I tried to solve a hogher order ODE system to reduce first order ODE sytem. In this case I have assume a initial conditions as a variable. (sse the attachment, Conver_to_first_order.mw).
I got an error in specification of initial value...
How can I solve this problem in RKF45 method with shooting technique.
Here, I have assume f=x[1], f'=x[2]. f''=x[3], f'''=x[3]' and theta=x[4], theta'=x[5], theta''=x[5]'
I try to dot product 2 vector that contain time derivative
the answer should be v . u_rho = rhodot
but Maple doesn't give me a proper answer. What should i do?
kind regard
with(LinearAlgebra);
with(Typesetting);
Settings(typesetprime = true);
Settings(typesetdot = true);
v := <diff(rho(t), t)*cos(theta(t)) - rho(t)*diff(theta(t), t)*sin(theta(t)), diff(rho(t), t)*sin(theta(t)) + rho(t)*diff(theta(t), t)*cos(theta(t)), diff(z(t), t)>
u_rho := <cos(theta(t)), sin(theta(t)), 0>
v . u_rho
Any one could find why Maple 2024 gives Error, (in evalf/int) invalid arguments on this ode? Why is it even calling evalf in first place as this is all symbolic.
Also reported to Maplesof just in case.
25504
`The "Physics Updates" version in the MapleCloud is 1752 and is the same as the version installed in this computer, created 2024, May 31, 18:17 hours Pacific Time.`
ode:=diff(y(x), x)^3 = (x - 2)^2;
ic:=y(2)=1;
Student:-ODEs:-ODESteps([ode,ic]);
(diff(y(x), x))^3 = (x-2)^2
y(2) = 1
dsolve([ode,ic])
y(x) = 1+(1/5)*(3*x-6)*RootOf(_Z^3-x^2+4*x-4)
DEtools:-odeadvisor(ode)
[_quadrature]
Download odetest_internal_error_evalf_int_june_3_2024.mw
Probably I am missing the obvious. In the attached worksheet the for statement gives me all results as desired but if I try to put this in a procedure I only get the last value. Could someone help me out. Thank you  ProcQuestion.mw
I wanted to do
map(X->odetest(X,ode) assuming x>0,[sol])
where sol are the solutions I wanted to test. The above does not work as is. After some trial and errors, I found this works
map(X->[odetest(X,ode) assuming x>0],[sol])
I am not sure why. But it works. Is this the above the correct way to add assuming to a command inside Map? Or is there a different way or better way to do this?
I want to stick to the map command as above and nothing else such as ~ or some other ones. I find map more clear to use for me.
Here is worksheet.
9592
ode:=x = diff(y(x), x)*sqrt(1 + diff(y(x), x)^2);
x = (diff(y(x), x))*(1+(diff(y(x), x))^2)^(1/2)
sol:=dsolve(ode);
y(x) = ((1/32)*I)*2^(1/2)*(-(256/3)*Pi^(1/2)*2^(1/2)*x^3*cosh((3/2)*arcsinh(2*x))-8*Pi^(1/2)*2^(1/2)*(-(64/3)*x^4-(8/3)*x^2+2/3)*sinh((3/2)*arcsinh(2*x))/(4*x^2+1)^(1/2))/Pi^(1/2)+c__1, y(x) = -((1/32)*I)*2^(1/2)*(-(256/3)*Pi^(1/2)*2^(1/2)*x^3*cosh((3/2)*arcsinh(2*x))-8*Pi^(1/2)*2^(1/2)*(-(64/3)*x^4-(8/3)*x^2+2/3)*sinh((3/2)*arcsinh(2*x))/(4*x^2+1)^(1/2))/Pi^(1/2)+c__1, y(x) = Int(-(1/2)*(-2+2*(4*x^2+1)^(1/2))^(1/2), x)+c__1, y(x) = Int((1/2)*(-2+2*(4*x^2+1)^(1/2))^(1/2), x)+c__1
[[(1/2)*(2*x*(4*x^2+1)^(1/2)+(-8*x^2*cosh((3/2)*arcsinh(2*x))*(4*x^2+1)^(1/2)+16*x^3*sinh((3/2)*arcsinh(2*x))-cosh((3/2)*arcsinh(2*x))*(4*x^2+1)^(1/2)+4*sinh((3/2)*arcsinh(2*x))*x)*(-2+2*(4*x^2+1)^(1/2))^(1/2))/(4*x^2+1)^(1/2)], [-(1/2)*(-2*x*(4*x^2+1)^(1/2)+(-8*x^2*cosh((3/2)*arcsinh(2*x))*(4*x^2+1)^(1/2)+16*x^3*sinh((3/2)*arcsinh(2*x))-cosh((3/2)*arcsinh(2*x))*(4*x^2+1)^(1/2)+4*sinh((3/2)*arcsinh(2*x))*x)*(-2+2*(4*x^2+1)^(1/2))^(1/2))/(4*x^2+1)^(1/2)], [2*x], [0]]
for item in [sol] do
    odetest(item,ode) assuming x>0;
od;
2*x
Download how_to_use_map_with_assuming.mw
These  are good example(s)  why I think Maple's simplify needs to be improved.
Example 1
Given an expression which is zero for nonnegative x, one would expect simplify to simplify it to zero when told that x is positive.
But nothing I tried with simplify worked. combine  figured it out.
But why? Is this not the job of simplify?
The expression is
e:=x-1/4*(-2+2*(4*x^2+1)^(1/2))^(1/2)*(2+2*(4*x^2+1)^(1/2))^(1/2);
Here is worksheet
x-(1/4)*(-2+2*(4*x^2+1)^(1/2))^(1/2)*(2+2*(4*x^2+1)^(1/2))^(1/2)
coulditbe(e=0);
#we see it is zero for x>=0
plot(e,x=-3..3)
simplify(e) assuming x>=0;
simplify(e,size) assuming x>=0;
expand(e) assuming x>=0;
simplify(e,sqrt) assuming x>=0;
simplify(e,symbolic) assuming x>=0;
combine(e) assuming x>=0;
Compare some other software on this same problem
It should be as simple as the above in Maple.
