Why can't maple integrate
`assuming`([int(GAMMA(a, s)*exp(-b*s), s = 0 .. infinity)], [b > 0, a > 0])
which has a simple result obtained by partial integration?
Is het possible to use the circletimes symbol  ⊗ from Maple's Operators palette as an alias for KroneckerProduct(A,B)?
Instead of KroneckerProduct(A,B) :  A ⊗ B
An abbriviation would be convenient for the following expression:
A ⊗ B ⊗ C ⊗ D ⊗ E ⊗ F ⊗ G
I tried alias, macro, applyrule but was not successfull.
Is is possible or should I add it to the Maple 2019 wishlist?
Harry
Is there information available about the improvements made up to the recent version of the Maple Physics Package?
Is there any way in maple to solve this to give answer back to plaintext from cipher-text.
toletter := proc (num) local cs, cn, sl, ltable, ans, ii; ltable := table([0 = "A", 1 = "B", 2 = "C", 3 = "D", 4 = "E", 5 = "F", 6 = "G", 7 = "H", 8 = "I", 9 = "J", 10 = "K", 11 = "L", 12 = "M", 13 = "N", 14 = "O", 15 = "P", 16 = "Q", 17 = "R", 18 = "S", 19 = "T", 20 = "U", 21 = "V", 22 = "W", 23 = "X", 24 = "Y", 25 = "Z"]); cn := num; sl := floor((1/2)*trunc(evalf(log10(cn))))+1; ans := " "; for ii to sl do cn := (1/100)*cn; cs := ltatble[100*frac(cn)]; ans := cat(cs, ans); cn := trunc(cn) end do; RETURN(ans) end proc
This is because of the answer that I get is not in letter form:
toletter(plaintext);
(ltatble[17]) || (ltatble[4]) || (ltatble[19]) || (ltatble[20]) ||
  (ltatble[17]) || (ltatble[13]) || (ltatble[19]) || (ltatble[14]
  ) || (ltatble[12]) || (ltatble[0]) || (ltatble[8]) || (ltatble[
  13]) || (ltatble[3]) || (ltatble[4]) || (ltatble[2]) || (
  ltatble[10]) || " "
Is there any way in maple to solve this;
diff(theta(eta), eta, eta)+Pr*f*(diff(theta(eta), eta)) = 0
To find the value of theta.
theta.mw
i've come across a confusing behavior where the same command (a copy/paste of another command) is giving an output in a a different form.
Attaching a screen shot that shows this. Eq 6.8 is executed just after 6.7.
(i know the command is weird, i.e. subs(beta=beta, ..), etc.. this is part of some larger code base and i just put this in when trying to undertand what's going on).
I would hope for the same command to spit out the same output in this case. (nothing else gets assigned/called in betwen).
any idea what's going on?
i'm on maple 2018.2 on linux.
I vaguely recall others complain about disappearing Code Edit Regions. Does anyone else recall that? I had one disappear from the very top of the attached worksheet (right after the restart), causing me to lose about 15-30 minutes of work. I've totally recreated the work, so I have no interest in this worksheet being repaired. I'm merely posting it in case anyone wants to do an autopsy on it.
Another issue that happened twice with this worksheet is that when I unchecked the "Expanded" box on the Code Edit Region menu (pull out from the right side of the screen) and copied the text to my clipboard (for posting on MaplePrimes), that copied text was missing my most-recent changes to the code. They reappeared when I expanded again. (But it's really difficult to copy-and-paste a multi-screen Code Edit Region when it's expanded.)
My final issue (and this has bothered me for years), is how the heck are you supposed to find the line with the syntax error in a several-hundred-line Code Edit Region? Unlike with inline code, the cursor is not placed near the error location._Binomial_missing_Code_region.mw
How do I remove infinity from a list
s:=[f(x) , exp(a), GAMMA(2x)-1 , infinity , 1, -infinity]
remove(has,%,infinity)
does not work.
