Can someone please explain in simple terms, why when I do
 r:=foo(r), where "r" is a Record, then the returned  "r" is not what is returned from foo()?  I want to write a proc foo() which takes in a Record variable, update some of its fields, and then return the updated Record to the caller
r:=Record('a','b');
foo:=proc(r)
    r:-b:=5;
    return(r);
But now when I call the above as follows
r:-b:=99;
print(r);
r:=foo(r):
print(r);
The last print above just prints "r" and not the Record. It seems to have erased the Record.
But it works, if I change the name of the variable to return the result into, as
r:-b:=99;
print(r);
r0:=foo(r):
print(r0);
When I do the same on say a Matrix, there is no problem
r:=<<1,1>>:
foo:=proc(r)
    r[1]:=5;
    return(r);
And now
r;
r:=foo(r):
print(r);
Why it worked with a Matrix but not with Record? Why can't one overwrite the Record on the call return?
What would be the correct way to pass in a Record to a function, and have the function update some of its fields, and then return back the updated copy of the Record without having to make a new variable "r0" as above?
Ball_Maple.mwsBall_Maple.txt
Attached is code in Maple 7 and a text file.There is a for loop in which I want the plots to be output, and the printf command - but I am not getting a plot at all.  Any advice most appreciated.  David
Hello everyone. Really need help here. How am i going to do a loop with different values of x and y.
For example this are the values,
I wish to do looping since the derivation is way too long and i have like 21 values of x and y each. i have no idea how to modify the coding for looping. Thank u in advanced :)
I really like Maple Record. I think it is one of the hidden gems in Maple. Very useful.
But I have basic questions on it. I just started to learn how to use it. It is very similar to Pascal Record.
1)
r:=Record(a,b);
                       r := Record(a, b)
type(r,'record');
whattype(r);
                             symbol
Why  type(r,'record') says true, but whattype(r) says symbol?
2)
Why Maple displays the record content to the screen automatically only first time, after it is created, but second time, it only echos the name? So one has to use print() each time to display the content of the record.  Not a big deal, but it is little annoying
r:=Record(a,b);
                       r := Record(a, b)
r;
                               r
print(r);
                          Record(a, b)
r:-a:=5;
                             a := 5
r
                               r
print(r);
                        Record(a = 5, b)
Compare this to say a set type, where it displays the content each time
r:={1,2,3};
                         r := {1, 2, 3}
r
                           {1, 2, 3}
I tried changing max_record_depth but I must be doing something wrong. It still does not display the content
interface(max_record_depth=10)
                               10
r:=Record(a,b);
                       r := Record(a, b)
r;
                               r
3) Why are these two behave the same way
r:=Record("y");
r:-y:=4;
r:=Record('y');
r:-y:=4;
Giving the name of the field as string worked the same way as second example which is a name.  I thought the first one above will not work as field name should be a name according to help.
I'm currently wondering about the "real" difference.
is() or type() can be used both for true/false checks. However when should what be used preferably?
For example I do not see what is better over the other when doing simple checks such as
is(2,'integer')
type(2,'integer')
Thanks for clarifying.
I can't workout the syntax to plot a sequence of arrow. See last line of document.
accel := plottools:-arrow(seq([M[j, 1][1], M[j, 1][2]], [M[j, 3][1], M[j, 3][2]], j = 1 .. i), colour = red)  Doesn't work and tried various things.
Would also appreciate an explination for how the lines are plotted. I found this line on Maple Primes. It works but I don't realy understant it.
orb := plot(([seq])([M[j, 1][1], M[j, 1][2]], j = 1 .. i), colour = blue)
Why is seq in square brackets?
