How do I solve (1/2)*n^2 +2n-1=O(n^2) in maple2018?Thank you
curry(`?[]`,f)([1]);
I have plotted a 3d figure with MAPLE. How can I snap a point in 3d figure and  show  the coordinate value of snaped point ?It  can be  carried out  easily in MATLAB,but I  cann‘t  snap the point used  point probe tool in MAPLE ?
Given 2 inputs
m = integer
c = integer
where c ≤ m/2
and variables, a_i, b_i, a, b (all non-negative integers)
Here, m is the digit length of a number where a_i and b_i represent digits in a number writen in base b. a is simply b-1 and is used as another digit.
I am interested in generating specific permutations of a_1 ... a_c  a ... a  b_c ... b_1 where the total number of digits is m and the number of a's in the centre is m-2c.
The permutations I am interested in satisfy the condition. a_i is to the left of b_j for i ≤ j
examples for m=7:
c=1
a1,a,a,a,a,a,b1
c=2
a1,a2,a,a,a,b2,b1
a1,a2,a,a,a,b1,b2
a1,b1,a,a,a,a2,b2
a2,a1,a,a,a,b1,b2
a2,a1,a,a,a,b2,b1
c=3
a1,a2,a3,a,b3,b2,b1
c=4
n/a   2c > m
I would like a function L(m,c) that creates all valid permuatations of a_1 .. a_c b_1 .. b_c  (2n terms)
I met up with a lecturer at my university and we came up with this code. Unfortunately it is for mathematica as he doesn't use Maple. I feel there may be a more efficient way than to generate all permutations and then delete some.
thank you in advance for any help.
Ben
with the Physics package, I want to represent a discrete two-dimensional Hilbert space in a direct-product basis.
I have looked at https://www.mapleprimes.com/posts/209099-Tensor-Product-Of-Quantum-State-Spaces but am not sure how to implement bracketrules.
Let's assume I have one-dimensional bases A and B that span a two-dimensional space C. A is of size Na and B is of size Nb. Consequently, C is of size Na * Nb.
If I understand it correclty, this can be done with
Setup(hilbertspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C})
First question: Is this correct and if yes, why do I need to specify quantumbasisdimension for C?
Then, I want to define, using bracketrules, <A[i]| <B[j]| |Psi> = X[i,j],
where |Psi> lives in the full, two-dimensional space C and X is a matrix.
<B[j]|Psi> would be a state living in A and <A[i]||Psi> would be a state in B.
How do I define this?
bracketrules = {%Bracket(Bra(A, i)*Bra(B, j), Ket(C, t)) = X[i,j](t)}
gives me an error.
I found a way using the nested expression
bracketrules = {%Bracket(Bra(A, i), Ket(A, j)) = X[i,j], %Bracket(Bra(B, j), Ket(C)) = Ket(A, j)}
giving
Bracket(Bra(A, i), Bracket(Bra(B, j), Ket(C, t))) = X[i,j]
but this is error prone, clumsy and only works in one direction:
Bracket(Bra(B, j), Bracket(Bra(A, i), Ket(C)))
does not work. Of course, I could also specify rules for the reverse direction but this is quite an effort for higher-dimensional spaces (I have, e.g., 9-dimensional spaces in mind).
So how do I do this properly?
Please have a look at the attached example, where I also included time-dependence.
Henrik
First try
restart; restart, with(Physics)
Setup(hilbertspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}, bracketrules = {%Bracket(Bra(A, i)*Bra(B, j), Ket(C, t)) = X[i, j](t)})
Error, (in Physics:-Setup) expected first argument in the Bracket defining a bracket rule to be a 'Bra'; received: Physics:-`*`(%Bra(A, i), %Bra(B, j))
Second try
Setup(hilbertspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}, bracketrules = {%Bracket(Bra(A, i), Bra(B, j), Ket(C, t)) = X[i, j](t)})
[bracketrules = {%Bracket(%Bra(A, i), %Bra(B, j), %Ket(C, t)) = X[i, j](t)}, disjointedspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}]
Physics:-`*`(Physics:-Bra(A, i), Physics:-Bra(B, j), Physics:-Ket(C, t))
Third try
Setup(hilbertspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}, bracketrules = {%Bracket(Bra(A, i), Ket(A, j, t)) = X[i, j](t), %Bracket(Bra(B, j), Ket(C, t)) = Ket(A, j, t)})
[bracketrules = {%Bracket(%Bra(A, i), %Ket(A, j, t)) = X[i, j](t), %Bracket(%Bra(B, j), %Ket(C, t)) = Physics:-Ket(A, j, t)}, disjointedspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}]
Bracket(Bra(A, i).Bra(B, j), Ket(C, t))
X[i, j](t)
Bracket(Bra(B, j), Bracket(Bra(A, i), Ket(C, t)))
Error, (in Physics:-Bracket) expected a Bra and a Ket as a first and last arguments, or no Bra and no Ket when using the shortcut notation; received: Physics:-Bra(B,j), Physics:-Bracket(Physics:-Bra(A,i),Physics:-Ket(C,t))
Download twoD.mw
How do you create a variable name with a dot?  ie/ ini.param
I don't think it's possible without using single quotes ie `ini.param`.  The single quotes will always need to be used.
