I am curious how one can fine the whattype of operation in expression when two variables are actually doing difference or division operation
like
whattype(a-b);
whattype(a/b);
is there any better method to find out actually for all five operations exactly.
1. a-b;  should tell the operation is difference(substraction(`-`))
2. a+b; should tell the operation is addition(`+`)
3. a*b;  should tell the operation is multiplication(`*`)
4. a/b;  should tell the operation is division(`/`)
5. a^b;  should tell the operation is power(`^`)
I understood that maple is reading a-b as a+(-b) and same a/b as a*(1/b). but, for programing it is very much comfortable to know exactly the operation. Especially when solving partial differentiation it is easy if I know exactly.
would be very grateful if I can get this thing solved. Any suggestions and coments are welcomed and thanks in advance
      I need to compute something involved with the pseudo differential operators.
https://en.wikipedia.org/wiki/Pseudo-differential_operator
Specifically, I need to calculate the inverse of a pseudo differential operator, the multiplication of two pseudo differential operators, and the n-th root of a pseudo differential operator.
I don't know whether Maple could handle these.
Respected sir,
I have attached a file that contain integration . Sir I am unable to solve please give me some hint.
PLease note followings
1. I want to get final expression , want to get the value of constant from boundary condition.
2.I want to get the final expression (.......+c1)
3.I will put boundary condition to determine the value of c1
Dear all;
I need a help to get a simple code about the null hypothesis test.
A drug is administrad to a population X of size 50 while a  placebo is given to a population Y of size 25.
Observed results of good bad and no effects are given in the following vectors for both population.
X=[ 20,11,19];
Y=[4,4,17];
test the null hypothesis H0: population independent of treatment versus the one tailed alternative that they are dependent by computing the theoretical contingency table with entries T[i,j] where i=1,2
for the two rows and j=1,2,3 for the three columns. At what p-value can we reject H0.
Many thanks
There is a simulation of a T handle in space done in matlab https://rotations.berkeley.edu/a-tumbling-t-handle-in-space/
Would like to see someone do this in Maple. More specifically how the Matlab code would look like translated to Maple
sign(-v1+a);
sign(-V1+a);
my respective outputs are
I cannot understand what is the difference between using lowercase and uppercase variable. Could Someone Explain me please.
I have to Two Lists with Equal size. Each element in one List is an variable and Each element in second List is an Value of the variable corresponds to First List.
Now when Ever I call a variable I need the script to read its value and Compute.
For Example:
List1 := [v1,v2,v3,v4];
List2 := [a*b/c, a/c,a*b-2,d];
computation := v1*diff(expression,x)+v3*diff(expression,y)+ v3*v4;
but I need the script to read it as
requiredComputation :=(a*b/c)*diff(expression,x)+(a*b-2)*diff(expression,y)+ a*b-2*d;
I used to do this kind of computation in matlab using containers and map. Is there any thing similar??
I was trying some calculations for a solar installation.
4.9kW system. 3.5 h sun/day.  $0.27/kWh
with(Units:-Standard):
                     "maple init loaded..."
4.9*Unit(kW)*3.5*Unit(h/day)
714.583333333333*Unit('W')
but I want it to output 17.15 kWh/day
I looked up previous questions, and got this rather convoluted solution:
Units[AddSystem]( NewSI, Units[GetSystem](SI), kWh/day );
 Units[UseSystem]( NewSI );
combine( 4.9*Unit(kW)*3.5*Unit(h/day), units );
17.15*Unit('kWh'/'d')
Hi. I hope this question is not a duplicate of my previous question. Fundiff function results in dirac terms in an equation. Are there commands that simply differentiates a term that is a function of (t) in an equation without involving diracs?
Can we change the color of the units measure?
ie 5 m (5 meters - where m is default black) can the m be changed to a different color for all unit measure entries?
MY CODE:
with(Physics);
Setup(Coordinatesystem = (X = [x, y, z, t]), metric = 4*dx*dt-dy^2-dz^2+4*u*(dt^2));
    * Partial match of  'Coordinatesystem' against keyword
       'coordinatesystems'
    Systems of spacetime Coordinates are: (Xequals(x,y,z,t))
[coordinatesystems = {X},
  metric = {(1, 4) = 2, (2, 2) = -1, (3, 3) = -1, (4, 4) = 4 u}]
g_[];      (here g is diplayed in matrix form)
Weyl[alpha, beta, mu, nu, nonzero];
            Physics:-Weyl[alpha, beta, mu, nu] = {}
So basically i'm trying to find the nonzero components of the weyl tensor which returns the empty set, i.e the weyl tensor apparently equals zero but I know this is not the case, can anyone see if I have input something wrong? Thanks in advance
g_[] in matrix form is
0 0 0 2
0 -1 0 0
0 0 -1 0
2 0 0 4u
UPDATE: u is a function of all varibles and I have not considered this which might be causing the problem
I trying to get a proc to work. In the 1st half of the document, I derive four sections for a pedal curve and plot them fine. In the second I try doing it with a procedure called Pedal. Am having problems. I think it might be something to do with the for.. do loop.
