I have a problem with "Infinitesimals" for the system of equations.
"Infinitesimals" Counts the system for (x, t) but shows an empty string for (x, y, z, t).
When I add to the equation (img 2) u [y, y], u [z, z] or simply y ^ 2, z ^ 2, Maple shows an empty string in Infinitesimal.
Thank you in advance.
Hi everybody,
Here is a piece of a more important worksheet where I need to push the number of Digits farther (Digits:=30:) than the default value.
Nevertheless I don't want to be annoyed by excessively lengthy outputs and I use interface(displayprecision=6).
It seems that the result of an operation which contains only floats is a 6 digits precision number but, as soon as the same operation contains an integer, the displayed precision equals the value of Digits  ???
To be honnest, simpler situations do not exhibit the behaviour shown in the attached file.
Can anyone explain me why I get tho wifferent displays for the quantity names xi__d ?
As always, great thanks in advance
displayprecision.mw
PS : I use Maple 2015.2 on Mac OSX El Capitan
Please house, I need help on how to compute a funtion a set of column data imported into maple and subsequently output results in a new column on the table.
I have successfully imported the table data from excel but I needed to write a code to recognize the column/columns I want to use as variables in the function and compute results using the column's data. Data table holds up to 14 x 25 datasets.
Any advice would be well appreciated.
this is a terrible maple crash just for a simple option !!!
only when i want to print the "x^2+y^2" in the caption of plot it raise exception !
but for some formulae there is no problem !
some technical guide or advise is needed ?
may someone check maple 2018 for this issue too ?
shekofte003.mw
Hello everybody,
I am quiet new to Maple and just have to program a small tool.
I need to show a conculison in a pop-up Window which should contain a matrix and a plot.
I tried different ways but they didn't work.
it seems that Maple2017 handles the noncommutative product wrongly (while it used to do it properly up to maple 17 afaik).
CODE:
with(Physics);
Setup(noncommutativeprefix={P,Q});
Q^2*P*Q + Q*P*Q^2;
simplify(%);
gives a correct result: BUT
Q(t)^2*P(t)*Q(t) + Q(t)*P(t)*Q(t)^2;
simplify(%)
gives the result:
2Q(t)^3*P(t)  (which is wrong).
It used to work fine in Maple 17. I need to differentiate noncommutative polynomials in P(t), Q(t), which was done without problem in Maple 17 but now seems to be broken.
Any explanation/workaround/fix? Is it fixed in Maple 2018?
One of the frustrating things I am finding in using Maple debugger is that I can't set breakpoint using stopat() at some line number in some inner module, if the inner module is local module. It has to be an exported module.
Here is an example
foo:=module()
   export main_entry;
   local foo1; #inner module. But if local, Can't set breakpoint from outside
   foo1:=module()
     export main_entry;
     local foo2;
     foo2:=proc() #or breakpoint in first line here
        local s,x;
        s:=1;     #suppose I want to set break point here
        s:=s+sin(x);
     main_entry:=proc()
        foo2();
  end module;
  main_entry :=proc()
    foo1:-main_entry(); #call inner module's proc
end module;
Since there is inner module, local to outside module, I can't set break into the inner module procs anywhere.
stopat(foo:-foo1::foo2);
Error, module does not export `foo1`
A workaround for now is to change "local" to "export" on the inner modules declarations I want to debug, so I can setbreak points inside them, then when done, make them local again. So changed "local foo1" to "export foo1" above, and now
          stopat(foo:-foo1::foo2,2);
works.
This was also a little strange to me, since foo2() is a LOCAL proc to module foo1, yet Maple did not complain like it did when module foo1 was a LOCAL module to foo. I would have expected Maple to complain again for same reason.
So I am using the above workaround for now. But it is just a little annoying becuase I have to keep changing module from LOCAL to EXPORT in order to set breakpoints, then remember to make them local again.
Is there a better workaround?
A product suggestion: make stopat() ignore the local module setting and treat it as export for the purpose of setting a break point. This way one does not have to change the code just to set a breakpoint. Or if not to change current behavior, add a new option, as in
          stopat(........, option= ignore_local_setting)
So the default remain the same as now, but with the new option, it will set breakpoint anywhere, even in local modules.
