rand1 := rand(2 .. 9):
4
(a*sqrt(a*a^b))^(1/c)
16^(1/4)*2^(1/8)
"example a:=2;b:=6;c:=4; result 2 D output is ((2*sqrt(2*2^(6)))^(1/(4)))"
but*result*is*16^(1/4)*2^(1/8)
assume(x > 0)
sqrt(x^3*(x^(3/4)))
(x^(15/4))^(1/2)
``(15/8)*How*determine*x*exponent*is
Download luythua.mw
From the screenshot we see that Maple has correctly replaced a in the defintion of s. But it has not incorported v[B]. I was a SMath (free from internet) user and this was a simple operation.
Thanks for any advice.
SymbolicEval.mw
How do you can convert g into ?
Can you help me?
I am trying to evaluate a function that contains an infinite sum. I need to evaluate the integral to determine a CDF, and from that hopefully the inverse CDF in order to sample the corresponding PDF.
The sum comes from a 2F1 hypergeometric function, which I have written manually in the attached file.
Can anyone tell me if and how it is possible to evaluate this integral, with respect to x?
I have inserted an image below, but also the entire file :) Marginal2.mw
Maple 2018 starts but block and hangs after the first imput.
Even after a clean install on a clean disk where there are no old files of maple.
My specs are: WIN10 pr 64/ I7 /16 GB/ SSD
Who has the same problem and a sollution?
Uxx + Uyy =0
      y is less than Pi,x is greater than 0
B.c are u(0,y)=0 , u(Pi,y)=sinh*Pi*cosy
              u(x,0)=sinx , u(x,Pi)=-sinhx
How can I compute MatrixInverse, MatrixMultiply and eigenvalues(eigenvectors) faster? are there any procedures or commands that can be used instead of those three command mentioned before to speed up calculations?
1.mw
In the above document, digits must be 30.
I want to know how to program a metric g_[ ]  so that entries are zero apart from the diagonal.
Basically I am using the physics package and can set it as arbitrary or can set it to be specific values but I just want arbitrary values across the diagonal. e.g
with(Physics);
                 [mathematicalnotation = true]
Setup(metric = arbitrary);
 [metric = {(1, 1) = _F1(X), (1, 2) = _F2(X), (1, 3) = _F3(X), (1, 4) = _F4(X), (2, 2) = _F5(X), (2, 3) = _F6(X),  (2, 4) = _F7(X),
(3, 3) = _F8(X), (3, 4) = _F9(X),  (4, 4) = _F10(X)}]
SO here I want to keep F1 F5 F8 and F10, thanks in advance!
THIS IS WHAT I TRIED:
with(Physics);
Setup(Coordinatesystem = (X = [x1, x2, x3, x4]), metric = f(dx1^2+dx2^2+dx3^2+dx4^2));
    * Partial match of  'Coordinatesystem' against keyword
       'coordinatesystems'
  Default differentiation variables for d_, D_ and dAlembertian
   are: (Xequals(x1,x2,x3,x4))
  Systems of spacetime Coordinates are: (Xequals(x1,x2,x3,x4))
Error, (in Physics:-Setup) expected definition of a metric as a tensorial algebraic expression with two free indices; received one with free indices {}
I have a solution to a linear ODE which is very long and complicated.  The solition clearly has some parts which are repeated and so it would would be easiest to express those repeated parts as something simpler.
For example, suppose I had
x = (-b + sqrt(b^2 - 4*a*c) ) /2*a
What is the command to take x and do someting like
Z = sqrt(b^2 - 4*a*c)
x = (-b + Z)/2*a
when plotting a polar function in terms of r and theta, is there a way to animate it?
For instance I want to animate u(r,theta)=rcos(theta) for theta between 0 and 2Pi.
i have to list
a := sort([.17, .23, .33, .39, .39, .40, .45, .52, .56, .59, .64, .66, .70, .76, .77, .78, .95, .97, 1.02, 1.12, 1.19, 1.24, 1.59, 1.74, 2.92])
b:=[5,seq(0,i=1..19)]:
i want to make aloop on a  by saying that for i=1 eliminate b[1] from a then sort the remining elements of a
then for i=2 eliminate b[2] from a then sort the rest elimant of a and so on
Q1: In place of three statments like >a:=3: b:=4; c:=5, I have found from an example in this forum that one can use >(a,b,c):=(3,4,5). And I find this useful in some applications. Anyone know what version of Maple introduced this? I can find not referneces in the Maple books I have
Q2: Maple someimes gives 'naked' decimals when I use Numeric formatting. Any way of avoiding this. I would  like 0.25 not .25
Many thanks
`~`[int](convert(convert(series(x^x, x), polynom), list), x = 0 .. 1)
Can this sequence (produced above in list form) be displayed as 1, -1/2^2, 1/3^3, -1/4^4, 1/5^5 -1/6^6 etc.
That is with the powers unevaluated.
What are the methods for writing code to the recursive matrix A  as follows?
When i am running a code in maple worksheet , one error is shown by maple. My code and error (in bold) is below
Instructional workheet for the FracSym package
G. F. Jefferson and J. Carminati
Read in accompanying packages: ASP, DESOLVII and initialise using the with command:
read `ASP v4.6.3.txt`:
DESOLVII_V5R5 (March 2011)(c), by Dr. K. T. Vu, Dr. J. Carminati and Miss G.
