Using Typesetting:-Suppress(f(t)) I can suppress the dependency of f(t) in the differential equation eq := {diff(f(t), t) = f(t)}; in the output when I type eq
However, when I want to export the output to LaTeX or MathML using latex(eq) and MathML[ExportPresentation](eq), the dependency on t is still there!
How to remove the dependency on t?
When I have an Operator like
eq:=1/r*diff(r*diff(f(r),r),r)
typically maple evaluates/expands it by product rule.
How can I tell him to not do it?
I tried using the inert operator % but probably i didn't do it right.
Hi everybody,
I want to compare the performances of a set of codes that realize the same operation.
The worksheet I use is organized this way
Code1 := proc(...) ... end proc:
CodeTools[Usage](Code1(...))
Code2 := proc(...) ... end proc:
CodeTools[Usage](Code2(...))
and so on.
It appears that the execution of the whole worksheet doesn't always return the same values for the different indicators, which means that the ranking of the codes can be affected
To obtain more precise indicators I thought do do some statistics.
I then replace each bloc by :
CodeX := proc(...) ... end proc:  # here X stands for 1, 2, ...
N := "some positive integer"
for n from 1 to N do
   CodeTools[Usage](CodeX(...))
   "catch the values of the indicators"
"compute some statistics on the samples ot these indicator"
The problem is that Usage doesn't return any values but only does a printf.
I investigated two ways to circumvent this problem:
  1. - redirect the printings to file MyFile by using writeto(MyFile)
    - read MyFile
    - extract the numerical values of the indicators
    - compute the desired statistics
      It works well but it is far from being elegant
  2. - insert with(CodeTools) after the restart (within a separate block)
    - copy-paste the output of showstat(Usage) to define a new function, let's say MyUsage
    - insert at the correct place some lines like
             Tcpu := CodeTools:-FormatTime(result:-cputime)  (if my time of interest is the cpu time)
                          (this for all the indicators)
    - insert the line  [..., Tcpu, ...]; before the 'end proc' declaration;
      More elegant but it doesn't work
      I get the error   error (in T) DoUsage is not a command of the CodeTools package
Do you have some idea (beyond the first method above) of the way to catch the performance indicators that Usage computes ?
Quadratic equation ax^2 + bx + c = 0. Coeff's long and ugly expressions in their own right, but I know that a is nonzero, that there is at least one real solution, and that I want the largest.
So, question: How do I get Maple to return the -b/2a PLUS sqrt((b/2a)^2-c/a) solution?
I am learning patmatch. And found strange problem.
When I make an expression inside a proc A, and pass this expression to another proc B, which then uses patmatch  on it, the pattern fails to match.
but calling proc B directly, with exactly same expression, patmatch does match.
This is confusing and not sure why it happens. It seems related to using symbol which was declared local vs. same symbol but is global. Here is an example
foo:=proc()
  local x,C1;
  boo(exp(C1+x));
boo:=proc(expr)
  local a,b,c,la;
  patmatch(expr,a::anything*exp(b::anything*C1+c::anything),'la');
Call to foo() returns false. But call to boo() returns true. Even though I am using same expression.
foo();
C1:='C1':
x:='x':
boo(exp(C1+x));
What Am I doing wrong, and how to make it work in both cases?
Not sure if it's the right place to ask this very simple question.
I have solved a DE and got x(t) = _C1*sin(sqrt(k)*t/sqrt(m)). Both _C1 and sqrt(k/m) are constants but I want to use different letters for them. I want _C1 to be renamed A and sqrt(k/m) to be renamed W. Can someone please suggest how I can do this ?
Hello everyone!
I miss a convinient way to build interactive plots with parameters assigned to sliders. E.g. of such expressions as "a*sin(b*x+c)". Before Maple 2017 I could just right-click the expression, choose "plot builder" and then select "interactive plot with three parameters". That's it. Since the introduction of the new interactive plot builder I am at a loss because that way have been lost and I don't know any other way equally quick and convinient. "Interactive plot builder" now means quite another thing!
Any suggestions?
Hello everyone!
I want to solve a pde and create a matrix. But unfortunately, an error is formed.
Please, someone help me to remove that error.
Here, I am attaching a mapple file.
pde_solu.mw
Probably I'm doing something severely wrong, but
sum(x^n,n=0..infinity)
does not evaluate to the geometric series result 1/(1-x), why?
Similarly this happens for the sum(x^n/n,n=1..infinity)
It works with Maple17 though.
Hi, i want to solve the Ax=b with jacobi method and 4 Iteration, A=Matrix(3, 3, [1, 2, 1, 2, 1, 3, -1, -3, 4]) and b=[8, 13, 5].
i want to write a code with for or if or while. tnx
MAPLE will evaluate the 1st integral below, but not the 2nd.  Is it possible to get MAPLE to do the evaluation?  I know it can be done numerically, but what about analytically?
int(sin(Pi*x*n/T), x);
int(sin(Pi*x*n/T)*cos(Pi*x*n/T)/(sin(Pi*x/T)*cos(Pi*x/T)), x);
Hi everyone !!
I have a problem to find a solution for some symbolic nonlinear equations. I used the solve command but it takes much time and finally, I stopped the process because doesn't give me a solution. I have attached the code.
Please, help me
Cond_Poincare.mw
I*mu*A(t[2])*omega[0]*(1/2)-A(t[2])*omega[0]*(diff(B(t[2]), t[2]))+I*(diff(A(t[2]), t[2]))*omega[0]-(1/4)*A(t[2])^5*beta[2]*omega[0]^2-(1/4)*A(t[2])^3*beta[1]*omega[0]^2-(1/2)*F[0]*exp(I*sigma*t[2]-I*B(t[2]))+5*alpha[2]*A(t[2])^5*(1/16)+3*alpha[1]*A(t[2])^3*(1/8);
((1/2)*I)*mu*A(t[2])*omega[0]-A(t[2])*omega[0]*(diff(B(t[2]), t[2]))+I*(diff(A(t[2]), t[2]))*omega[0]-(1/4)*A(t[2])^5*beta[2]*omega[0]^2-(1/4)*A(t[2])^3*beta[1]*omega[0]^2-(1/2)*F[0]*exp(I*sigma*t[2]-I*B(t[2]))+(5/16)*alpha[2]*A(t[2])^5+(3/8)*alpha[1]*A(t[2])^3
simplify(%);
-(1/2)*F[0]*exp(-I*(-sigma*t[2]+B(t[2])))+I*(diff(A(t[2]), t[2]))*omega[0]+(1/2)*(-2*(diff(B(t[2]), t[2]))*omega[0]+(-(1/2)*beta[2]*omega[0]^2+(5/8)*alpha[2])*A(t[2])^4+(-(1/2)*beta[1]*omega[0]^2+(3/4)*alpha[1])*A(t[2])^2+I*mu*omega[0])*A(t[2])
subs(C(t2)=-sigma*t2+B(t2),%);
Download no_change.mw
I need to use newtons method to solve this in maple if someone can help me i will be very thankfull
help required to find the value of u analytically
First 818 819 820 821 822 823 824 Last Page 820 of 2429
