I am working on a Maple file to find the right force excerted in a specifik angle (theta). This is the script Maple than has to work out:
eq4 := Fh1 = (1/2)*(solFh2*sqrt(2)-40)/sin(theta);
eq5 := Fh1 = (1/2)*(solFh2*sqrt(2)-100)/cos(theta);
sol := solve({eq4, eq5}, {Fh1, theta});
Next it gives me the answers as following:
sol := {Fh1 = 121.6477702, theta = .9606764638}, {Fh1 = -121.6477702, theta = -2.180916190}
Which is correct: I get a force (Fh1 = ± 121.6477...) with 2 angles (theta = .9696... or theta=-2.1809...)
If i want to continue working with Fh1 it gives an error saying it has 2 values for it (obviously a positive and a negative value). Is there a way to continue working with the positive values of Fh1 and theta?
I was thinking of solving the intersect equation on the positive 'theta'-axis in a form like:
sol := solve({eq4, eq5}, {Fh1, theta>0}); as theta is my horizontal axis and a positve theta gives me a positive Fh1 but Maple doesn't work that straightforward.
Thanks a lot!
Hi I was wondering if you can help me with some maple commands about using Euler's method. My professor created a tutorial on using some commands to calculate the value via Euler's method.
Her commands in the tutorial for using Euler's method  for a differential equation- dy/dx= x+y   y(0)=1
x0:=0:y0:=1:xf:=1:n:=10:
h:=evalf((xf-x0)/n);
f:=(x,y) -> x+y
x:=x0:y:=y0:
This next step confuses me the most, my professor uses this syntax to compute the values of approximation via Euler's method. N represents the number of pieces we want to approximate the value with. X0 is initial and XF is final.
forifrom1tondo k:=f(x,y):y:=y+h*k:x:=x+h:print(x,y):od:
I tried replicating this syntax on the exact same problem, copying the syntax commands word for word. Yet, I keep getting the same error "unable to parce" error, with the "od" being highlighted. But on her tutorial, it gave her an two columns with the intervals (n) and all it's values. She even did the same did for only wanting 1 loop printed
forifrom1tondo k:=f(x,y):y:=y+h*k:x:=x+h:od:print(x,y):.   And it gave her only 1 loop.
I tried both and still got the error. Please Help, Thanks in advance
Hey, i'm trying do demonstrate that a nonlinear system has a semistable limit cycle but i get a warning at the plot command saying "Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct" and i dont understand it. So i wonder if someone here could help me?
restart; with(PDEtools); with(plots);
eq1 := diff(x(t), t) = x(t)*(x(t)^2+y(t)^2-1)^2-y(t);
           d              /    2       2    \
          --- x(t) = x(t) \x(t)  + y(t)  - 1/  - y(t)
           dt
eq2 := diff(y(t), t) = y(t)*(x(t)^2+y(t)^2-1)^2+x(t);
           d              /    2       2    \
          --- y(t) = y(t) \x(t)  + y(t)  - 1/  + x(t)
           dt
tr := {x(t) = r(t)*cos(theta(t)), y(t) = r(t)*sin(theta(t))};
     {x(t) = r(t) cos(theta(t)), y(t) = r(t) sin(theta(t))}
eq1b := dchange(tr, x(t)*eq1+y(t)*eq2, [r(t), theta(t)], simplify);
              / d      \       2 /        4         2\
         r(t) |--- r(t)| = r(t)  \1 + r(t)  - 2 r(t) /
              \ dt     /
eq1b := expand(eq1b/r(t));
                d                    5         3
               --- r(t) = r(t) + r(t)  - 2 r(t)
                dt
eq2b := dchange(tr, y(t)*eq1-x(t)*eq2, [r(t), theta(t)], simplify);
                      2 / d          \        2
                 -r(t)  |--- theta(t)| = -r(t)
                        \ dt         /
eq2b := simplify(eq2b/(-r(t)^2));
                         d
                        --- theta(t) = 1
                         dt
sol1 := dsolve({eq1b, r(0) = r[0]}, r(t));
          /      /  /     2  \
          |      |  | r[0]   |          2     2
r(t) = exp|RootOf|ln|--------| (exp(_Z))  r[0]
          \      \  \r[0] - 1/
                           2     2
   - ln(r[0] + 1) (exp(_Z))  r[0]
       /             2\
