1-Write a Maple ProcInserer procedure (x, pos, L) that inserts the element x into L at position pos.
 2- Write an inverse procedure (L) taking as argument a list L and returning the list obtained by inverting L in the decreasing direction of the indices.
The function given is f(x)= x3/4-sin x +1/2, interval=[0,2*pi]
a) plot the function over the interval to see its general behaviour.
f := x -> x^(3/4)-sin(x)+1/2;
plot(f(x), x=0..2*Pi);
b)FInd the interior points where f'=0.You may want to plot the f' as well.
d1:=D(f)(x);
plot (d1, x=0..2*Pi);
fsolve(d1=0, x);
       5.231279862
c) Find the interior points where f' does not exist.I don't know how to show question c) in Maple. Please help?plot(x^(3/4)-sin(x)+1/2, x=0..2*Pi)    plot(3/4*x^(-1/4)-cos(x) , x=0..2*Pi)
When i do this,
d2:=solve(d1=infinity,x);
Is this the correct way to shoe f' does not exist? How to I get the numerical value of the RootOf....?
Write a procedure that says whether or not an item a is in a  list L, and at which place (if there are several times the same item, you can return the place of the first, or the list of places of all the occurrences of a).
I got a double sum as a solution to heat equation in 2d. How do I plot that för different time values?
I can't get the right syntax for add, op
Can anyone tell me why the following command
restart; with(plots): with(Statistics):  with(numapprox):
 create an error of this type?
Error, Got internal error in Typesetting:-Parse : "cannot determine if this expression is true or false: membertype(specfunc(Typesetting:-mspace),Typesetting:-mempty(Typesetting:-mspace(depth = "0.0ex",height = "0.0ex",width = "0.0em",linebreak = "newline")))"
lambda := .2;
                              0.2
mu := .3;
                              0.3
F := proc (n)
exp(-lambda*t)*(lambda*t)^n/factorial(n)
P := proc (n) local ret, i; ret := 0;
for i from 0 to n do
if i = 0 then ret := ret+evalf(exp(-lambda*t))
elif i = 1 then ret := ret+evalf((diff(exp(-lambda*t), t))/mu+lambda*exp(-lambda*t)/mu)
elif i < n then ret := ret+evalf((diff(exp(-lambda*t)*(lambda*t)^(n-1)/factorial(n-1), t))/mu+(lambda+mu)*exp(-lambda*t)*(lambda*t)^(n-1)/(mu*factorial(n-1))-lambda*exp(-lambda*t)*(lambda*t)^(n-2)/(mu*factorial(n-2)))
else ret := ret-(diff(exp(-lambda*t)*(lambda*t)^n/factorial(n), t))/mu+lambda*exp(-lambda*t)*(lambda*t)^(n-1)/(mu*factorial(n-1)) end if
ret
Hello everyone
I am new in mapple software and i am facing some proplem to tackle  Laplace equation and Poisson equation. I want to find out the potential psi given in two equations
I want to solve following equ with finite difference method in order to find potential psi .In the second equation  n = concentration of electrons  ,p= concentration of holes and C= additional concentration ,q is electronic charge .
Can anyone suggeset how I can solve this type of partial differential equation with numerical method (FDM) in mapple?
Hi everybody:
i want to obtain the binary(basis of two) of a number with procedure and without use the convert command, can everyone help me? tnx.
I am trying to find k1,m1,k2,m2 from these four equations defined in sys but Maple does not give any solution. Any suggestions?
sys := {(k1*m1+k1*m2+k2*m1+sqrt(k1^2*m1^2+2*k1^2*m1*m2+k1^2*m2^2+2*k1*k2*m1^2-2*k1*k2*m1*m2+k2^2*m1^2))/(2*m1*m2) = (2*Pi*8.78)^2, .8347192842*k1/m1 = (2*Pi*4.8515)^2, -(-30.85287127*k1-k2)/m2 = (2*Pi*8.78)^2, -(-k1*m1-k1*m2-k2*m1+sqrt(k1^2*m1^2+2*k1^2*m1*m2+k1^2*m2^2+2*k1*k2*m1^2-2*k1*k2*m1*m2+k2^2*m1^2))/(2*m1*m2) = (2*Pi*4.8515)^2};
solve(sys, {m1,k1,m2,k2});
Bahar
I have 6 parameters, say p1 - p6, which enter my Monte Carlo Code and computes a 1-D Array of floats of size 1000 . I have an experimental array of floats of the same size. My code outputs an array which is the difference of these two arrays. The objective function is the sum of the sqares of the elements in this output array. I have initial guess for the parameters: p1i - p6i. I need to find the values of the 6 parameters which minimize the objective function.
