19-20*n}, {x = -20*n^2+22*n-1, y = 20*n^2-22*n+11, z = 11-20*n}, {x = -20*n^2+18*n+1, y = 20*n^2-18*n+9, z = 9-20*n}, {x = -20*n^2+2*n+5, y = 20*n^2-2*n+5, z = 1-20*n}
This may seem a bit trivial, but I prefer f'(x) to writing diff(f(x),x) in 1D input. How to achieve?
differential.mw
15
"maple init loaded..."
In Document mode, this works fine.
f := proc (x) options operator, arrow; x^2 end proc
diff(f(x), x)
2*x
But I mainly use Worksheet (1D) mode, and I can't seem to acheve the same, without using diff(f(x),x)
f:x->x^2
f'(x)
Error, unexpected single forward quote
Download differential.mw
Simple question:
Why does
(exp(I*t))^q;
`assuming`([simplify(%)], [t > 0, t < 2*Pi, q > 0, q < 1])
not simplify to exp(I*t*q)
The Maplecloud and maplesoft web pages only have the latest version of the physics package.
Is there an archive of older physics packages?  ie. the latest versions to go with each of the older versions of Maple?
does anyone khow to force maple to automatically simplify expressions that look like this:
cc:=arctan(sin(phi)/cos(phi))-arccos(cos(phi))
simplify(cc) assuming phi::real; #should be zero
i've played with convert/expand/simplify and in certain cases of course i can force maple to do this... (kind of manually).. but was hoping this could be more automatic.
thanks!
The round(x) statement rounds x to the nearest integer but if x has unirs it appears not to work. Known bug?
RoundUnits.mw
a := 15; b := 5.3
c := (1/100)*a+b
5.450000000
c := round(c)
5
A := 15*Unit('cm'); B := 5.3*Unit('m')
C := A+B
15*Units:-Unit(cm)+5.3*Units:-Unit(m)
C := simplify(C)
5.450000000*Units:-Unit(m)
Cr := round(C)
round(5.450000000*Units:-Unit(m))
Download RoundUnits.mw
Hello, I am getting the following output from maple: (-ln(lambda)-gamma-ln(k+b))/(k+b) . I have all variables (lambda, k, b) but not gamma and I am not sure what actually it is. I believe it is some kind of Gamma function but I cannot find any expressions for that. Ussually for gamma function I get something like GAMMA(x). Does someone know what this lower case gamma is?
I wish to write a simple procedure to evaluate the Poisson quantile function, F, for many possible parameter values, lambda.
The Maple commands to evaluate F for individual lambda values works just fine, however, I have tried to write a simple procedure to evaluate F for prescribed lambda values (imported from Excel) but to no avail. I'm missing something quite basic, I'm sure.
Can anybody offer a suggestion please? Thanks.
Inverse_Poisson_Procedure.mw
i want to gain diff(p(t), t) and diff(q(t), t) and Jacobian matrix
 according to the attached pdf file.
please help me.
simplify.mw
k := diff(a(t), t) = -mu*a(t)-(1/4)*alpha6*a(t)*sin(gamma(t))
j := a(t)*(diff(gamma(t), t)) = 2*a(t)*sigma-(6*(1/8))*(alpha1-alpha2+(1/3)*alpha3)*a(t)^3-(1/2)*alpha6*a(t)*cos(gamma(t))
a(t)*(diff(gamma(t), t)) = 2*a(t)*sigma-(3/4)*(alpha1-alpha2+(1/3)*alpha3)*a(t)^3-(1/2)*alpha6*a(t)*cos(gamma(t))
"p(t):=a(t)*cos(gamma(t))"
proc (t) options operator, arrow, function_assign; a(t)*cos(gamma(t)) end proc
"q(t):=a(t)*sin(gamma(t))"
proc (t) options operator, arrow, function_assign; a(t)*sin(gamma(t)) end proc
diff(p(t), t)
(diff(a(t), t))*cos(gamma(t))-a(t)*(diff(gamma(t), t))*sin(gamma(t))
(-mu*a(t)-(1/4)*alpha6*a(t)*sin(gamma(t)))*cos(gamma(t))-a(t)*(2*sigma-(6*(1/8))*(alpha1-alpha2+(1/3)*alpha3)*a(t)^2-(1/2)*alpha6*cos(gamma(t)))*sin(gamma(t))
(-mu*a(t)-(1/4)*alpha6*a(t)*sin(gamma(t)))*cos(gamma(t))-a(t)*(2*sigma-(3/4)*(alpha1-alpha2+(1/3)*alpha3)*a(t)^2-(1/2)*alpha6*cos(gamma(t)))*sin(gamma(t))
diff(p(t), t)
2*t
subs.pdf
Download simplify.mw
I am having some trouble with a procedure. One of the procedures arguments is a mathematical function g(var). For simplification lets say I wish to make a procedure which calculates some values of the unknown function, g:
SomeProc:=proc(g,var:=x)
f(var):=g
return f(2)
end proc
This does not seem to work. No matter what value of var is inserted into f, the return is g(var).
Any help would be much appreciated:
How do I combine log10 terms. I can do it with natural logs but I have not been able do do it with log10.
First 756 757 758 759 760 761 762 Last Page 758 of 2429
