I have a question about function as parameter in procedure
is it possible that I type
f := x-> x+1
Test (f(x))
instead of Test(f) ?
where Test is a simple procedure that takes in one function parameter
Test := proc (f)
return f(1) + f (2)
    Hello, colleagues!
    I want to find zero function given by the process that integrates the ODE, but get this warning and do not know what to do with it.  I will be grateful to any advice!!!
T0 := 300; G1 := 1.2*10^6; G2 := 1.2*10^6; k := 1.79333595*10^(-6); l := 1/(12*10^4); U_max := 5.0; th0 := .5; q0 := 0.1e-2:
u(x):=piecewise(x<=-1,-U_max,x>1,U_max,x<=1 and x>-1,0):
sys := diff(x1(t), t) = x2(t),
           diff(x2(t), t) = l*u(x4(t))-k*sin(2*x1(t)),
           diff(x4(t), t) = -x3(t),
            diff(x3(t), t) = 2*k*cos(2*x1(t))*x4(t);
init:=x1(0)=th0,   x2(0)=q0:
h1 := proc (t1, alpha_1, alpha_2, th_0, q_0, g1)::float;
local X1, X3, Res;
ptions operator, arrow;
global sys, u;
X1 := eval(x1(t), dsolve({sys, x1(0) = th_0, x2(0) = q_0, x3(0) = alpha_1, x4(0) = alpha_2}, numeric, range = 0 .. t1, output = listprocedure));
X3 := eval(x3(t), dsolve({sys, x1(0) = th_0, x2(0) = q_0, x3(0) = alpha_1, x4(0) = alpha_2}, numeric, range = 0 .. t1, output = listprocedure));
es := X3(t1)+2*g1*X1(t1);
return Res end proc
h2 := proc (t1, alpha_1, alpha_2, th_0, q_0, g2)::float;
local X2, X4, Res;
options operator, arrow;
global sys, u;
X2 := eval(x2(t), dsolve({sys, x1(0) = th_0, x2(0) = q_0, x3(0) = alpha_1, x4(0) = alpha_2}, numeric, range = 0 .. t1, output = listprocedure));
X4 := eval(x4(t), dsolve({sys, x1(0) = th_0, x2(0) = q_0, x3(0) = alpha_1, x4(0) = alpha_2}, numeric, range = 0 .. t1, output = listprocedure));
Res := X4(t1)+2*g2*X2(t1);
return Res
end proc
Test_h1 := proc (x, y)::float;
h1(10.0, x, y, 0.209327944398961e-2, -0.417641536045032e-3, G2)
Test_h2 := proc (x, y)::float;
h2(10.0, x, y, 0.209327944398961e-2, -0.417641536045032e-3, G2)
end proc
fsolve([Test_h1, Test_h2]);
Warning, unable to store _EnvDSNumericSaveDigits when datatype=integer[8]
Test_2.mw
Can someone help me to find graph of this type of solutions .
finalsol := exp(I*(-k*x+t*(k^2+2*rho^2-2*sigma^2)+theta))*rho*tanh(-2*k*rho*t+rho*x);
sol1 := eval(finalsol, [rho = .5, theta = .5, sigma = .5, k = .5]);
graph1 := plot3d(sol1, t = -5 .. 5, x = -5 .. 5, numpoints = 300, frames = 50, axes = framed, color = x, thickness = 5, axesfont = ["HELVETICA", "ROMAN", 24], labelfont = ["HELVETICA", "ROMAN", 24]);
ContPlot1 := contourplot(sol1, t = -20 .. 20, x = -20 .. 20, frames = 50, axes = framed, thickness = 5, numpoints = 300, a*xesfont = ["HELVETICA", "ROMAN", 24], labelfont = ["HELVETICA", "ROMAN", 24])
plot_solution.mw
in maple 12,
i follow https://en.wikipedia.org/wiki/Eigenvalue_algorithm
it said QR return eigenvector but after compare with eigenvector function, they are not the result from eigenvector function
M := Matrix([[1,2,3],[4,5,6],[7,8,9]]);
A := HessenbergForm(M);
Q1, R1 := QRDecomposition(A);
Q1, R1 := QRDecomposition(M);
v, e := Eigenvectors(M);
v, e := evalf(Eigenvectors(M));
in maple 2015
if start from GivensRotationMatrix , how many times of
GivensRotationMatrix in order to calculate the result of QR decomposition?
can this QR decomposition calculate the result of eigenvector?