with(plots)
with(plottools)
[annulus, arc, arrow, circle, cone, cuboid, curve, cutin, cutout, cylinder, disk, dodecahedron, ellipse, ellipticArc, exportplot, extrude, getdata, hemisphere, hexahedron, homothety, hyperbola, icosahedron, importplot, line, octahedron, parallelepiped, pieslice, point, polygon, prism, project, rectangle, reflect, rotate, scale, sector, semitorus, sphere, stellate, tetrahedron, torus, transform, translate]
M := Matrix(60, 3, {(1, 1) = Vector(2, {(1) = -3, (2) = 5}), (1, 2) = Vector(2, {(1) = -2, (2) = -2}), (1, 3) = Vector(2, {(1) = 0, (2) = 0}), (2, 1) = Vector(2, {(1) = -5, (2) = 3}), (2, 2) = Vector(2, {(1) = -1, (2) = -3}), (2, 3) = Vector(2, {(1) = 1, (2) = -1}), (3, 1) = Vector(2, {(1) = -6, (2) = 0}), (3, 2) = Vector(2, {(1) = 0, (2) = -3}), (3, 3) = Vector(2, {(1) = 1, (2) = 0}), (4, 1) = Vector(2, {(1) = -6, (2) = -3}), (4, 2) = Vector(2, {(1) = 1, (2) = -2}), (4, 3) = Vector(2, {(1) = 1, (2) = 1}), (5, 1) = Vector(2, {(1) = -5, (2) = -5}), (5, 2) = Vector(2, {(1) = 2, (2) = -1}), (5, 3) = Vector(2, {(1) = 1, (2) = 1}), (6, 1) = Vector(2, {(1) = -3, (2) = -6}), (6, 2) = Vector(2, {(1) = 3, (2) = 0}), (6, 3) = Vector(2, {(1) = 1, (2) = 1}), (7, 1) = Vector(2, {(1) = 0, (2) = -6}), (7, 2) = Vector(2, {(1) = 3, (2) = 1}), (7, 3) = Vector(2, {(1) = 0, (2) = 1}), (8, 1) = Vector(2, {(1) = 3, (2) = -5}), (8, 2) = Vector(2, {(1) = 2, (2) = 2}), (8, 3) = Vector(2, {(1) = -1, (2) = 1}), (9, 1) = Vector(2, {(1) = 5, (2) = -3}), (9, 2) = Vector(2, {(1) = 1, (2) = 3}), (9, 3) = Vector(2, {(1) = -1, (2) = 1}), (10, 1) = Vector(2, {(1) = 6, (2) = 0}), (10, 2) = Vector(2, {(1) = 0, (2) = 3}), (10, 3) = Vector(2, {(1) = -1, (2) = 0}), (11, 1) = Vector(2, {(1) = 6, (2) = 3}), (11, 2) = Vector(2, {(1) = -1, (2) = 2}), (11, 3) = Vector(2, {(1) = -1, (2) = -1}), (12, 1) = Vector(2, {(1) = 5, (2) = 5}), (12, 2) = Vector(2, {(1) = -2, (2) = 1}), (12, 3) = Vector(2, {(1) = -1, (2) = -1}), (13, 1) = Vector(2, {(1) = 3, (2) = 6}), (13, 2) = Vector(2, {(1) = -3, (2) = 0}), (13, 3) = Vector(2, {(1) = -1, (2) = -1}), (14, 1) = Vector(2, {(1) = 0, (2) = 6}), (14, 2) = Vector(2, {(1) = -3, (2) = -1}), (14, 3) = Vector(2, {(1) = 0, (2) = -1}), (15, 1) = Vector(2, {(1) = -3, (2) = 5}), (15, 2) = Vector(2, {(1) = -2, (2) = -2}), (15, 3) = Vector(2, {(1) = 1, (2) = -1}), (16, 1) = Vector(2, {(1) = -5, (2) = 3}), (16, 2) = Vector(2, {(1) = -1, (2) = -3}), (16, 3) = Vector(2, {(1) = 1, (2) = -1}), (17, 1) = Vector(2, {(1) = -6, (2) = 0}), (17, 2) = Vector(2, {(1) = 0, (2) = -3}), (17, 3) = Vector(2, {(1) = 1, (2) = 0}), (18, 1) = Vector(2, {(1) = -6, (2) = -3}), (18, 2) = Vector(2, {(1) = 1, (2) = -2}), (18, 3) = Vector(2, {(1) = 1, (2) = 1}), (19, 1) = Vector(2, {(1) = -5, (2) = -5}), (19, 2) = Vector(2, {(1) = 2, (2) = -1}), (19, 3) = Vector(2, {(1) = 1, (2) = 1}), (20, 1) = Vector(2, {(1) = -3, (2) = -6}), (20, 