Please help me to remove error from the plotting. Here I have attached a mapple file
.u_nonlinerafit.mw
I figured out what the interpolation is, but can someone please give me a reference for the publication of the person that discovered that this works thankyou.
PolyI1 := proc (N, n) options operator, arrow; (-1)^N*(sum(n*factorial(n-1)*(-1)^k*a[k]/(factorial(n-N-1)*(n-k)*factorial(k)*factorial(N-k)), k = 0 .. N)) end proc
PolyI2 := proc (N, n) options operator, arrow; CurveFitting[PolynomialInterpolation]([seq([k, a[k]], k = 0 .. N)], n) end proc
collect(expand(PolyI1(2, n)), n); PolyI2(2, n)
((1/2)*a[2]-a[1]+(1/2)*a[0])*n^2+(-(1/2)*a[2]+2*a[1]-(3/2)*a[0])*n+a[0]
collect(expand(PolyI1(3, n)), n); PolyI2(3, n)
((1/6)*a[3]-(1/2)*a[2]+(1/2)*a[1]-(1/6)*a[0])*n^3+(-(1/2)*a[3]+a[0]-(5/2)*a[1]+2*a[2])*n^2+(-(3/2)*a[2]+(1/3)*a[3]-(11/6)*a[0]+3*a[1])*n+a[0]
collect(expand(PolyI1(4, n)), n); PolyI2(4, n)
(-(1/6)*a[1]+(1/4)*a[2]-(1/6)*a[3]+(1/24)*a[0]+(1/24)*a[4])*n^4+(-(5/12)*a[0]+(3/2)*a[1]-2*a[2]+(7/6)*a[3]-(1/4)*a[4])*n^3+((35/24)*a[0]-(13/3)*a[1]+(19/4)*a[2]-(7/3)*a[3]+(11/24)*a[4])*n^2+(-(25/12)*a[0]-(1/4)*a[4]+4*a[1]-3*a[2]+(4/3)*a[3])*n+a[0]
collect(expand(PolyI1(5, n)), n); PolyI2(5, n)
((1/12)*a[3]-(1/120)*a[0]+(1/24)*a[1]-(1/12)*a[2]-(1/24)*a[4]+(1/120)*a[5])*n^5+(-a[3]+(11/24)*a[4]+(1/8)*a[0]-(7/12)*a[1]+(13/12)*a[2]-(1/12)*a[5])*n^4+((49/12)*a[3]-(41/24)*a[4]+(7/24)*a[5]-(17/24)*a[0]+(71/24)*a[1]-(59/12)*a[2])*n^3+((15/8)*a[0]-(13/2)*a[3]+(61/24)*a[4]-(5/12)*a[5]-(77/12)*a[1]+(107/12)*a[2])*n^2+(-(137/60)*a[0]+5*a[1]+(10/3)*a[3]-(5/4)*a[4]+(1/5)*a[5]-5*a[2])*n+a[0]
Download 21052018002.mw
When I import a csv file, (ie. a:=Import("c:/test.csv") the first column is a time stamp column.  So when I use the command a[1] the timestamp column is displayed as well as the next column which is I guess 1.  Similarily a[2] gives timestamp column plus column 3.  So it looks like timestamp column is column 0?  But a[0] gives invalid index error.
So when I convert(a,Array) the first timestamp column is missing.
Am I not understanding DataFrames correctly or is Maple not manipulating it correctly.  Perhaps it's some other issue that I'm not understanding.  Any ideas?  Why doesn't that first column appear in the convert but yet shows up in the original?
Tonight I came across something that OEIS had referenced as the maximum fermi dirac divisor of a number, so i decided it might be a good idea to study this concept by first figuring out how to enumerate the subset of these divisors.
But rather than specifically about this subject, i wanted to ask if my way of "enumeration of numbers meeting specific criteria" is inferior to other methods i have seen. For example this guy named Alois Heinz uses select in the following manner to obtain  the least divisor of a number that is greater than it's square root:
Where as I have always been constructing piecewise expressions as seen in the example of what i have been doing tonight:
with(numtheory):
`&Fscr;` := proc (n) options operator, arrow; {seq(seq(piecewise(frac(ln(ln(divisors(n)[k])/ln(ithprime(j)))/ln(2)) = 0 and divisors(n)[k] <> 1 and divisors(n)[k] <> 2, divisors(n)[k], NULL), j = 1 .. pi(divisors(n)[k])), k = 1 .. nops(divisors(n)))} end proc
`&Fscr;`(200000)
{4, 5, 16, 25, 625}
Download 21052018.mw
So basically, because it is very hard for me to break habits once i have formed them, my question is, is it going to be beneficial for me to switch to this persons method of enumeration, or am i ok just to continue my way?
Sorry I am just having difficulties understanding what this error means exactly, normally maple returns an error message stating the procedure that was being executed when the error was encountered, but in this situation it says (in unknown) which doesnt really make sense, i mean how can a procedure unknown to maple be being executed in the first place, or is this a procedure name itself?
hi,i used ifsolve  comand in my sheat and i have aloop over it  but some times my equations   can't be  solved .My question is how i give an order to maple to stop the loop if the equations can't solve
Hi.