A user should not have to try 100 different commands in Maple to find which works.
simplify should have done it in first place. What Am I overlooking here?
Maple 2024
Download why_simplify_do_not_work_example.mw
EXAMPLE 2
In this example the expression is zero for x<0. Here nothing worked for me. This is challenge for Maple experts here to find the command to simplify this to zero.
I know it is zero for x<0.
e := -1/2*(-2*x*sqrt(4*x^2 + 1) + (16*x^3*sinh(3/2*arcsinh(2*x)) - 8*x^2*cosh(3/2*arcsinh(2*x))*sqrt(4*x^2 + 1) + 4*sinh(3/2*arcsinh(2*x))*x - cosh(3/2*arcsinh(2*x))*sqrt(4*x^2 + 1))*sqrt(-2 + 2*sqrt(4*x^2 + 1)))/sqrt(4*x^2 + 1)
24064
e:=-1/2*(-2*x*sqrt(4*x^2 + 1) + (16*x^3*sinh(3/2*arcsinh(2*x)) - 8*x^2*cosh(3/2*arcsinh(2*x))*sqrt(4*x^2 + 1) + 4*sinh(3/2*arcsinh(2*x))*x - cosh(3/2*arcsinh(2*x))*sqrt(4*x^2 + 1))*sqrt(-2 + 2*sqrt(4*x^2 + 1)))/sqrt(4*x^2 + 1);
-(1/2)*(-2*x*(4*x^2+1)^(1/2)+(16*x^3*sinh((3/2)*arcsinh(2*x))-8*x^2*cosh((3/2)*arcsinh(2*x))*(4*x^2+1)^(1/2)+4*sinh((3/2)*arcsinh(2*x))*x-cosh((3/2)*arcsinh(2*x))*(4*x^2+1)^(1/2))*(-2+2*(4*x^2+1)^(1/2))^(1/2))/(4*x^2+1)^(1/2)
plot(e,x=-10..3);
coulditbe(e=0)
simplify(e) assuming x<0;
-8*((cosh((3/2)*arcsinh(2*x))*(-(1/2)*x^2-1/16)*(4*x^2+1)^(1/2)+sinh((3/2)*arcsinh(2*x))*x*(x^2+1/4))*(-2+2*(4*x^2+1)^(1/2))^(1/2)-(1/8)*x*(4*x^2+1)^(1/2))/(4*x^2+1)^(1/2)
simplify(e,symbolic) assuming x<0;
combine(e) assuming x<0;
simplify(e,arctrig) assuming x<0;
simplify(e,sqrt) assuming x<0;
simplify(normal(e),sqrt) assuming x<0;
simplify(normal(e, expanded)) assuming x<0;
simplify(radnormal(e)) assuming x<0;
(1/8)*((4*x^2+(4*x^2+1)^(1/2)+1)*(-2+2*(4*x^2+1)^(1/2))-64*x*((1/2)*cosh((3/2)*arcsinh(2*x))*(-1/8-x^2)*(4*x^2+1)^(1/2)+sinh((3/2)*arcsinh(2*x))*x*(x^2+1/4))*(-2+2*(4*x^2+1)^(1/2))^(1/2))/((4*x^2+1)^(1/2)*x)
simplify(evala(e)) assuming x<0;
Using some other software gives
I'd like to find command to do the same in Maple. i.e. simplify it to zero. What else to try?
Download why_simplify_do_not_work_example_2.mw
I think I found another problem with odetest.  When solution is implicit, it fails to verify the solution against the ode when adding the IC. (not everytime, but in some cases).
But it does verify the solution against the ode when IC is not given. I give 3 examples.  Also at bottom is worksheet of all of this.
Example 1
ode:=diff(y(x), x) = sin(y(x));
ic:=y(0)=Pi/2;
mysol:=ln(tan(y(x)/2))=x;
It says solution satisfies the ode itself OK
odetest(mysol,ode);
gives 0
But adding IC now gives
odetest(mysol,[ode,ic]);
Which I am having hard time reading. Is it now saying the solution does not satisfy the ode or the IC? Both are supposed to be zero.
Are these not supposed to be in same order given? so it looks like if we go left to right, it is saying the solution do not satisfy the ode now but it does satisfy the IC. Right?
But before it said the solution satisfies the ode.
Also, we can see the IC is satisfied. Let do it by hand
eval(mysol,[y(x)=Pi/2,x=0])
              0 = 0
So why does it say solution satisfies the ode first, then when adding the IC, now it changed its mind?
Also, solving for y(x) from the implicit solution, now it verifies it OK  with the IC also:
ic:=y(0)=Pi/2;
mysol_explicit:=solve(mysol,y(x));
odetest(y(x)=mysol_explicit,[ode,ic])
          [0, 0]
You see. Same solution. But different result from odetest depending if it is implicit or explicit.
Is this supposed to happen or is this a bug in odetest I should report? odetest is supposed to handle both explicit and implicit solutions. I know my solutions are correct. I just use odetest for verification. I also plotted my solution against maple's solutions and they are exact match.
Example 2
ode:=diff(y(x),x)=1+y(x)^2;
mysol:=arctan(y(x))=x;
ic:=y(0)=0;
odetest(mysol,ode);
Gives 0 for the first call to odetest but gives [diff(y(x), x) - 1 - y(x)^2, 0] for the second call.