It should yield
s:=[f(x) , exp(a), GAMMA(2x)-1 , 1]
with(StringTools)
s := "xABCx etc"; RegMatch("x(.+)x", s, 'm', 'n'); m; n; RegSubs(m = n, s)
"xABCx etc"
"xABCx"
"ABC"
"ABC etc"
s := "(ABC) etc"; RegMatch("\\((.+)\\)", s, 'm', 'n'); m; n; RegSubs(m = n, s)
"(ABC) etc"
"(ABC)"
"ABC"
"(ABC) etc"
In the second case RegSubs treats the expression m as containing special characters. Can one tell it to treat what it receives as a literal string - perhaps some "escape" function?
Download regsubs_problem.mw
EDIT  There is such a function. suffices.
How to solve the following second order ODE system? (I want to solve analytically and numerically and to compare the results) Thanks. Best regards.
where
Initial conditions:
Other symbols in the equation (v_0,a_0 etc.) are constant.
MY CODE TRY:  Code.mw
I tried to write a code for matrices in the question. ( I used x instead of gamma in the code)
n:=2:
  M:= tau -> Matrix
      ( n,
        n,
        shape=identity
      +Matrix
      ( n,
        n,             (i,j)->2*x*sin(i*Pi*v_0*tau)*sin(j*Pi*v_0*tau)
  C:=tau -> Matrix
              ( n,
                n,
                (i,j)->4*(i*Pi*v_0*tau)*sin(i*Pi*v_0*tau)*cos(j*Pi*v_0*tau)
  K:=tau -> n^4*Pi^2* Matrix
      ( n,
        n,
        shape=identity
      )-Matrix
      ( n,
        n,
        (i,j)-> 2*mu*(i*Pi*v_0)^2*sin(i*Pi*v_0*tau)*sin(j*Pi*v_0*tau)+2*mu*(i*Pi*a_0)*sin(i*Pi*v_0*tau)*cos(j*Pi*v_0*tau)
f:=tau -> Vector
      ( n,
        (i,j)-> x*Pi^2*(Pi/2+v_0^2*sum(((1-(-1)^k)/k^3)*sin(k*Pi*v_0*tau),k=1..infinity)-a_0*sum(((1-(-1)^k)/k^4)*cos(k*Pi*v_0*tau),k=1..infinity))*sin(i*Pi*v_0*tau)
X:= Vector(n, i-> x[i](t)):
sys:= M(tau).diff~(X, tau$2)+C(tau).diff~(X, tau)+K(tau).X=f(tau):
how I can determined time period?
thank you
period.mw
d := (10+20*cos(Omega*t)+30*cos(9*sqrt(2)*t))^2
(10+20*cos(Omega*t)+30*cos(9*2^(1/2)*t))^2
with(StringTools)
period(d)
period((10+20*cos(Omega*t)+30*cos(9*2^(1/2)*t))^2)
Download period.mw
For some reason algsub or applyrule is not performing what they has to do.
I dont understand exactly where the below lines are wrongly declared. Clearly the variable is not substituted
I get the following errors when attempting to use the Sockets package to interface with the serial input and output for a USB device connected and reported to have no known problems by Windows 10:
with(Sockets):
LookupService("busboy");
Error, could not determine determine port number for service "busboy"
LookupService(998);
Errror, cannot  determine "tcp"  service on port 998
server :=
proc (sid)
Sockets:-Write(sid, sprintf("Hello %s on port %d, from %s\r\n", Sockets:-GetPeerHost(sid), Sockets:-GetPeerPort(sid), Sockets:-GetHostName()))
Sockets:-Serve(GetPeerPort(sid), server);
Error, (in Sockets:-GetPeerHost) Unknown error
sid := Open("localhost", "echo");
Error, (in Sockets:-Serve) cannot bind address: Unknown error
Can this expression be transferred to gamma function form?
Int(exp(-Pr*(s*eta*lambda^2+lambda*eta+exp(-lambda*eta))/lambda^2), eta)
First 755 756 757 758 759 760 761 Last Page 757 of 2429
