I fail to understand from the manual how to do total differentiation.
e.g let's say I have a trivial transform defined as
u=t(x,y)-s(x,y);
then I should get
du=diff(t,x)dx+diff(t,y)dy ...etc
Apparently the operator D_Dx should be able to perform the total derivative, but somehow I cant see this is possible.
What do I miss ?
I was attempting to remove part of string using StringTools:-Remove()
But it causes server.exe crash each time.
Any idea why this happens?
Worksheet below
`The "Physics Updates" version in the MapleCloud is 1735. The version installed in this computer is 1732 created 2024, April 17, 19:33 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
ode:=x*y(x)*diff(y(x), x) = (x + 1)*(y(x) + 1):
ode:=diff(y(x), x$2) = (y(x) + 1):
the_output:=Student:-ODEs:-ODESteps(ode,y(x)):
s:=latex(the_output,'output'=string):
StringTools:-Remove(s,"\\begin{array}{ccc}");
Download crash_during_string_tools_remove_maple_2024.mw
ps. reported to Maplesoft also.
Maple dsolve fails to find many singular solutions using the option 'singsol'=all.
Any idea why that is? Here is one example
ode:=diff(y(x),x)=(y(x)-3)^2;
dsolve(ode,y(x),'singsol'=all)
It returns
But we see that y=3 is singular solution which can't be obtained from the above solution for any value of c1
Mathematica finds this singular solution
ode=y'[x]==(y[x]-3)^2
DSolve[ode,y[x],x,IncludeSingularSolutions->True]
Here is second example.
ode:=diff(y(x),x)=2*x*sqrt(1-y(x)^2);
Gives
But it misses the y=1,y=-1 singular solutions.
Is there something I am doing wrong? Why does Maple sometimes fail to find singular solutions?
ps. reported to Mapesoft also.
Update
I remembered now a case similar to this. one has to use `Lie` solver and now Maple gives the singular solution
dsolve(ode,Lie,'singsol'=all)
There is no mention of this in help and it is still not clear to me if one has to always use Lie solver to obtain singsol or if this is just a coincidence for this one case.
Same for the other case:
dsolve(ode,'Lie','singsol'=all)
gives
I think singsol should work all the time and not only when using specific solver. If Lie solver is needed for singsol to work, then help should be clear and say this.
Consider the following exact algebraic number expr
kernelopts('version'):
Physics:-Version():
expr := Physics:-`*`(2-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2), sqrt(1-(1-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2))^2))+Physics:-`*`(Physics:-`*`(3+Physics:-`*`(4, 1-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2)), 1/12), sqrt(3-Physics:-`*`(4, (1-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2))^2)))+Physics:-`*`(Physics:-`*`(2, Physics:-`*`(2-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2), 1/3)), sqrt(Physics:-`*`(Physics:-`*`(2, 2-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2)), 1-Physics:-`*`(2, 1-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2)))))+Physics:-`*`(Physics:-`*`(1+Physics:-`*`(2, 1-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2)), 1/6), sqrt(Physics:-`*`(2, (1/4)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2)^2-Physics:-`*`(3, (1-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345, index = 2)-1/2)^2))^2)))):
CodeTools:-Usage(PolynomialTools:-MinimalPolynomial(expr));
memory used=0.97MiB, alloc change=12.00KiB, cpu time=31.00ms, real time=27.00ms, gc time=0ns
27*_X^2+70*_X-433
evalf[30](eval(27*_X^2+70*_X-433, _X = expr));
0.262508598220109180966e-6
"evalf((mp:=CodeTools:-Usage(evala(':-Minpoly'(expr,_X)))));"
memory used=70.25GiB, alloc change=48.00MiB, cpu time=23.63m, real time=21.81m, gc time=3.18m
-422.3889573*_X+2208.949800*_X^4-225.8139518*_X^3-230.2173498*_X^2+59.33811620+_X^10-19.92850932*_X^9+166.6440365*_X^8-755.9985571*_X^7+1997.484781*_X^6-3014.379082*_X^5
type(mp, polynom(rational, _X))
Download wrong_minpoly.mw
I would like to find its minimal polynomial (without a priori knowledge).
