I'm new to maple and have a problem when using the dsolve in a for loop. I get the error message Error, (in dsolve/numeric/process_input) the independent variable (t in phi(t)) cannot be a procedure name and I dont now why.
The code design is
for k to kk do
vars := x(t), y(t), phi(t);
ic := x(0) = xx, y(0) = yy, phi(0) = zz;
sys := diff(x(t), t) = y(t),
diff(y(t), t) = -2*gamma*y(t)-alpha*x(t)-beta*x(t)^3+F*cos(phi(t)),
diff(phi(t), t) = 1;
sol := dsolve({ic, sys}, {vars}, numeric, output = listprocedure, numeric = -1);
assign(sol);
x := x(t);
y := y(t);
phi := phi(t);
numpts := 50;
pts := seq([x(2*Pi*i), y(2*Pi*i)], i = 1 .. numpts);
plt(k) := plot([pts], view = [-1.5 .. 1.5, -.5 .. 1], color = black);
xx := 'xx'; yy := 'yy'; zz := 'zz';
xx := x(2*Pi*numpts);
yy := y(2*Pi*numpts);
zz := phi(2*Pi*numpts);
unassign(x, y, phi);
end do
Let's say you have a m times n matrix and you want to ask Maple to computes all of its p minors (p smaller than minimum of m and n). Is there any prepared command for it at Maple? I can write a procedure myself, I just want to know if there is a command in Maple or not. The minor command in LinearAlgebra package is just computing determinant of a square matrix after removing a given row and a given column which is not what I'm talking about.
I am totally stuck in the question:
I can do it for seperate cases, but how to do it, with somekind of sequence
Integral for x= 0 to infinity of [2 sin(x/2)/x] ^ 2n
this has to be equal to:
2n* pi (sum of [(-1)^j * (n-j)^(2n-1)] / [j! * (2n-j)!]
I showed it for j=0 and n=1
But how to do it for n =1,2,3 and 4
I need a help to finish just two lines in my code:
1)How substitute condition in a system of equations
2) How solve the obtained system ( not a linear system)
3) If its possible to plot the set of points (x_i,y_j, u_{ij})
Many thanks for your help
codetosee.mw
hi
how i can pdsolve these partial differentialequations?
10.mw
restart; R := 1; UB := 1; lambda := 1; pe1 := 1; pe2 := 1; L := 1; Gr := 1; Br := 1; p := 1; LinearAlgebra:-HermitianTranspose(L) := 1; Nb := 1; Nt := 1; a := lambda*pe1*u(r, z)*(diff(sigma(r, z), z))-(diff(r*(diff(sigma(r, z), r)), r))/r-lambda^2*(diff(sigma(r, z), z, z))-Nt*((diff(r*(diff(theta(r, z), r)), r))/r+lambda^2*(diff(theta(r, z), z, z)))/Nb
u(r, z)*(diff(sigma(r, z), z))-(diff(sigma(r, z), r)+r*(diff(diff(sigma(r, z), r), r)))/r-(diff(diff(sigma(r, z), z), z))-(diff(theta(r, z), r)+r*(diff(diff(theta(r, z), r), r)))/r-(diff(diff(theta(r, z), z), z))
b := lambda*pe2*u(r, z)*(diff(theta(r, z), z))-(diff(r*(diff(theta(r, z), r)), r))/r-lambda^2*(diff(theta(r, z), z, z))-Nb*((diff(sigma(r, z), r))*(diff(theta(r, z), r))+(diff(sigma(r, z), z))*(diff(theta(r, z), z))*lambda^2)-Nt*((diff(theta(r, z), r))^2+lambda^2*(diff(theta(r, z), z))^2)
u(r, z)*(diff(theta(r, z), z))-(diff(theta(r, z), r)+r*(diff(diff(theta(r, z), r), r)))/r-(diff(diff(theta(r, z), z), z))-(diff(sigma(r, z), r))*(diff(theta(r, z), r))-(diff(sigma(r, z), z))*(diff(theta(r, z), z))-(diff(theta(r, z), r))^2-(diff(theta(r, z), z))^2
c := -p+(diff(r*(diff(u(r, z), r)), r))/r-L^2*(diff(r*(diff((diff(r*(diff(u(r, z), r)), r))/r, r)), r))/r+Gr*theta(r, z)+Br*sigma(r, z)
-1+(diff(u(r, z), r)+r*(diff(diff(u(r, z), r), r)))/r-(-(diff(u(r, z), r)+r*(diff(diff(u(r, z), r), r)))/r^2+(2*(diff(diff(u(r, z), r), r))+r*(diff(diff(diff(u(r, z), r), r), r)))/r+r*(2*(diff(u(r, z), r)+r*(diff(diff(u(r, z), r), r)))/r^3-2*(2*(diff(diff(u(r, z), r), r))+r*(diff(diff(diff(u(r, z), r), r), r)))/r^2+(3*(diff(diff(diff(u(r, z), r), r), r))+r*(diff(diff(diff(diff(u(r, z), r), r), r), r)))/r))/r+theta(r, z)+sigma(r, z)
