Hello everyone!
I miss a convinient way to build interactive plots with parameters assigned to sliders. E.g. of such expressions as "a*sin(b*x+c)". Before Maple 2017 I could just right-click the expression, choose "plot builder" and then select "interactive plot with three parameters". That's it. Since the introduction of the new interactive plot builder I am at a loss because that way have been lost and I don't know any other way equally quick and convinient. "Interactive plot builder" now means quite another thing!
Any suggestions?
Hello everyone!
I want to solve a pde and create a matrix. But unfortunately, an error is formed.
Please, someone help me to remove that error.
Here, I am attaching a mapple file.
pde_solu.mw
Probably I'm doing something severely wrong, but
sum(x^n,n=0..infinity)
does not evaluate to the geometric series result 1/(1-x), why?
Similarly this happens for the sum(x^n/n,n=1..infinity)
It works with Maple17 though.
Hi, i want to solve the Ax=b with jacobi method and 4 Iteration, A=Matrix(3, 3, [1, 2, 1, 2, 1, 3, -1, -3, 4]) and b=[8, 13, 5].
i want to write a code with for or if or while. tnx
MAPLE will evaluate the 1st integral below, but not the 2nd.  Is it possible to get MAPLE to do the evaluation?  I know it can be done numerically, but what about analytically?
int(sin(Pi*x*n/T), x);
int(sin(Pi*x*n/T)*cos(Pi*x*n/T)/(sin(Pi*x/T)*cos(Pi*x/T)), x);
Hi everyone !!
I have a problem to find a solution for some symbolic nonlinear equations. I used the solve command but it takes much time and finally, I stopped the process because doesn't give me a solution. I have attached the code.
Please, help me
Cond_Poincare.mw
I*mu*A(t[2])*omega[0]*(1/2)-A(t[2])*omega[0]*(diff(B(t[2]), t[2]))+I*(diff(A(t[2]), t[2]))*omega[0]-(1/4)*A(t[2])^5*beta[2]*omega[0]^2-(1/4)*A(t[2])^3*beta[1]*omega[0]^2-(1/2)*F[0]*exp(I*sigma*t[2]-I*B(t[2]))+5*alpha[2]*A(t[2])^5*(1/16)+3*alpha[1]*A(t[2])^3*(1/8);
((1/2)*I)*mu*A(t[2])*omega[0]-A(t[2])*omega[0]*(diff(B(t[2]), t[2]))+I*(diff(A(t[2]), t[2]))*omega[0]-(1/4)*A(t[2])^5*beta[2]*omega[0]^2-(1/4)*A(t[2])^3*beta[1]*omega[0]^2-(1/2)*F[0]*exp(I*sigma*t[2]-I*B(t[2]))+(5/16)*alpha[2]*A(t[2])^5+(3/8)*alpha[1]*A(t[2])^3
simplify(%);
-(1/2)*F[0]*exp(-I*(-sigma*t[2]+B(t[2])))+I*(diff(A(t[2]), t[2]))*omega[0]+(1/2)*(-2*(diff(B(t[2]), t[2]))*omega[0]+(-(1/2)*beta[2]*omega[0]^2+(5/8)*alpha[2])*A(t[2])^4+(-(1/2)*beta[1]*omega[0]^2+(3/4)*alpha[1])*A(t[2])^2+I*mu*omega[0])*A(t[2])
subs(C(t2)=-sigma*t2+B(t2),%);
Download no_change.mw
I need to use newtons method to solve this in maple if someone can help me i will be very thankfull
help required to find the value of u analytically
Dear friends, i want to solve inequalities as follow:
solve({0 < Q, 0 < delta, 0 < t, 0 < E[0], 0 < lambda[1], 0 < (lambda[1]^2*(Q+2*t+4*delta-4*E[0])+lambda[1]*(Q+2*t+3*delta-7*E[0])-3*E[0])/((lambda[1]^2-6*lambda[1]-6)*t), Q < -(3*delta*lambda[1]+2*t*lambda[1]-4*E[0]*lambda[1]+6*delta-3*E[0])/lambda[1], delta < E[0]*(4*lambda[1]+3)/(3*(lambda[1]+2)), t < -(3*delta*lambda[1]-4*E[0]*lambda[1]+6*delta-3*E[0])/(2*lambda[1]), lambda[1] < 1, (lambda[1]^2*(Q+2*t+4*delta-4*E[0])+lambda[1]*(Q+2*t+3*delta-7*E[0])-3*E[0])/((lambda[1]^2-6*lambda[1]-6)*t) < (lambda[1]*(-2*Q-4*t-2*delta+3*E[0])-lambda[1]^2*delta+lambda[1]^2*E[0]+2*E[0]-2*Q-4*t)/((lambda[1]^2-6*lambda[1]-6)*t) and (lambda[1]*(-2*Q-4*t-2*delta+3*E[0])-lambda[1]^2*delta+lambda[1]^2*E[0]+2*E[0]-2*Q-4*t)/((lambda[1]^2-6*lambda[1]-6)*t) < 1})
But, processing is very heavy and takes too much time! is there any alternative solution?
