I'm trying to use CodeTools[Profile] to investigate my memory leak and the effect or lack there of of 'forget' to improve it.
I copied my code from an example:
with(CodeTools[Profiling]);
 [Allow, Build, Coverage, GetProfileTable, Ignore, IsProfiled,
   LoadProfiles, Merge, PrintProfiles, Profile, Remove,
   SaveProfiles, Select, SortBy, UnProfile]
Profile([PickAngles(1.0, 1.0, 1.0)]);
Error, (in CodeTools:-Profiling:-Profile) unexpected argument(s)
The 'unexpected argument' is the 'result' from 'PickAngles'. I've tried with and w/o the '[]' but it does the same thing failing to recognize that 'PickAngles' is a procedure.
The example I used is here:
https://www.maplesoft.com/support/help/maple/view.aspx?path=CodeTools%2FProfiling%2FProfile procedure.
I did what to make of the subscript Profiles in the example so I used '[Profiles]' and that worked or seemed to.
Dear Users!
I hope you are doing well. In the attached file I want to convert the system of ODEs (attained the system against the value of M) into matrix form and need the matrices A, B and vector b. Remember the order of A, B and b vary as M vary. I am waiting for your kind response. Please take care and thanks
System_of_ODEs.mw
I can import maple, but I get an error when importing namespace/symbols:
import maple.namespace as mpl
The below is not properly rendering in my browser. You probably have to open the worksheet
De Morgan's law from https://en.wikipedia.org/wiki/De_Morgan%27s_laws
iff(not (P or Q), `and`(not P, not Q))
not (P or Q) implies not (P or Q)
iff(not (P and Q), `or`(not P, not Q))
not (P and Q) implies not (P and Q)
Edit: Asking differently: Which symbol from the palettes can be used for equivalence (in a logic context)?
Edit2: Title changed. Original title: Why does Maple replace the equivalence symbol by an implication symbol
Download De_Morgans_law.mw
hi
I have a linear system with varibles trying to plot 3d the solutions x, y, z
here is my code: linear_var.mw
please any comment might help.
Omega:=10:N:=0.5:M:=sqrt(N(N+1)):
a11:=0.5*(1+2*N)+M*cos(phi):
a12:=-0.5*((1+theta)^3+(1-theta)^3):a13:=-0.5*(N+M*cos(phi))*((1+theta)^3-(1-theta)^3): a21:=M*sin(phi): a22:=(-(1+2*N)+0.5*M*cos(phi))*((1+theta)^3+(1-theta)^3): a23:=-(Omega+0.5*((1+theta)^3-(1-theta)^3)*M*sin(phi)): a31:=0.25*((1+theta)^3-(1-theta)^3): a32:=Omega: a33:=-0.5-(N+0.25)*((1+theta)^3+(1-theta)^3): b1:=-0.5*a31: b2:=0: b3:=0.25+((1+theta)^3+(1-theta)^3)/8:
slove([a11*x+a12*y+a13*z=b1,a21*x+a22*y+a23*z=b2,a31*x+a32*y+a33*z=b3[,[x,y,z]);
Error, unable to match delimiters
Typesetting:-mambiguous(Typesetting:-mambiguous(slovelparlsqba11
  sdotx + a12sdoty + a13sdotzequalsb1commaa21sdotx + a22sdoty +
  a23sdotzequalsb2commaa31sdotx + a32sdoty + a33sdotzequalsb3lsqb
  comma(xyz)rparsemi,
  Typesetting:-merror("unable to match delimiters")))
plot3d(x, theta = .1 .. 5, phi = 0 .. 2*Pi, axes = boxed);
plot3d(y, theta = .1 .. 5, phi = 0 .. 2*Pi, axes = boxed); plot3d(z, theta = .1 .. 5, phi = 0 .. 2*Pi, axes = boxed);
I would like solving systems of congruences like the following one:
154x+69y = 0 mod 7^3
13x+716y = 0 mod 13^3
23x+3059y = 0 mod 23^3
I need the minimal non-trivial solution. I know that the solution of the system above is x=1103, y=26390.
How could I find the solution with Maple?
I'm having problems with my maple not saving. I get no error message and no windows pop up.
The error occurred after the summer holidays in Maple 2022. I use Windows 11, everything is up to date. Have no Anti-virus programs.
  I have tried the following after I discovered the error:
- To install Maple 2023
- Uninstall and delete all maple folders, then reinstall Maple 2023
- Pressed Ctrl + s
- Press "Save as..."
- Pressed on the floppy disk/save icon
- Restarted computer and updated windows
- Run Maple as administrator
The only thing I can be allowed to do is:
- Ctrl + p
- Print to PDF/printer
Really hope you can help!
Dear power users, I am making the switch from Mathcad towards Maple and would like to know what is the most efficient alternative in Maple for a solve block. I have attached a work document to illustrate better my question.SolveBlockQuestion.mw Any help is highly appreciated.
Say I have ,
sol1 := C*vout*vin/(Iout*L*k^2)
and I want to simplify this expression by replacing  with .
Then I need to simplify it further by noting that , and that , so that the answer is only in terms of , , and .
I tried eval(sol1, vin/Iout = omega*Lm) initially to step through the first substitution, but that just returned the same expression.
I don't know where my last exchange with @mz6687  has been moved (not to the initial question  https://www.mapleprimes.com/questions/237066-Determinant-The-System-Hangs for what I see).
Nevertheless here is the reply I was sending to @mz6687  which ended with the message "Page not found".
Are_you_ok_with_that.mw
Could the one who moved the question meanwhile be so kind as to attach this reply?
TIA
If one writes Pi or Catalan, the output is Pi or Catalan, and writing evalf(Pi) or evalf(Catalan) we get approximations.
I would like to define other constants behaving in the same way. How to do it?
How to export Maplet file to .exe file to run independently without installing Maple software?
I can't figure how to simplify
 V:= V1*R2/(s*C*R1*R2+R1_R2)
into
V = V1 *R2/(R1+R2)/(C*R1*R2*s/(R1+R2)+1)
with Maple
Basically, divide numerator and denominator by the s^0 coefficient.
`[Length of output exceeds limit of 1000000]`
Hello, I want to get the the homogeneous balance principle for the Differential-Difference Equation with Maple. Can anyone help?
the homogeneous balance principle:The balance is made between sentences with the highest degree of nonlinearity and the highest order of the available derivative. We consider the power of terms like u^p as pM and u(q) as M + q and put them equal (pM=M+q) and get the value of M. Now, if M = 1/n (where m is an integer), then we use the transformation U= W^n, where W is a new function.
example:
First 166 167 168 169 170 171 172 Last Page 168 of 2428
