If I do    odetest(...,odeA) I get correct result. But if I do    odetest(...,odeB);  odetest(...,odeA);   now it gives wrong output for the odeA one.
Same exact code. It just depends on the call done before it.
Why would issuing a command before changes the output of odetest? It seems Maple remembers something from last call. But I have no idea how to fix this.
Is there a way to tell odetest not to remember or cache any results from last calls? i.e. Can I clear its remember table before calling odetest??
This is messing all my testing now since I get different result each time depending on which call was made before. I can't do restart before testing each ode, since this is done in a loop.  I just need a way to tell Maple to clear its internal cache so that each call to odetest is not affected by last call result.
Doing forget(odetest); before the call had no effect.
Reported to Maplesoft.
Worksheet below
#EXAMPLE 1
ode:=x*diff(y(x),x)^n=0;
sol:=dsolve(ode);
odetest(sol,ode);
x*(diff(y(x), x))^n = 0
y(x) = c__1
ode:=diff(y(x),x)^n=0;
sol:=dsolve(ode);
odetest(sol,ode);
y(x) = c__1
0^n
##EXAMPLE 1 repeated. Why now different result??
sol:=dsolve(ode);
odetest(sol,ode);
y(x) = c__1
x*0^n
Download why_different_result_from_odetest_june_6_2024.mw
Update
FYI, I got email from Maplesupport that Maple R&D group will look at this issue.
So hopefully this will be fixed in a future version of Maple.
I am not able to find a workaround but doing tracing I see that odetest does rememebr something from last call but have no idea to fix this myself.
I want to display W__LJ as I typed it, without Maple running the calculations resulting in the output here below:
'W__LJ = 0.75 + 0.98*((1.18/Gamma)^1.9 - (1.15/Gamma)^0.98)';
W__LJ = .75+1.342152577*(1/Gamma)^1.9-1.123854165*(1/Gamma)^.98
Download display_formula.mw
This is important as I will place such expression in a plot like this:
textplot([2,0.9,typeset('W__LJ=0.75+0.98((1.18/Gamma)^1.9-(1.15/Gamma)^0.98)')],'font'=["helvetica","roman",35])
and I need it in the original functional form, which is easier to interpret.
I can't figure this out. Same exact patmatch works in global worksheet. But fails inside a proc.
I am using same exact code. In proc, I am doing    a::anything where `a` is now local symbol ofcourse. In worksheet, it is global ofcourse. I make sure I clear `a` in worksheet each time also.
So why it pathmatch fail in the proc? I must be doing something wrong but do not see it.,
26148
a:='a':
stat:=0^n:
if patmatch(stat,0^a::anything) then
     0;
     stat;
  fi;
foo:=proc(stat)
  local a;
     0;
     stat;
  fi;
#why this does not return zero as expected?
foo(stat)
0^n
Here is screen shot in debugger showing patmatch failed inside the proc
Very strange. What do I need to change in the proc to make it work as in worksheet?
Download patmatch_in_proc.mw
Is the following valid result from odetest? is returns 0^n when 0 was expected.
Is this a bug or valid result? Maple solution is correct, so I expected 0 only not 0^n as result.
25748
`The "Physics Updates" version in the MapleCloud is 1756 and is the same as the version installed in this computer, created 2024, June 5, 19:39 hours Pacific Time.`
ode:=diff(y(x), x)^n = 0
sol:=dsolve(ode)
y(x) = c__1
odetest(sol,ode)
0^n
odetest(sol,ode) assuming n::real
0^n
odetest(sol,ode) assuming n>0
0^n
Download strange_odetest_result_june_6_2024.mw
Update
Until this bug is fixed, I added the following to my code which checks for odetest result. it looks for 0^anything and changes it to 0.
ode:=diff(y(x), x)^n= 0;
sol:=dsolve(ode);
stat:=odetest(sol,ode);
if patmatch(stat,0^a::anything) then 0; else stat; fi
gives    0
I found this problem when using odetest to check mysolution for this ode and was not getting 0 as expected,.
These two expressions are the same
e1:=-sqrt(-(exp(-2 + 2*x) - 2)*exp(-2 + 2*x))/(exp(-2 + 2*x) - 2);
e2:=1/sqrt(2*exp(-2*x)*exp(2) - 1);
Is there an automated way to simplify e1 to e2? Below are my attempts. The closest I got is
simplify(e1) assuming real;
But that still does not give same as e2. I can do it by "hand" as shown. But I like to find automated way since this is done in code without looking at expression. So I can't use the "hand" method there.
We can assume everything in real domain.
15244
plot([e1,e2],x=-3..3)
-(-(exp(-2+2*x)-2)*exp(-2+2*x))^(1/2)/(exp(-2+2*x)-2)
1/(2*exp(-2*x)*exp(2)-1)^(1/2)
simplify(e1,size);
simplify(e1,symbolic);
simplify(e1) assuming real; #closest but still no cigar
-I*exp(-1+x)/(exp(-2+2*x)-2)^(1/2)
exp(-1+x)/(-exp(-2+2*x)+2)^(1/2)
#can do it "by hand" by dividing upstairs and downstrais by numerator
A:=exp(-1 + x);
B:=-exp(-2 + 2*x) + 2;
e3:=1/sqrt( simplify(expand(B/A^2)))
exp(-1+x)
-exp(-2+2*x)+2
1/(-1+2*exp(2-2*x))^(1/2)
#verify
plot([e3,e2],x=-3..3)
Download simplification_june_6_2024.mw
I have two surfaces crossing the z=0 plane for some ranges of x and y values.