I have 3 lists of equal length:
A:=[1,1,1,1,1,2,2,2,2,2,3,3,3,3,3,4,4,4,4,4,5,5,5,5,5]
B:=[1,2,3,4,5,1,2,3,4,5,1,2,3,4,5,1,2,3,4,5,1,2,3,4,5]
C:=[5,2,7,9,1,6,2,8,4,6,2,1,5,8,3,5,2,9,6,6,3,2,1,6,4]
I would like to make a 3-D plot of C dependent on A and B (Ex. C(1,1)=5, C(1,2)=2.. C(5,5)=4).
What would be the best way to plot this? I have tried 'pointplot3d' which returns a decent result, but I would prefer a filled plot if possible.
hi
I want to mix two curve and have only one figure(I want to compare two curve in one plot domain )?
plot.mw
h1 := solve(Vdc = 0.1500000000e-2*sqrt(2.53669508*10^8*u^3-6.06101011*10^8*u^2+3.46343435*10^8*u), u); plot([h1], Vdc = 0 .. 11.5, color = [magenta], thickness = 1); plot(Vector([0, 3.38, 5.21, 6.97, 8.4108, 10.099, 10.9232, 11.8091]), Vector([0, 0.760e-1, .1275, .1994, .2286, .3222, .3637, .999]), style = point, symbol = asterisk, color = "Blue")
Download plot.mw
Hi, fairly simple question,
I solve a simple equation:
solve(x^x = 4, allsolutions, explicit);
#(2*(I*Pi*_Z7+ln(2)))/LambertW(_Z9, 2*ln(2)+(2*I)*Pi*_Z7)
Maple  gave me solution with prefix _Z for integer values, but why  _Z9 must be exactly equal  Zero  to be correct ?.
If _Z9 is integer it can also take other values than zero ?
More information see attached file:
Download Allsolution.mw
There is a builtin command "callback". It exists both in Maple 5 and today's Maple. There is no documentation on it. What is it? Why does it exist? Is there any code that uses it?
I've been using the physics package to calculate various different tensors but I can't see that I can calculate a cotton tensor for a given metric, is this included in the physics package? If so what is the calling sequence as I cannot find it. I understand I could use the differential geometry package but I do not want to as I don't know how to set up an arbitrary metric, thanks in advance.
Where can I find help with graphing on Maple?
Hi there,
I have difficulties in solving the first partial derivatives dw/db and dw/dvarphi of this equation with its constraint:
w := exp(exp(x*b)*(r-1)/(1+varphi*exp(x*b))) where ln(r) = varphi*(exp(x*b))(r-1)/(1+varphi*exp(x*b))-1
Please help.
Sarni Berliana
In a recent question (a few hours ago) Teep failed to compute quantiles of a negative binomial random variable as soon as the probability of success is small (even for a value of 0.05 the computational time is very prohibitive).
Teep used the package Statistics:
I discovered inadvertently that the package Student[Statistics] worked perfectly on the same problem, even for a success probability as small as 3e-10
What is the necessity to have two packages that share theoritically some features especially if one of them (Statistics) contains a lot of flaws and is not capable to return an answer as the other (Student[Statistics]) does?
In the present case of numerically computing quantiles, why people decide to implement a good algorithm in one package and a poor one in the other? Or why they didn't verify if the two packages gave identical answers on the same problem?
Anyone knows how to see a manual for DirectSearch:-GlobalSearch that explains what is done inside the function?
I tried to write "help(DirectSearch:-GlobalSearch)" and nothing. It opened an empty page written (no matches found). Is there any help for this function so I can know what's going on there?
More specifically, I'm trying solve the optimization probelm min(||Ax-b||_p) s.t. ||x||=1.
where A is a given matrix of size (n \times d)
b is a given vector of size (n \times 1)
p>0 is a scalar
and x is an unkown vector of size (d \times 1) that should be a unit vector.
I used DirectSearch:-GlobalSearch to solve this optimization problem. But since it's a non-convex optimization probelm, the function doesn't always return the optimal value. I want to read the manual of the function to understand what is done there and for which cases there are most chances that the function will not return the optimal value.
First 758 759 760 761 762 763 764 Last Page 760 of 2429