2) = Vector(2, {(1) = 3, (2) = 0}), (20, 3) = Vector(2, {(1) = 1, (2) = 1}), (21, 1) = Vector(2, {(1) = 0, (2) = -6}), (21, 2) = Vector(2, {(1) = 3, (2) = 1}), (21, 3) = Vector(2, {(1) = 0, (2) = 1}), (22, 1) = Vector(2, {(1) = 3, (2) = -5}), (22, 2) = Vector(2, {(1) = 2, (2) = 2}), (22, 3) = Vector(2, {(1) = -1, (2) = 1}), (23, 1) = Vector(2, {(1) = 5, (2) = -3}), (23, 2) = Vector(2, {(1) = 1, (2) = 3}), (23, 3) = Vector(2, {(1) = -1, (2) = 1}), (24, 1) = Vector(2, {(1) = 6, (2) = 0}), (24, 2) = Vector(2, {(1) = 0, (2) = 3}), (24, 3) = Vector(2, {(1) = -1, (2) = 0}), (25, 1) = Vector(2, {(1) = 6, (2) = 3}), (25, 2) = Vector(2, {(1) = -1, (2) = 2}), (25, 3) = Vector(2, {(1) = -1, (2) = -1}), (26, 1) = Vector(2, {(1) = 5, (2) = 5}), (26, 2) = Vector(2, {(1) = -2, (2) = 1}), (26, 3) = Vector(2, {(1) = -1, (2) = -1}), (27, 1) = Vector(2, {(1) = 3, (2) = 6}), (27, 2) = Vector(2, {(1) = -3, (2) = 0}), (27, 3) = Vector(2, {(1) = -1, (2) = -1}), (28, 1) = Vector(2, {(1) = 0, (2) = 6}), (28, 2) = Vector(2, {(1) = -3, (2) = -1}), (28, 3) = Vector(2, {(1) = 0, (2) = -1}), (29, 1) = Vector(2, {(1) = -3, (2) = 5}), (29, 2) = Vector(2, {(1) = -2, (2) = -2}), (29, 3) = Vector(2, {(1) = 1, (2) = -1}), (30, 1) = Vector(2, {(1) = -5, (2) = 3}), (30, 2) = Vector(2, {(1) = -1, (2) = -3}), (30, 3) = Vector(2, {(1) = 1, (2) = -1}), (31, 1) = Vector(2, {(1) = -6, (2) = 0}), (31, 2) = Vector(2, {(1) = 0, (2) = -3}), (31, 3) = Vector(2, {(1) = 1, (2) = 0}), (32, 1) = Vector(2, {(1) = -6, (2) = -3}), (32, 2) = Vector(2, {(1) = 1, (2) = -2}), (32, 3) = Vector(2, {(1) = 1, (2) = 1}), (33, 1) = Vector(2, {(1) = -5, (2) = -5}), (33, 2) = Vector(2, {(1) = 2, (2) = -1}), (33, 3) = Vector(2, {(1) = 1, (2) = 1}), (34, 1) = Vector(2, {(1) = -3, (2) = -6}), (34, 2) = Vector(2, {(1) = 3, (2) = 0}), (34, 3) = Vector(2, {(1) = 1, (2) = 1}), (35, 1) = Vector(2, {(1) = 0, (2) = -6}), (35, 2) = Vector(2, {(1) = 3, (2) = 1}), (35, 3) = Vector(2, {(1) = 0, (2) = 1}), (36, 1) = Vector(2, {(1) = 3, (2) = -5}), (36, 2) = Vector(2, {(1) = 2, (2) = 2}), (36, 3) = Vector(2, {(1) = -1, (2) = 1}), (37, 1) = Vector(2, {(1) = 5, (2) = -3}), (37, 2) = Vector(2, {(1) = 1, (2) = 3}), (37, 3) = Vector(2, {(1) = -1, (2) = 1}), (38, 1) = Vector(2, {(1) = 6, (2) = 0}), (38, 2) = Vector(2, {(1) = 0, (2) = 3}), (38, 3) = Vector(2, {(1) = -1, (2) = 0}), (39, 1) = Vector(2, {(1) = 6, (2) = 3}), (39, 2) = Vector(2, {(1) = -1, (2) = 2}), (39, 3) = Vector(2, {(1) = -1, (2) = -1}), (40, 1) = Vector(2, {(1) = 5, (2) = 5}), (40, 2) = Vector(2, {(1) = -2, (2) = 1}), (40, 3) = Vector(2, {(1) = -1, (2) = -1}), (41, 1) = Vector(2, {(1) = 3, (2) = 6}), (41, 2) = Vector(2, {(1) = -3, (2) = 0}), (41, 3) = Vector(2, {(1) = -1, (2) = -1}), (42, 1) = Vector(2, {(1) = 0, (2) = 6}), (42, 2) = Vector(2, {(1) = -3, (2) = -1}), (42, 3) = Vector(2, {(1) = 0, (2) = -1}), (43, 1) = Vector(2, {(1) = -3, (2) = 