According to the documentation,
if is an exact algebraic number, and and are not given, then PolynomialTools:-MinimalPolynomial(expr) will call  to compute an exact minimal polynomial of . If a name is not specified for the variable , then  will be used.
Regretfully, it is easy to see that the minimal polynomial of expr cannot be the returned 27*_X^2 + 70*_X - 433. And when I invoke  directly, the result is still not correct (and this evaluation takes a rather long time).
Another help page mentions that
the call mp := evala(Minpoly(expr, _X)) computes the monic minimal polynomial of  in the variable  over the field of rational numbers (or multivariate rational functions); the resulting polynomial will not contain any algebraic numbers or functions.
However, as type(mp, polynom(rational, _X)) gives , we know that cannot be the desired minimal polynomial of expr either.
So, what is the proper way to compute the minimal polynomial of expr in Maple?
Code:
use alpha=1-(1/2)/(1-(RootOf(16*_Z*(_Z*(2*_Z*(_Z*(8*_Z*(_Z*(_Z*(_Z*(32*_Z*(8*_Z-33)+1513)-812)-13)+267)-1469)-330)+811)+279)+345,index=2)-1/2)**2) in
	expr:=(1+alpha)*sqrt(1-alpha**2)+(3+4*alpha)/12*sqrt(3-4*alpha**2)+2*(1+alpha)/3*sqrt(2*(1+alpha)*(1-2*alpha))+(1+2*alpha)/6*sqrt(2*((1-alpha)**2-3*alpha**2))
end:
Of note, the minimal polynomial of an algebraic number zeta is the unique irreducible monic polynomial of smallest degree p(x) with rational coefficients such that p(zeta)=0 and whose leading coefficient is 1
I have a set of 3 differential equations called "odesys" that I need to solve. I input this line to solve them and I get the following error.
sols := dsolve([odesys, ICs], {Theta[1](t), Theta[2](t), Theta[3](t)})
Error, (in dsolve) not a system with respect to the unknowns {Theta[1](t), Theta[2](t), Theta[3](t)}
I've also tried it using the exact syntax that the thetas are in the equation and I get this error.
sols := dsolve([odesys, ICs], {Theta(t)[1], Theta(t)[2], Theta(t)[3]});
Error, (in dsolve) required an indication of the solving variables for the given system
I don't know even know which error message is better. The equations are second order and non-linear if that has any bearing on anything.
How to convert a ploting values in a graph to excel?
with(PDETools): with(DETools): with(plots):with(plottools):
eq1 := ((D@@2)(f))(eta)*f(eta)*sin(alpha)+((D@@2)(f))(eta)*eta*cos(alpha)+2*((D@@3)(f))(eta) = 0;
ics := f(0) = 0, (D(f))(0) = 0, (D(f))(10) = 1; bcs := (D(f))(10) = 0, theta(10) = 0, phi(10) = 0;
Parameters1 := alpha = (1/3)*Pi;
sol1 := dsolve(eval({eq1, ics}, {Parameters1}), numeric);
p1 := odeplot(sol1, [[eta, ((D@@2)(f))(eta)]], eta = 0 .. 10, color = [red], axes = boxed);
display({p1});
To simplify, I will use some of my test code, but I need to use a vector index within a sum.
m=Vector[column](3, [1, 1, 1]);
sum(L[k], k = 1 .. 3) ;
returns "Error, bad index into Vector"
is there a way around this problem?
I am particularly interested in a full coordplot3d display for ellipsoidal coords.
the BlockCopy command is a miracle for me that I don't understand. Is there an easier command or an easy to understand documentation?
Dear all, I'm new with maple. How can I extend an existing matrix?
XX := Matrix(2, 4, [[1, 1, 1, 1], [2, 2, 2, 2]])
extend(XX,1,0,0) # doesn't work
Thanks for help
I am trying to solve several problems of  solving  around 200 undetermined variables out of a set of aroud 300 2nd-order equations (such as a*b=c).
I just use "solve" command.
