Dear Maple users,
I have very interesting problem with evaluating of only symbolic equations.
The problem is: (In document mode)
When I try to evaluate all numeric values for example typing 1+2 and press Enter it successfuly evaluates 3.
But when I try to evaluate symbolic values for example x + y nothing happens.
I tried lots of things to solve this, but no luck.
Shortly if the equation contains only numbers it evaluates successfuly.
And if the equation contains one or more symbolic variables like (x, y, z, variable1, test1), it does nothing.
What could be the problem?
(Because of this problem I cannot use the document mode, so I'm using the worksheet mode. Worksheet mode works good, but sometimes it is not calculating like document mode)
System is Windows 7 x64
Maple 2016
8 x 3.50GHz Xeon CPU
128 GB RAM
Windows Language is Turkish, (I tried with also USA English, but no luck either)
Keyboard is Turkish TR, (I tried with also US English, but no luck either)
Hi every body,
I’m a new member. I have a question about plot command in Maple. My question is “how to plot a vector field v = [v1,v2]=[x^2+y^2,x+y] with (x,y) within an elliptic domain defined by x^2/1+y^2/2 = 1” .
lqh
Suppose,  there are
  • 50 vertices
  • list of coordinates of these 50 vertices
Now I want to create a graph with minimum distance.
The starting point of the graph should be vertice 1. From there,  the closest point has to be added to a list X. and from this point, it should calculate again the closest point and add this value to the same list X.
So actually I want to start in point 1 and I want to see the sequence of how the graph (I think minimum spanning tree?) is created
How can I code this in Maple?
Thanks in advance!
Adam,
Hi Everybody,
I have a simple question: Does Maple solve systems of partial differential equations with boundary conditions?
Can somebody give me an example?
I have only found numerical solutions to this kind of systems but no symbolic example.
Thanks a lot for yor help.
To my amazement, the following code hangs
with(Physics):
Setup(anticommutativeprefix = psi):
Dagger(psi);
at the last line, or produces the output "Error, (in sprintf) too many levels of recursion" if I wait long enough.
What is going on? Am I just being stupid? The version line verifies to me that I am using the Physics package as shipped with Maple 2017, version date 17th of May 2017. If I outcomment the Setup line, then Dagger does not hang. Do others experience the same behaviour?
Hey,
I am using codegen to generate code from Maple expressions. More specifically I want to export non quadratic matix. The export works for matrices that have more columns than rows, but not for matrices with more rows than columns. There I receive the error:
Error, (in codegen/array/entry) 2nd index, 3, larger than upper array bound 2
A workaround would be to transpose the matrix before the export, and to transpose on the import (in Matlab) but I don't want to overcomplicate my code. Thanks for your help!
I have attached a demonstration worksheet below.
## test codegen non quadratic returnarray
## works
#Myfun := Matrix(3,3)
## works
#Myfun := Matrix(2,3):Myfun(2,3):= 3*b;
## does not work
Myfun := Matrix(3,2):Myfun(3,2):= 3*b;
Myfun := Matrix(3, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0, (3, 1) = 0, (3, 2) = 3*b})
Myfun(1):= 7*a;
Myfun := Matrix(3, 2, {(1, 1) = 7*a, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0, (3, 1) = 0, (3, 2) = 3*b})
## codegen works best with arraybased matrices, and call by reference becomes possible
returnArray:= convert(Myfun,matrix)
returnArray := Matrix(3, 2, {(1, 1) = 7*a, (1, 2) = 0, (2, 1) = 0, (2, 2) = 0, (3, 1) = 0, (3, 2) = 3*b})
codegen[makeproc](Myfun,[a,b])
codegen[makeproc](returnArray,[returnArray,a,b])
codegen[makeproc](returnArray,[a,b])
Download codegen_rectangular_matrix.mw
Hi, everybody.
