I am asking the students to write down the integral  (1/3)*int(10*cos(2*Pi*t/3),t=-1..1) without calculating it.  Both Maple TA in student answer, and Maple in my algorithm evaluate the integral. I just want the formula to be displayed not evaluated. How can I do that.  Thanks in advance.
I am using this proc by Carl Love posted here
https://www.mapleprimes.com/questions/211401-How-Do-I-Print-Text-Followed-By-Math
TSprintf:= proc()
   local e;
   uses T= Typesetting;
   T:-mrow(seq(`if`(e::string, T:-mn(e), T:-Typeset(T:-EV(e))), e= [args]))
when I do
         TSprintf("Solving ", diff(y(x),x)=x);
it works fine and it prints on the screen as expected.
The problem is that inside a proc, if I use an error() later on, the message do not show up
foo:=proc()
   TSprintf("Solving ", _passed);
   error "opps"
And now when I call it like this
  foo(diff(y(x),x)=x);
      Error, (in foo) opps   # Where the message "solving...." gone?? it does not show on the screen
I only see the "opps" and never see the message.  If I remove error(), then it shows up. But with standard printf, both show up
foo:=proc()
   printf("Solving %a", _passed);
   error "opps";
    Solving diff(y(x),x) = x  # printf message shows OK
    Error, (in foo) opps      # from error
Why TSprintf message do not show up if there is an error() after it?
Hello all,
     When using maple's differential equation solvers (dsolve or pdsolve), solutions will often have undetermined constants (or functions) _C1, _F2(x), _F5(t,x), etc. These are automatically generated and could potentially cause name collisions. I've found that passing names as part of the solver's ranking prevents this. For instance
D[1,1](y)(t,x) + y(t,x) = 0:
pdsolve(%);
would return y(t,x) = _F1(x)*cos(t) + _F2(x)*sin(t). However, if _F1(x,z) is defined elsewhere, then passing
pdsolve(%, {y(t,x), _F1(x,z), _F2(x,z)});
instead returns y(t,x) = _F3(x)*cos(t) + _F4(x)*sin(t), preventing a collision.
However, it seems that PDEtools:-Solve doesn't follow this same convention. Indeed, calling PDEtools:-Solve(%, {y(t,x), _F1(x,z), _F2(x,z)}) on the above system returns y(t,x) = _F1(x)*cos(t) + _F2(x)*sin(t).
In all fairness, this is only a problem since my "colliding" functions are actually different functions: they differ in their arguments. When the arguments are the same (for instance, passing {y(t,x), _F1(x), _F2(x)} to Solve) then no collision occurs.
Nevertheless, having two different functions with the same name is causing problems for my code (later invocations of Solve with both _F1(x) and _F1(x,z) causes an "found functions with same name" error).
Is there any trick to avoid this behavior?
I am learning to use module().  If one has a local private proc() inside  a module, then on calling this local proc from inside the module itself, does one need to call it using module_name:-local_proc() or is it safe  to just call it using local_proc()?
i.e. will Maple always look to resolve this name inside the module first, before looking outside? What order Maple uses to resolve names?
Here is an example
private_proc:= proc()
    print("Opps, should not be calling this, global copy");
foo :=module()
    local private_proc;
    export public_proc;
    private_proc:=proc()
        print("inside private");
   public_proc:= proc()
        private_proc(); #will this always call foo:-private_proc() and not
                        #any other global proc with that name?
end module;
foo:-public_proc();
gives "inside private". So it seems to work without having to use foo:-private_proc(). But I thought to ask if the above will always work like this.
Hi guys,
I always thought matrices (Matrix) and 2D arrays (Array) where different objects in Maple.
In the attached file you will find a few examples of build-in functions which prove that Maple doesn't always check correctly the type of the arguments.
Beyond the questions set in the attached file, is there some tacit and unspoken rule in Maple which considers that Matrix and 2D Array have to be treated equally ?
Thanks for your answers
Matrix_or_Array.mw
For the most part, when I have come across bugs (or what appears to be bugs from my naive view, maybe it is left unevaluated for some means of diplomacy that I am not privy to) they are very difficult or impossible for me to find a way to get around.
But I have found alot recently that I was able to fix very quickly using functions that are already inbuilt in maple. Most have to do  with evaluating functions of trancendental arguements or composites of trancendental functions, but still, it leaves me feeling a little disturbed just how readily it was resolved.
I don't know exactly what to say, perhaps a 'dispatch' needed to be included in an inbuilt procedure to inform the 'engine' that a user has come across a bug of some kind at that address, so that maplesoft can keep the process of applying patches in house, avoiding having to enable the evolution/personal development the inept user that clearly stumbled upon the bug by sheer coincidence whist entering formula and observing output in a relatively sub human cognitive state?