NULLNULL
Typesetting:-mrow(Typesetting:-mi("Trunc", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("≔", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("proc", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("procedure", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("`+`", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "{", close = "}"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("odr", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("posint", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("≔", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("2", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("v", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("list", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("name", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("≔", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("x", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mi(""), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("description", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms(" Truncates an algebraic equation to required degree"), Typesetting:-mo(";", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("local", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("≔", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("`if`", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("procedure", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("v", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(";", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mi("print", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(";", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("if", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("not", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("`+`", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("Can't truncate 1-term expression"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("else", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("select", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("q", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("→", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("degree", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("q", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("v", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("≤", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("odr", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mi(""), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("proc", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"))
NULLNULLNULL
a := 3; b := -1; c := -1
C := (x^2+y^2+12*x+9)^2-4*(2*x+3)^3
p21 := plots:-implicitplot(C, x = -3 .. 3, y = -5 .. 5, colour = "Salmon", gridrefine = 2, size = [300, 300])
sol1 := [solve(C, y)]
[(-x^2-12*x-9+2*(8*x^3+36*x^2+54*x+27)^(1/2))^(1/2), -(-x^2-12*x-9+2*(8*x^3+36*x^2+54*x+27)^(1/2))^(1/2), (-x^2-12*x-9-2*(8*x^3+36*x^2+54*x+27)^(1/2))^(1/2), -(-x^2-12*x-9-2*(8*x^3+36*x^2+54*x+27)^(1/2))^(1/2)]
f1 := expand(eval(C, [x = X+r, y = Y+s]))
X^4+4*X^3*r+2*X^2*Y^2+4*X^2*Y*s+6*X^2*r^2+2*X^2*s^2+4*X*Y^2*r+8*X*Y*r*s+4*X*r^3+4*X*r*s^2+Y^4+4*Y^3*s+2*Y^2*r^2+6*Y^2*s^2+4*Y*r^2*s+4*Y*s^3+r^4+2*r^2*s^2+s^4-8*X^3-24*X^2*r+24*X*Y^2+48*X*Y*s-24*X*r^2+24*X*s^2+24*Y^2*r+48*Y*r*s-8*r^3+24*r*s^2+18*X^2+36*X*r+18*Y^2+36*Y*s+18*r^2+18*s^2-27
ltg1 := simplify(expand(eval(Trunc(f1, 1, [Y, X]), [X = x-r, Y = y-s])))
-3*r^4+(4*x+16)*r^3+(-6*s^2+4*s*y-24*x-18)*r^2+((4*x-48)*s^2+48*s*y+36*x)*r-27-3*s^4+4*s^3*y+(24*x-18)*s^2+36*s*y
NULLThis*section*works*out*the*pedal*curve
xp1 := 1; yp1 := 2; lprp1 := -coeff(ltg1, y)*x+coeff(ltg1, x)*y+K1; for i to nops(sol1) do s := eval(sol1[i], x = r); print("s  ", s); K1 := solve(eval(lprp1, [x = xp1, y = yp1]), K1); print("K1  ", K1); sol2 := solve([ltg1, lprp1], [x, y]); Pedal || i := [rhs(sol2[1, 1]), rhs(sol2[1, 2])]; p9 || i := plot([op(Pedal || i), r = -20 .. 20], colour = "MediumSeaGreen"); unassign('K1', 'sol2') end do
"K1  ", -4*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(3/2)-4*r^2*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)+16*(8*r^3+36*r^2+54*r+27)^(1/2)*r-48*r*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)+192*r^2+96*(8*r^3+36*r^2+54*r+27)^(1/2)-36*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)+576*r+432
seq(simplify(Pedal || i), i = 1 .. nops(sol1))
[((((2*r+3)^3)^(1/2)+6*r+9)*(-r^2-12*r-9+2*((2*r+3)^3)^(1/2))^(1/2)-2*(r-3)*(r^2+(5/2)*r-((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18), ((-2*r^2-3*r-((2*r+3)^3)^(1/2))*(-r^2-12*r-9+2*((2*r+3)^3)^(1/2))^(1/2)+6*(r-3)*(r-(1/6)*((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18)], [((-((2*r+3)^3)^(1/2)-6*r-9)*(-r^2-12*r-9+2*((2*r+3)^3)^(1/2))^(1/2)-2*(r-3)*(r^2+(5/2)*r-((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18), ((2*r^2+((2*r+3)^3)^(1/2)+3*r)*(-r^2-12*r-9+2*((2*r+3)^3)^(1/2))^(1/2)+6*(r-3)*(r-(1/6)*((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18)], [((6*r-((2*r+3)^3)^(1/2)+9)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)-2*(r-3)*(r^2+(5/2)*r+((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18), ((-2*r^2+((2*r+3)^3)^(1/2)-3*r)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+6*(r-3)*(r+(1/6)*((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18)], [((((2*r+3)^3)^(1/2)-6*r-9)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)-2*(r-3)*(r^2+(5/2)*r+((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18), ((2*r^2-((2*r+3)^3)^(1/2)+3*r)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+6*(r-3)*(r+(1/6)*((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18)]
plots:-display(p21, seq(p9 || i, i = 1 .. nops(sol1)), size = [600, 600], scaling = constrained, caption = " Curve and it's Pedal curve")
This I can't get to work. All 4 sections of the pedal curve are the same and should not be.