bc := {sigma(R, z) = 0, sigma(r, 0) = 1, theta(R, z) = 0, theta(r, 0) = 1, u(R, z) = UB, (D[1](sigma))(0, z) = 0, (D[1](sigma))(r, LinearAlgebra:-HermitianTranspose(L)) = 0, (D[1](theta))(0, z) = 0, (D[1](theta))(r, LinearAlgebra:-HermitianTranspose(L)) = 0, (D[1](u))(0, z) = 0, (D[2](u))(R, z) = 0}
{sigma(1, z) = 0, sigma(r, 0) = 1, theta(1, z) = 0, theta(r, 0) = 1, u(1, z) = 1, (D[1](sigma))(0, z) = 0, (D[1](sigma))(r, 1) = 0, (D[1](theta))(0, z) = 0, (D[1](theta))(r, 1) = 0, (D[1](u))(0, z) = 0, (D[2](u))(1, z) = 0}
Download 10.mw
I have this situation:
We have sol[1] = "A=1", etc. How do I pick up just the solution values 1, 2 and 3 from sol? This is a generated system in a larger program, so I don't have access to the individual numbers coming out of a single step.
mapleatha
Good day,
I have a problem with inequalities plotting (trsh_con.mw). I need to plot them(eq5,eq7) in the same box. But I get the wrong solution. The plot not giving me correct region for 2 inequalities. I attach the mw file. Are there any options to overcome such problems?
I need help solving Translation Step4 and Dilation Step5
Translation
Ta,b(x,y)=(x+a,y+b)
Dilation
Dk(x,y)=(kx,ky)
This works:
plot(tickmarks = [spacing(1), spacing(2)]);
but not this:
plot(axis = [tickmarks = [spacing(1), spacing(2)]]);
Error, (in plot) incorrect value for option tickmarks or gridlines: [spacing(1), spacing(2)]
Seems wrong, and the problem is that for gridlines neither form works, so gridlines=[spacing(1), spacing(2)] doesn't seem to be possible.
In the partial fraction decomposition Maple often changes the order of the terms.
For example,
How do we remedy this?
mapleatha
Dear Maple  users,
I am facing the memory allocation problem while calculating the inverse Laplace transformation of a big expression. I have many such terms (401) and I am importing them from a text file.
For an individual term itself, Maple consumes huge memory but at the end, it is able to calculate it in about an hour. I want to automate the process of reading and writing the terms one by one from the different text files. While doing so, maple eats a lot of memory and I see the error msg
"Error, (in expand/bigprod) Maple was unable to allocate enough memory to complete this computation.
Please see ?alloc "
Is there a way to do so? The maple file is attached.
InvLaplace_ex.mw
I have invalid operator parameter name, i don't know where is the mistake.
fdfd.mw
I'm producing multiple matrices via a for-loop (n = + 100) and I want to export each matrix into the same Excel-sheet, however I want to insert all matrices in cells beneath each other. I'm wondering if anyone knows how to do this? I've tried a loop variable but that doesn't work inside the "  " to specify the cells...
Note: Matrices are all 11x6. That means I want them inserted in the same sheet, in cells like this:
1st matrix: A1:F11
2nd matrix: A12:F23
3rd matrix: A24:F35
etc.
In other words: how to execute a loop-variable inside the " ", or to bypass it???
Please help! It's for my MSc Thesis:)
Helo dearz!
I want to find the inverse laplace transfrom (numerically) of the attached file of solution u and v for any values of M. I am waiting for your positive response.
Help_v2.mw
how to download  wkptest from http://cpc.cs.qub.ac.uk/summaries/ADTY_v1_0.html and install on maple?
First 912 913 914 915 916 917 918 Last Page 914 of 2434
