When I finished the following code, I can not export the .eps file for the densityplot
restart; t := 1; a[1] := 0; a[2] := 2; a[4] := 0; a[5] := 1; a[6] := -1; a[8] := 0; g := t*a[3]+x*a[1]+y*a[2]+a[4]; h := t*a[7]+x*a[5]+y*a[6]+a[8]; f := g^2+h^2+a[9]; a[3] := -(3*a[1]^3+a[1]*a[2]^2+3*a[1]*a[5]^2-a[1]*a[6]^2+2*a[2]*a[5]*a[6])/(3*(a[1]^2+a[5]^2)); a[7] := -(3*a[1]^2*a[5]+2*a[1]*a[2]*a[6]-a[2]^2*a[5]+3*a[5]^3+a[5]*a[6]^2)/(3*(a[1]^2+a[5]^2)); a[9] := (3*(a[1]^6+3*a[1]^4*a[5]^2+3*a[1]^2*a[5]^4+a[5]^6))/(a[1]*a[6]-a[2]*a[5])^2; u := (4*(2*a[1]^2+a[5]^2))/f-8*(g*a[1]+h*a[5])^2/f^2; with(plots); plot3d(u, x = -20 .. 20, y = -20 .. 20, axes = frame, labels = ["x", "y", "z"], labeldirections = ["horizontal", "horizontal", "horizontal"], labelfont = ["TIMES", 16], style = patchnogrid); densityplot(u, x = -10 .. 10, y = -10 .. 10, axes = frame, labels = ["x", "y"], labeldirections = ["horizontal", "horizontal"], labelfont = ["TIMES", 16], colorstyle = HUE, style = patchnogrid); contourplot(u, x = -5 .. 5, y = -5 .. 5, labels = ["x", "y"], labeldirections = ["horizontal", "horizontal"], labelfont = ["TIMES", 16])
Two sets of ordered pairs (i.e. A and B) are calculated in a problem.
A = {[0.5, 3.15], [1, 4.87], [1.5, 6.56], [2, 8.22]}
B = {[0.5, 3.67], [1, 4.94], [1.5, 5.29], [2, 5.93]}
Two control points are considered to check the validity of interpolated polynomials as follows:
- Control point for A:
  Calculated by interpolation [1.75, 7.3959] ... Exact amount [1.75, 7.3971]
- Control point for B:
  Calculated by interpolation [1.75, 5.4981] ... Exact amount [1.75, 5.6225]
The calculated polynomial via interpolation for sets A and B are plotted for independent variable between 0.5 and  2. The plot of interpolated polynomial for A is a curve without local extremum. However ordered pairs in B show that the polynomial should be a strictly increasing function, but the plot of interpolated polynomial for B has many local extremums. By increasing ordered pairs in B, the local extremums are increased. Moreover, the control point for B shows that the interpolated polynomial is not reliable.
The more exact ordered pairs for B are presented in below. If more ordered pairs are required for interpolation, you can use them.
{[0.75, 4.1457],[1.25, 4.9448],[1.75,5.62]}
How can I find the best curve fitting for ordered pairs in B?
Thank you for taking your time
Hi everybody,
Why f generates the error "... orthopoly is not a module or member"
f := proc(n)
   uses orthopoly;
   H(n,z);
as g works correctly ?
g := proc(n)
   orthopoly:-H(n,z);
I want to animate the functions approximate_f and f in the worksheet where 0<=t<=1.
Please find the following code.
code.mw
Thank you very much.
Does anybody mind clarifying what the three argument signum means?
I have the expression
signum(0,R-sqrt(R^2+z^2),1)
in which z>0, R>0. I guess I know what signum means, however in this case according to the help it is considering signum of 0 and then in the help it is talking about some environment variable. I just dont quite understand...
Does it mean Maple has issues to clarify the sign of R-sqrt(R^2+z^2) ??