Changing the solution to explicit. now it verifies it
odetest(y(x)=mysol_explicit,[ode,ic]);
Now it gives [0,0]
Example 3
ode:=diff(y(x), x) - 2*y(x) = 2*sqrt(y(x));
ic:=y(0)=1;
mysol:=ln(sqrt(y(x))+1)=x+ln(2);
odetest(mysol,ode);
odetest(mysol,[ode,ic]) assuming positive;
Gives for the first call but  [diff(y(x), x) - 2*y(x) - 2*sqrt(y(x)), 0] but when using explicit it now verifies OK
odetest(y(x)=mysol_explicit,[ode,ic]) assuming positive;
           [0, 0]
Maple 2024 on windows 10
23112
`The "Physics Updates" version in the MapleCloud is 1751 and is the same as the version installed in this computer, created 2024, May 31, 18:17 hours Pacific Time.`
Example 1
ic:=y(0)=Pi/2;
odetest(mysol,ode);
y(0) = (1/2)*Pi
ln(tan((1/2)*y(x))) = x
[diff(y(x), x)-sin(y(x)), 0]
2*arctan(exp(x))
[0, 0]
Example 2
ic:=y(0)=0;
odetest(mysol,ode);
diff(y(x), x) = 1+y(x)^2
arctan(y(x)) = x
y(0) = 0
[diff(y(x), x)-1-y(x)^2, 0]
tan(x)
[0, 0]
Example 3
ic:=y(0)=1;
odetest(mysol,ode);
diff(y(x), x)-2*y(x) = 2*y(x)^(1/2)
y(0) = 1
ln(y(x)^(1/2)+1) = x+ln(2)
[diff(y(x), x)-2*y(x)-2*y(x)^(1/2), 0]
(2*exp(x)-1)^2
[0, 0]
Download odetest_implicit_problem_june_2_2024.mw
Simple question. I hope it has simple answer. I have always thought that what int() returns should match exactly what "default" result shows when using int() with the option _RETURNVERBOSE
I mean exact match. But this below shows that int() result underwent some simplification as it is not the same as default.
integrand:=sin(x)/(sin(x) + 1);
maple_result_1 :=int(integrand,x);
maple_result_2 := int(integrand,x,'method'=':-_RETURNVERBOSE')[1]
Ofcourse maple_result_2 can be made the same as maple_result_1
simplify(rhs(maple_result_2)) assuming 0<x and x<Pi;
But this is beside the point. Why is "default" is not excatly the same as int() result?  It seems that int() does something more after obtaining the :"default" result as shown.
Should default not match exactly result from int() ?
Maple 2024.
Determine the solution or integral curve given by the differential equation x+yy'=0 by the method of isodine. hence display its 2Dplot
Maple int gives one result, called the "default" result unless one uses method=_RETURNVERBOSE to look for other results.
First, how does Maple decide what is "default" i.e. given all the methods listed, what method then used for "default".
Here is an example where default result makes it hard to solve for a differential equation. The integrand is
1/(y+sqrt(y))
Maple int default gives anti as ln(y - 1) + 2*arctanh(sqrt(y))  which is complex valued for all y. The arctanh is only defined for argument between -1 and 1 also. Having sqrt there makes it now valid for 0 to 1. But ln(y-1) is negative in this region also. Hence complex.
Using method=_RETURNVERBOSE we see much better anti derivatives hidding there and given by "derivativedivides" and "meijerg" as 2*ln(1 + sqrt(y)) which is complex valued only for negative y and real for all positive y. Same for "trager"  ln(2*sqrt(y) + 1 + y)
So it would have been much better if Maple picks the best anti-derivative automatically and use that for default instead and give this to the user.
Why is this important? Try to solve   the ode y'/(y+sqrt(y))=2 with IC y(0)=1 and you see we can't solve for the constant of integration using  ln(y - 1) + 2*arctanh(sqrt(y))=2x+c since at y=1 we get division by zero. If Maple had returned 2*ln(1 + sqrt(y)) instead then solving for constant of integration is trivial now since anti is real and defined at y=1
This is just one example of many.
My question is, How does Maple integrate decide what is "default" and why it does not try harder to pick better one (using number of known metrices for this sort of thing) from the other solvers it already has access to?
What is the point of having all these other nice integrate methods, if the default used is not the "best" one?
Should user then always use method=_RETURNVERBOSE and then try to pick the "best" one themselves? This will be too much work for user to do.
I think Maple should do this automatically. Btw, I tried few other CAS integrators and the all give the better result given above by "meijerg" automatically.
Maple 2024
Update
Here is a quick function, called it smart_int() which returns the anti-derivative with the smallest leaf size from Maple.
Ofcourse smallest leaf size does not mean the anti-derivative is necessarily the "best" using other measures. But this function already allowed me to solve some ode's I could not solve before using Maple's defaullt int result because it made solving for constant of integration easier now.
Feel free to improve and change. If you find any bugs please let me know
The test here shows the result of smart_int compared to int on few integrals. You see on many of them smart_int gives smaller result. Additional criteria for selection can ofcourse be added and I will probably do that.
For example, do not pick ones with complex numbers if there is one without even though leaf size is smaller. This check has been added also.
Check the last integral in this test. The difference is so large.