I am attempting to obtain a solution to, what appears to be a simple PDE system (3 equations) and have encountered an error with the initial / boundary conditions. Can anyone provide and guidance / help with this?
The worksheet follows.
PDE_System.mw
I'm  trying to converting an infinite series from several terms to sigma form.
The series in question is:
x-x^2/(t*Log[t])+(2/3)*x^3/(t^2*Log[t]^2)+(-1/(2*t^3*Log[t]^3)-1/(4*t^3*Log[t]^2)-1/(6*t^3*Log[t]))*x^4+(2/(5*t^4*Log[t]^4)+2/(5*t^4*Log[t]^3)+4/(15*t^4*Log[t]^2))*x^5+(-1/(3*t^5*Log[t]^5)-1/(2*t^5*Log[t]^4)-5/(12*t^5*Log[t]^3)-5/(36*t^5*Log[t]^2)-1/(15*t^5*Log[t]))*x^6+(2/(7*t^6*Log[t]^6)+4/(7*t^6*Log[t]^5)+25/(42*t^6*Log[t]^4)+1/(3*t^6*Log[t]^3)+46/(315*t^6*Log[t]^2))*x^7+(-1/(4*t^7*Log[t]^7)-5/(8*t^7*Log[t]^6)-19/(24*t^7*Log[t]^5)-19/(32*t^7*Log[t]^4)-19/(60*t^7*Log[t]^3)-7/(80*t^7*Log[t]^2)-1/(28*t^7*Log[t]))*x^8+(2/(9*t^8*Log[t]^8)+2/(3*t^8*Log[t]^7)+1/(t^8*Log[t]^6)+25/(27*t^8*Log[t]^5)+163/(270*t^8*Log[t]^4)+106/(405*t^8*Log[t]^3)+88/(945*t^8*Log[t]^2))*x^9+(-1/(5*t^9*Log[t]^9)-7/(10*t^9*Log[t]^8)-73/(60*t^9*Log[t]^7)-4/(3*t^9*Log[t]^6)-149/(144*t^9*Log[t]^5)-691/(1200*t^9*Log[t]^4)-18569/(75600*t^9*Log[t]^3)-761/(12600*t^9*Log[t]^2)-1/(45*t^9*Log[t]))*x^10I've attached the worksheet 1.mw.
The example below works but not for the above I just get:
Error, invalid arguments to coeffs
Not sure where I'm going wrong any idea how to do this?
EXAMPLE that works from https://math.stackexchange.com/questions/2786296/strategy-or-software-for-representing-infinite-series-in-sigma-form
I've also attached the worksheet for this 2.mw
S:= 1-x+4/3*(x^2)-2*x^3+16/5*(x^4)-16/3*(x^5)+64/7*(x^6)-16*x^7+256/9*(x^8)-256/5*(x^9)+1024/11*(x^10);
Coeffs:= [seq(coeff(S, x, j), j=0..10)];
g:= gfun:-guessgf(Coeffs,x);
convert(g[1], FPS, x);
results in:
Sum((-1)^k*2^k*x^k/(k+1), k = 0 .. infinity)
or
rec:= gfun:-listtorec(Coeffs, a(n));
aa:= rsolve(rec[1],a(n));
Sum(aa*x^n, n=0..infinity);
results in the same desired result.
Hellow , Any body can help me to write the codes for the differential equation to solve by Galerkin finite element method by four elements by taking step size h=pi/2 and compare with homotropy method by plotting the graph of Galerkin method, homotropy method and exact, here is my codes
ode := diff(y(x), x, x) + y(x)-1=0:
ics := y(0) = 0, y(2*pi) = 0:
dsolve({ics, ode}):
How to do a full reinstall so that no settings are kept?
I tried deleting the maple 2017 folder in program files after I uninstalled but that did not help.
Hello everybody!
I just wrote my first Maple Worksheet for a Uni course and was trying to export it to LaTeX for the report that I have to hand in, but sadly it isn't working properly. I managed to get it to produce an output PDF in LaTeX, but the formatting is horrible and for some reason all text appears twice.
I already searched for other threads on this topic, but all of them appear to be pretty old and I wanted to aks if anyone has andy advice/experiences on how to make the LaTeX export work with more current Maple versions.
I'd be grateful for any advice!
- Chris
Hi everyone
I need help, I have downloaded Maple, and I have read about the student package, which can show the step by step solution, I would like to see the step by step solution than just a final solution to the equation problem.
I have the maple 2017, but does anyone know, how to download this package, and use it in maple?
https://www.maplesoft.com/support/help/maple/view.aspx?path=Student%2FBasics%2FLinearSolveSteps
There is several links to this, but I cant find it where to download the package, I hope that someone is able to help me
Helo, guys, i am a beginner here I want solve a system of first order differential equation using RK4. Please I need help please.
I need my results are nice and neat in final presentation so how can I change the way it present matrix in maple, its so messy in hear like picture . It happend resulted in Maple can reduce the same ratio such as As^2+Bs^2=(A+B)s^2, I tried all my best to find way to simply it but its so hard due to my noob in maple. Please help me make it nice and neat in array of matrix [    ].
I am wondering how to plot a function and a histogram together on the same set of axis.
First 823 824 825 826 827 828 829 Last Page 825 of 2429