Thank you in advance.
I am in the process of rewriting a long program so that it invokes procs.  After each proc I write I want to test the proc, so am not interested in any further output.  So in the code I entered `quit` (12);  - which I obtained from the Maple 7 Help documentation.  ...and possibly for good measure:  done;   The system crashed and I had to start again.   I have looked on the MaplePrimes documentation.  There are a couple of posts which treat this as an amusement.  eg
subs(_=sscanf(D,%m)[],proc() _end)();   which I haven't been game to try yet.
  I am curious about the number 12.  In the Maple 7 documentation the output is meant to give some useful information regards bytes used, allocation, & time taken.  Maple 7 documentation says that the number between parentheses should be an nteger in the  range 0..255.  Does varying this number make any difference?
WARNING!  Running the following program could crash your system.  Save any work before trying it.
restart:  `quit` (12);
   I'm curious to know what that does on later versions.  I'm running Maple 7 on Windows 7, so I suspect some incompatibility.
Any comments, advice gratefully received.  David
C_t := -A(t)*omega[0]*(sigma-(diff(C(t), t)))-(1/4)*A(t)^5*beta[2]*omega[0]^2-(1/4)*A(t)^3*beta[1]*omega[0]^2-(1/2)*F[0]*cos(C(t))+5*alpha[2]*A(t)^5*(1/16)+3*alpha[1]*A(t)^3*(1/8) = 0;
-A(t)*omega[0]*(sigma-(diff(C(t), t)))-0.3297500000e-1*A(t)^5*omega[0]^2-0.8345000000e-1*A(t)^3*omega[0]^2-cos(C(t))+0.4059375000e-1*A(t)^5+.1249125000*A(t)^3 = 0
A_t := (1/2)*mu*A(t)*omega[0]+(diff(A(t), t))*omega[0]-(1/2)*F[0]*sin(C(t)) = 0;
0.5000000000e-2*A(t)*omega[0]+(diff(A(t), t))*omega[0]-sin(C(t)) = 0
F[0] :=2: w0 := 1: alpha[1]:=0.3331:alpha[2]:=0.1299:beta[1]:=0.3338:beta[2]:=0.1319:mu:=0.01:sigma=0:
sigma = `0:`
C_t;A_t;
ICS:=[C(0)=0,D(C)=0,A(0)=1,D(A)=0]:
sol:=dsolve({C_t,A_t,ICS},[C(t2),D(C),A(t2),D(A)],type=numeric):
pRange:=0..20:
 Atime:=odeplot( sol, [t, A],t=pRange, numpoints=10000 ):
Atime;
odeplot(sol, [t, A], t = 0 .. 20, numpoints = 10000)
Download phase_plot.mw
rho := -2*K*(s+K)^2*k[e]*sinh((s+K)*x/d)/(s*d^2*(4*(s+K)^3*cosh((s+K)*h/d)*h/d^2-4*K*(s+K)*cosh((s+K)*h/d)*h/d+4*sinh((s+K)*h/d)*K))
l.mw
All variables are constant except s and x
I would like to ask, how can I translate a Maple worksheet to a Mathematica notebook.
I'm working on coding questions and I want to realize a particular addition (sometimes called "Nim addition")
Here is an example in base 3
Let A=11 and B=21 two numbers written inbase 10.
I want to realize the operation "A plus B" defined this way
  1. write A and B in base 3 : A -> a=102  and B -> b=210
  2. do c=a+b just as if a and b were numbers in base 10 : c=312
  3. compute all digits modulo 3 : 312 -> 012 = 12
  4. write this number in base 10 : 12 -> 5
Then 11 plus 21 = 5
In Maple"s syntax :
A := 11:
B := 21:
a := convert(A, base, 3):   # returns [1, 0, 2]
b := convert(B, base, 3):   # returns [0, 1, 2]
# the simplest thing I found to implement operation 2 and 3 above is :
# 1/ convert each list into polynomials (let's say pa and pb)
# 2/ set pc = pa+pb mod 3
# 3/ convert pc into a list
# Instead of coding something like pa := add(a[k]*x^(k-1), k=1..numelems(a)),
# I found more astute to use the gfun package
sa := gfun[listtoseries](a, x, 'ogf'):  # returns x^2+2+O(x^3)
sb := gfun[listtoseries](b, x, 'ogf'):  # returns 2*x^2+x+O(x^3)
pc := convert(sa, polynom)+convert(sb, polynom) mod 3; # returns x+2
Unfortunately I can't use now gfun[seriestolist](pc, 'revogf') for pc is obviously not a serie !
Reciprocally sc := sa+sb mod 3 doesn't return x+2+O(x^3)
Then I'm trapped here and I don't know how to go further
(of course I know how to proceed if I build directly the polynoms associated to a and b ... but it is far less elegant)
Does anyone have some idea ?
This problems raise the following question: how can we add tho series ?
For instance sa+sb returns (x^2+2+O(x^3))+(2*x^2+x+O(x^3)) without, apparently, no way to simplify this into  x+2+O(x^3)
First 849 850 851 852 853 854 855 Last Page 851 of 2459