#smart_int picks the anti-derivative with smallest leaf count
#version June 1, 2024. Maple 2024
#change: added check not to pick one with complex even is smaller
#change: added percentage reduction
smart_int:=proc(integrand,x::symbol)
local anti,result_of_int,a,b;
    local F:=proc(a,b)::truefalse;
       if (has(a,I) and has(b,I)) or ( not has(a,I)  and not has(b,I)) then
           evalb(MmaTranslator:-Mma:-LeafCount(a)<MmaTranslator:-Mma:-LeafCount(b));
       elif has(a,I) then
           false;
           true;
       fi;
    try
        anti := timelimit(60,int(integrand,x,'method'=':-_RETURNVERBOSE'));
        if evalb(op(0,anti)='int') then
           RETURN(anti);
        fi;
    catch:
        RETURN(Int(integrand,x));
    end try;
    result_of_int := select(type,anti,string=algebraic);
    if nops(result_of_int)=0 then
    fi;
    result_of_int := map(X->rhs(X),result_of_int);
    result_of_int := sort(result_of_int,(a,b)->F(a,b));
    #return the one with smallest leaf size
    RETURN(result_of_int[1]);
#TESTS
tests:=[1/(x+sqrt(x)),1/(sin(x)),1/(cos(x)),sin(x)/(sin(x)+1),1/((1+x)^(2/3)-(1+x)^(1/2)),1/x^3/(1+x)^(3/2),1/(1-x)^(7/2)/x^5,x*((-a+x)/(b-x))^(1/2),x/(-x^2+5)/(-x^2+3)^(1/2),exp(arcsin(x))*x^3/(-x^2+1)^(1/2),x*arctan(x)^2*ln(x^2+1),(x^2+1)/(-x^2+1)/(x^4+1)^(1/2),(a+b*f*x+b*sin(f*x+e))/(a+a*cos(f*x+e)),x*ln(1/x+1),1/x/(x^5+1)];
result:=map(X->[Int(X,x),int(X,x),smart_int(X,x)],tests):
for item in result do
    print("###################################\nintegral",item[1]);
    print("maple default result ",item[2]);
    print("smart int result ",item[3]);
    PERCENTAGE:=MmaTranslator:-Mma:-LeafCount(item[3])*100/MmaTranslator:-Mma:-LeafCount(item[2]):
    print("smart int percentage size relative to default ",sprintf("%.2f",PERCENTAGE));
[1/(x+x^(1/2)), 1/sin(x), 1/cos(x), sin(x)/(sin(x)+1), 1/((1+x)^(2/3)-(1+x)^(1/2)), 1/(x^3*(1+x)^(3/2)), 1/((1-x)^(7/2)*x^5), x*((-a+x)/(b-x))^(1/2), x/((-x^2+5)*(-x^2+3)^(1/2)), exp(arcsin(x))*x^3/(-x^2+1)^(1/2), x*arctan(x)^2*ln(x^2+1), (x^2+1)/((-x^2+1)*(x^4+1)^(1/2)), (a+b*f*x+b*sin(f*x+e))/(a+a*cos(f*x+e)), x*ln(1/x+1), 1/(x*(x^5+1))]
integral", Int(1/(x+x^(1/2)), x)
"maple default result ", ln(x-1)+2*arctanh(x^(1/2))
"smart int result ", 2*ln(x^(1/2)+1)
"smart int percentage size relative to default ", "72.73"
integral", Int(1/sin(x), x)
"maple default result ", ln(csc(x)-cot(x))
"smart int result ", ln(tan((1/2)*x))
"smart int percentage size relative to default ", "62.50"
integral", Int(1/cos(x), x)
"maple default result ", ln(sec(x)+tan(x))
"smart int result ", ln(sec(x)+tan(x))
"smart int percentage size relative to default ", "100.00"
integral", Int(sin(x)/(sin(x)+1), x)
"maple default result ", 2/(tan((1/2)*x)+1)+x
"smart int result ", (x*tan((1/2)*x)+2+x)/(tan((1/2)*x)+1)
"smart int percentage size relative to default ", "150.00"
integral", Int(1/((1+x)^(2/3)-(1+x)^(1/2)), x)
"maple default result ", 6*(1+x)^(1/6)+3*(1+x)^(1/3)+ln(x)+2*ln((1+x)^(1/6)-1)-ln((1+x)^(1/3)+(1+x)^(1/6)+1)-2*ln((1+x)^(1/6)+1)+ln((1+x)^(1/3)-(1+x)^(1/6)+1)-ln((1+x)^(1/2)+1)+ln((1+x)^(1/2)-1)+2*ln((1+x)^(1/3)-1)-ln((1+x)^(2/3)+(1+x)^(1/3)+1)
"smart int result ", 3*(1+x)^(1/3)+6*(1+x)^(1/6)+6*ln((1+x)^(1/6)-1)
"smart int percentage size relative to default ", "22.73"
integral", Int(1/(x^3*(1+x)^(3/2)), x)
"maple default result ", (1/8)/((1+x)^(1/2)+1)^2+(7/8)/((1+x)^(1/2)+1)-(15/8)*ln((1+x)^(1/2)+1)-(1/8)/((1+x)^(1/2)-1)^2+(7/8)/((1+x)^(1/2)-1)+(15/8)*ln((1+x)^(1/2)-1)+2/(1+x)^(1/2)
"smart int result ", (1/4)*(15*x^2+5*x-2)/((1+x)^(1/2)*x^2)-(15/4)*arctanh((1+x)^(1/2))
"smart int percentage size relative to default ", "40.28"
integral", Int(1/((1-x)^(7/2)*x^5), x)
"maple default result ", (1/64)/((1-x)^(1/2)+1)^4+(17/96)/((1-x)^(1/2)+1)^3+(159/128)/((1-x)^(1/2)+1)^2+(1083/128)/((1-x)^(1/2)+1)-(3003/128)*ln((1-x)^(1/2)+1)-(1/64)/((1-x)^(1/2)-1)^4+(17/96)/((1-x)^(1/2)-1)^3-(159/128)/((1-x)^(1/2)-1)^2+(1083/128)/((1-x)^(1/2)-1)+(3003/128)*ln((1-x)^(1/2)-1)+(2/5)/(1-x)^(5/2)+(10/3)/(1-x)^(3/2)+30/(1-x)^(1/2)