Parse:-ConvertTo1D, "`%1` is not a module or member", RonanRoutines
Pedal2 := Pedal(C, xp1, yp1)
"K||i", -8*r^3+(-4*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)+48)*r^2-8*(-(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)-3)^2*r-4*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(3/2)+48*r^2+576*r+432+96*(8*r^3+36*r^2+54*r+27)^(1/2)-36*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)
seq(simplify(Pedal2[i]), i = 1 .. nops(sol1))
[((4*r^2+6*((2*r+3)^3)^(1/2)+30*r+36)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(-r^2-34*r-69)*((2*r+3)^3)^(1/2)-26*r^3-243*r^2-540*r-351)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162), (((r+9)*((2*r+3)^3)^(1/2)+14*r^2+51*r+45)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(12*r+72)*((2*r+3)^3)^(1/2)+4*r^3+126*r^2+432*r+378)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162)], [((4*r^2+6*((2*r+3)^3)^(1/2)+30*r+36)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(-r^2-34*r-69)*((2*r+3)^3)^(1/2)-26*r^3-243*r^2-540*r-351)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162), (((r+9)*((2*r+3)^3)^(1/2)+14*r^2+51*r+45)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(12*r+72)*((2*r+3)^3)^(1/2)+4*r^3+126*r^2+432*r+378)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162)], [((4*r^2+6*((2*r+3)^3)^(1/2)+30*r+36)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(-r^2-34*r-69)*((2*r+3)^3)^(1/2)-26*r^3-243*r^2-540*r-351)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162), (((r+9)*((2*r+3)^3)^(1/2)+14*r^2+51*r+45)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(12*r+72)*((2*r+3)^3)^(1/2)+4*r^3+126*r^2+432*r+378)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162)], [((4*r^2+6*((2*r+3)^3)^(1/2)+30*r+36)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(-r^2-34*r-69)*((2*r+3)^3)^(1/2)-26*r^3-243*r^2-540*r-351)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162), (((r+9)*((2*r+3)^3)^(1/2)+14*r^2+51*r+45)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(12*r+72)*((2*r+3)^3)^(1/2)+4*r^3+126*r^2+432*r+378)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162)]
for i to nops(sol1) do p9 || i := plot([op(Pedal2[i]), r = -20 .. 20], colour = "MediumSeaGreen") end do
Download Proc_for_Pedal_not_working.mw
Hi all
I have the following ordinary differential equation, where all the parameter used are constant ( A,B,C,D,E,F,G,H).
Is there any technique gives a solution
diff(y(x), x$2)+(A/x+B/x^2+C)*(diff(y(x), x))+D*(diff(y(x), x))^2/x+E*(diff(y(x), x))^3+F/x+G/x^2+H/x^3 = 0;
 thanks for your help
Dear all;
I hope an idea to solve the following problem.
P(n,t): probability at time t
Lambda and mu : two given parameters ( can be fixed ), and we assure mu greater then lambda
 t : time parameter ( we can say that 0<= t <=T , and T fixed )
 for n an integrer  greater then 1 we have the following equation
eq := diff(P(n, t), t) = -(lambda+mu)*P(n, t)+lambda*P(n-1, t)+mu*P(n+1, t);
for n=0, we have
ics := diff(P(0, t), t) = -lambda*P(0, t)+mu*P(1, t);
How can we compute P(n,t) ,
is there an exact solution or a numerical method to get the value of P(n,t)
Then we plot( P(n,t),t=0..100) ;
Many thinks
Can somebody please help me with this assignment?
Struggling a bit with the Euler-method from task d) and further.
First 762 763 764 765 766 767 768 Last Page 764 of 2429