5}), (43, 2) = Vector(2, {(1) = -2, (2) = -2}), (43, 3) = Vector(2, {(1) = 1, (2) = -1}), (44, 1) = Vector(2, {(1) = -5, (2) = 3}), (44, 2) = Vector(2, {(1) = -1, (2) = -3}), (44, 3) = Vector(2, {(1) = 1, (2) = -1}), (45, 1) = Vector(2, {(1) = -6, (2) = 0}), (45, 2) = Vector(2, {(1) = 0, (2) = -3}), (45, 3) = Vector(2, {(1) = 1, (2) = 0}), (46, 1) = Vector(2, {(1) = -6, (2) = -3}), (46, 2) = Vector(2, {(1) = 1, (2) = -2}), (46, 3) = Vector(2, {(1) = 1, (2) = 1}), (47, 1) = Vector(2, {(1) = -5, (2) = -5}), (47, 2) = Vector(2, {(1) = 2, (2) = -1}), (47, 3) = Vector(2, {(1) = 1, (2) = 1}), (48, 1) = Vector(2, {(1) = -3, (2) = -6}), (48, 2) = Vector(2, {(1) = 3, (2) = 0}), (48, 3) = Vector(2, {(1) = 1, (2) = 1}), (49, 1) = Vector(2, {(1) = 0, (2) = -6}), (49, 2) = Vector(2, {(1) = 3, (2) = 1}), (49, 3) = Vector(2, {(1) = 0, (2) = 1}), (50, 1) = Vector(2, {(1) = 3, (2) = -5}), (50, 2) = Vector(2, {(1) = 2, (2) = 2}), (50, 3) = Vector(2, {(1) = -1, (2) = 1}), (51, 1) = Vector(2, {(1) = 5, (2) = -3}), (51, 2) = Vector(2, {(1) = 1, (2) = 3}), (51, 3) = Vector(2, {(1) = -1, (2) = 1}), (52, 1) = Vector(2, {(1) = 6, (2) = 0}), (52, 2) = Vector(2, {(1) = 0, (2) = 3}), (52, 3) = Vector(2, {(1) = -1, (2) = 0}), (53, 1) = Vector(2, {(1) = 6, (2) = 3}), (53, 2) = Vector(2, {(1) = -1, (2) = 2}), (53, 3) = Vector(2, {(1) = -1, (2) = -1}), (54, 1) = Vector(2, {(1) = 5, (2) = 5}), (54, 2) = Vector(2, {(1) = -2, (2) = 1}), (54, 3) = Vector(2, {(1) = -1, (2) = -1}), (55, 1) = Vector(2, {(1) = 3, (2) = 6}), (55, 2) = Vector(2, {(1) = -3, (2) = 0}), (55, 3) = Vector(2, {(1) = -1, (2) = -1}), (56, 1) = Vector(2, {(1) = 0, (2) = 6}), (56, 2) = Vector(2, {(1) = -3, (2) = -1}), (56, 3) = Vector(2, {(1) = 0, (2) = -1}), (57, 1) = Vector(2, {(1) = -3, (2) = 5}), (57, 2) = Vector(2, {(1) = -2, (2) = -2}), (57, 3) = Vector(2, {(1) = 1, (2) = -1}), (58, 1) = Vector(2, {(1) = -5, (2) = 3}), (58, 2) = Vector(2, {(1) = -1, (2) = -3}), (58, 3) = Vector(2, {(1) = 1, (2) = -1}), (59, 1) = Vector(2, {(1) = -6, (2) = 0}), (59, 2) = Vector(2, {(1) = 0, (2) = -3}), (59, 3) = Vector(2, {(1) = 1, (2) = 0}), (60, 1) = Vector(2, {(1) = -6, (2) = -3}), (60, 2) = Vector(2, {(1) = 1, (2) = -2}), (60, 3) = Vector(2, {(1) = 1, (2) = 1})})
xmin := 0; xmax := 0; ymin := 0; ymax := 0; for i from 2 while M[i, 1] <> M[1, 1] and i < 25 do xmin := min(M[i, 1][1], xmin); ymin := min(M[i, 1][2], ymin); xmax := max(M[i, 1][1], xmax); ymax := max(M[i, 1][1], ymax) end do; i, xmin, xmax, ymin, ymax
25, -6, 6, -6, 6
orb := plot(([seq])([M[j, 1][1], M[j, 1][2]], j = 1 .. i), colour = blue); l1 := plot(sqrt(2-sqrt(2))*x/sqrt(2+sqrt(2)), x = xmin .. xmax, colour = green); l2 := plot(-sqrt(2-sqrt(2))*x/sqrt(2+sqrt(2)), x = xmin .. xmax, colour = green); l3 := plot(sqrt(2+sqrt(2))*x/sqrt(2-sqrt(2)), x = xmin .. xmax, y = ymin .. ymax, colour = green); l4 := plot(-sqrt(2+sqrt(2))*x/sqrt(2-sqrt(2)), x = xmin .. xmax, y = ymin .. ymax, colour = green); display(orb, l1, l2, l3, l4, scaling = constrained)