"smart int result ", (1/960)*(45045*x^6-105105*x^5+69069*x^4-6435*x^3-1430*x^2-520*x-240)/((x-1)^2*(1-x)^(1/2)*x^4)-(3003/64)*arctanh((1-x)^(1/2))
"smart int percentage size relative to default ", "37.18"
integral", Int(x*((-a+x)/(b-x))^(1/2), x)
"maple default result ", (1/8)*(arctan((1/2)*(-b+2*x-a)/(-a*b+a*x+b*x-x^2)^(1/2))*a^2+2*b*arctan((1/2)*(-b+2*x-a)/(-a*b+a*x+b*x-x^2)^(1/2))*a-3*arctan((1/2)*(-b+2*x-a)/(-a*b+a*x+b*x-x^2)^(1/2))*b^2+4*(-a*b+a*x+b*x-x^2)^(1/2)*x-2*(-a*b+a*x+b*x-x^2)^(1/2)*a+6*(-a*b+a*x+b*x-x^2)^(1/2)*b)*(-(-a+x)/(-b+x))^(1/2)*(-b+x)/(-(-a+x)*(-b+x))^(1/2)
"smart int result ", (1/4)*(a-3*b-2*x)*(b-x)*(-(a-x)/(b-x))^(1/2)*(-(a-x)*(b-x))^(1/2)/(-(-a+x)*(-b+x))^(1/2)+((1/4)*b*a+(1/8)*a^2-(3/8)*b^2)*arctan((x-(1/2)*a-(1/2)*b)/(-x^2+(a+b)*x-b*a)^(1/2))*(-(a-x)/(b-x))^(1/2)*(-(a-x)*(b-x))^(1/2)/(a-x)
"smart int percentage size relative to default ", "67.63"
integral", Int(x/((-x^2+5)*(-x^2+3)^(1/2)), x)
"maple default result ", -(1/4)*2^(1/2)*arctan((1/4)*(-4-2*5^(1/2)*(x-5^(1/2)))*2^(1/2)/(-(x-5^(1/2))^2-2*5^(1/2)*(x-5^(1/2))-2)^(1/2))-(1/4)*2^(1/2)*arctan((1/4)*(-4+2*5^(1/2)*(x+5^(1/2)))*2^(1/2)/(-(x+5^(1/2))^2+2*5^(1/2)*(x+5^(1/2))-2)^(1/2))
"smart int result ", -(1/2)*2^(1/2)*arctan((1/2)*(-x^2+3)^(1/2)*2^(1/2))
"smart int percentage size relative to default ", "20.20"
integral", Int(exp(arcsin(x))*x^3/(-x^2+1)^(1/2), x)
"maple default result ", int(exp(arcsin(x))*x^3/(-x^2+1)^(1/2), x)
"smart int result ", Int(exp(arcsin(x))*x^3/(-x^2+1)^(1/2), x)
integral", Int(x*arctan(x)^2*ln(x^2+1), x)
"maple default result ", (2*I)*ln(2)*arctan(x)-ln((1+I*x)^2/(x^2+1)+1)*arctan(x)^2*x^2+(1/2)*csgn(I*(1+I*x)^2/(x^2+1))^3*Pi*arctan(x)+(1/2)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^3*Pi*arctan(x)-I*csgn(I*(1+I*x)/(x^2+1)^(1/2))*csgn(I*(1+I*x)^2/(x^2+1))^2*Pi*arctan(x)*x-((1/2)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1))^2*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)*Pi*arctan(x)*x-((1/4)*I)*csgn(I*(1+I*x)/(x^2+1)^(1/2))^2*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)^2*x^2-((1/4)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)^2+((1/4)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*Pi*arctan(x)^2*x^2+((1/4)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)^2*x^2+((1/4)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1))^2*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)*Pi*arctan(x)^2*x^2-((1/2)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1))*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^2*Pi*arctan(x)^2*x^2-((1/2)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*Pi*arctan(x)*x+((1/2)*I)*csgn(I*(1+I*x)/(x^2+1)^(1/2))*csgn(I*(1+I*x)^2/(x^2+1))^2*Pi*arctan(x)^2*x^2+((1/2)*I)*csgn(I*(1+I*x)/(x^2+1)^(1/2))^2*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)*x+((1/2)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))*csgn(I*(1+I*x)^2/(x^2+1))*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*Pi*ln((1+I*x)^2/(x^2+1)+1)+I*csgn(I*((1+I*x)^2/(x^2+1)+1))*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^2*Pi*arctan(x)*x-((1/2)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)*x-2*ln(2)*arctan(x)*x+ln(2)*arctan(x)^2*x^2-(1/2)*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^3*Pi*arctan(x)+2*ln((1+I*x)^2/(x^2+1)+1)*arctan(x)*x+((1/2)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)*x-((1/4)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)^2*x^2+ln((1+I*x)^2/(x^2+1)+1)^2+3*ln((1+I*x)^2/(x^2+1)+1)+3*arctan(x)*x-(1/2)*arctan(x)^2*x^2-(-(2*I)*arctan(x)-arctan(x)^2+2*arctan(x)*x-arctan(x)^2*x^2+2*ln((1+I*x)^2/(x^2+1)+1))*ln((1+I*x)/(x^2+1)^(1/2))-2*ln((1+I*x)^2/(x^2+1)+1)*ln(2)+ln(2)*arctan(x)^2-(3*I)*arctan(x)-arctan(x)^2*ln((1+I*x)^2/(x^2+1)+1)+((1/2)*I)*csgn(I*(1+I*x)^2/(x^2+1))^3*Pi*ln((1+I*x)^2/(x^2+1)+1)-((1/2)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^3*Pi*ln((1+I*x)^2/(x^2+1)+1)+((1