How can I calculate the roots of the following  trigonometric function?
F[lambda[i]] := (sin(lambda[i])-tan(y*lambda[i])*cos(lambda[i]))*((1-1/B)*lambda[i]^2-k)+(lambda[i]^3/B+lambda[i])*(cos(lambda[i])-tan(`yλ`[i])*sin(lambda[i]))
Where : i=1..n , B=1..30, y = 0.9 and k=0.003
An error message during opening a Maple file is seen:
ibb.co/hqOOkJ
I put the file link in below. The Maple file has been saved as Maple 2016.
https://files.fm/u/jpc3k5s4
I will be grateful if you can recover the file. Thanks
I would like to plot a graph whose legend has a Greek character with a numeric subscript. Below, there is a small example, where I show what I am trying to do:
# Simplified example, which is not working:
omega0:= 10:
plot(omega^2/omega0, omega = 1..1.5,
legend = [sprintf("%s = %.1f",`ω`[0],omega0)]);
# The character I want to be plotted inside the legend:
`ω`[0];
I suppose the problem is that " `ω[0]` is not considered a string and, therefore, I can not call it in the legend with a "%s". I do not know how to make it work, though. Does anyone know how to do so?
From help it says
"For any variable used within a procedure without being explicitly
mentioned in a local localSequence; or global globalSequence; the
following rules are used to determine whether it is local or global:
The variable is searched for amongst the locals and globals (explicit or implicit)
in surrounding procedures
, starting with the innermost.  If the name is
encountered as a parameter, local variable, or global variable of such
a surrounding procedure, that is what it refers to."
So it seems if I do not use explicit "global" on a variable, Maple can figure
if it is global or not using the above rules. But when I use explicit "global"
on a variable, Maple did not seem to do the same thing. Here is an example
foo:=proc()
  local a, inner_proc;
  inner_proc := proc()
     local b;
     b   := ithprime(10);
     a   := b; #this assiged the global (to this proc)
               #variable, which is "a" correctly
  inner_proc();
  return(a);
calling foo() gives 29.
But since the variable "a" in foo() is a global with respect to the inner_proc() (based on what the above help page seems to say), then why this does not work
foo:=proc()
     local b;
     global a;
     b   := ithprime(10);
     a   := b;
  inner_proc();
  return(a);
Now foo() returns "a". So Maple did not assign 29 to the global "a", (global to the inner_proc).
This for me makes little sense. Is global in Maple means the outermost scope only, skipping everything in between?
I thought global means any variable outside the proc itself. So if the proc() was inside another proc(), then the variables in the outer proc are global to the inner proc, even if they are declared local to the outer proc.
Why did Maple not do the assignment when I explicitly declare "a" to be global in the inner proc?
If you type ithprime (10^7) and hit return, the answer 179424673 is returned instantaneously, but if you do ithprime(10^8) there is no answer in ~ one hour plus (and maybe never), it just says “evaluating” and no answer comes. I have done calculations in Maple where the answer was a prime with ~18,000 digits yet cannot get beyond ithprime(10^7) when writing a code that needs to work up the prime list, looking for a particular one. Has anyone else encountered this apparent limitation in Maple?
Is there a way around it?
I'm having a hard time trying to understand and use the various fitting functions.
For starters, if I copy and paste the code from the example on the Maple support Help page for NonlinearFit(), I'm not able to successfully execute the code. It gives the error:
Error, (in Statistics:-NonlinearFit) complex value encountered
I've attached my Maple file: testing_nonlinearfit.mw
     I'm having trouble simplifying this square root:
assume(p::positive):
sqrt(sqrt(p^2+1)-1)*sqrt(sqrt(p^2+1)+1):
expand(%);
I expect it to give just p but instead it returns the full, unsimplifed expression.
This appears as part of a larger expression, and if it fails to simplify, terms won't cancel and the expression is much longer than it needs to be.
First 811 812 813 814 815 816 817 Last Page 813 of 2429