I have a problem when I try to plot3d a sub-surface from a surface as follows:
S := proc (u, v) options operator, arrow; Matrix([[40*u], [80*v], [10*u^2*v+20*u*v+15]]) end proc;
S(u, v)
Matrix(3, 1, {(1, 1) = 40*u, (2, 1) = 80*v, (3, 1) = 10*u^2*v+20*u*v+15})
p:= proc(u,v) if u<v then S(u,v) else S(u,v)+10 end if end proc:
h:= proc(u) 2*u  end proc:
plot3d(p, 0 .. 1, 0 .. h)
Download sub-surface.mw
sub-surface.mw
Please help me!
Thanks and have a nice day.
how can i plot tangent function without its Asymptote on kPi/2s ? actuallt i want to plot without its vertical Asymptote, could anybody help? tnx
plot(tan(x),x=-2*Pi..2*Pi,style = line,color = "Blue",legend = "tangent Plot",axes=boxed,gridlines);
Download plot.mw
i want to know the area under a diagram plotted by pdsolve, how can i do that? for example in below , what is the area under p1 diagram?
restart:k:=5;
5
EQ:=diff(u(x,t),t)=k*diff(u(x,t),x$2);
diff(u(x, t), t) = 5*(diff(diff(u(x, t), x), x))
ibc:=u(0,t)=0,u(1,t)=0, u(x,0) = x;
u(0, t) = 0, u(1, t) = 0, u(x, 0) = x
sol:=pdsolve({EQ},{ibc},numeric);
_m2021168030176
p1:=sol:-plot(u,x=0.5,t=0...10,style = line,color = "Blue",legend = "heat Plot",axes=boxed);
M:=op(1,op(1,p1));
M := Array(1..201, 1..2, {(1, 1) = .0, (1, 2) = .5, (2, 1) = 0.5e-1, (2, 2) = .2702110502740721, (3, 1) = .1, (3, 2) = -0.176887059080428e-1, (4, 1) = .15, (4, 2) = -0.6515347962762406e-2, (5, 1) = .2, (5, 2) = 0.74109221595503715e-2, (6, 1) = .25, (6, 2) = -0.6178984348254404e-2, (7, 1) = .3, (7, 2) = 0.49645329554988925e-2, (8, 1) = .35, (8, 2) = -0.3948699801548904e-2, (9, 1) = .4, (9, 2) = 0.31161325326115076e-2, (10, 1) = .45, (10, 2) = -0.24369292293079273e-2, (11, 1) = .5, (11, 2) = 0.18845070914387395e-2, (12, 1) = .55, (12, 2) = -0.14366378752131666e-2, (13, 1) = .6, (13, 2) = 0.10748767238662861e-2, (14, 1) = .65, (14, 2) = -0.7839388660633711e-3, (15, 1) = .7, (15, 2) = 0.5511660027174686e-3, (16, 1) = .75, (16, 2) = -0.3660810752890637e-3, (17, 1) = .8, (17, 2) = 0.22001797006812284e-3, (18, 1) = .85, (18, 2) = -0.10581369353881973e-3, (19, 1) = .9, (19, 2) = 0.1755251750102873e-4, (20, 1) = .95, (20, 2) = 0.4964665498398858e-4, (21, 1) = 1.0, (21, 2) = -0.9980698165105276e-4, (22, 1) = 1.05, (22, 2) = 0.1362404856962589e-3, (23, 1) = 1.1, (23, 2) = -0.16167000912668705e-3, (24, 1) = 1.15, (24, 2) = 0.17833050358069153e-3, (25, 1) = 1.2, (25, 2) = -0.18805314257842951e-3, (26, 1) = 1.25, (26, 2) = 0.19233515285281392e-3, (27, 1) = 1.3, (27, 2) = -0.19239777469550633e-3, (28, 1) = 1.35, (28, 2) = 0.18923435555607597e-3, (29, 1) = 1.4, (29, 2) = -0.18365024366673088e-3, (30, 1) = 1.45, (30, 2) = 0.17629586775928352e-3, (31, 1) = 1.5, (31, 