Hi, I wondered if anyone knows a way to separate out addition (or subtraction) terms in an equation.
For example given eqn1:
eqn1:= (1/2)*p+1+(-4*p^2-p-1)/(3*p^3+7*p^2+2*p+2)
I would like to get the first rational term before the first plus (or minus) sign. In this case it would be (p/2).
This is a trivial example shown above but the real value in this is that I want to customize my own factorizations using the pratial fraction function of Maple. In this case I would not know eqn1 before hand but it would be the solution to some previous factorization and I need just the first term (before the first plus sign).
If anyone knows any tips or tricks that will set me on the right path to doing this it is most appreciated.
Hey, I'm sitting with an extremely annoying problem. Basically, I want a "Mathematical Expression" component to include a definition of a variable, so I want it to say, for example, "h := 3", now, I can easily type this into the component field myself, and it all works great, but I want to manipulate the field with a button component. Every time I attempt it, it seems as if the ":=" symbol is protected, however I can write it myself without trouble.
Good day, I need to 2D plot from points which I get by solving numerically 17-degree equations. Firstly I take an only first solution of the equation as below, and I have a Matrix with 3 column which represents X, Y, and VALUE respectively. On the left side should be the first column ( X ), and right axis Y (2. column). As seen from Matrix X and Y getting the value between 0 and 10. Is there any option that I can plot my data in 2D?  Thanks in advance.
points := seq(seq(seq(Fun[n, i, j], n = 0 .. step), i = 0 .. step), j = 1);
Mat := Matrix((step+1)^2, 3, [points]);
         .                             X                  Y                 VALUE
pointplot3d(Mat, style = point, color = black);
I have a system of equations (4) which I would like to plot in regards to a fifth variable. Is there a good way to do this. Some of the solutions would end up as negative values, which is not an option I am interested in having.
C__A is my variable, and the other variables I would like to solve are tau,C__B,C__C,C__D. Im specifically interested in tau with regards to C__A. I hope this makes sense :)
regards
C__A := .75;
                              0.75
a := tau = (C__A0-C__A)/(-r__A);
                                  0.75
    tau = - ------------------------------------------------
            -0.00900 C__B + 0.03500000000 C__C  - 0.075 C__C
b := tau = (C__B0-C__B)/(-r__B);
                               2 - C__B
c := tau = (C__C0-C__C)/(-r__C);
                                C__C
         tau = ---------------------------------------
               0.01800 C__B - 0.070 C__C  - 0.075 C__C
d := tau = (C__D0-C__D)/(-r__D);
                           13.33333333 C__D
                                 C__C
sol := fsolve([a, b, c, d], {C__B = 1, C__C = .2, C__D = .2, tau = 50});
{C__B = 1.673672109, C__C = 0.2289836744, C__D = 0.4236721086,
  tau = 24.66971264}
I'm trying to solve the equation
diff(y(x), x) = -A*y(x)/x+x^alpha*(C+(y(x)^alpha/x^alpha-C)^(-gamma))/y(x)^alpha
i.e
and I'm getting the following answer
y(x) = RootOf(-ln(x)-Intat(_a^alpha/(_a^(1+alpha)*A-C-(_a^alpha-C)^(-gamma)+_a^(1+alpha)), _a = _Z)+_C1)*x
i.e
Please tell me what exactly is '_a' and '_Z'. I'm finding it hard to understand this language.
I'm doing a Maximum/Minimum problem ( Calculus 3).
I need to plot f(x,y) =   x2  + y 2 -2y + 1
over R={x,y): x 2 + y 2         (less than or equal sign) 4}
When I use Maple solve on functions that involves exp, ln to decide the maxima, minima points by solving derivative equals zero, it only returns the first point, not the second point.
Which by definition it shall return two points, one at 2.030837315, the other around 6.7.
See the Maple code and exported PDF attached.
Maple_Solve_MinMaxma.mw
Maple_Solve_MinMaxma.pdf
Digits:=10;
to 10 do
evalf(add(sin(k), k = 1 .. 10000)) od;
10
1.633891035
1.633891035
1.633891035
1.633891046
1.633891046
1.633891046
1.633891012
1.633891012
1.633891012
1.633891049
restart;   # execute several times to obtain randomness
`Standard Worksheet Interface, Maple 2016.2, Windows 7, January 13 2017 Build ID 1194701`
Digits:=18;
18
to 10 do
1.63389102179246197
1.63389102179246223
1.63389102179246223
1.63389102179246233
1.63389102179246233
1.63389102179246242
1.63389102179246242
1.63389102179246371
1.63389102179246371
1.63389102179246410
Hello i need a tutor to help me with  Numerical analysis on Maple and the programming part. Im In UAE but we can do this online as well
The excel file consists of data (v2, Re, t) and I would like plot the variable "t" aginst the variables "v2" and "Re". Could anyone point me out?
Attached is the excel data.Collapsetime.xlsx
Very kind wishes,
Wang Zhe
Hello, everyone. I have a group project where we have to explain the Josephus problem and use Maple to solve the problem. I am trying to solve the problem in multiple ways (because why not), but I am struggling with my third procedure. I understand the logic behind it and how its supposed to achieve O(k*logn), but the code that I wrote for it doesn't seem to produce the correct result.
JosephusImproved := proc (n, k)
local count, result:
if n = 1 then
return 0:
elif 1 < n < k then
return JosephusImproved(n - 1, k) + k + 1 mod n:
count := floor(n / k):
result := JosephusImproved(n - count, k):
result := result - n mod k:
if result < 0 then
result := result + n
result := floor(result /(k - 1)):
return result:
end if:
end if:
Note: The regular recursive expression [Josephus(n - 1, k) + k + 1 mod n] has a "+ 1" since that was the only way I could make Maple do the calculation correctly. Proven with a Cyclic procedure I already made.
Note 2: I am using Maple 2016 and 2D Math.
I would like some insight as to how I could fix this so that it works, just like the regular recursive procedure and cyclic list that I have.
Cheers.
I am plotting the following function using implicitplot command.:
plots[implicitplot3d]((17.31626331*M^3-(4*(z[1]-z[2])^2*M^2-1.171300684*(z[1]+z[2])^2)*(1.082266457-2*M)*(1.082266457-3*M))^2 = 4.598621420*(z[1]+z[2])^2*M*(1.082266457-2*M)^3*(4*(z[1]-z[2])^2*M^2-1.171300684*(z[1]+z[2])^2), M = 0 .. 1, z[1] = 0 .. 10, z[2] = -10 .. 0);
How can I extract data points from the plot obtained
Ive been trying to plot the following system
With these initial conditions (Also G*M=1)
ics:=[x(0)=1, y(0)=0,vx(0)=0,vy(0)=1];
I use this command to try and do this
with(DEtools):
DEplot(subs({G=1,M=1},satODE1),{x(t),y(t),vx(t),vy(t)},t=-2..2,ics,scene=[x(t),y(t)],scaling=constrained);
But I get this error message
Error, (in DEtools/DEplot/CheckInitial) too few initial conditions: [x(0) = 1]
Which I find odd because I have an initial condition for each variable
Im not sure what makes this different to other DE's Ive plotted other than having more equations in the system
How can I plot a paraboloid?
How can I accelerate the convergence rate of the following series:
First 1031 1032 1033 1034 1035 1036 1037 Last Page 1033 of 2462