Error, invalid input: seq expects its 3rd argument, step, to be of type numeric, but received j = 1 .. 25
Download plot_arrows_sequence.mw
with(plots)
with(plottools)
25, -6, 6, -6, 6
I want to learn about why sometimes different algebraic expressions are ordered differently, and what would be the best way to instruct maple to chose a different "rule" for which a set of arithmetic functions are ordered, while still maintaining the axiom of uniqueness.
I figured this would be accomplished on a case by case basis, and it may involve just using lists instead,defining a procedure to produce the desired ordering for any given set of functions, and using the "remove" command to replace the set "difference" operator and the Join command for the lists in place of the union operator. Then of course using the "Remove Duplicates" option from ListTools to impose the axiom of unique elements.
Is this the best way to go about this, or is there a much simpler way, that includes an abstract algebra package that I'm unaware of thus far?
Hello everyone. Does anyone know how to display more than one rectangles on a single graph?
For example,
RECTANGLE 1:
RECTANGLE 2:
We wish to display both rectangles on a single graph without adjusting any of the coordinates. Look forward to anyone that familiar or even have any idea on this issue. Thanks in advanced:)
Dear sir, I hereby request you to suggest an appropriate method to plot phase portrait sketches for the above cited subject
in 2D and 3D for the problem
With thanks and regards.
Mr M ANAND
Associate Profesoor in Mathematics.
This question is related to an answer I gave here:
So, please look at a simple worksheet containing only a few lines; the resuts are in the # comments.
evalf(frac(Pi^20));
#                              23.
printlevel:=40:
evalf(frac(Pi^20));
  ###  prinlevel stuff
#                              0.
And now the questions.
1. Why the first evalf(frac(Pi^20))  does not  call  `evalf/frac`?
     (the second does, trace(`evalf/frac`)  shows this  if inserted).
     Note that  `evalf/frac`(Pi^20)    returns  0.
2. Why evalf(frac(Pi^20))    depends on printlevel?
    Note that  if  printlevel is changed to 20 (say)  the result is again 23.
3. Why if we set interface(typesetting=standard)  in a fresh session
     the results are both 23?
I can't get a While do loop to work as expected.
For i from 2 while M[i,1]<>M[1,1] and i<25 do..   It doesn't catch row 15 where M[15,1] =M[1,1] but it does stop at i = 24 ok.
M[1, 1]; for i from 2 while M[i, 1] <> M[1, 1] and i < 25 do print(i, M[i, 1]) end do
24, Vector[column](%id = 18446745366646139710)
Download Test_While_do_loop.mw
I'm currently wondering about the cut I'm looking for in the following worksheet.