Rayleigh's identity is listed below:
              infinity
                 )             2      /      2        1      1  \
                /        |f(k)|  = int||f(t)| , t = - - T .. - T|
               -----                  \               2      2  /
            k = -infinity
sum(abs(f(k))^2, k = -infinity .. infinity) = int(abs(f(t))^2, t = -(1/2)*T .. (1/2)*T);
This identity is an extension from Parseval's theorem for the case where the function of interest is periodic.  The link below provides a worksheet that confirms for a finite series that Rayleigh's identity is valid to within so many significant figures as the frequency parameter, k, increases for CASE 1.  However, for CASE 2 concurrence between the integral and the finite series is not that great.  I suspect I have an error somewhere that is causing the discrepancy.  I thought it might be useful if I get other sets of eyes on this to help isolate the discrepancy.  How I came up with Ck for CASE 2 I can create another worksheet with that derivation if requested.
Rayleighs_identity.mw
Appreciate any useful feedback
I found that when changing constant of integration from _C1 to C1, Maple now fails to verify solution.
Is one supposed to only use constant with _ in it for this? I prefer to use C1 instead of _C1. Why does Maple odetest fail in this case? Is there a way around this?
Here is an example
ode:=diff(y(x),x)=x*ln(y(x)):
implicit_sol := -Ei(1, -ln(y(x)))+C1=(1/2)*x^2;
explicit_sol := solve(implicit_sol,y(x)):
odetest(y(x)=explicit_sol,ode);
Now changing C1 to _C1 and nothing else, odetest verifies the solution
implicit_sol:= subs(C1=_C1,implicit_sol);
I understand the using symbol with _ is a convention in Maple for global symbols. But I want to use C1 and not _C1 as it is easier to read.
Hello guys,
I have three equations with three unknowns that I can not solve but my friend solved it with Mathematica, but I do not know how to get answers with Maple.
Thankssolutions.mw
I'm writing an equation that has a term including divergence .. i'd like to print that as the sum of the derivatives
for example instead of nabla(u) display it as ux+uy+uz
VectorCalculus[SetCoordinates]('cartesian'[x, y, z]); F := x, y, z, t
vel := VectorCalculus[VectorField](`<,>`(u(F), v(F), w(F)))
vel := u(x, y, z, t)*`#mover(mi("e"),mo("&lowbar;"))`[x]+v(x, y, z, t)*`#mover(mi("e"),mo("&lowbar;"))`[y]+w(x, y, z, t)*`#mover(mi("e"),mo("&lowbar;"))`[z]
Mass_eqn := diff(rho(F), t)+Divergence(rho(F)*vel)
Mass_eqn := diff(rho(x, y, z, t), t)+VectorCalculus[Nabla].(Vector(3, {(1) = rho(x, y, z, t)*u(x, y, z, t), (2) = rho(x, y, z, t)*v(x, y, z, t), (3) = rho(x, y, z, t)*w(x, y, z, t)}))
print(Mass_eqn)
Download aero.mw
How do I convert a complex number to abs and arg presentation.
For example:
z=1+1*I would be z=sqrt(2)*exp(I*Pi/4)
or when doing a calculation how can I tell him to always present these number in that form and do not expand out.
I have variables like: x1, x2, x3, x4, ...
I want to unassign all x? variables.
How can I do it?
I tried
for i from 1 to n_x do ... unassign('x||i') ... od:
but it does not work :(
How can I run Maple Script ,hold it and continue to run it ?
Somethink like Matlab pause statment
Tank you
How I can convert my maple code to matlab?.