       |(exp(_Z) - 1) |          2     2            2        2
   - ln|--------------| (exp(_Z))  r[0]  + (exp(_Z))  _Z r[0]
       \ exp(_Z) - 2  /
                                /     2  \
                2     2         | r[0]   |             2
   + 2 (exp(_Z))  r[0]  t - 2 ln|--------| exp(_Z) r[0]
                                \r[0] - 1/
   + 2 ln(r[0] + 1) exp(_Z) r[0]
         /             2\
   + 2 ln|--------------| exp(_Z) r[0]  - 2 exp(_Z) _Z r[0]
         \ exp(_Z) - 2  /
                           /     2  \
                   2       | r[0]   |          2
   - 4 exp(_Z) r[0]  t - ln|--------| (exp(_Z))
                           \r[0] - 1/
                                 /             2\
                           2     |(exp(_Z) - 1) |          2
   + ln(r[0] + 1) (exp(_Z))  + ln|--------------| (exp(_Z))
                                 \ exp(_Z) - 2  /
                                          /     2  \
              2                   2       | r[0]   |
   - (exp(_Z))  _Z - 2 t (exp(_Z))  + 2 ln|--------| exp(_Z)
                                          \r[0] - 1/
                                  /             2\
                                  |(exp(_Z) - 1) |
   - 2 ln(r[0] + 1) exp(_Z) - 2 ln|--------------| exp(_Z)
                                  \ exp(_Z) - 2  /
              2                                    2
   - (exp(_Z))  + 2 _Z exp(_Z) + 4 t exp(_Z) + r[0]  + 2 exp(_Z)
   - 1|| - 1
sol1 := simplify(sol1);
          /      /   /     2  \
          |      |   | r[0]   |               2
r(t) = exp|RootOf|-ln|--------| exp(2 _Z) r[0]
          \      \   \r[0] - 1/
   + ln(r[0] + 1) exp(2 _Z) r[0]
       /             2\
   + ln|--------------| exp(2 _Z) r[0]  - exp(2 _Z) _Z r[0]
       \ exp(_Z) - 2  /
                               /     2  \
                     2         | r[0]   |             2
   - 2 exp(2 _Z) r[0]  t + 2 ln|--------| exp(_Z) r[0]
                               \r[0] - 1/
   - 2 ln(r[0] + 1) exp(_Z) r[0]
         /             2\
   - 2 ln|--------------| exp(_Z) r[0]  + 2 exp(_Z) _Z r[0]
         \ exp(_Z) - 2  /
                           /     2  \
                   2       | r[0]   |
   + 4 exp(_Z) r[0]  t + ln|--------| exp(2 _Z)
                           \r[0] - 1/
                                /             2\
                                |(exp(_Z) - 1) |
   - ln(r[0] + 1) exp(2 _Z) - ln|--------------| exp(2 _Z)
                                \ exp(_Z) - 2  /
                                        /     2  \
                                        | r[0]   |
   + exp(2 _Z) _Z + 2 t exp(2 _Z) - 2 ln|--------| exp(_Z)
                                        \r[0] - 1/
                                  /             2\
                                  |(exp(_Z) - 1) |
   + 2 ln(r[0] + 1) exp(_Z) + 2 ln|--------------| exp(_Z)
                                  \ exp(_Z) - 2  /
   + exp(2 _Z) - 2 _Z exp(_Z) - 4 t exp(_Z) - r[0]  - 2 exp(_Z)
   + 1|| - 1
sol2 := dsolve({eq2b, theta(0) = theta[0]}, theta(t));
                    theta(t) = t + theta[0]
theta[0] := (1/4)*Pi;
                              - Pi
                              4
plot1 := polarplot([subs(r[0] = .1, rhs(sol1)), rhs(sol2), t = 0 .. 10], color = red);
plot2 := polarplot([subs(r[0] = 2, rhs(sol1)), rhs(sol2), t = 0 .. 10], color = blue);
display({plot1, plot2}, scaling = constrained, tickmarks = [4, 3], view = [-2 .. 2, -2 .. 2]);
Suppose I have a questions that says simplify some random square root
using the algorithm
$radicand=range(10,50,1);
$ques="sqrt($radicand)";
$ques_exact=maple("simplify($ques);");
$ques_ML=maple("f := $ques_exact: XMLTools[Print](MathML[Export](f));");
How do I create an answer field that ONLY allows the student to provide the simplified answer $ques_ML??  How might I provide partial points if they do not simplify (for a classic pythag triangle question for example)?