/4)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^3*Pi*arctan(x)^2-((1/4)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^3*Pi*arctan(x)^2-((1/4)*I)*csgn(I*(1+I*x)^2/(x^2+1))^3*Pi*arctan(x)^2+((1/2)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^3*Pi*ln((1+I*x)^2/(x^2+1)+1)-(1/2)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*Pi*arctan(x)-(1/2)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)+(1/2)*csgn(I*(1+I*x)/(x^2+1)^(1/2))^2*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)-csgn(I*(1+I*x)/(x^2+1)^(1/2))*csgn(I*(1+I*x)^2/(x^2+1))^2*Pi*arctan(x)-(1/2)*csgn(I*((1+I*x)^2/(x^2+1)+1))^2*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)*Pi*arctan(x)+csgn(I*((1+I*x)^2/(x^2+1)+1))*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^2*Pi*arctan(x)-((1/2)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1))*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^2*Pi*arctan(x)^2+((1/2)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^3*Pi*arctan(x)*x+((1/2)*I)*csgn(I*(1+I*x)^2/(x^2+1))^3*Pi*arctan(x)*x-((1/4)*I)*csgn(I*(1+I*x)/(x^2+1)^(1/2))^2*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)^2+((1/4)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^3*Pi*arctan(x)^2*x^2+((1/4)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1))^2*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)*Pi*arctan(x)^2-((1/4)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^3*Pi*arctan(x)^2*x^2-((1/4)*I)*csgn(I*(1+I*x)^2/(x^2+1))^3*Pi*arctan(x)^2*x^2-((1/2)*I)*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^3*Pi*arctan(x)*x+((1/4)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*Pi*arctan(x)^2+((1/4)*I)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)^2+((1/2)*I)*csgn(I*(1+I*x)/(x^2+1)^(1/2))*csgn(I*(1+I*x)^2/(x^2+1))^2*Pi*arctan(x)^2+((1/2)*I)*ln((1+I*x)^2/(x^2+1)+1)*Pi*csgn(I*(1+I*x)/(x^2+1)^(1/2))^2*csgn(I*(1+I*x)^2/(x^2+1))-((1/2)*I)*ln((1+I*x)^2/(x^2+1)+1)*Pi*csgn(I*((1+I*x)^2/(x^2+1)+1))^2*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)-((1/2)*I)*ln((1+I*x)^2/(x^2+1)+1)*Pi*csgn(I*(1+I*x)^2/(x^2+1))*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2-((1/2)*I)*ln((1+I*x)^2/(x^2+1)+1)*Pi*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))^2-I*csgn(I*(1+I*x)/(x^2+1)^(1/2))*csgn(I*(1+I*x)^2/(x^2+1))^2*ln((1+I*x)^2/(x^2+1)+1)*Pi+(1/2)*csgn(I*(1+I*x)^2/((x^2+1)*((1+I*x)^2/(x^2+1)+1)^2))*csgn(I/((1+I*x)^2/(x^2+1)+1)^2)*csgn(I*(1+I*x)^2/(x^2+1))*Pi*arctan(x)+I*ln((1+I*x)^2/(x^2+1)+1)*Pi*csgn(I*((1+I*x)^2/(x^2+1)+1))*csgn(I*((1+I*x)^2/(x^2+1)+1)^2)^2-(1/2)*arctan(x)^2
"smart int result ", (1/2)*ln(x^2+1)*arctan(x)^2*x^2-(1/2)*arctan(x)^2*x^2-ln(x^2+1)*arctan(x)*x+(1/2)*ln(x^2+1)*arctan(x)^2+3*arctan(x)*x-(3/2)*arctan(x)^2+(1/4)*ln(x^2+1)^2-(3/2)*ln(x^2+1)
"smart int percentage size relative to default ", "2.45"
integral", Int((x^2+1)/((-x^2+1)*(x^4+1)^(1/2)), x)
"maple default result ", (1/4)*(arctanh((x^2-x+1)*2^(1/2)/(x^4+1)^(1/2))-arctanh((x^2+x+1)*2^(1/2)/(x^4+1)^(1/2)))*2^(1/2)
"smart int result ", (1/2)*arctanh((1/2)*(x^4+1)^(1/2)*2^(1/2)/x)*2^(1/2)
"smart int percentage size relative to default ", "45.65"
integral", Int((a+b*f*x+b*sin(f*x+e))/(a+a*cos(f*x+e)), x)
"maple default result ", tan((1/2)*f*x+(1/2)*e)/f+b*x*tan((1/2)*f*x+(1/2)*e)/a-b*ln(1+tan((1/2)*f*x+(1/2)*e)^2)/(a*f)-b*ln(cos(f*x+e)+1)/(a*f)
"smart int result ", tan((1/2)*f*x+(1/2)*e)*(b*f*x+a)/(a*f)
"smart int percentage size relative to default ", "31.43"
integral", Int(x*ln(1/x+1), x)
"maple default result ", (1/2)*ln(1/x)+(1/2)*x-(1/2)*ln(1/x+1)*(1/x+1)*(1/x-1)*x^2
"smart int result ", (1/2)*x^2*ln(1/x+1)+(1/2)*x-(1/2)*ln(1+x)
"smart int percentage size relative to default ", "67.74"
integral", Int(1/(x*(x^5+1)), x)
"maple default result ", -(1/5)*ln(1+x)+ln(x)-(1/5)*ln(x^4-x^3+x^2-x+1)
"smart int result ", ln(x)-(1/5)*ln(x^5+1)
"smart int percentage size relative to default ", "39.29"
Download smart_int.mw
How to correct this code ? Thank you.
