Can someone help with the simplification of the result of this code? I am sure the "qs" in the final result should not appear.
Thanking you in anticipation of your positive responses
#k=1
P:=sum(a[k]*x^k, k=0..2):
assume(alpha>0,alpha <= 1):
Q:=fracdiff(P,x,alpha);
e1:=simplify(eval(P, x=q))=y[n]:
e2:=simplify(eval(Q,x=q))=f[n]:
e3:=simplify(eval(Q,x=q+h^alpha))=f[n+1]:
var:=seq(a[i], i=0..2):
M:=e||(1..3):
Cc:=eval(<var>, solve(eval({M}),{var}) ):
for i from 1 to 3 do
	a[i-1]:=Cc[i]:
Cf:=P:
E:=collect(Cf, [y[n], f[n], f[n+1]], recursive):
print():
#y[n+1]=collect(simplify(simplify(expand(eval(Cf,x=q+h^alpha)),size)), [y[n],f[n],f[n+1]], factor);
y[n+1]=simplify(eval(Cf, x=q+h^alpha)):
collect(%, [y[n], f[n], f[n+1]], recursive);
I want to solve the following algebraic equation system using solve command. But, it gives only the trivial solution. I want to find a,b and c in terms of k. k is a constant here. Thanks in advance.
Input:
solve({-6*c+(3/2)*c^2-2*b-3*b*c+(3/2)*b^2-3*a*c+(k^2)*b-b+(3/2)*(a^2)+(k^2)*a-a=0,
-2*b-3*b*c+3*(b^2)-6*a*c+2*(k^2)*c-2*c-9*a*b+3*(k^2)*b-3*b+6*(a^2)+4*(k^2)*a-4*a=0,
(3/2)*(b^2)-3*a*c+(k^2)*c-c-9*a*b+3*(k^2)*b-3*b+9*(a^2)+6*(k^2)*a-a=0,
-3*a*b+(k^2)*b-b+6*(a^2)+4*(k^2)*a-4*a=0,
(3/2)*(a^2)+(k^2)*a-a=0},{a,b,c});
Output:
{a=0, b=0, c=0}
I want to solve an ODE of second order with Adams-Bashforth method.
It seems the solution has convergence for a small range of requested interval.
Please download the file from link below and made your comment on it.
Thank you for taking your time
https://ufile.io/f9a0e
When I input the the following command line in Maple 2018.1
 > Int(1/(1+sqrt(x)),x=0..1)=int(1/(1+sqrt(x)),x=0..1);
the output is
>Int(1/(1+sqrt(x)), x = 0 .. 1) = MeijerG([[0, 0, 1/2], []], [[1/2, 0], [-1]], 1)/Pi
which is not the desired result!  How can I get the desired result like this
>2-ln(2)
Thanks a lot.
Goodday everyone,
Please, anyone with useful informations on the above stated error code should help.
Below is the attached file.
Error_invalid_subscript_selector.mw
Thanks in anticipation for your response
Please how do I add a number to column values in a matrix.
I needed to covert a column data representing temperatue values from celcius  to kelvin and I needed to add 273 to this column.
Thank you in advance.
What is a good way to generate a random, high degree polynomial with integer coefficients, that has a high number of real roots. Example a degree 800 with 600 real roots. I am not looking for a mul application.
I entered this function
f:=x->(4*x^2-4)^(4/5);
Then I entered f(0) and got (-4)^(4/5).
When I tried to approximate , I got -2.452480922+1.781831689*I
I am looking for the real number value, which is 3.031433 with my TI-83 calculator and here https://www.desmos.com/calculator/b1soxuhbri
How do I set it in maple so that x is assumed to be real in f(x) and all outputs are real.
Hello everyone. Below is the loop coding to plot the rectangles.
This will give me  21 rectangles with 21 graphs. And how am I going to combine them(21 rectangles) in one single graph? Really appreciate your help. Thank you in advanced! :)
Hey and Thanks for your input.
restart; f := ((1/2-I*t)^(-s)-(1/2+I*t)^(-s))/(2*I); fc := evalc(f); `assuming`([simplify(int(f, t = 0 .. infinity))], [s > 1]); `assuming`([simplify(int(fc, t = 0 .. infinity))], [s > 1])
-((1/2)*I)*((1/2-I*t)^(-s)-(1/2+I*t)^(-s))
exp(-(1/2)*s*ln(1/4+t^2))*sin(s*arctan(2*t))
2^(s-1)/(s-1)
(1/2)*4^s/(s-1)
Download function_evaluation_goes_wrong.mw
Am I doing something wrong?
