This is a notional example
1/ I define a matrix through some procedure, for instance
p := k -> Matrix(3, 3, (i,j) -> i+j+k mod 3)
2/ Now I would like to animate the plot of matrices p(k) for successive values of k.
The red commend below doesn't work
N := 5:
plots[animate](Statistics[HeatMap], [ p(k) ], k=0..N, frames=N+1);
Could you please help me to fix this ?
TIA
Dear sir
 I am facing the problem with executing the program with Maple13. The software problem is maple13 is not executing the programs and showing the dialogue box as waiting for the kernel. Actually, what is this kernel, which is not understanding me? So please can anyone do a favor in this regard? How to connect to the kernel?
Hi Guys :)
I need some Help with solving a nonlinear system.
I have 3 equations.
These 3 equations have 7 unknown variables in it. But 5 of them are constants which I don't want to solve. I just want to solve three of them.
I tried it with fsolve but I always get the error :
fsolve({eq1, eq3, eq5}, {a, b, c});
Error, (in fsolve) {eq1, eq3, eq5} are in the equation, and are not solved for
i tried to define the variables as Parameters but then i get this error:
Parameters(t1, t2, t3, t4, t5, t6, t7, b1, t, v1, v2, s1, s2, j, a, b, c);
fsolve({eq1, eq3, eq5}, {ca, cb, cc});
Error, (in fsolve) {b1, eq3, eq5, j, t, t1, t2, t3, t4, t5, t6, t7} are in the equation, and are not solved for
Here is the script : Non-Linear_system.mw
 has sb an Idea?
I'm trying to define a monomial order - Monomials are first compared by their weighted degree, with ties broken by pure lexiocraphic order (plex). I want the monomial order just to find the LeadingTerm of polynomials.
Maple has wdeg(W,V) as a built in monomial order, which compares monomials first by their weights, but breaks ties using reverse lexicographic order (tdeg).
One way I could plausibly do this is using the 'matrix' constructor, and defining the plex order by a succession of weights, but this seems like overkill, and I would have a n*n matrix, where I'd like n to reach over 1000.
Is anyone aware of a simple way of defining such a monomial order?
result3.mw
with(LinearAlgebra); restart; delta := 0.407e-9; C := 2023.2; L := 5*delta
0.2035e-8
eq := (1/12)*delta^2*S^4+S^2+omega^2/C^2
0.1380408333e-19*S^4+S^2+0.2442993814e-6*omega^2
solve(eq, S)
0.7244233290e-6*(-0.6902041665e32+2760816666.*(-0.8430822546e19*omega^2+0.6250000000e45)^(1/2))^(1/2), -0.7244233290e-6*(-0.6902041665e32+2760816666.*(-0.8430822546e19*omega^2+0.6250000000e45)^(1/2))^(1/2), 0.7244233290e-6*(-0.6902041665e32-2760816666.*(-0.8430822546e19*omega^2+0.6250000000e45)^(1/2))^(1/2), -0.7244233290e-6*(-0.6902041665e32-2760816666.*(-0.8430822546e19*omega^2+0.6250000000e45)^(1/2))^(1/2)
U := _C1*exp(sqrt(-2*C*(3*C-sqrt(-3*delta^2*omega^2+9*C^2)))*x/(C*delta))+_C2*exp(-sqrt(-2*C*(3*C-sqrt(-3*delta^2*omega^2+9*C^2)))*x/(C*delta))+_C3*exp(sqrt(-2*C*(3*C+sqrt(-3*delta^2*omega^2+9*C^2)))*x/(C*delta))+_C4*exp(-sqrt(-2*C*(3*C+sqrt(-3*delta^2*omega^2+9*C^2)))*x/(C*delta))
U2 := diff(U, x)
1214414.026*_C1*(-24560029.44+4046.4*(-0.496947e-18*omega^2+36840044.16)^(1/2))^(1/2)*exp(1214414.026*(-24560029.44+4046.4*(-0.496947e-18*omega^2+36840044.16)^(1/2))^(1/2)*x)-1214414.026*_C2*(-24560029.44+4046.4*(-0.496947e-18*omega^2+36840044.16)^(1/2))^(1/2)*exp(-1214414.026*(-24560029.44+4046.4*(-0.496947e-18*omega^2+36840044.16)^(1/2))^(1/2)*x)+1214414.026*_C3*(-24560029.44-4046.4*(-0.496947e-18*omega^2+36840044.16)^(1/2))^(1/2)*exp(1214414.026*(-24560029.44-4046.4*(-0.496947e-18*omega^2+36840044.16)^(1/2))^(1/2)*x)-1214414.026*_C4*(-24560029.44-4046.4*(-0.496947e-18*omega^2+36840044.16)^(1/2))^(1/2)*exp(-1214414.026*(-24560029.44-4046.4*(-0.496947e-18*omega^2+36840044.16)^(1/2))^(1/2)*x)
A := simplify(Matrix(4, 4, [[coeff(subs(x = 0, U), _C1), coeff(subs(x = 0, U), _C2), coeff(subs(x = 0, U), _C3), coeff(subs(x = 0, U), _C4)], [coeff(subs(x = L, U), _C1), coeff(subs(x = L, U), _C2), coeff(subs(x = L, U), _C3), coeff(subs(x = L, U), _C4)], [coeff(subs(x = L, U2), _C1), coeff(subs(x = L, U2), _C2), coeff(subs(x = L, U2), _C3), coeff(subs(x = L, U2), _C4)], [coeff(subs(x = 0, U2), _C1), coeff(subs(x = 0, U2), _C2), coeff(subs(x = 0, U2), _C3), coeff(subs(x = 0, U2), _C4)]]))
Matrix(%id = 18446746958277761134)
solve(Determinant(A) = 0)
Download result3.mw
0.2035e-8
solve(eq, S)
U2 := diff(U, x)
Download result3.mw
I am trying maplemint for first time, but some of the messages it generates do not seem to make sense to me and they all seem to be false alarms.
