how to download  wkptest from http://cpc.cs.qub.ac.uk/summaries/ADTY_v1_0.html and install on maple?
I understand that matlab has function 'rfwrite' to generate touchstone file. This is a datafile used for high frequency modeling.
Is there any such package in Maple?
I´m new to Maple and I´m trying to find the minimum distance of an ECC from its parity check matrix or the generator matrix. Is this possible?
I have work sheet full of greek letters as words and parameters, some times I need to find where the specific letter is, but it seems find facility (Ctrl+F) couldnt find greek letters.
Suppose I have following workshee
II := 1
JJ := 1
N := 1
UK2
U1 := add(add(add(add(add((2*Rr[i, m]*Rr[k, m]/((2*m+1)*(2*j+1))*(2*b/(2*a)))*(A[1, 1]*U[i, j]*U[k, j]+2*A[1, 6]*U[i, j]*V[k, j]+A[5, 5]*W[i, j]*W[k, j]+A[6, 6]*V[i, j]*V[k, j]+2*B[1, 1]*Phi[i, j]*U[k, j]+2*B[1, 6]*V[i, j]*Phi[k, j]+2*B[1, 6]*Xi[i, j]*U[k, j]+2*B[6, 6]*Xi[i, j]*V[k, j]+Dd[1, 1]*Phi[i, j]*Phi[k, j]+2*Dd[1, 6]*Phi[i, j]*Xi[k, j]+Dd[6, 6]*Xi[i, j]*Xi[k, j]+(-R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^4+4*S[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^3-6*T[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2+4*K[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-Delta[1, 1, q])*GAMMA[i, j, q]*GAMMA[k, j, q]+(2*R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^3-6*S[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2+6*T[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-2*K[1, 1, q])*Omega[i, j, q]*GAMMA[k, j, q]+(-2*R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2+4*S[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-2*T[1, 1, q])*Theta[i, j, q]*GAMMA[k, j, q]+(2*E[1, 5, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2-4*F[1, 5, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]+2*G[1, 5, q])*W[i, j]*GAMMA[k, j, q]+(-R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]^2+2*S[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-T[1, 1, q])*Omega[i, j, q]*Omega[k, j, q]+(2*R[1, 1, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]-2*S[1, 1, q])*Theta[i, j, q]*Omega[k, j, q]+(-2*E[1, 5, q]*`#mover(mi("z"),mo("&uminus0;"))`[q]+2*F[1, 5, q])*W[i, j]*Omega[k, j, q]-R[1, 1, q]*Theta[i, j, q]*Theta[k, j, q]+2*E[1, 5, q]*W[i, j]*Theta[k, j, q]), i = 0 .. II), k = 0 .. II), m = 0 .. II), j = 0 .. JJ), q = 1 .. N):
Download greekfind.mw
t, how to find for example `#mover(mi("z"),mo("&uminus0;"))`[q] in it?
A fact that seems to be not documented. Probably it should be obvious.
Digits := d0
evalf[d](expr);
The toplevel float sub-expressions in expr  are computed with Digits=d0 but in procedures Digits is set to d.
Notice that the actual float parameters of the toplevel procedures are evalf-ed with Digits=d0.
g:=proc() convert(1/3., string) end:
h:=proc() 1/3. end:
Digits:=3;
evalf[10]([
  1/3. = h(),
  convert(1/3.,string) = g(),
  fsolve(3*x=1) = add([1/3]),
  fsolve(x/3=1/9.) # 1/9. being at top level is evalf-ed with Digits=3
[.333 = .3333333333, ".333" = ".3333333333", .3333333333 = .3333333333, .3330000000]
k:=proc(x) convert(x,string) end:
kernelopts(floatPi);
4.+Pi;
7.14
evalf(k(1/3.+Pi));
# floatPi seems to be ignored inside actual parameters
".333+Pi"
evalf(k(4+evalf(Pi)));
"7.14"
evalf(k(4+Pi));
# 4 not being float (or "infected" by a float) is not evalf-ed
"4+Pi"
### (this is documented)
`evalf/h` := proc() 7.777 end:
evalf(h(1/3));
.333
evalf('h'(1/3));
7.777
Download digits.mw
(edited)
variables := s, phi(s);
                           s, phi(s)
expr := (k*s^2+1)*(diff(phi(s), s, s))-k*phi(s)+s*k*(diff(phi(s), s));
  /   2    \ / d  / d        \\                  / d        \
  \k s  + 1/ |--- |--- phi(s)|| - k phi(s) + s k |--- phi(s)|
             \ ds \ ds       //                  \ ds       /
expr2 := int(expr, s);
                           /   2    \ / d        \
             -s k phi(s) + \k s  + 1/ |--- phi(s)|
                                      \ ds       /
int(expr2, s);
            /              /   2    \ / d        \   \
         int|-s k phi(s) + \k s  + 1/ |--- phi(s)|, s|
            \                         \ ds       /   /
solve({int(expr2, s)});
Error, (in solve) cannot solve expressions with int(-s*k*phi(s)+(k*s^2+1)*(diff(phi(s), s)), s) for s
I DIDN'T GET THE SOLUTION.PLEASE HELP
I have two big symbolic and numerical matrices in a worksheet, whats the best way and easiest way to transfer them to another maple worksheet?