I evaluate it in 2 ways but get different answers. Any idea what the problem here is?
restart; dIs := sqrt(Pi/(I*s))*exp(I*s*t-I*s*omega0^2); Is1 := `assuming`([simplify(int(dIs, s))], [s > 0]); dIs := `assuming`([int(exp(-I*(omega^2+omega0^2-t)*s), omega = -infinity .. infinity)], [s > 0]); Is2 := int(%, s); plot3d(Im(eval(Is1, [t = x+I*y, s = 1, omega0 = 1])), x = -3 .. 3, y = -3 .. 3)
(-I*Pi/s)^(1/2)*exp(I*s*t-I*s*omega0^2)
(1/2-(1/2)*I)*Pi*2^(1/2)*erf(s^(1/2)*(I*(omega0^2-t))^(1/2))/(I*(omega0^2-t))^(1/2)
exp(I*s*t-I*s*omega0^2)*Pi^(1/2)/(I*s)^(1/2)
-I*Pi*erf((omega0^2-t)^(1/2)*(I*s)^(1/2))/(omega0^2-t)^(1/2)
Download CutErrorFunction.mw
restart; with(plots);
  semilogplot, setcolors, setoptions, setoptions3d, spacecurve,
fixedparameter1 := [n = .3, W[e] = .3, M = .2, gamma = 1, delta = -1, N[r] = .8, Pr = .72, Nb = .5, Nt = .5, Bi = 2, Pr = .72, Le = 5];
[n = 0.3, W[e] = 0.3, M = 0.2, gamma = 1, delta = -1, N[r] = 0.8,
  Pr = 0.72, Nb = 0.5, Nt = 0.5, Bi = 2, Pr = 0.72, Le = 5]
eq1 := (1-n)*(diff(f(eta), eta, eta, eta))+f(eta)*(diff(f(eta), eta, eta))-M*(diff(f(eta), eta))+n*W[e]*(diff(f(eta), eta, eta, eta))*(diff(f(eta), eta, eta)) = 0;
        /  d   /  d   /  d         \\\
(1 - n) |----- |----- |----- f(eta)|||
        \ deta \ deta \ deta       ///
            /  d   /  d         \\     /  d         \
   + f(eta) |----- |----- f(eta)|| - M |----- f(eta)|
            \ deta \ deta       //     \ deta       /
            /  d   /  d   /  d         \\\ /  d   /  d         \\
   + n W[e] |----- |----- |----- f(eta)||| |----- |----- f(eta)|| =
            \ deta \ deta \ deta       /// \ deta \ deta       //
deq1; eval(eq1, fixedparameter1);
    /  d   /  d   /  d         \\\
0.7 |----- |----- |----- f(eta)|||
            /  d   /  d         \\       /  d         \
   + f(eta) |----- |----- f(eta)|| - 0.2 |----- f(eta)|
   + 0.09 |----- |----- |----- f(eta)||| |----- |----- f(eta)|| =
eq2 := (1+(4/3)*N[r])*(diff(theta(eta), eta, eta))+Pr*f(eta)*(diff(theta(eta), eta))+Nb*(diff(phi(eta), eta))*(diff(theta(eta), eta))+Nt*(diff(theta(eta), eta))*(diff(theta(eta), eta)) = 0;
          /    4     \ /  d   /  d             \\
          |1 + - N[r]| |----- |----- theta(eta)||
          \    3     / \ deta \ deta           //
                         /  d             \
             + Pr f(eta) |----- theta(eta)|
                         \ deta           /
                  /  d           \ /  d             \
             + Nb |----- phi(eta)| |----- theta(eta)|
                  \ deta         / \ deta           /
                  /  d             \
             + Nt |----- theta(eta)|  = 0
                  \ deta           /
deq2; eval(eq2, fixedparameter1);
                      /  d   /  d             \\
          2.066666667 |----- |----- theta(eta)||
                      \ deta \ deta           //
                           /  d             \
             + 0.72 f(eta) |----- theta(eta)|
                           \ deta           /
                   /  d           \ /  d             \
             + 0.5 |----- phi(eta)| |----- theta(eta)|
                   \ deta         / \ deta           /
                   /  d             \