And not sure how make maplemint generate true warnings to make it easier to filter the real problems from the not real ones. For example, I made some module to try
my_module:=module()
export foo;
local  f,A,n,x;
#private stuff here
f:= x -> x^2:
A := int(f(x)*sin(n*x),x=0..Pi) assuming n::integer;
#public stuff here
foo:= proc()
        A;
end module;
maplemint(my_module) generates
Module my_module()
  These local variables were never used:  x
  These local variables were used but never assigned a value:  n
  These local variables were assigned a value, but otherwise unused:  f
Well, "x" is clearly used. It is the integration variable?  And I can't assign value to "n", it is just a symbol used in the symbolic integration and assumed to be integer.
It also says "f" is not used. But "f" is used in definition of "A" inside the integrand.
So all these messages are not really needed. Is there a way to make maplemint not generate these? I do not see how I could change the code to remove these messages. Is something wrong with my code above?
Code works as expected
my_module:-foo();  gives (-Pi^2*(-1)^n*n^2+2*(-1)^n-2)/n^3
Here is another simpler example of where maplemint messages can't be removed no matter what.
foo:= proc()
	 local x;
	 plot(sin(x),x=-Pi..Pi);
and maplemint(foo) gives
Procedure foo()
  These local variables were used but never assigned a value:  x
boo:= proc()
And now
maplemint(boo);
Procedure boo()
  These names were used as global names but were not declared:  x
Here is another example where maplemint complains about option names for plot3 being undeclared
foo:= proc()
    local p,x,y;
    p:=plot3d(sin(x)*cos(y),x=0..Pi,y=0..Pi,
              axes = none, projection=0.9,
              orientation=[-30,55,0], scaling=unconstrained
    p:
And
maplemint(foo);
Procedure foo()
     axes, none, orientation, projection, scaling, unconstrained
       x, y
If one has to go each time through 100's of messages like these in order to find 1 or 2 real ones which indicate real problems, then using maplemint is not going to an effective way to find problems in code.
I have a parameter k and I'm simply trying to make a list of symbols m1,m2...,m2(k-1),m2k to which I'm attempting to assign dx1,dy1,...,dxk,dyk. I've tried
m := i -> 'parse(cat(m, i))'
dx:= i->'eval(cat(dx,i))'
dy:=i ->'eval(cat(dy,i))'
PW > ms := eval(seq(op([m(2*i-1), m(2*i)]), i = 1 .. k));
PW > xys := eval(seq(op([dx(i), dy(i)]), i = 1 .. k));
F > assign(ms = xys);
for loops, $ expressions, and I feel just about anything else but I can't seem to resolve this rather basic issue.
I'm trying to solve a very simple trigonometric equation but for some reason Maple shows me only a single solution where there are more than one.
For example in this code:
f:=sin(x);
solve(f,x);
Maple returns x=0. eventhough there's another solution x=180 (or pi).
Anyone knows how to force Maple to return all the solutions?
I just noticed something funny. If I use the left side tool of Maple to define a matrix with zero entries and then change some entries and take determinant, then Maple treats zeros as symbold!!!! If I have to define my matrix completely myself, then what is the use of this tool?
Basic question on Maple scoping, having hard time finding it doing search.
I noticed when I do this
get_plot:= proc()
Maple did not complain that `x` inside the proc() was implicitly declared. So this tells me that `x` is set local in scope to the body of the plot() itself and this is done automatically. right?  This is same as in Mathematica actually.
But when I did this
get_plot := proc()
    local x;
    x:=10;
get_plot();
I got an error that Error, (in plot) unexpected option: 10 = -Pi .. Pi. So my theory was wrong.