I'm struggling to solve a problem with the Maple 2015 worksheet interface. I have a very dense 2D plot, with lots of oscillations, that was generated using Maple 2015 on Windows 10. Substantial parts of the plot are missing; it looks like the tips of the oscillations being clipped out. If I load the same worksheet into Maple 18 on Windows 7 then the plot looks fine (i.e. nothing is clipped). I've dug through the options in Maple 2015 and nothing I try seems to fix the problem. Any advice would be greatly appreciated.
Many thanks,
David
I started using Maple recently. The output sometime is not simplified like that in the attached picture. How can I simplify such expressions?
http://www.maplesoft.com/applications/view.aspx?SID=1526&view=html
near the middle, it says
I just tried in Maple 2016 and that is not what it did. It says this was in Maple 8. It seems this was "fixed" in Maple 2015.
My question: How could Maple 8 have simplified rand()/rand() to 1 before evaluating rand()?  i.e. why was not rand() evaluated first, before the simplification was made? it seems to have worked as if one typed x/x , but rand() would have been a function, and it should be evaluated before?
Just wondering why Maple 8 did the above, that is all.
How to view the source code for a created .mv file in Maple?
 helo my friends,
i try to do this code, please help me to understant what is the problem
I am tying to compute the wronskian of a fourth order DE: y=C1e2x+ C2e-x +C3xe-x+ C4x2e-x Here's what I did:
with(VectorCalculus):
Determinant(Wronskian([e^(2*x), e^(-x), xe^(-x), x^2*e^(-x)], x)):
which gave nothing.
Can anyone please help?
Thanks in advance,
AJ
newbie here. When I give Maple 2016.2  a boundary value ODE with an eigenvalue in it, it returns the trivial solution. I was wondering if Maple supports finding non-trivial solution and also give the eigenvalue values associated with the non-trivial solution?
ode:=diff(y(x),x$2)+lambda*y(x)=0;
bc:=y(0)=0,y(L)=0:
assume(L>0,L,'real'):
sol:=dsolve({ode,bc},y(x));
The outtput is `y(x)=0`
In Mathematica, it gives both trivial and non-trivial solution:
Clear[L0, lam, x, y, r]
ode = y''[x] + lam y[x] == 0;
bc = {y[0] == 0, y[L0] == 0};
sol = Assuming[Element[L0, Reals] && L0 > 0,
  DSolveValue[{ode, bc}, y[x], x]]
And the answer is
If Maple does not currently support this, any one knows if this will added to Maple 2017?
Hi, there!
I try to simplify the next expression:
Simplify(LeviCivita[4, sigma, lambda, rho]*LeviCivita[4, xi, eta, mu]*g_[rho, mu]*qp[sigma]*q[lambda]*qp[xi]*q[eta])
Maple gives answer:
In reality it is incorrect answer, because indices must run over 1,2,3 but not 1,2,3,4!
SumOverRepeatedIndices(%) confirms that maple mistakes.
