sol := dsolve([op(eqs), op(ICs)], numeric, range = 0 .. tmax, abserr = 10^(-3), relerr = 10^(-3), stiff = true, maxfun = 0);
can any one tell how to remove this error?
Good day
Recently, I decided to learn Maple. So, I came across these exercises(uploaded) but I don't have any idea about the shooting method's Maple coding and how to compare especially representing it in tables.
What is the Maple coding needed?
How do I compare both results in a tabular form?
How do I calculate the error analysis? and
How do I plot the graph?
I believe with the knowldege gotten from the solutions of this exercises, I will be able to answer any question on shooting method.
Thank You.
How come there is an imaginary value in the result?
int(exp(-t)/(1-t), t = 0 .. infinity, CauchyPrincipalValue = true)
I am currently working on my Final Year project with the topic.
What Maple code can I use to compare shooting method result with the exact solutions and also plot the graph?
I have uploaded my sample questions BOUNDARY_VALUE_PROBLEMS.docx
Link to sample questions https://drive.google.com/open?id=1B9SKvcoiUw8tgFShqDwl_YHmh7If8oW0
I am grateful
how save data as table or file? such as this data aa.mw
I have this sum which should be equal to argument(GAMMA(I*x)) with x>0.
`assuming`([x*ln(n)-(1/2)*Pi-(sum(arctan(x/k), k = 1 .. n))], [x > 1]);
aG := `assuming`([limit(%, n = infinity)], [x > 1]);
`~`[evalf](eval([aG, argument(GAMMA(I*x))], x = 1))
However this limit evaluation is somehow broken in as it always gives some order symbol O(1) etc..
What is happening here?
Given a list with sublists e.g.
[[a,b],[[c,d,e]]]
is there a way of merging everything into a single list, for example
[a,b,c,d,e]
i have a problem when i try to re run my code by doing execute entire sheet, but when i first create it, it run without any errors
I have a Vector of polynomials in x[1] and x[2]; and I want to use coeffs to get the coefficients of bothe elements of the Vector; using the command:
Eq2Coeffs := `~`[coeffs](%, [x[1], x[2]])
bizarely the result i get is something in terms of x[1] and x[2].
Here is the worksheet this problem emerged in, the specific command is 3.8.
Hi ,
I want to ask if there is any maple code of how to construct wavelet to solve fractional differential eqautions? Or any reference may be help me
Hi there!
I like to work with output labels, since it allows me to execute a lot of code without having to make sure the respective previous calculations already ran each time I open the file.
Say my output is a list, and has label (1.3), then I can address the 2nd element of that list by (1.3)[2].
Sometimes output is organised in cases, for example when solving for the root of an equation. How can I address a specific case of that output using the output’s label?
If the case specifier is simple enough I can do that with "assuming". But when it is more complicated it is quite cumbersome to do so.
Thanks for help!
In the following program why the first row of Matrix P is costant, while I expect it varies?
MCK := Matrix(1, 1, {(1, 1) = 0.1627682387e-16*mu})
P := Matrix(2, 111):
`ρ__∞` := 1.225:
j := 1:
for `U__&infin;` from 333 to 335 do `M__&infin;` := `U__&infin;`/(331.2); mu := `&rho;__&infin;`*`U__&infin;`*(`M__&infin;`^2-2)/sqrt((`M__&infin;`^2-1)^3); P[1 .. 2, j] := `<,>`(`<,>`(MCK), `<,>`(j)); j := j+1 end do:
P[1, 1 .. j-1]
Vector[row]([0.1627682387e-16*mu, 0.1627682387e-16*mu, 0.1627682387e-16*mu])
Download Sooal.mw
here my problem i work on ;
i want maple to end the enternal loop if it can't solve the equation after  some iteration maple couldnt solve the equation and get stuck