While in Mathematica, one can do the above and it will work
getPlot[]:=Module[{x},
  x=10;
  Plot[Sin[x],{x,0,10}]
getPlot[]
It works, becuase the x inside plot have local scope for the Plot command only and it is not the same as the x outside the plot.
But in Maple, it seems once I declared x to be local, then the plot will use that local x.
So the question is, why did Maple not complain in the first example above that x is implicilty declared as normally happen when one does something like
foo := proc()
    x:=10;
The 'x' is either local or not. which is it? Why above gives warning but not
foo:= proc()
Basically, I wanted to know if I should write like this
foo:= proc()
  local x;
or without the local x if not needed.
Ok so i have entered the code as follows for my input dialog, but I do not want to vary the size of the window, rather the size of the text window inside the dialog window that the student is prompted to enter a paragraph that is related to an algebraic expression in the adjacent container. I cannot see this option available in the help page for the maplet, so i was just wondering if there is a more appropriate choice of maplet i can use that will enable me to do this.
> with(Maplets[Elements]); OpenCommentaryDialog := Maplet(InputDialog['ID1']("Enter comments relevant to the expression assigned for this IIRF", 'onapprove' = Shutdown(['ID1']), 'oncancel' = Shutdown(), resizable = true, width = 1000, height = 1000));
> Maplets[Display](OpenCommentaryDialog);
I also want the text content the student enters to be able to be passed to a data structure that stores all comments made for all expressions in the worksheet, again I was unable to find how to do this on the help page
Dear Friends,
I would appreciate your help in resolving some issues. Let me describe my dummy code and the issues I am having.
I want to know the proper value of two parameters beta and `ΔA` in a tripe integral function  by the NonlinearFit command.The triple integral function is complex.
The code of function is below:
int(tan(beta)^2*exp(-Pi*tan(beta)^2*((x-varepsilon)^2+(0-varsigma)^2)/eta^2)/eta^2, [eta = 22.83-sqrt((5.83+`ΔA`)^2-varepsilon^2) .. 22.83+sqrt((5.83+`ΔA`)^2-varepsilon^2), varepsilon = -5.83-`ΔA` .. 5.83+`ΔA`, varsigma = -1 .. 1])-(int(tan(beta)^2*exp(-Pi*tan(beta)^2*((x-varepsilon)^2+(0-varsigma)^2)/eta^2)/eta^2, [eta = 22.83-sqrt(5.83^2-varepsilon^2) .. 22.83+sqrt(5.83^2-varepsilon^2), varepsilon = -5.83 .. 5.83, varsigma = -1 .. 1]))
And this is the complete code:
datax := [-8, -4.5, -.5, 4.5, 8, 11.5, 14.5];
datay := [0.287e-2, 0.266e-2, 0.259e-2, 0.199e-2, 0.164e-2, 0.113e-2, 0.78e-3];
f := NonlinearFit(int(tan(beta)^2*exp(-Pi*tan(beta)^2*((x-varepsilon)^2+(0-varsigma)^2)/eta^2)/eta^2, [eta = 22.83-sqrt((5.83+`ΔA`)^2-varepsilon^2) .. 22.83+sqrt((5.83+`ΔA`)^2-varepsilon^2), varepsilon = -5.83-`ΔA` .. 5.83+`ΔA`, varsigma = -1 .. 1])-(int(tan(beta)^2*exp(-Pi*tan(beta)^2*((x-varepsilon)^2+(0-varsigma)^2)/eta^2)/eta^2, [eta = 22.83-sqrt(5.83^2-varepsilon^2) .. 22.83+sqrt(5.83^2-varepsilon^2), varepsilon = -5.83 .. 5.83, varsigma = -1 .. 1])), datax, datay, x)
I try to run it and get the value of parameters beta and `ΔA` ,but I keep getting this error,
Error, (in Statistics:-NonlinearFit) integration range or variable must be specified in the second argument, got HFloat(1.0) = HFloat(16.073603031200726) .. HFloat(29.58639696879927)
Does someone how to deal with this problem?
I would sincerely appreciate any inputs in this regard.
Ok so as title says that is what i need, or the process of changing the document property listing that is generated when i start a new worksheet.
