Suppose I have a subset of R^2, say (x,y) € [0,1] x [0,1]
Now I map
x=r*exp(t)
y=r*exp(-t)
Is it possible to do a 2d contourplot to just see where [0,1]x[0,1] is mapped onto ?
Hi everyone,
I'm having some difficulty replicating a vector diagram.
So I have learnt how to plot the vector diagram and I have been getting the correct results however the graph I am trying to replicate has some sort of limit within the range they are using which changes the direction of the vector. I was hoping to get this result, but I don't know how to achieve it. Could anyone point me to the right direction please.
Graph I want to replicate (i've highlighted the section that I want to achieve), what I get.
I look forward to your replies.
Thank you in advance
Are these errors to be expected? Why do they happen?
solve({x<>10, -infinity<x , x<infinity, -infinity<y , y<infinity},{x,y});
Error, (in solver) invalid input: SolveTools:-Inequality:-LinearUnivariateSystem expects its 1st argument, eqns, to be of type ({list, set})({`<`, `<=`, `=`}), but received {x <> -infinity, x < 10}
But it works when replacing x<>10 by y<>10
solve({y<>10,-infinity<x , x<infinity, -infinity<y , y<infinity},{x,y});
            {10 < y, x < infinity, y < infinity, -infinity < x}, {y <> -infinity, x < infinity, y < 10, -infinity < x}
What is the difference in the above two?
It also work when replacing x<>10 by x=10
solve({x=10, -infinity<x, x<infinity, -infinity<y , y<infinity},{x,y});
               {x = 10, y < infinity, -infinity < y}
It also works when removing the y parts by keeping x<>10
solve({x<>10, -infinity<x , x<infinity},{x,y});
           {y = y, 10 < x, x < infinity}, {y = y, x < 10, -infinity < x}
it also works when removing x<>10 and putting back the y stuff
solve({-infinity<x , x<infinity, -infinity<y , y<infinity},{x,y});
              {x < infinity, y < infinity, -infinity < x, -infinity < y}
Why Maple gives an error for some cases and not the others?
Maple 2018.1
I need to find a relation between delta [m,k] in terms of m and k
delta[m,k]=f(m,k), where k=0,1,2,...,m
A code is written (delta.mw) to find delta[m,k] for a certain amoun of m.
Is there a way or a code to find a general form of f(m,k)?
I've written a completely symbolic expression involving sum function. When I hit enter, Maple 2016.2 evaluates the expression although it's completely symbolic and not evaluable.
How to stop Maple from falsely evaluating a symbolic expression? I dis use the restart command to make sure all variables are empty. When evaluating Maple generate a very large open form expression that makes no mathematical sense.
Maple file in the following link
https://www.dropbox.com/s/13ciwothh1pqijk/sumBug.mw?dl=0
Please advice
I am fairly new to Maple and I'm currently researching twisted multiloop algebras. I'm trying to use Maple to automate many of the calculations. For example, suppose xy = yx + 2z and I have the expression wxy (the variables are non-commutative. I already have this functionality working properly with the physics package). I want Maple to make the substitution for xy and simplfiy. For example: wxy = w(yx + 2z) = wyx + 2wz. Is this possible?
Thank you for your help.
I have two matrices, one of the dimension of solution space that i have been using solve to navigate
this matrix will look something like:
M := matrix([[3, 2, 1], [2, 1, 1],[2, 1, 1]])
and I have another matix of the times that it takes solve to find these regions:
N := matrix([[.2, .4, .8], [.3, .6, .5], [.8, 2.3, 2.6]])
I'd like to find the sets {N[ij]:M[ij]=m for some integer m}; that is I'd like to get all the elements of N on entries of M with the same number so i can start thinking about them statistiaclly.
i.e. for 3 i'd like the list [.2]
      for 2                      [.4 .3 .8]
and so on.
I wish to extract a minimum route in a network given both start and end positions.
Also, I wish to avoid a spur in the circuit and obtain one continuous orthogonal  path.
As an example, take the 7-node case having 14 arcs (see worksheet) using Dijkstra's algorithm (I assume this is fit for purpose in this particular case).
Starting with node 1, the algorithm suggests the paths:
1>2>3>4>5>6>7.>8>9 and 1>2>3>4>5>10>11>12>13>14 (here, there is a spur at node 5 where the paths separate)
Is it possible obtain one minimum path?
The source node is prescribed in the routine - can anyone explain how to prescribe the end node?
Thanks for reading!
Shortest_Circuit.mw
I tried to integrate
int((1-x^floor(u))/((1-x)*u^2), u = 1 .. infinity, numeric)
where x=-1. The result should be log 2 = 0.6931471806. However it gives me 0.6687714032.
When using a numeric cut off, the result improves, so what is the issue here?
6687714032
Hello.
I have this problem when executing the entire worksheet or selected groups.
Also Maple can crash by itself, to its heart's content)
What I can do to solve this problem?
OS: W7 x64, Java is up to date
Thx.
Hi Guys i need some Help.
I created a work sheet where i am calculatin the polynominial coefficient of an equation. The Problem is that if i take these coefficient and then calculate the root with Matlab and compare it with the symbolic toolbox  i get wrong roots. My question now is did i something wrong by creating the coefficient ?
Polynom_Calculation.mw
These are the values for the parameters :
b1=0
b2=0
v1=0
v2=0
s1=0
s2=0.175
j2=0.28
tau =20
th1 = 0
th3 = 0
i added  my Maple skript. i hope that sb can help me.
In the first one I used hypergeometric function where the number is converged. Now using the series expansion of hypergeometric function I rewrite the equation as in the 2nd and 3rd case. But here it is not converging. I expect the same answer as in the first case i.e 0.14042. Thank you
problem2.mw
I have an 8*5 matrix, and i'd like to replace elements of it that are >20 with 20. For those interestedm, the matrix comes from this question.
M := Matrix(8, 5, {(1, 1) = 1.266, (1, 2) = .734, (1, 3) = .656, (1, 4) = .735, (1, 5) = 1.843, (2, 1) = 2.859, (2, 2) = 5.625, (2, 3) = 5.188, (2, 4) = 5.453, (2, 5) = 10.765, (3, 1) = 3.281, (3, 2) = 9.000, (3, 3) = 5.516, (3, 4) = 5.828, (3, 5) = 6.156, (4, 1) = 7.718, (4, 2) = 34.125, (4, 3) = 5.453, (4, 4) = 5.344, (4, 5) = 5.453, (5, 1) = 8.703, (5, 2) = 6.515, (5, 3) = 6.125, (5, 4) = 6.641, (5, 5) = 6.734, (6, 1) = 17.766, (6, 2) = 8.578, (6, 3) = 8.765, (6, 4) = 9.875, (6, 5) = 32.610, (7, 1) = 22.156, (7, 2) = 15.640, (7, 3) = 15.610, (7, 4) = 15.187, (7, 5) = 23.735, (8, 1) = 20.140, (8, 2) = 20.156, (8, 3) = 20.266, (8, 4) = 19.344, (8, 5) = 21.078})
I tried to create a logical matrix that i could input into M (this is how it works in maple) to select the elements so i could replace  them, but this didn't work
Hello,  how can i  to adapt the  commands  below  to write  in fprintf a vector with  N components.
 fd≔fopen("temp_file",WRITE);
fprintf(fd,"x = %d, y = %g",x,y)
fclose(fd)
For exemple: Given a vector (or list)  v:=[1,2,3,4,....N], i would like to get  a file with  N column and 1 line, where N is a integer number, which i will give.
Thanks for any help.
First 795 796 797 798 799 800 801 Last Page 797 of 2429