2) = -0.16769415545232156e-3, (32, 1) = 1.55, (32, 2) = 0.15826324867687376e-3, (33, 1) = 1.6, (33, 2) = -0.1483353129733858e-3, (34, 1) = 1.65, (34, 2) = 0.1381721031382132e-3, (35, 1) = 1.7, (35, 2) = -0.12797783595325005e-3, (36, 1) = 1.75, (36, 2) = 0.11790982779578369e-3, (37, 1) = 1.8, (37, 2) = -0.10808727763435372e-3, (38, 1) = 1.85, (38, 2) = 0.9859851163881829e-4, (39, 1) = 1.9, (39, 2) = -0.8950695218043435e-4, (40, 1) = 1.95, (40, 2) = 0.8085602954949057e-4, (41, 1) = 2.0, (41, 2) = -0.7267321775920382e-4, (42, 1) = 2.05, (42, 2) = 0.6497334507523223e-4, (43, 1) = 2.1, (43, 2) = -0.5776130436199765e-4, (44, 1) = 2.15, (44, 2) = 0.5103426709812118e-4, (45, 1) = 2.2, (45, 2) = -0.4478348725852213e-4, (46, 1) = 2.25, (46, 2) = 0.3899576658643508e-4, (47, 1) = 2.3, (47, 2) = -0.336546405833609e-4, (48, 1) = 2.35, (48, 2) = 0.28741334410836633e-4, (49, 1) = 2.4, (49, 2) = -0.2423552947809686e-4, (50, 1) = 2.45, (50, 2) = 0.20115974495047912e-4, (51, 1) = 2.5, (51, 2) = -0.16360968960468515e-4, (52, 1) = 2.55, (52, 2) = 0.12948742231058999e-4, (53, 1) = 2.6, (53, 2) = -0.985774731176686e-5, (54, 1) = 2.65, (54, 2) = 0.706688518346671e-5, (55, 1) = 2.7, (55, 2) = -0.4555672725651303e-5, (56, 1) = 2.75, (56, 2) = 0.23043650036730538e-5, (57, 1) = 2.8, (57, 2) = -0.29404079279315267e-6, (58, 1) = 2.85, (58, 2) = -0.14933413612624144e-5, (59, 1) = 2.9, (59, 2) = 0.30749105483557417e-5, (60, 1) = 2.95, (60, 2) = -0.4466869448461453e-5, (61, 1) = 3.0, (61, 2) = 0.5684494809229467e-5, (62, 1) = 3.05, (62, 2) = -0.67421491593684444e-5, (63, 1) = 3.1, (63, 2) = 0.765330108066053e-5, (64, 1) = 3.15, (64, 2) = -0.8430551865031369e-5, (65, 1) = 3.2, (65, 2) = 0.9085666798487518e-5, (66, 1) = 3.25, (66, 2) = -0.9629609655930039e-5, (67, 1) = 3.3, (67, 2) = 0.10072579272402201e-4, (68, 1) = 3.35, (68, 2) = -0.1042404728762369e-4, (69, 1) = 3.4, (69, 2) = 0.1069279635035891e-4, (70, 1) = 3.45, (70, 2) = -0.10886958224421352e-4, (71, 1) = 3.5, (71, 2) = 0.11014051364892259e-4, (72, 1) = 3.55, (72, 2) = -0.11081017636391213e-4, (73, 1) = 3.6, (73, 2) = 0.11094257929051255e-4, (74, 1) = 3.65, (74, 2) = -0.11059666495657345e-4, (75, 1) = 3.7, (75, 2) = 0.109826638880031e-4, (76, 1) = 3.75, (76, 2) = -0.10868228414258878e-4, (77, 1) = 3.8, (77, 2) = 0.10720926073958364e-4, (78, 1) = 3.85, (78, 2) = -0.1054493895470911e-4, (79, 1) = 3.9, (79, 2) = 0.1034409209623252e-4, (80, 1) = 3.95, (80, 2) = -0.10121878843963985e-4, (81, 1) = 4.0, (81, 2) = 0.9881484727059153e-5, (82, 1) = 4.05, (82, 2) = -0.9625809905064345e-5, (83, 1) = 4.1, (83, 2) = 0.9357490234275213e-5, (84, 1) = 4.15, (84, 2) = -0.9078917009490728e-5, (85, 1) = 4.2, (85, 