The reason being is that of course the obvious solution is for me to have a personalized template for a worksheet with the desired attribute listing, which i have, but the trouble is i have already generated a large number of archive entries in a database or "library" of worksheets that i am building that have the standard attribute listing, and for the new functionality that i have chosen i rely on having the specific custom attribute listing for the new template, and i want to implement this functionality into use for the existing database entries as well as the future ones created, without having to copy and paste things for each of the existing entries for the obvious reason that this is boring and annoying
I've 2 equatoions that i wish to solve to get 2 values, which should be used as an input for the next step and so on,
I've managed to produce the equations, but i can't force the code to use the output of the first loop T1[1] and T2[1] into the 2nd loop and so on
It produces only equations, I'd appreciate it if anyone could tell me how to do that into an array or something similar
k := 28:
Tinf := 200; -1; h := 45; -1; `Δt` := 15; -1; t_total := 150; -1; T1[0] := Tinf; -1; T2[0] := Tinf; -1; L := 0.4e-1; -1; M := 3; -1; `Δx` := L/(M-1); -1; tau := alpha*`Δt`/`Δx`^2; -1; for i from 0 to t_total/`Δt` do T1[i+1] = tau*(T0+T2[i])+(1-2*tau)*T1[i]+tau*g*`Δx`^2/k; 2*h*`Δx`*(Tinf-T2[i])/k+2*(T1[i]-T2[i])+g*`Δx`^2/k = (T2[i+1]-T2[i])/tau end do
T1[1] = 139.7321429
71.42857143 = 2.133333333*T2[1]-426.6666666
T1[2] = .4687500000*T2[1]+0.625000000e-1*T1[1]+33.48214286
84.28571429-2.064285714*T2[1]+2*T1[1] = 2.133333333*T2[2]-2.133333333*T2[1]
T1[3] = .4687500000*T2[2]+0.625000000e-1*T1[2]+33.48214286
84.28571429-2.064285714*T2[2]+2*T1[2] = 2.133333333*T2[3]-2.133333333*T2[2]
T1[4] = .4687500000*T2[3]+0.625000000e-1*T1[3]+33.48214286
84.28571429-2.064285714*T2[3]+2*T1[3] = 2.133333333*T2[4]-2.133333333*T2[3]
T1[5] = .4687500000*T2[4]+0.625000000e-1*T1[4]+33.48214286
84.28571429-2.064285714*T2[4]+2*T1[4] = 2.133333333*T2[5]-2.133333333*T2[4]
T1[6] = .4687500000*T2[5]+0.625000000e-1*T1[5]+33.48214286
84.28571429-2.064285714*T2[5]+2*T1[5] = 2.133333333*T2[6]-2.133333333*T2[5]
T1[7] = .4687500000*T2[6]+0.625000000e-1*T1[6]+33.48214286
84.28571429-2.064285714*T2[6]+2*T1[6] = 2.133333333*T2[7]-2.133333333*T2[6]
T1[8] = .4687500000*T2[7]+0.625000000e-1*T1[7]+33.48214286
84.28571429-2.064285714*T2[7]+2*T1[7] = 2.133333333*T2[8]-2.133333333*T2[7]
T1[9] = .4687500000*T2[8]+0.625000000e-1*T1[8]+33.48214286
84.28571429-2.064285714*T2[8]+2*T1[8] = 2.133333333*T2[9]-2.133333333*T2[8]
T1[10] = .4687500000*T2[9]+0.625000000e-1*T1[9]+33.48214286
84.28571429-2.064285714*T2[9]+2*T1[9] = 2.133333333*T2[10]-2.133333333*T2[9]
T1[11] = .4687500000*T2[10]+0.625000000e-1*T1[10]+33.48214286
84.28571429-2.064285714*T2[10]+2*T1[10] = 2.133333333*T2[11]-2.133333333*T2[10]
Download Advheat-ex55.mwAdvheat-ex55.mw
I using Maple 18 (not Maple 2018) and I'm trying to figure out how to grab earthquake data from earthquakescanada database from here http://www.earthquakescanada.nrcan.gc.ca//stndon/NEDB-BNDS/bull-en.php using the HTTP requests.
First I used the default search within the web browser, and get a new address which I enter as the URL
HTTP:-Get("http://www.earthquakescanada.nrcan.gc.ca//stndon/NEDB-BNDS/bull-en.php?time_start=2018%2F04%2F23+22%3A47%3A00&time_end=2018%2F05%2F23+22%3A47%3A00&depth_min=0&depth_max=100&mag_min=-3&mag_max=9.9&shape_type=region&radius_center_lat=50&radius_center_lon=-95&radius_radius=1000&region_north=90&region_south=41&region_east=-40&region_west=-150&eq_type_L=1&display_list=1&list_sort=date&list_order=a&tpl_output=html&submited=1"
It takes a long time to download the information and would require HTML surgery but changing the option for output to txt or csv, it's faster and in a much more readable form.  However it's not in a table or Array format, it has become a string.
Is there any way to use ImportMatrix, or ImportData to get a better format of the information?  - both give errors in Maple18.  Or am I stuck trying to use string surgery in Maple 18?  The Import command isn't available until Maple 2016 (I don't mean the Import command within ExcelTools) and I believe that works in Maple 2018 however I'm at a loss for trying to use it in Maple 18.
First 821 822 823 824 825 826 827 Last Page 823 of 2429