             + 0.5 |----- theta(eta)|  = 0
                   \ deta           /
eq3 := diff(phi(eta), eta, eta)+Pr*Le*f(eta)*(diff(phi(eta), eta))+Nt*(diff(theta(eta), eta, eta))/Nb = 0;
    /  d   /  d           \\                /  d           \
    |----- |----- phi(eta)|| + Pr Le f(eta) |----- phi(eta)|
            /  d   /  d             \\
         Nt |----- |----- theta(eta)||
            \ deta \ deta           //
       + ----------------------------- = 0
                      Nb
deq3 := eval(eq3, fixedparameter1);
    /  d   /  d           \\               /  d           \
    |----- |----- phi(eta)|| + 3.60 f(eta) |----- phi(eta)|
                     /  d   /  d             \\
       + 1.000000000 |----- |----- theta(eta)|| = 0
                     \ deta \ deta           //
bcs1 := f(0) = 0, D(f)(0) = 1+gamma*(D@D)(F)(0)+delta*(D@D@D)(f)(0), D(f)(8) = 0;
 f(0) = 0,
   D(f)(0) = 1 + gamma @@(D, 2)(F)(0) + delta @@(D, 3)(f)(0),
   D(f)(8) = 0
bc1 := eval(bcs1, fixedparameter1);
   f(0) = 0, D(f)(0) = 1 + @@(D, 2)(F)(0) - @@(D, 3)(f)(0),
     D(f)(8) = 0
bcs2 := D(theta)(0) = Bi*(theta(0)-1), theta(8) = 0;
         D(theta)(0) = Bi (theta(0) - 1), theta(8) = 0
bc2 := eval(bcs2, fixedparameter1);
           D(theta)(0) = 2 theta(0) - 2, theta(8) = 0
bcs3 := Nb*D(phi)(0)+Nt*D(theta)(0) = 0, Nb*D(phi)(0)+Nt*D(theta)(0) = 0, phi(8) = 0;
        Nb D(phi)(0) + Nt D(theta)(0) = 0,
          Nb D(phi)(0) + Nt D(theta)(0) = 0, phi(8) = 0
bc3 := eval(bcs3, fixedparameter1);
       0.5 D(phi)(0) + 0.5 D(theta)(0) = 0,
         0.5 D(phi)(0) + 0.5 D(theta)(0) = 0, phi(8) = 0
R := dsolve({bc1, bc2, bc3, deq1, deq2, deq3}, [f(eta), theta(eta), phi(eta)], numeric, output = listprocedure);
Hello! I am trying to make an if statement that is IF a bound is not equal to NULL, it does things, and if it IS equal to NULL, the bounds are set to zero. When a bound is null, they say
bound1:=()
My first if statement will not work, please help!
bound1:=solve(tau(x)=(Intv||j)[1],x,useassumptions) assuming (Intv||i)[1]<=x<=(Intv||i)[2] ;
bound2:=solve(tau(x)=(Intv||j)[2],x,useassumptions) assuming (Intv||i)[1]<=x<=(Intv||i)[2];
if bound1<>NULL;bound2<>NULL;  then
if bound1<=bound2   then
lower:=bound1;  upper:=bound2
else lower:=bound2;   upper:=bound1 end if;
else lower:=0; upper:=0 end if;
Let be given tetrahedron ABCD, where AB = BC = AC = a, AD = d, AD = e, CD = f. I know that, If the measure of angle of AB and CD equal to Pi/3, then we have d^2 - e^2 - a*f = 0. I tried:
ListTools[Categorize];
L := [];
for a to 30 do for d to 30 do
for e to 30 do for f to 30 do
if abs(d-e) < a and a < d+e and abs(a-e) < d and d < a+e and abs(d-a) < e and e < d+a and abs(d-f) < a and a < d+f and abs(a-f) < d and d < a+f and abs(d-a) < f and f < d+a and abs(e-f) < a and a < e+f and abs(a-f) < e and e < a+f and abs(a-e) < a and a < a+e and -a*f+d^2-e^2 = 0 and igcd(a, d, e, f) = 1 and nops({a, d, e, f}) = 4
then L := [op(L), [a, d, e, f]] end if end do end do end do end do;
nops(L);
L;
Another way to find the length of edges of a tetrahedron knowing that the mesure angle of two opposite?
First 839 840 841 842 843 844 845 Last Page 841 of 2459