with(LinearAlgebra); with(VectorCalculus); with(Student[LinearAlgebra]); with(SignalProcessing); with(Statistics); with(stats)
f[1] := n/R+sum(x[i], i = 1 .. n)-(sum((2+a[i])*x[i]*exp(R*x[i])/(exp(R*x[i])-1+Q), i = 1 .. n))
f[2] := m/S+sum(y[j], j = 1 .. m)-(sum((2+b[j])*y[j]*exp(y[j]*S)/(exp(y[j]*S)-1+Q), j = 1 .. m))
f[3] := (n+m+sum(a[i], i = 1 .. n)+sum(b[j], j = 1 .. m))/Q-(sum((2+a[i])/(exp(R*x[i])-1+Q), i = 1 .. n))-(sum((2+b[j])/(exp(y[j]*S)-1+Q), j = 1 .. m))
E1[1] := 0.5e-1
E2[1] := 0.5e-1
E3[1] := 0.5e-1
n := 45; m := 45
n := 45; m := 45
a := [seq(0, i = 1 .. 21), 2, 2, 1, seq(0, i = 1 .. 21)]; b := [seq(0, i = 1 .. 21), 2, 2, 1, seq(0, i = 1 .. 21)]
lambda1 := .9; lambda2 := .1; `&alpha;_&alpha;` := 5
K := 1000
so := 1; while so < K+1 do W := GenerateUniform(n, 0, 1); for iii to n do vv[iii] := W[iii]^(1/(iii+sum(a[jjj], jjj = n-iii+1 .. n))) end do; for sss to n do uu[sss] := 1-product(vv[n-jjj+1], jjj = 1 .. sss); x[sss] := fsolve(1-`&alpha;_&alpha;`/(exp(lambda1*t)-1+`&alpha;_&alpha;`) = uu[sss], t = 0 .. infinity) end do; U := GenerateUniform(m, 0, 1); for ii to m do v[ii] := U[ii]^(1/(ii+sum(b[jj], jj = m-ii+1 .. m))) end do; for ss to m do u[ss] := 1-product(v[m-jj+1], jj = 1 .. ss); y[ss] := fsolve(1-`&alpha;_&alpha;`/(exp(lambda2*t)-1+`&alpha;_&alpha;`) = u[ss], t = 0 .. infinity) end do; c := describe[quartile[1]]([seq(x[i], i = 1 .. n)]); cc := describe[quartile[3]]([seq(x[i], i = 1 .. n)]); L := describe[quartile[1]]([seq(y[i], i = 1 .. m)]); LL := describe[quartile[3]]([seq(y[i], i = 1 .. m)]); R[1] := fsolve(9*exp(R*c)-exp(R*cc) = 8, R = 0 .. infinity); S[1] := fsolve(9*exp(S*L)-exp(S*LL) = 8, S = 0 .. infinity); Q[1] := 3*(exp(R[1]*c)-1+(exp(S[1]*L)-1))*(1/2); for h to 40 while `and`(`and`(`and`(`and`(`and`(abs(E1[h]) > 0.5e-3, abs(E2[h]) > 0.5e-3), abs(E3[h]) > 0.5e-3), Q[h] > 2), S[h] > 0), R[h] > 0) do printlevel := 2; Q[h+1] := fsolve(eval(f[3], {R = R[h], S = S[h]}) = 0, Q = 0 .. infinity); S[h+1] := fsolve(eval(f[2], Q = Q[h+1]) = 0, S = 0 .. infinity); R[h+1] := fsolve(eval(f[1], Q = Q[h+1]) = 0, R = 0 .. infinity); if fsolve(eval(f[3], {R = R[h], S = S[h]}) = 0, Q = 0 .. infinity) = NULL then break end if; if fsolve(eval(f[2], Q = Q[h+1]) = 0, S = 0 .. infinity) = NULL then break end if; if fsolve(eval(f[1], Q = Q[h+1]) = 0, R = 0 .. infinity) = NULL then break end if; E1[h+1] := abs(R[h+1]-R[h]); E2[h+1] := abs(S[h+1]-S[h]); E3[h+1] := abs(Q[h+1]-Q[h]); KK := Matrix([[R[h]], [S[h]], [Q[h]]]) end do; A[so] := Determinant(KK[1]); B[so] := Determinant(KK[2]); C[so] := Determinant(KK[3]); so := so+1 end do
Error, cannot determine if this expression is true or false: 0 < K
Download Q3.mw
Hello to everyone!
I was trying to implement the following proc:
restart; with(plots); with(plottools)
"AngleSpectrum  :=  proc( theta )  local A, B, C, a1,a2,col,k,n;  n := floor(2*Pi/theta):  for k from 1 to n do      a1 := theta*(k-1);   a2 := theta*(k);      if( k mod 2 = 0) then col := COLOR(RGB,.8,.3,.5);      else col := COLOR(RGB,.4,.3,.5) ; fi;      A[k] := plottools[pieslice]([0,0], 1, a1..a2, color = col  ):      C[k] := textplot( [ evalf(1.2*cos(a2)), evalf(1.2*sin(a2)),                   convert(a2, string)]):  od:  display( seq( {A[k], C[k]}, k = 1..n), scaling=constrained);  end proc:"
Error, unterminated loop
Can anyone help me to figure out my mistake?
Download proc.mw
Good day everyone,
          I am trying to write a code for the loop of the equations below such the Theta[k] and Phi[k] start from 2 to M while F[k] starts from 4  to M.
         Anyone with good informations should please.
         Below is the link.
Thanks in anticipation
Solution_1.mw
First 789 790 791 792 793 794 795 Last Page 791 of 2429