Why is Maple 13 giving me
instead of (s-3)/((s-3)^2+4)?
mapleatha
It seems if for some reason Maple runs a command that returns an error but the error is outputing to the display, and it is very very large, javaw.exe will consume enormous amounts of memory and pretty much freeze your system.  It took me forever to get into task manager on Windows to try to kill the processes slowing my system down to a crawl.
For example if you run say listplot on a 60,000 set data element which is not in the correct form for listplot, Maple will error each element and attempt to output it to the screen which on my system quickly ran javaw.exe up to 2.5 Gb of memory usage. But then it went to zero again (probably due to garbage collection or something) and quickly ramped back up into 2 Gb.  Momentarily I was given enough system control to kill some processes to Maple and Firefox which eventually allowed me to take back control of my system.  When this first occurred, I did a hard reset, the second time I wanted to see if I could have any luck otherwise, but it took 5 minutes of frustration to get my system back to normal operating condition.
Hopefully Maple developers can use this information to prevent system hangs like this in the future.  Additionally pushing the interupt the current operation did little to stop the process already underway.
how to intergrate 6*(int(int(r(1-r^p*cos(t)^p-r^p*sin(t)^p)^(1/p), t = 0 .. (1/2)*pi), r = 0 .. 1))
when p = 0.05 to 4 with 0.05 increments.
Thanks a lot
it should be (cos(t))^p not cos(t)^p. same for sin(t)^p
int(sqrt(t^4+1)-t^2, t = 1 .. infinity);
       -(1/3*I)*sqrt(2)*(-(2*I)*EllipticK(I)-EllipticK(I*sqrt(-2)))+(1/3*I)*sqrt(2)*EllipticF((1/2)*sqrt(2)+
       (1/2*I)*sqrt(2), I)+(1/3)*sqrt(2)*(-(2*I)*EllipticK(I)-EllipticK(I*sqrt(-2)))-(1/3)*sqrt(2)*
       EllipticF((1/2)*sqrt(2)+(1/2*I)*sqrt(2), I)-(1/3)*sqrt(2)+1/3
The result is the correct value for int(sqrt(t^4+1)-t^2, t = 1 .. -infinity).
I am trying to find the orthocenter in the x,y plane, given three coordinates  (x1,y1) (x2,y2) (x3,y3).
I am trying to avoid division by zero.
orthocenter.mw
orthocenter:=proc(x1,y1,x2,y2,x3,y3)
local m1,m2,m3,L1,L2,L3,slope;
slope:=(a,b,c,d)->(d-b)/(c-a);
if x1=x2 then L1:=x=x1;
elif y1=y2 then L1:=y=y1;
else m1:=-1/slope(x2,y2,x3,y3); L1:=y-y1=m1*(x-x1);
if x2=x3 then L2:=x=x2;
elif y2=y3 then L2:=y=y2;
else m2:=-1/slope(x1,y1,x3,y3);L2:=y-y2=m2*(x-x2);
if x1=x3 then L3:=x=x1;
elif y1=y3 then L3:=y=y1;
else m3:=-1/slope(x1,y1,x2,y2);L3:= y-y3= m3*(x-x3);
print(solve({L1,L2,L3},{x,y}));
orthocenter(1,1,3,4,5,3);
{x = 11/4, y = 9/2}
orthocenter(0,0,0,3,4,1)
Error, (in slope) numeric exception: division by zero
Download orthocenter.mw
Hi! I need a help to understand how the variables in maple 17 works
I want to know if it's possible to change a variable, that I have already declared in a proc, along the body of a procedure. For example this procedure:
>Bucklingload:= proc(a,b,c,d,Q,pr)
local A;
A:=FN(a,b,c,d,Q); #vector of another gobal variable
while A[1] >0 do
Q:=Q+pr ;#"Q"and "pr" are both a list, wich the first value of the vector B decrease his value after an increase estimated in "pr" in "Q"
A[1];
After execute the worksheet, maple display this message:" illegal use of a formal parameter ". I want to know if its possible to use Q as a local variable chaging his value in this loop
Thank you all and sorry for my english!
The following website contains worksheets written in an early version of Maple.
http://www.yorku.ca/marko/ComPhys/
I would like to import worksheets 5.1 and 5.2 and work with them in Maple 2016. Is this possible?
Clicking on the worksheet id, e.g. 5.1, displays an .mws worksheet written in HTML which is not supported as an import format.
I'm currently working on compressing audio files using DCT to remove the frequencies that only contribute marginally to human perception of the sound. To do this, I'd like to do as the attached image describes. Sadly, I'm having trouble plotting the values of the DCT-coefficients as done in figure 6.4 b) and d).
Any help would be kindly appreciated.
First 913 914 915 916 917 918 919 Last Page 915 of 2434