For the first surface, x=Gamma is bounded between 0 and 10 and y=rho between -1 and +1. For the second surface, x=Gamma_1 is bounded between 0 and 10 and y=Gamma_2 between 0 and 10 as well. I want to clearly identify (parametric):
  1. For which Gamma and rho ranges of values the first surface is positive (and for which negative)
  2. For which Gamma_1 and Gamma_2 ranges of values the second surface is positive (and for which negative)
Worksheet: sign_regions.mw (highlighted in yellow my two failed attempts)
How do I get the susset that contains unknowns on the rhs of the elements?
# I need this subset {a=1/sqrt(2+A), b=6*sqrt(4+N),  d=5*H}
C:={a=1/sqrt(2+A),b=6*sqrt(4+N) ,c=sqrt(7),d=5*H,,e=-12,f=-96}
{a = 1/(2+A)^(1/2), b = 6*(4+N)^(1/2), c = 7^(1/2), d = 5*H, e = -12, f = -96}
selectremove(has,indets(rhs~(C)),C)
{}, {A, H, K, N, 1/(2+A)^(1/2), (4+N)^(1/2)}
selectremove(has,lhs~(C)=indets(rhs~(C)),C)
() = (), {a, b, c, d, e} = {H, K, N, (4+N)^(1/2)}
Download 2024-06-05_Q_Select_Remove_indet_elements.mw
Hello, in a Maple script intended for Maple Learn I need to use a slider but I don't know how to get its value.
What should I do to get it?
I have a positive surface that I plot3d for bounded x- and y- value ranges. It reaches 1000 but it's mostly flat except almost at the edges of the x- and y-axes. Therefore, I inlcude view=[default,default,0..10] among the options of plot3d so that I can focus on the features of interest.
For coloring I use 'colorscheme'=["zgradient",["LightGray", "Gray", "Green"]]. However, this applies to the whole surface (up to 1000) and NOT exclusively to the viewed part as I would like to.
Question: how to scale the zgradient so that it only applies to my "view" portion?
Note that I don't want to do this by using the 'markers' options to readjust the color splits manually, as I don't know the exact proportion and I don't want to randomly play around with different triplets until I achieve a visually satisfying result...
We see that this ode (x + y(x))*(1+diff(y(x),x)) = 0  has 2 solutions, One when (x + y(x))=0 and one when (1+diff(y(x),x))=0. Maple gives 3 solutions. They are correct but why?
Also when changing (1+diff(y(x),x)) to (a+diff(y(x),x)) now it gives only two solution.
Why does this happen? Should it not just return 2 solutions in both cases? and more strange one
(x + y(x))^2 *(1+diff(y(x), x))=0; now it gives 4 solutions. But this is no different. We also have 2 solutions. One when (x + y(x))=0 and one when (1+diff(y(x), x))=0. This time the extra two solutions are complex.
17168
`The "Physics Updates" version in the MapleCloud is 1754 and is the same as the version installed in this computer, created 2024, June 3, 20:39 hours Pacific Time.`
ode:=(x + y(x))*(a+diff(y(x),x)) = 0;
dsolve(ode);
map(X->odetest(X,ode),[%])
(x+y(x))*(a+diff(y(x), x)) = 0
y(x) = -x, y(x) = -a*x+c__1
[0, 0]
ode:=(x + y(x))*(1+diff(y(x),x)) = 0;
dsolve(ode);
(x+y(x))*(1+diff(y(x), x)) = 0
y(x) = -x, y(x) = -x-c__1, y(x) = -x+c__1
[0, 0, 0]
ode:= (x + y(x))^2 *(1+diff(y(x), x))=0;
dsolve(ode);
(x+y(x))^2*(1+diff(y(x), x)) = 0
y(x) = -x, y(x) = -x+c__1, y(x) = -(1/2)*c__1-((1/2)*I)*3^(1/2)*c__1-x, y(x) = -(1/2)*c__1+((1/2)*I)*3^(1/2)*c__1-x
[0, 0, 0, 0]
Download why_extra_solution_from_dsolve_june_5_2024.mw
Any idea why this sometimes happens? odeadvisor says ode is quadrature but when asking it to solve it using quadrature sometimes it works and sometimes not.
Am I doing something wrong?