2) = 0.87922554398473e-5, (86, 1) = 4.25, (86, 2) = -0.8499461919063325e-5, (87, 1) = 4.3, (87, 2) = 0.8202300151001906e-5, (88, 1) = 4.35, (88, 2) = -0.7902356191213331e-5, (89, 1) = 4.4, (89, 2) = 0.7601052464222056e-5, (90, 1) = 4.45, (90, 2) = -0.72996608149495766e-5, (91, 1) = 4.5, (91, 2) = 0.699931465092186e-5, (92, 1) = 4.55, (92, 2) = -0.6701020229904285e-5, (93, 1) = 4.6, (93, 2) = 0.6405667145430395e-5, (94, 1) = 4.65, (94, 2) = -0.6114038060383664e-5, (95, 1) = 4.7, (95, 2) = 0.5826817736440689e-5, (96, 1) = 4.75, (96, 2) = -0.5544601404792595e-5, (97, 1) = 4.8, (97, 2) = 0.52679025211894145e-5, (98, 1) = 4.85, (98, 2) = -0.4997159946020307e-5, (99, 1) = 4.9, (99, 2) = 0.47327445878452e-5, (100, 1) = 4.95, (100, 2) = -0.4474965546586055e-5, (101, 1) = 5.0, (101, 2) = 0.4224075790442743e-5, (102, 1) = 5.05, (102, 2) = -0.3980277398539528e-5, (103, 1) = 5.1, (103, 2) = 0.3743726399348483e-5, (104, 1) = 5.15, (104, 2) = -0.35145372330544755e-5, (105, 1) = 5.2, (105, 2) = 0.3292786864253045e-5, (106, 1) = 5.25, (106, 2) = -0.3078518569671755e-5, (107, 1) = 5.3, (107, 2) = 0.28717454240173786e-5, (108, 1) = 5.35, (108, 2) = -0.2672453505531053e-5, (109, 1) = 5.4, (109, 2) = 0.2480604841418905e-5, (110, 1) = 5.45, (110, 2) = -0.22961401119743008e-5, (111, 1) = 5.5, (111, 2) = 0.21189811309571416e-5, (112, 1) = 5.55, (112, 2) = -0.19490331186010634e-5, (113, 1) = 5.6, (113, 2) = 0.17861867825155937e-5, (114, 1) = 5.65, (114, 2) = -0.16303202207033257e-5, (115, 1) = 5.7, (115, 2) = 0.14813006599365237e-5, (116, 1) = 5.75, (116, 2) = -0.13389860418240196e-5, (117, 1) = 5.8, (117, 2) = 0.12032264680435905e-5, (118, 1) = 5.85, (118, 2) = -0.10738655154134225e-5, (119, 1) = 5.9, (119, 2) = 0.9507414307327055e-6, (120, 1) = 5.95, (120, 2) = -0.8336882146176523e-6, (121, 1) = 6.0, (121, 2) = 0.7225366029120385e-6, (122, 1) = 6.05, (122, 2) = -0.6171149536407717e-6, (123, 1) = 6.1, (123, 2) = 0.5172500469062582e-6, (124, 1) = 6.15, (124, 2) = -0.422767804599377e-6, (125, 1) = 6.2, (125, 2) = 0.3334939363034557e-6, (126, 1) = 6.25, (126, 2) = -0.24925451730719557e-6, (127, 1) = 6.3, (127, 2) = 0.1698765042164462e-6, (128, 1) = 6.35, (128, 2) = -0.9518819325289293e-7, (129, 1) = 6.4, (129, 2) = 0.25019625957658297e-7, (130, 1) = 6.45, (130, 2) = 0.4079705332935711e-7, (131, 1) = 6.5, (131, 2) = -0.10242728416703212e-6, (132, 1) = 6.55, (132, 2) = 0.16003381713738053e-6, (133, 1) = 6.6, (133, 2) = -0.21377647792892648e-6, (134, 1) = 6.65, (134, 2) = 0.2638119651684455e-6, (135, 1) = 6.7, (135, 2) = -0.31029367903289395e-6, (136, 1) = 6.75, (136, 2) = 0.3533715778983202e-6, (137, 1) = 6.8, (137, 2) = -0.3931920604894687e-6, (138, 