  I want to calculate values of constants a[1] and b[1] by NonlinearFit model for two equations mentioned in below
(1/a[1]*x*t)*(1+a[1]*x^(2)*t+2*b[1]*x)    and  (1/b[1]*x*t)*(5*x*t+20*b[1]*a[1]*x*t^2+2*b[1]*x)
I know for the nonlinearfit model we need a data. But in my case, I do not have any data. So maybe data can be obtained by the numerical method, but how I do not know
i want to write the code for picewise polynomial :
if i take h=10 ,interval [0,1] takes the values j =0,0.1,0.2,     so on up to 1 and the polynomial it should take
(x-xj+1)/0.1,when x<0.1,
(x-xj+2)/0.1  when x<0.2
(x-xj+9)/0.1   when x<1
I only just noticed the Start.mw file being always number 1 in my Recent document list.  I don't recall it being there, ever, and I don't think it should.  Why is it there now?  Anyone else have this?
I am trying to show visually how many Lie derivatives of two different objects are needed to get a unique solution to a problem, so i want to create a graph of the form:
for the elements of this workseet:
3d_plot_of_Lie_derivatives_against_numelems.mw
Ok the error message I originally recieved in requesting 'expression' rather than 'value' was telling me the input is ambigous, isn't exactly helpful.
With the uploaded worksheet as last attempted, it gives the error of something about an invalid sequence, but still and I honestly do not see how when MathML is an XML application, surely whatever is put into the math container is retrievable considering XML applications are based on just handling the rendering of symbols.
Anyway I can only post here seeings that following the link for error messages rarely opens an actual help page in the brower, it simply tells you there is no help page for that error.
MathML[ImportModified](DocumentTools[GetProperty]('IIRN_CONTENT15', 'value'))
Error, (in MathML:-ImportModified) Typesetting:-merror("invalid sequence")
MathML[ImportModified](DocumentTools[GetProperty]('IIRN15', 'value'));
808066846690
Download 26052018.mw
Hellow,
how to write the codes for linear Lagranges piecewise polynomial in the interval x=[0,1] by taking h=0.1.
if we fix h=0.1 automatically it should take the polynomial like these sample
x<0.1,(x-1)/0.2,x<0.2,(x^2-3x)/0.2,..... so on
Dear sir,
I want to plot the graph of Differential Equation numerically and other equation by changing the parameter values beta=2,2.5,5 . i am writing an sample codes and graph. the range of x is 0,..0.1
Eq1:=diff(y(x), x, x)+beta*y(x) = 0, y(1) = sin(1), (D(y))(1) = cos(1):
Eq2:=y=beta*e^x+sin(2*x)+x^2:
In the same vein as my last question, I need to bang out function symbols depending on a variable list of parameters, and refer to them later. I'm currently doing this:
PW > FunGen := symb -> PDETools[declare](symb(w1, w2, x1, y1), symb);
F > F0 := [b, seq(cat(r, i), i = 1 .. k), seq(cat(s, i), i = 1 .. k)];
                          [b, r1, s1]
PW > map(FunGen, F0);
          b(w1, w2, x1, y1) will now be displayed as b
         r1(w1, w2, x1, y1) will now be displayed as r1
         s1(w1, w2, x1, y1) will now be displayed as s1
F > dx := i -> 'eval(cat(dx, i))';
dy := i -> eval(cat(dy, i));
r := i -> parse(cat(r, i, "(w1,w2,x1,y1)"));
s := i-> parse(cat(s, i, "(w1,w2,x1,y1)"));
epsilon := i -> cat(epsilon, i);
F > bb := parse(cat(b, "(w1,w2,x1,y1)"));
I generate the function aliases for r,s,b depending on w1,w2,x1,y1, and refer to them later with 'r(i)', 's(i)' and bb. In general however, the number of x's and y's is variable (depending on k).
What I would like to do is something like
F > args := w1, w2, seq([x || i, y || i][], i = 1 .. k);
                         w1, w2, x1, y1
PW > FunGen := symb -> PDETools[declare](symb(args), symb)
r := i -> (cat(r, i)(args)
This does now however work, even though cat(r, i)(args) on a standalone line does indeed produce ri(w1, w2, x1, y1) and correctly parses to r1, etc.
Hi All,
I recently switched from Maple 18 to Maple 2018. I was trying to execute and old worksheet created with Maple 18 in which a DAE have to be solved numerically. In Maple 18 the worksheet works flawlessly whereas Maple 2018 throws 'Error, (in dsolve/numeric/process_input) invalid specification of initial conditions...'
Initial conditions are given in the form {x1(0) = 1, x2(0) = 2, D(x1)(0) = 1, D(x2)(0) = 0 ....} and are the same in both cases ( I merely executed without any modification the same worksheet in the two Maple versions).
I feel I've missed out something in the changelog... any idea on what is happening?
PS. call to dsolve
dsolve(dsys_numeric, numeric, implicit = true, stiff = true, optimize = true, compile = true):
First 820 821 822 823 824 825 826 Last Page 822 of 2429