my preamble is:
with(Physics)
Coordinates(X);
Setup(spaceindices = lowercaselatin)
Setup(tensors = q[mu](X))
PDEtools:-declare(q(X))
Setup(tensors = qp[mu](X))
PDEtools:-declare(qp(X))
I have a derivative distribution function f that is defined:
f:=piecewise(x < .114e-1,0.,x < .129e-1,0.,x < .147e-1,0.,x < .167e-1,0.,x < .189e-1,0.,x < .215e-1,0.,x < .244e-1,0.,x < .278e-1,0.,x < .315e-1,0.,x < .358e-1,0.,x < .407e-1,0.,x < .463e-1,0.,x < .526e-1,0.,x < .597e-1,0.,x < .679e-1,0.,x < .771e-1,0.,x < .876e-1,0.,x < .995e-1,0.,x < .113,0.,x < .128,0.,x < .146,0.,x < .166,0.,x < .188,0.,x < .214,0.,x < .243,0.,x < .276,0.,x < .314,0.,x < .357,0.,x < .405,0.,x < .46,0.,x < .523,0.,x < .594,0.,x < .675,-.8800000000+1.481481481*x,x < .767,-.3935869565+.7608695652*x,x < .872,-.3213333333+.6666666667*x,x < .991,-.2529411765+.5882352941*x,x < 1.13,-.1690647482+.5035971223*x,x < 1.28,-.2026666667+.5333333333*x,x < 1.45,-.1223529412+.4705882353*x,x < 1.65,-.1650000000+.5000000000*x,x < 1.88,-.2726086957+.5652173913*x,x < 2.13,-.5636000000+.7200000000*x,x < 2.42,-.8662068966+.8620689655*x,x < 2.75,-1.200000000+1.000000000*x,x < 3.12,-1.645945946+1.162162162*x,x < 3.55,-1.865581395+1.232558140*x,x < 4.03,-2.075416667+1.291666667*x,x < 4.58,-1.925818182+1.254545455*x,x < 5.21,-1.559682540+1.174603175*x,x < 5.92,-.7967605634+1.028169014*x,x < 6.72,.3320000000+.8375000000*x,x < 7.64,1.942608696+.5978260870*x,x < 8.68,3.791923077+.3557692308*x,x < 9.86,5.850169492+.1186440678*x,x < 11.2,7.902985075-.8955223881e-1*x,x < 12.7,9.737333333-.2533333333*x,x < 14.5,10.82388889-.3388888889*x,x < 16.4,11.78631579-.4052631579*x,x < 18.7,11.34347826-.3782608696*x,x < 21.2,10.85240000-.3520000000*x,x < 24.1,9.311379310-.2793103448*x,x < 27.4,7.619090909-.2090909091*x,x < 31.1,5.814864865-.1432432432*x,x < 35.3,4.025714286-.8571428571e-1*x,x < 40.1,2.544375000-.4375000000e-1*x,x < 45.6,1.519090909-.1818181818e-1*x,x < 51.8,.8370967742-.3225806452e-2*x,x < 58.9,.6700000000,x < 66.9,.5963750000+.1250000000e-2*x,x < 76,.9005494505-.3296703297e-2*x,x < 86.4,1.161538462-.6730769231e-2*x,x < 98.1,1.318461538-.8547008547e-2*x,x < 111,1.544651163-.1085271318e-1*x,x < 127,1.241875000-.8125000000e-2*x,x < 144,1.106470588-.7058823529e-2*x,x < 163,.7721052632-.4736842105e-2*x,x < 186,0,x < 211,0,x < 240,0,x < 272,0,x < 310,0,x < 352,0,x < 400,0,x < 454,0,x < 516,0,x < 586,0,x < 666,0,x < 756,0,x < 859,0,x < 976,0,x < 1110,0,x < 1260,0,x < 1430,0,x < 1630,0,x < 1850,0,x < 2100,0,x < 2390,0,x < 2710,0,0):
I want to do a simple numerical integration of that function - that means I have k points of independent variable x and together with dependent variable points it looks like:
I was trying to resolve this in Maple:
f_list:=convert(f,list):
integralbodyx:=[seq(0+((200-0)/100)*i,i=1..100)]:
integralbodyy:=[seq(sum((eval(f_list[0+((200-0)/100)*j],x=(0+((200-0)/100)*j)))*2,j=1..i),i=1..100)]:
but I get an error
Error, (in limit/mrv/limsimpl) too many levels of recursion
Can you help me with the syntax? Thank you.
Dears
Hope you would be fine. I want to solve the following PDEs by numerically for v[nf]=alpha[nf]=Ec=mu[nf]=C=1 and Pr=6.2
Eq1 := diff(u(x, t), t) = v[nf]*(diff(u(x, t), x, x));
Eq2 := diff(u(x, t), t) = alpha[nf]*(diff(theta(x, t), x, x))/Pr+Ec*mu[nf]*C*(diff(u(x, t), x))^2;
ICs := u(x, 0) = 0, theta(x, 0);
BCs := u(0, t) = 1, theta(0, t) = 1, u(10, t) = 0, theta(10, t) = 0;
and find the values of (diff(u(0, t), x))/(1-phi)^2.5 for different values of phi. Thanks in advace
With my best regards and sincerely.
Muhammad Usman
School of Mathematical Sciences
Peking University, Beijing, China
First 1024 1025 1026 1027 1028 1029 1030 Last Page 1026 of 2462