   Jefferson
 The authors kindly request that this software be referenced, if it is used
    in work eventuating in a publication, by citing the article:
  K.T. Vu, G.F. Jefferson, J. Carminati, Finding generalised symmetries of
     differential equations
using the MAPLE package DESOLVII,Comput. Phys. Commun. 183 (2012) 1044-1054.
       ASP (November 2011), by Miss G. Jefferson and Dr. J. Carminati
    G.F. Jefferson, J. Carminati, ASP: Automated Symbolic Computation of
       Approximate Symmetries
    of Differential Equations, Comput. Phys. Comm. 184 (2013) 1045-1063.
with(ASP);
              [ApproximateSymmetry, applygenerator, commutator]
with(desolv);
[classify, comtab, defeqn, deteq_split, extgenerator, gendef, genvec,
  icde_cons, liesolve, mod_eq, originalVar, pdesolv, reduceVar, reduceVargen,
  symmetry, varchange]
Read in FracSym and initialise using the with command:
read `FracSym.v1.16.txt`;
       FracSym (April 2013), by Miss G. Jefferson and Dr. J. Carminati
    in work eventuating in a publication, by citing:
G.F. Jefferson, J. Carminati, FracSym: Automated symbolic computation of Lie
   symmetries
of fractional differential equations, Comput. Phys. Comm. Submitted May 2013.
with(FracSym);
 [Rfracdiff, TotalD, applyFracgen, evalTotalD, expandsum, fracDet, fracGen,
   split]
BASIC OPERATORS
The Riemann-Liouville fractional derivatives is expressed in "inert" form using the FracSym routine Rfracdiff.
The explicit formula for the form of these fractional derivatives may be found in I. Podlubny, Fractional differential equations: An introduction to fractional derivatives, fractional differential equations, some methods of their solution and some of their applications, San Diego, 1999.)
Rfracdiff(u(x, t),t,alpha);
                                alpha
                             D[t     ](u(x, t))
If the fractional derivative is taken for a product, the generalised Leibnitz rule is used to express the result (the product operator used is &* and is non-commutative).
Rfracdiff(u(x, t)&*v(x,t),t,alpha);
     infinity
        )                          (alpha - n)              n
       /     binomial(alpha, n) D[t           ](u(x, t)) D[t ](v(x, t))
      n = 0
Rfracdiff(v(x, t)&*u(x,t),t,alpha);
     infinity
        )                          (alpha - n)              n
       /     binomial(alpha, n) D[t           ](v(x, t)) D[t ](u(x, t))
      n = 0
Fractional derivatives of integer order revert to the MAPLE diff routine.
Rfracdiff(u(x, t)&*v(x,t),t,2);
         / d  / d         \\             / d         \ / d         \
         |--- |--- u(x, t)|| v(x, t) + 2 |--- u(x, t)| |--- v(x, t)|
         \ dt \ dt        //             \ dt        / \ dt        /
                      / d  / d         \\
            + u(x, t) |--- |--- v(x, t)||
                      \ dt \ dt        //
The FracSym rouine TotalD may also be used to find total derivatives. evalTotalD is then used to evaluate the result (in jet notation). For example,
TotalD(xi[x](x, y),x,2);
                             D[x ](xi[x](x, y))
evalTotalD([%],[y],[x]);
        [     / d             \      2 / d  / d             \\
        [y_xx |--- xi[x](x, y)| + y_x  |--- |--- xi[x](x, y)||
        [     \ dy            /        \ dy \ dy            //
               / d  / d             \\       / d  / d             \\]
           + 2 |--- |--- xi[x](x, y)|| y_x + |--- |--- xi[x](x, y)||]
               \ dy \ dx            //       \ dx \ dx            //]
EXAMPLE -  FINDING SYMMETRIES FOR A FRACTIONAL DE
Consider the fractional PDE from: R. Sahadevan, T. Bakkyaraj, Invariant analysis of time fractional generalized Burgers and Korteweg-de Vries equations, J. Math. Anal. Appl. 393 (2012) 341-347.
We use the Rfracdiff routine to express the
                                    alpha
 fractional derivative with respect to t:
fde1:=Rfracdiff(u(x, t),t,alpha) = (diff(u(x, t), x,x))+n*(u(x, t))^p*(diff(u(x, t),  x));
        alpha             / d  / d         \\            p / d         \
     D[t     ](u(x, t)) = |--- |--- u(x, t)|| + n u(x, t)  |--- u(x, t)|
                          \ dx \ dx        //              \ dx        /
sys1:=[Rfracdiff(u(x, t),t,alpha) = (diff(v(x, t), x)), Rfracdiff(v(x, t),t,alpha) = -u(x, t)*diff(u(x, t),x)];
[   alpha              d              alpha                      / d         \]
[D[t     ](u(x, t)) = --- v(x, t), D[t     ](v(x, t)) = -u(x, t) |--- u(x, t)|]
[                      dx                                        \ dx        /]
We use the the FracSym routine fracDet to find the determining equations for the symmetry for fde1.
NOTE: The fourth argument (some integer at least 1) corresponds to the number of terms to be "peeled off" from the sums which occur in the extended infintesimal function for the fractional derivative. A value of 2 provides a good balance between information for solution of determining equations and speed.
deteqs:=fracDet([sys1], [u, v],[x, t], 2, alpha=(0.1)..1);
Error, (in desolv/PickLHSDerivative) Cannot pick out the left hand side derivatives
Please suggest what problem it may be?
First 763 764 765 766 767 768 769 Last Page 765 of 2429