dsolv.mw
fdsolve := proc({alpha:=NULL, t0:=NULL,
                 t1:=NULL, x0:=NULL, y0:=NULL,
                 N:=NULL}, params)
    local t, h, h1, h2, c, b, x, y, L, n, l, X, Y, f, g;
    eval(F(t,x,y), params);
    f := unapply(%, [t,x,y]);
    eval(G(t,x,y), params);
    g := unapply(%, [t,x,y]);
    L := floor(1/alpha);
    h := (t1 - t0)/N;
    h1 := h^alpha/GAMMA(alpha+1);
    h2 := h^alpha/GAMMA(alpha+2);
    c := (i,n) ->
        `if`(i=0,
            (n-1)^(alpha+1) - (n-1-alpha)*n^alpha,
            (n-i+1)^(alpha+1) + (n-i-1)^(alpha+1) - 2*(n-i)^(alpha+1));
    b := (i,n) -> (n-i)^alpha - (n-1-i)^alpha;
    t := Array(0..N, i-> (1-i/N)*t0 + i/N*t1, datatype=float[8]);
    x[0], y[0] := x0, y0;
    for n from 0 to N-1 do
        X[0], Y[0] :=
            x[0] + h1*add(b(i,n+1)*f(t[i],x[i],y[i]), i=0..n),
            y[0] + h1*add(b(i,n+1)*g(t[i],x[i],y[i]), i=0..n);
        for l from 1 to L do
            X[l], Y[l] :=
                x[0] + h2*add(c(i,n+1)*f(t[i],x[i],y[i]), i=0..n)
                     + h2*f(t[n+1], X[l-1], Y[l-1]),
                y[0] + h2*add(c(i,n+1)*g(t[i],x[i],y[i]), i=0..n)
                     + h2*g(t[n+1], X[l-1], Y[l-1]);
        x[n+1], y[n+1] := X[L], Y[L];
        #printf("y[%d]=%a\n", n+1, y[n+1]);
    return Array(0..N, i -> [t[i], x[i], y[i]]);
F := (t,x,y) -> r*x*(1-x/k) - beta*x*y/(a+x^2);
G := (t,x,y) -> mu*beta*x*y/(a+x^2) - d*y - eta*x*y;
proc (t, x, y) options operator, arrow; r*x*(1-x/k)-beta*x*y/(a+x^2) end proc
proc (t, x, y) options operator, arrow; mu*beta*x*y/(a+x^2)-d*y-eta*x*y end proc
params := { r=0.05, a=0.8, mu=0.8, d=0.24,
            eta=0.01, beta=0.6, k=1.6 };
{a = .8, beta = .6, d = .24, eta = 0.1e-1, k = 1.6, mu = .8, r = 0.5e-1}
T := 300.0;  # time interval: 0 < t < T
q := 100;    # divide the time interval into q subintervals
300.0
100
We produce several solutions starting from various initial data x__0, y__0.
This reproduces the phase diagran in the cited article's Figure 2  (alpha=0.98):
sol := fdsolve(alpha=0.98, t0=0.0, t1=T, x0=2.5, y0=0.14, N=q, params):
p1 := plot([seq([sol[i][2], sol[i][3]], i=0..q)])
Download dsolv.mw
I want to check that all entries in a list are of some value. Say 0. (or in general, if all entries satisfy some condition).
So, If any entry is not zero, then it returns false. It returns true only if all elements meet this conditions.
What would be the right way to do this in Maple? I know I could write a loop. But I am asking if there is a build-in function in Maple. Here is an example
ode:=y(x)*diff(y(x),x)=x*(y(x)^2+2):
sol:= dsolve(ode,y(x)):
check:=map(z->odetest(z,ode1),[sol]);
                       check := [0, 0]
I want to check that all entries in check are zero. This tells me all my solution are correct.
I can't use member(check,0) since this only check if at least one entry is zero. I want to chek that all entries are zero.
In Mathematica, it has AllTrue function. Like this
check = {0, 0, 0};
AllTrue[check, # == 0 &]
     True
The "#==0&"  is the test to do. It uses this test on each element automatically. If all satisfy this test, then it returns true.
Again, I can easily write a small function in Maple to do this,
alltrue :=proc(arr,value)
    local z;
    for z in arr do
        if z<>value then
           return(false);
        fi;
    od;
    return(true);
alltrue(check,0) return true.
But I am asking if there is a build-in such function similar to the above one in Mathematica, which accepts a more general test function to use.
I am interested in obtaining a Maple program (symbolic language) that can evaluate exponentials of non-commuting operators.
eA+B=eAeBeC1eC2eC3...
See R. M. Wilcox, J. Math. Phys. 8, (1967), 962
This is the Baker-Campbell-Hausdorff expansion, or equivalently the Zassenhaus expansion.
First 813 814 815 816 817 818 819 Last Page 815 of 2429