22020
Example 1 that does not work
ode:=diff(y(x),x)=-1;
DEtools:-odeadvisor(ode);
diff(y(x), x) = -1
[_quadrature]
sol:=dsolve(ode,y(x),['quadrature']);
"sol := "
Example 2 that works
ode:=diff(y(x),x)=x;
diff(y(x), x) = x
[_quadrature]
y(x) = (1/2)*x^2+c__1
Download sometimes_dsolve_works_on_quadrature_june_5_2024.mw
I have a data, how can I study this data using N-soft set : Normalized the data, membership function, analyse the risk, ..... compute the risk, interpret the results
Cancer_patient.xlsx
N_soft_set.mw
Thank you for your help
Maybe someone get the code working ?
with(VectorCalculus):
# Example 1: Vector Field and Visualization
V := [x, y, z]:
print("Vector Field V:", V):
fieldplot3d([V[1], V[2], V[3]], x = -2..2, y = -2..2, z = -2..2, arrows = slim, title = "Vector Field in 3D"):
# Example 2: Tangent Vector to a Curve
curve := [cos(t), sin(t), t]:
print("Curve:", curve):
tangent := diff(curve, t):
print("Tangent Vector:", tangent):
plot3d([cos(t), sin(t), t], t = 0..2*Pi, labels = [x, y, z], title = "Curve in 3D"):
# Example 3: Curvature of a Surface
u := 'u': v := 'v':
surface := [u, v, u^2 - v^2]:
print("Surface:", surface):
# Compute the first fundamental form
ru := [diff(surface[1], u), diff(surface[2], u), diff(surface[3], u)]:
rv := [diff(surface[1], v), diff(surface[2], v), diff(surface[3], v)]:
E := ru[1]^2 + ru[2]^2 + ru[3]^2:
F := ru[1]*rv[1] + ru[2]*rv[2] + ru[3]*rv[3]:
G := rv[1]^2 + rv[2]^2 + rv[3]^2:
firstFundamentalForm := Matrix([[E, F], [F, G]]):
print("First Fundamental Form:", firstFundamentalForm):
# Compute the second fundamental form
ruu := [diff(surface[1], u, u), diff(surface[2], u, u), diff(surface[3], u, u)]:
ruv := [diff(surface[1], u, v), diff(surface[2], u, v), diff(surface[3], u, v)]:
rvv := [diff(surface[1], v, v), diff(surface[2], v, v), diff(surface[3], v, v)]:
normal := CrossProduct(ru, rv):
normal := eval(normal / sqrt(normal[1]^2 + normal[2]^2 + normal[3]^2)):
L := ruu[1]*normal[1] + ruu[2]*normal[2] + ruu[3]*normal[3]:
M := ruv[1]*normal[1] + ruv[2]*normal[2] + ruv[3]*normal[3]:
N := rvv[1]*normal[1] + rvv[2]*normal[2] + rvv[3]*normal[3]:
secondFundamentalForm := Matrix([[L, M], [M, N]]):
print("Second Fundamental Form:", secondFundamentalForm):
# Compute the Christoffel symbols
# Ensure DifferentialGeometry package is loaded
with(DifferentialGeometry):
DGsetup([u, v], N):
Gamma := Christoffel(firstFundamentalForm):
print("Christoffel Symbols:", Gamma):
# Visualize the surface
plot3d([u, v, u^2 - v^2], u = -2..2, v = -2..2, labels = [u, v, z], title = "Saddle Surface in 3D"):
I was about to convert -1 to exp(I*Pi).
First try by intuition
convert(-1, exp);
                               -1
False intuition. Next try by right click on -1 and consulting the context pannel: -> nothing that rings a bell
Entering a complex number 0.5000000001 + 0.8660254037*I to see if that changes something
-> something but no exponential form
Next: AI assitant
->   OK, I know this. -> refine query
Polar, of course!
convert(-1, polar);
                          polar(1, Pi)
Not what I want. Maybe
convert(convert(-1, polar), exp);
                               -1
Next -> Ask for help in MaplePrimes whether there is a command
In relation to my comment below:
https://www.mapleprimes.com/questions/238277-Robustness-Of-Plotevalsomething#comment301920 (whose my worksheet rho-analysis_mmcdara_Gammapositive_MaPal.mw builds on the Sturm's analysis of @mmcdara)
I would like to better understand how to isolate/pin down the 4 real roots whose existence was confirmed by Sturm's analysis. To do so, @acer suggested to look into RootFinding:-Parametric: rho-analysis_acc(1).mw
Questions:
  1. Why the plot doesn't change if I also include -1<rho and rho<1 among the equations to solve? I understood that regions 1, 4 and 5 have 0 solutions anyway but if I add the constraints on rho I should expect 2 regions instead of 5, right?
  2. I don't understand SampleSolutions(m,2)=0.56 and SampleSolutions(m,3)=0.51 (even after reading help page). How are these numeric values found?
  3. Looking at the big picture, how to reconcile this CellPlot with A) my plot3d of Eq in https://www.mapleprimes.com/questions/238277-Robustness-Of-Plotevalsomething#comment301920 and B) @mmcdara Sturm's analysis. I am having a hard time putting all together.
    EDIT: I formulated this question by branching out from my comment
    https://www.mapleprimes.com/questions/238277-Robustness-Of-Plotevalsomething#comment301920 in the corresponding thread. If inappropriate, please help me migrate this question as appropriate.
First 100 101 102 103 104 105 106 Last Page 102 of 2427