I am trying to create a question that generates two complex numbers and asks for the product of the two complex numbers.
This is what I have so far in the algorithm box of the question creator but it doesn't give me the correct answer:
$a=5 + 20*I;
$b=4 - 12*I;
$ans= maple("evalc($a*$b)");
This is my first time using MapleTA. Any help would be appreciated.
I am having trouble in plotting the 3d plot of explicit expressions. Lets say
eq1:=f(z)
eq2:=g(z)
then how can I plot f(z) and g(z) together with z in 3d plot?
Sunit
Can I create a Groebner basis in Maple with system of inequalities and how should I do that?
For example: I have problem with 30 inequlities (all have to be binary {0,1}) and all inequalities are >=1 but if I put
F := [x1+x2+x3-1, x1+x5+x7-1 etc]; and after that I create Groebner basis, I get that system has no solutions, but I know it has.
Thank you in advance!
in this ODE, with initial conditions, I am trying to verify my solution, but I can't figure how Maple obtained the final answer.  I can obtain same solution, but before using the initial conditions to find the constant of integrations. The problem comes in solving for the constant of integration from initial conditions. I do not know how Maple did it, becuause when I do the normal steps, I get division by zero.
ode:=diff(y(x),x)=x*ln(y(x)):
ic:=y(1)=1:
sol:=dsolve({ode,ic},y(x));
gives "sol := y(x) = 1"
Now I solve without IC, then try to find _C1 by hand
sol:=dsolve(ode,y(x));
       sol := y(x) = exp(RootOf(x^2+2*Ei(1, -_Z)+2*_C1))
Now used remove_RootOf
sol2:=DEtools:-remove_RootOf(sol);
            sol2 := x^2+2*Ei(1, -ln(y(x)))+2*_C1 = 0
Now I followed the steps I learned at school, which is to plugin y=1 and x=1 in the solution to get an equation to solve for _C1
eq := subs({y(x)=1,x=1},sol2);
            eq := 1+2*Ei(1, -ln(1))+2*_C1 = 0
But Ei(1, -ln(1)) is a division by zero. So can't solve for _C1
solve(eq,_C1);
       Error, (in Ei) numeric exception: division by zero
So how would you solve for _C1 in the above? Or how did the smart Maple do it?
I tried using limits, but that did not help.  I tried using allvalues instead of remove_RootOf, and that did not get rid of RootOf.  Next I tried not to remove RootOf and keep it there to see what happens
eq := subs({y(x)=1,x=1},sol);
             eq := 1 = exp(RootOf(1+2*Ei(1, -_Z)+2*_C1))
c1:=solve(eq,_C1, AllSolutions);
              c1 := -1/2-Ei(1, -(2*I)*Pi*_Z1)
subs(_C1=c1,sol);
             y(x) = exp(RootOf(x^2+2*Ei(1, -_Z)-1-2*Ei(1, -(2*I)*Pi*_Z1)))
simplify(%);
            x^2+2*Ei(1, -ln(y(x)))-1-2*Ei(1, -(2*I)*Pi*_Z1) = 0
DEtools:-remove_RootOf(%);
solve(%,y(x));
So I can't figure how Maple obtained y(x)=1. Maple must have used different method to solve for _C1.
What would be the Maple commands to use to obtain y(x)=1, starting from
and given that y(1)=1 ?
In the calculation below, A and B both simplify to 1.  Why doesn't A*B simplify to 1?  Tested on Maple 2017 and 2018.
A := (1 - cos(s)^2)/sin(s)^2;
(1-cos(s)^2)/sin(s)^2
B := (1 - cos(t)^2)/sin(t)^2;
(1-cos(t)^2)/sin(t)^2
simplify(A);
simplify(B);
Why doesn't this simplify to 1?
simplify(A*B);
((cos(t)^2-1)*cos(s)^2-cos(t)^2+1)/(sin(s)^2*sin(t)^2)
First 838 839 840 841 842 843 844 Last Page 840 of 2459