Hi I was hoping if someone could mark this proof for a lemma regarding the Euler totient functin for me.
totient_lemma_proof.mw
How am I going to evaluate function like this ? I tried signum evalf, eval and solve, they dont work
I am working on problems in identifiability and I am interested in how many Lie derivatives of two kinds are required to get a full result for a simple system, and more interestingly a way of visualising what comes out when too few Lie derivatives are used.
The method is simple, I use Lie derivatives my own program GTS2 to get relationships that must be conserved for the output for two parameter vectors to give the same output (you can find it along with everything else for this question here.
An example of a list of parameter relationships is:
[{R = R, Rh = Rh, alpha = alpha, C[T] = C[T], Ch[T] = Ch[T], k[a1] = -(k[a2]*C[T]*R-kh[a1]*Ch[T]*Rh-kh[a2]*Ch[T]*Rh)/(R*C[T]), k[a2] = k[a2], k[d1] = k[d1], k[d2] = k[d2], kh[a1] = kh[a1], kh[a2] = kh[a2], kh[d1] = -(k[d1]*x[2]-k[d1]*xh[1]-k[d1]*xh[2]-k[d2]*x[2]+kh[d2]*xh[2])/xh[1], kh[d2] = kh[d2], x[1] = -x[2]+xh[1]+xh[2], x[2] = x[2], xh[1] = xh[1], xh[2] = xh[2]},{...},{...}]
i.e. they will show that there are multiple relationships that satisfy the Lie derivative conditions (each relationship is in a seperate set within the list) and within each set some parameters can vary freely (like R and Rh in the above) and others are determined by the ones that vary freely (like k[a1] and kh[a2]).
I want to count the numbers of parameters that have their relationships determined in three different ways so i can plot these numbers as the numbers of both types of Lie-Derivatives vary. These numbers are:
  1. N_i number of identifiabile parameters; parameters that in all solutions are of the form {p=ph or ph=p}
  2. N_l number of locally identifiable parameters; parameters that in all solutions take either the form {p=ph or ph=p} or {p=some function of the parameters with hs at the end of their names or ph=some function of exclusively the parameters without hs at the end of their names}
  3. N_u number of unidentifiable parameters; parameters that are neither identifiable or n locally-identifiable.
    I think its nice to have a link to a worksheet at the end of a question, so here_it_is_again.
Acknowledgement: most of the code in the above was based on snippets written by @Carl Love in response to my previous questions.
EDIT: I had some teaching to do, so uploaded the question early as i was writing in a computer room- as a result the maple worksheet I originally included was confusing, the worksheet I've included in this edit is much easier to understand.
TLDR: i am looking a way to count the numbers of outputs of various types from a program that is built around maples solve feature, and stuck
f := proc (y) options operator, arrow; -(1-tanh(y-.25)^2)^2+2*tanh(y-.25)^2*(1-tanh(y-.25)^2) end proc;
g := proc (y) options operator, arrow; (2*cosh(y-.25)^2-3)/cosh(y-.25)^4 end proc;
f(10);
                                      -8
                        2.719999946 10
g(10);
                                      -8
                        2.718614181 10
g(y) is simplify (f(y)), but f(10) is not equal g(10), why?
prove that
∇ x (∅F) = ∅∇ x F + (∇∅) x F
where ∅ and F are differentiable scalar function and vector function respectively.
When a child proc calls a parent local proc using parent_module:-parent_proc(), Maple gives an error. But when the child calls the parent local proc using just parent_proc() it works. Why is that?
parent_module:=module()
 local child_module;
 local parent_proc;
 export parent_entry;
 child_module:= module()
    export child_entry;
    child_entry :=proc()
     #parent_module:-parent_proc(); #this fails
     parent_proc(); #this works
  end module;
 #local
 parent_proc :=proc()
   print("insider parent proc");
 #public
 parent_entry :=proc()
   child_module:-child_entry();
end module;
parent_module:-parent_entry();
but the other way, (the commented code above) gives
Error, (in child_entry) module does not export `parent_proc`
Hello there!
I was wondering if there is a way we can skip one or more variables from LSSolve to be optimized on a specific value?