1) = 6.85, (138, 2) = 0.4298978711906126e-6, (139, 1) = 6.9, (139, 2) = -0.4636280263535863e-6, (140, 1) = 6.95, (140, 2) = 0.494517759612214e-6, (141, 1) = 7.0, (141, 2) = -0.5226984843620009e-6, (142, 1) = 7.05, (142, 2) = 0.5482977717131691e-6, (143, 1) = 7.1, (143, 2) = -0.5714393423533197e-6, (144, 1) = 7.15, (144, 2) = 0.5922430708876365e-6, (145, 1) = 7.2, (145, 2) = -0.610825001331253e-6, (146, 1) = 7.25, (146, 2) = 0.6272973725430698e-6, (147, 1) = 7.3, (147, 2) = -0.641768652482882e-6, (148, 1) = 7.35, (148, 2) = 0.6543435802710991e-6, (149, 1) = 7.4, (149, 2) = -0.6651232151103739e-6, (150, 1) = 7.45, (150, 2) = 0.6742049912106031e-6, (151, 1) = 7.5, (151, 2) = -0.6816827779311618e-6, (152, 1) = 7.55, (152, 2) = 0.6876469444194619e-6, (153, 1) = 7.6, (153, 2) = -0.6921844280904861e-6, (154, 1) = 7.65, (154, 2) = 0.6953788063481056e-6, (155, 1) = 7.7, (155, 2) = -0.6973103710014924e-6, (156, 1) = 7.75, (156, 2) = 0.6980562048815929e-6, (157, 1) = 7.8, (157, 2) = -0.6976902602061175e-6, (158, 1) = 7.85, (158, 2) = 0.6962834382846133e-6, (159, 1) = 7.9, (159, 2) = -0.6939036701932665e-6, (160, 1) = 7.95, (160, 2) = 0.690615998086224e-6, (161, 1) = 8.0, (161, 2) = -0.6864826568410622e-6, (162, 1) = 8.05, (162, 2) = 0.6815631557688252e-6, (163, 1) = 8.1, (163, 2) = -0.6759143601450263e-6, (164, 1) = 8.15, (164, 2) = 0.669590572344911e-6, (165, 1) = 8.2, (165, 2) = -0.6626436123890619e-6, (166, 1) = 8.25, (166, 2) = 0.6551228977290213e-6, (167, 1) = 8.3, (167, 2) = -0.647075522119317e-6, (168, 1) = 8.35, (168, 2) = 0.6385463334437125e-6, (169, 1) = 8.4, (169, 2) = -0.629578010378859e-6, (170, 1) = 8.45, (170, 2) = 0.6202111377936157e-6, (171, 1) = 8.5, (171, 2) = -0.6104842807971703e-6, (172, 1) = 8.55, (172, 2) = 0.6004340573606388e-6, (173, 1) = 8.6, (173, 2) = -0.5900952094508935e-6, (174, 1) = 8.65, (174, 2) = 0.5795006726227363e-6, (175, 1) = 8.7, (175, 2) = -0.5686816440282655e-6, (176, 1) = 8.75, (176, 2) = 0.5576676488088356e-6, (177, 1) = 8.8, (177, 2) = -0.5464866048451384e-6, (178, 1) = 8.85, (178, 2) = 0.5351648858455677e-6, (179, 1) = 8.9, (179, 2) = -0.5237273827621483e-6, (180, 1) = 8.95, (180, 2) = 0.5121975635274654e-6, (181, 1) = 9.0, (181, 2) = -0.5005975311119593e-6, (182, 1) = 9.05, (182, 2) = 0.488948079906314e-6, (183, 1) = 9.1, (183, 2) = -0.4772687504359755e-6, (184, 1) = 9.15, (184, 2) = 0.46557788242095225e-6, (185, 1) = 9.2, (185, 2) = -0.45389266619653036e-6, (186, 1) = 9.25, (186, 2) = 0.4422291925122823e-6, (187, 1) = 9.3, (187, 2) = -0.43060250073186364e-6, (188, 1) = 9.35, (188, 2) = 0.4190266254556287e-6, (189, 1) = 9.4, (189, 2) = -0.4075146415927183e-6, (190, 1) = 9.45, (190, 2) = 