Obviously I do not have an explicit mathematical form for the objective function and nor its Jacobian.
Could some one please help me in this task.  Thanks in advance.
Greetings, I am trying to make augmented matrix in the form of A, B and F where A is the tridiagonal matrix, B is the vector and F is the non-linear part of the system. I already tried (A,B,F):=augment(X,output='A','B','F'); but it is an error. Can someone help me? Thank you in advance!
The matrix X is as follows:
X:=[[[-lambda/(h^2),-u/(2 h)+lambda/(h^2),0,0],
       [u/(2 h)+lambda/(h^2),-lambda/(h^2),-u/(2 h)+lambda/(h^2),0],
       [0,u/(2 h)+lambda/(h^2),-lambda/(h^2),-u/(2 h)+lambda/(h^2)],
       [0,0,u/(2 h)+lambda/(h^2),-lambda/(h^2)]]];
I have a matrix with complex entries! and I want to multyply that by it's conjugate. But I can have a simplify form for example  I have matrix A and B as below thier multiplication is a real matrix but it does not give me in simplifyied form!
I have made a plots[multiple] with 3 different functions, but I wish to connect the ends with vertical lines. Does anybody have a solution to this? I have uploaded screenshot Thank you in advance. BR Jens
Hello people in mapleprimes,
I am writing this sentences, hoping to be given any answer from you, to the
question I have, about conversion of Array to List.
a:=plot3d(theta*z,theta=0..2,z=0..1,coords=cylindrical,grid=[3,2]);
A:=op([1,1],a);
brings a response of Array as, which I call BB,
Array(1 .. 3, 1 .. 2, 1 .. 3, {(1, 2, 3) = HFloat(1.), (2, 2, 1) = HFloat(.540302305868139765), (2, 2, 2) = HFloat(.841470984807896505), (2, 2, 3) = HFloat(1.), (3, 2, 1) = HFloat(-.832293673094284814), (3, 2, 2) = HFloat(1.81859485365136342), (3, 2, 3) = HFloat(1.)}, datatype = float[8])
And, I converted it to List, with
convert(A,list,nested);
The response of this is, which I call CC,
[[[0., 0., 0.], [0., 0., 1.]], [[0., 0., 0.], [.540302305868140, .841470984807897, 1.]], [[-0., 0., 0.], [-.832293673094285, 1.81859485365136, 1.]]]
, which is composed of three lists:
Then, my question is following:
Seeing CC, I can see three segments are shown.
The first one is  the segment between [0., 0., 0.] and [0., 0., 1.].
But, I can't find any elements of Array BB corresponding to [0,0,0] above in CC.
And as for 0, 0 in [0, 0, 1] in CC above, the first 0 should be (1,2,1) and the second one should be (1,2,2).
But, there are no such (1,2,1) and (1,2,2) in BB.
Despite of these, BB is converted to CC, from any reason I want to know and ask this question for.
As for [[0., 0., 0.], [.540302305868140, .841470984807897, 1.]] in BB, the circumstances are the same.
I don't know from where [0,0,0] appeared. Surely, as MESH requires three points, you might say that
such things might occur. But, it is only after I converted Array BB to List CC, with plot3d or MESH then having no relation
to the present circumstances. So, I think that it is not possible to say that Maple added [0,0,0] or such things to Array BB
 as it is about plot 3D or about MESH.
So, my question is how the conversion of BB to CC could have occurred.
May_16_2018_question.mw
How can I this problem using maple when you are meant to use a linear transformation and find an equation for eq* using a matrix.
The matrix
The eqution.
eq := 2*x-3*y+z = 4
eq*
This is how the problem is specifed.
A: eq --> eq*
First 824 825 826 827 828 829 830 Last Page 826 of 2429