For exmaple, please see the following file
restart; with(Optimization)
[ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize, NLPSolve, QPSolve]
LSSolve([x-1, y-1, z-1], {-10 <= x, x <= 0, 6*x+3*y <= 1}, initialpoint = {x = -1, y = 1})
[.711111111111111138, [x = HFloat(-0.06666666666666665), y = HFloat(0.46666666666666656), z = HFloat(1.0)]]
Can I skip the value of x and just find a global minimum of the objective functions over the given range of x, not just the specific value?  Its because I need to keep x as a variable.
Download LSSOLVEparameter.mw
Bisection := proc (f, a, b, delta)
local startpoint, endpoint, midpoint; startpoint := a; endpoint := b;
do midpoint := (1/2)*startpoint+(1/2)*endpoint;
if abs(startpoint-endpoint) < delta or abs(f(midpoint)) < delta then
return midpoint
elif f(midpoint) < 0 then endpoint := midpoint
elif 0 < f(midpoint) then startpoint := midpoint
end if end do end proc
I'm trying to do a procedure for bisection method but it doesnt give me answer when  I type
Bisection (x-> x + 0.001 , 1, -1, 0.001 )
it returns Bisection (x-> x + 0.001 , 1, -1, 0.001 )
why this is happening, Is it because the procedure is wrong ? or does not provide answer
What is the difference between a divisor and a factor? Like:
with(numtheory):
X := 89733992396903316277681863138688595394562888838833;
S := map(expand, [op(ifactor(X))]):
And we have the singleton of unity for the output of:
divisors(X/(product(S[j], j = 1 .. nops(S))));
and so on:
seq(divisors(X/(product(S[j], j = 1 .. nops(S)-k))), k = 0 .. 3);
but yet if i try
divisors(X);
my computer freezes.
So yes although my friend is somewhat embarassed to not know the difference and needed me to ask for him what the difference between a divisor and a factor is.
Like is it just the uniqueness? ie a factor is one of the terms in the product of a number's prime factorization, where as any number that divides the number is considered to be a divisor?
like for example i can then go:
seq(min(`minus`(divisors(X/(product(S[j], j = 1 .. nops(S)-k))), {1})), k = 1 .. 10);
X:=X/(131*(139*(151*(163*(173*167)*157)*149)*137)*127)
from the first 10 terms reducing it original number substantially to:
 17026820583257598495326242577
and carry this on i dont see why i cant end up with the divisor set that caused my computer to freeze if i just called divisors(X) as I originally did
https://www.youtube.com/watch?v=qSO2lLiDybg
with(numtheory):
S0 := map(expand, [op(ifactor(X))]);
[31, 47, 59, 61, 67, 71, 73, 79, 89, 97, 101, 103, 107, 109, 113, 127, 131, 137, 139, 149, 151, 157, 163, 167, 173]
P := convert([seq(min(`minus`(divisors(X/(product(S0[j], j = 1 .. nops(S0)-k))), {1})), k = 1 .. 15)], '`*`');
72255473008151934648648475807453
S1 := divisors(X/P):
seq(`mod`(X, S1[k]), k = 1 .. nops(S1))
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
Download what_the_fook.mw
I am writing a code which for various discrete x values needs to import from a pre established file,  values of f(x), which must be used for the present calculation, then forgotten. Is there any way I can set this up in Maple? If so I would be much obliged to learn how to do it. I have ~100 data pairs (x,f(x)), with no formula.
David.
I encountered a bug in a combination of simplify and Int. A minimal example is given by the following commands (code attached in file bug.mw):
# simplification bug: first result pulls r out from under the dr integration
integrand := r;
simplify(Int(integrand, phi = 0 .. 2*Pi, r = 0 .. 2));
simplify(Int(integrand, r = 0 .. 2, phi = 0 .. 2*Pi));
simplify(Int(integrand, r = 0 .. 2));
simplify(Int(integrand, phi = 0 .. 2*Pi));
give a wrong result at the first simplify, whereas the others work correctly. It seems that simplify only checks the first integration variable when deciding whether to pull out the factor r from the integral.
As Maplesoft does not advertise a dedicated bug report email/site I post it here. If there is one, where can one find it?
Cordially,
  htc
First 815 816 817 818 819 820 821 Last Page 817 of 2429