with(geometry);
_EnvHorizontalName := 'x';
_EnvVerticalName := 'y';
x0 := 10;
y0 := 9;
a := 7;
b := 5;
c := sqrt(a^2 - b^2);
ellipse(el, x^2/a^2 + y^2/b^2 - 1);
point(F1, -c, 0);
point(F2, c, 0);
point(P, x0, y0);
eq := simplify((a^2 - x0^2)*(y - y0)^2 + (b^2 - y0^2)*(x - x0)^2 + 2*x0*y0*(x - x0)*(y - y0)) = 0;
sol := solve({eq}, {y});
line(tang1, op(sol[1]));
slope(tang1);
line(tang2, op(sol[2]));
slope(tang2);
sol2 := op(solve({op(sol[1]), x^2/a^2 + y^2/b^2 - 1 = 0}, {x, y}));
xM2 = rhs(sol2[1]);
yM2 = rhs(sol2[2]);
point(M2, xM2, yM2);
sol3 := op(solve({op(sol[2]), x^2/a^2 + y^2/b^2 - 1 = 0}, {x, y}));
xM3 = rhs(sol3[1]);
yM3 = rhs(sol3[2]);
point(M3, xM3, yM3);
assume(xM2 - xM3 <> 0);
line(Pol, [M2, M3]);
coordinates(M2);
display(textplot([[-c, 0, "F1"], [c, 0, "F2"], [coordinates(P)[], "P"]], align = {"above", 'right'}), draw([el(color = red), P(color = black, symbol = solidcircle, symbolsize = 16), tang1(color = green), tang2(color = green), Pol(color = red, thickness = 3), F1(color = blue, symbol = solidcircle, symbolsize = 16), F2(color = red, symbol = solidcircle, symbolsize = 16)]), axes = none);
how to solve this using integration by parts?
with(IntegrationTools):
eq1:=int(1-(sum(p[i]*(1-exp(-((t-xi)/tau[i]))),i=1..n)),xi=0..t);
int(1-(sum(p[i]*(1-exp(-(t-xi)/tau[i])), i = 1 .. n)), xi = 0 .. t)
Download 1111.mw
Any workaround or why ODESteps gives this internal Maple error?  Is this known limitation of ODESteps?
ps. reported also to Maplesoft just in case.
17128
`The "Physics Updates" version in the MapleCloud is 1750 and is the same as the version installed in this computer, created 2024, May 31, 10:47 hours Pacific Time.`
DEtools:-odeadvisor(ode);
[_quadrature]
ic:=y(0) = 1;
y(0) = 1
Error, (in ln) numeric exception: division by zero
ic:=y(0) = 1;
dsolve([ode,ic]);
y(0) = 1
y(x) = 4*exp(2*x)-4*exp(x)+1
Download bug_in_odesteps_divide_by_zero_may_31_2024.mw
What should I do to simplify eq13 further using trig sum identities?
Thank you for your help in advance,
phi := (x,n,L) -> sqrt(2/L)*sin(n*Pi*x/L + 1/2*n*Pi);
proc (x, n, L) options operator, arrow; sqrt(2/L)*sin(n*Pi*x/L+(1/2)*n*Pi) end proc
eq1 := W[n,m](q,p) = simplify(1/Pi*Int(phi(q+y,n,L)*exp(-2*I*p*y)*phi(q-y,m,L),y=-L/2+abs(q)..L/2-abs(q)));
W[n, m](q, p) = 2*(Int(sin((1/2)*n*Pi*(2*q+2*y+L)/L)*exp(-(2*I)*p*y)*sin((1/2)*m*Pi*(2*q-2*y+L)/L), y = -(1/2)*L+abs(q) .. (1/2)*L-abs(q)))/(L*Pi)
eq2 := simplify(convert(eq1,int)) assuming(n,integer,m,integer);
W[n, m](q, p) = (-16*(I*((-(1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*L*p*sin(n*Pi*(abs(q)+q)/L)+(1/2)*cos(n*Pi*(abs(q)+q)/L)*(((1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*n*Pi)*exp(I*p*(L-2*abs(q)))*sin(m*Pi*(L-abs(q)+q)/L)+16*exp(-I*p*(L-2*abs(q)))*(I*L*p*((-(1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*sin(m*Pi*(abs(q)+q)/L)-(1/2)*cos(m*Pi*(abs(q)+q)/L)*m*((-(1/4)*m^2+(1/4)*n^2)*Pi^2+p^2*L^2)*Pi)*sin(n*Pi*(L-abs(q)+q)/L)+8*Pi*(-m*exp(I*p*(L-2*abs(q)))*((((1/4)*m^2-(1/4)*n^2)*Pi^2-p^2*L^2)*sin(n*Pi*(abs(q)+q)/L)+I*L*p*Pi*n*cos(n*Pi*(abs(q)+q)/L))*cos(m*Pi*(L-abs(q)+q)/L)+exp(-I*p*(L-2*abs(q)))*cos(n*Pi*(L-abs(q)+q)/L)*n*((((1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*sin(m*Pi*(abs(q)+q)/L)+I*L*p*Pi*m*cos(m*Pi*(abs(q)+q)/L))))/((m-n)^2*(m+n)^2*Pi^5-8*L^2*p^2*(m^2+n^2)*Pi^3+16*L^4*p^4*Pi)
Wigner function evaluated for q > 0 and q < 0, respectively
eq10 := simplify(eq2) assuming(q>0);
eq11 := simplify(eq2) assuming(q<0);
eq12 := simplify(eq10) assuming(m,integer,n,integer);