0.39607870790862633e-6, (191, 1) = 9.5, (191, 2) = -0.38473010907775763e-6, (192, 1) = 9.55, (192, 2) = 0.37347929627010353e-6, (193, 1) = 9.6, (193, 2) = -0.362335926303425e-6, (194, 1) = 9.65, (194, 2) = 0.35130889939221703e-6, (195, 1) = 9.7, (195, 2) = -0.34040639552618525e-6, (196, 1) = 9.75, (196, 2) = 0.3296359095107469e-6, (197, 1) = 9.8, (197, 2) = -0.3190042847032402e-6, (198, 1) = 9.85, (198, 2) = 0.30851774547799635e-6, (199, 1) = 9.9, (199, 2) = -0.29818192845446557e-6, (200, 1) = 9.95, (200, 2) = 0.2880019125209349e-6, (201, 1) = 10.0, (201, 2) = -0.2779822476886622e-6}, datatype = float[8], order = C_order)
Download heat_equation_(2).mw
Hello everyone.
Please can I meet with Computational or/and Numerical anlysts that have worked or working on the algorihms particularly (Runge Kutta Nystrom, Block multistep methods including hybrid and Block Boundaru Value methods) for the solution of both IVP and BVP.
I will appreciante if I can learn from them and possibly collaborate with them. Thank you in anticipation of your positive response.
How to write a code find fundamental matrix of the following Matrix?
restart; with(LinearAlgebra): A:=Matrix([[0, 1, 0, 0], [-a, 0, b, 0], [0, 0, 0, 1], [c, 0, -d, 0]]);eigenvectors(A);
where a,b,c,d∈IR.
I want to find eigenvalues and eigenvectors and then want to calculate e^( λ i)*ri  where λi's are eigenvalues, ri's are eigenvectors of A for i=1,2,3,4  respectively.
Then, I want to calculate Wronskian of the matrix which consists of vectors e^(λi)*ri in the columns. Could you help me?
See: Fundamental Matrix
Find and classify all the critical point(s) for
f(x,y)=x3 + 3xy2 - 15x + y3 - 15y .
updated
after refer from
https://en.wikipedia.org/wiki/List_of_representations_of_e
exponential1 := sum((1/n!), n=0..infinity);
exponential1 is not a decimal number, it is exp(1)
hoyeung1:= sum((Int(exp(LambertW(1/(-1+x))*(-1+x)), x)), x=0..infinity);
hoyeung2:= sum((Int(exp(LambertW(1/(-1+x!))*(-1+x!)), x)), x=0..infinity);
how to evalute hoyeung1 or hoyeung2 as a decimal number?
how to evalute hoyeung^x as a decimal number function is func1 := proc(x) return hoyeung^x end proc:
but i do not know whether sum((Int(exp(LambertW(1/(-1+x))*(-1+x)), x))*m^x, x=0..infinity) = hoyeung^x
can limit(1+(Int(exp(LambertW(1/(-1+x))*(-1+x)), x)))^x, x=infinity) = hoyeung^1 ?
I need a help from someone who knows the GRTensor commands.
If you create a tensor of rank 2 using the grdef ("F {(a) (b)}"). Until then, okay!
However, I would like to define each of the 16 tensor components and I do not know how to do.
Could someone help me?
Thank you very much!
First 970 971 972 973 974 975 976 Last Page 972 of 2434