eq13 := simplify(eq11) assuming(m,integer,n,integer);
W[n, m](q, p) = (16*exp(-I*p*(L-2*q))*(I*p*L*((-(1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*sin(n*Pi)+(1/2)*cos(n*Pi)*Pi*n*(((1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2))*sin(2*m*Pi*q/L)-16*exp(I*p*(L-2*q))*(I*p*L*((-(1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*sin(m*Pi)-(1/2)*Pi*cos(m*Pi)*((-(1/4)*m^2+(1/4)*n^2)*Pi^2+p^2*L^2)*m)*sin(2*n*Pi*q/L)+8*Pi*(exp(-I*p*(L-2*q))*((((1/4)*m^2-(1/4)*n^2)*Pi^2-p^2*L^2)*sin(n*Pi)+I*L*n*p*Pi*cos(n*Pi))*m*cos(2*m*Pi*q/L)-((((1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*sin(m*Pi)+I*L*m*p*Pi*cos(m*Pi))*cos(2*n*Pi*q/L)*n*exp(I*p*(L-2*q))))/((m-n)^2*(m+n)^2*Pi^5-8*L^2*p^2*(m^2+n^2)*Pi^3+16*L^4*p^4*Pi)
W[n, m](q, p) = (-8*exp(I*p*(L+2*q))*n*(((1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*sin(m*Pi*(L+2*q)/L)+8*m*(-exp(-I*p*(L+2*q))*((-(1/4)*m^2+(1/4)*n^2)*Pi^2+p^2*L^2)*sin(n*Pi*(L+2*q)/L)+I*Pi*n*p*L*(cos(n*Pi*(L+2*q)/L)*exp(-I*p*(L+2*q))-exp(I*p*(L+2*q))*cos(m*Pi*(L+2*q)/L))))/((m-n)^2*(m+n)^2*Pi^4-8*L^2*p^2*(m^2+n^2)*Pi^2+16*L^4*p^4)
W[n, m](q, p) = (8*(-1)^n*(((1/4)*m^2-(1/4)*n^2)*Pi^2+p^2*L^2)*n*exp(-I*p*(L-2*q))*sin(2*m*Pi*q/L)-8*m*(-(-1)^m*exp(I*p*(L-2*q))*((-(1/4)*m^2+(1/4)*n^2)*Pi^2+p^2*L^2)*sin(2*n*Pi*q/L)+I*n*(cos(2*n*Pi*q/L)*exp(I*p*(L-2*q))*(-1)^m-exp(-I*p*(L-2*q))*(-1)^n*cos(2*m*Pi*q/L))*Pi*L*p))/((m-n)^2*(m+n)^2*Pi^4-8*L^2*p^2*(m^2+n^2)*Pi^2+16*L^4*p^4)
Download test5.mw
How to get the animation graphs for eta =0..10
restart; with(plots)
ga := .2; Gc := .2; n := 2; Sc := .5; Kp := .2; Q := 0.5e-1; Gr := .2
A := .1Pr := 6.2; Nt := .2; alpha := .1; Rd := 1.5; M := .5; E1 := .3; Ec := .3; Thetap := .2; Nb := .2
a1 := 1.301348831
a2 := 1.298194584
a3 := .9728927630; a4 := .9161173998
a5 := 1.316893419
a6 := 1.333333333
OdeSys := a1*((diff(f(eta), eta, eta, eta))*(2*eta*ga+1)+2*(diff(f(eta), eta, eta))*ga)/a2+A^2-(diff(f(eta), eta))^2+f(eta)*(diff(f(eta), eta, eta))-a1*Kp*(diff(f(eta), eta))/a2-a6*M*(diff(f(eta), eta))/a2+a4*(Theta(eta)*Gr+Phi(eta)*Gc)/a2, f(eta)*(diff(Theta(eta), eta))+a5*(1+4*Rd*(1/3))*((diff(Theta(eta), eta, eta))*(2*eta*ga+1)+2*(diff(Theta(eta), eta))*ga)/(a3*Pr)+(diff(f(eta), eta, eta))^2*(2*eta*ga+1)*Ec*a1/a3+Theta(eta)*Q/a3, f(eta)*(diff(Phi(eta), eta))+((diff(Phi(eta), eta, eta))*(2*eta*ga+1)+2*(diff(Phi(eta), eta))*ga)/Sc+Nt*((diff(Theta(eta), eta, eta))*(2*eta*ga+1)+2*(diff(Theta(eta), eta))*ga)/(Nb*Sc)-Kr*(1+Theta(eta)*(Thetap-1))^n*exp(-E1/(1+Theta(eta)*(Thetap-1))); Cond := f(0) = 0, (D(f))(0) = 1, a5*(D(Theta))(0) = -alpha*(Theta(0)-1), Phi(0) = 1, (D(f))(10) = A, Theta(10) = 0, Phi(10) = 0
KrVals := [0.1e-1, .1, .2, .3]
for j to numelems(KrVals) do Ans[j] := dsolve(eval([OdeSys, Cond], Kr = KrVals[j]), numeric, output = listprocedure) end do
  cols := [red, blue,green, black]:
 plotA:= display
  ( [ seq
      ( odeplot
        ( Ans[k],[eta,D(f)(eta)],
          eta=0..10,
          color=cols[k]
        k=1..numelems(KrVals)
    'axes'= 'boxed',labels=[eta,'f(eta)']
  cols := [red, blue, green,black]:
plotC:= display( [ seq( odeplot
        ( Ans[k],[eta,Theta(eta)],
          eta=0..10,
          color=cols[k]
    'axes'= 'boxed',labels=[eta,'Theta(eta)']
plotA1 := display(seq(plot3d(r*(eval(f(:-eta), Ans[k]))(eta), eta = 0 .. 10, r = -5 .. 5, color = cols[k]), k = 1 .. nops(KrVals)), linestyle = "solid", style = contour, thickness = 1)
Download ode_plots_animation_graphs.mw
i need like this demo plot
First 101 102 103 104 105 106 107 Last Page 103 of 2427