1. Maple continuingly evaluates and does not return result, how to make it work?
2. In some problems, i have results, but there are great of freedom, which i want to restrict them in some way.
As the following worksheet shows,
kernelopts('version');
`Maple 2024.0, X86 64 WINDOWS, Mar 01 2024, Build ID 1794891`
`The "Physics Updates" version in the MapleCloud is 1732 and is the same as the version installed in this computer, created 2024, April 12, 17:58 hours Pacific Time.`
with(RealDomain):
eval(MTM:-det(<
   a, b/2, d/2 |
   b/2, c, e/2 |
   d/2, e/2, f
  >), PDETools:-Solve(MTM:-det(<
     x**2 + y**2, x1**2 + y1**2, x2**2 + y2**2, x3**2 + y3**2 |
     x, x1, x2, x3 |
     y, y1, y2, y3 |
     1, 1, 1, 1
    >) = inner([a, b, c, d, e, f], [x**2, x*y, y**2, x, y, 1]),
   {f, e, d, c, b, a}, 'independentof' = {y, x}))/MTM:-det(<
  x1, x2, x3 |
  y1, y2, y3 |
  1, 1, 1
 >): simplify(`%`);
-(1/4)*(x1^2-2*x1*x2+x2^2+(y1-y2)^2)*(x2^2-2*x2*x3+x3^2+(y2-y3)^2)*(x1^2-2*x1*x3+x3^2+(y1-y3)^2)
eval(MTM:-det(<
   a, b/2, d/2 |
   b/2, c, e/2 |
   d/2, e/2, f
     x**2 - y**2, x1**2 - y1**2, x2**2 - y2**2, x3**2 - y3**2, x4**2 - y4**2 |
     x*y, x1*y1, x2*y2, x3*y3, x4*y4 |
     x, x1, x2, x3, x4 |
     y, y1, y2, y3, y4 |
     1, 1, 1, 1, 1
   {f, e, d, c, b, a}, 'independentof' = {y, x}))/(MTM:-det(<
   x2, x3, x4 |
   y2, y3, y4 |
   1, 1, 1
  >)*MTM:-det(<
   x3, x4, x1 |
   y3, y4, y1 |
   1, 1, 1
  >)*MTM:-det(<
   x4, x1, x2 |
   y4, y1, y2 |
   1, 1, 1
  >)*MTM:-det(<
   x1, x2, x3 |
   y1, y2, y3 |
   1, 1, 1
  >)): simplify(`%`);
(1/4)*((x2-x3)*x1-x2*x4+x3*x4+(y2-y3)*(y1-y4))*((x3-x4)*x1+(x4-x3)*x2+(y3-y4)*(y1-y2))*((x2-x4)*x1-x2*x3+x3*x4+(y2-y4)*(y1-y3))
Download Why_not_consider_subexpressions?.mw
the underlined part is evidently not the simplest. (For instance, shouldn't RealDomain:-simplify(x2^2 - 2*x2*x3 + x3^2 + (y2 - y3)^2, 'size') and RealDomain:-simplify((x2-x3)*x1-x2*x4+x3*x4+(y2-y3)*(y1-y4), 'size') be converted into RealDomain:-simplify((x2 - x3)^2 + (y2 - y3)^2, 'size') and RealDomain:-simplify((x2 - x3)*(x1 - x4) + (y2 - y3)*(y1 - y4), 'size')?)
If I understand correctly, , by default, should try combining every part of an expression with every other to apply a vast range of potential transformations to look at many different forms of it and make progress in picking out the simplest possible one. So, why is simplify unable to touch certain sub-expressions when they are encountered at intermediate stages in a computation?
I have a double for loop which has a numeric integration located inside of the innermost loop. When I try to run my worksheet I recieve an error in which the numeric integration is not computed for a certain set of values in my loops. If I take these two values and input them into my function and then integrate outside of the loop it appears to work just fine. Not sure what to make of this. Any thoughts would be appreciated.
Secondly, to avoid any confusion about what I am trying to do and if someone has general comments on my worksheet I added some text in the worksheet to describe what I am interested in doing, even though I am sure most people here would be able to figure that out from the commands alone.
LoopError.mw
Could someone be able to spot why I get different solution when solving for the constant of integration from this Maple dsolve solution manually than when asking Maple to do it directly?
This is the ode
ode:=x*y(x)*diff(y(x), x) = (x + 1)*(y(x) + 1);
ic:=y(1) = 1;
If I ask Maple to solve it with the IC all at once, it gives solution which odetest verifies OK.
If I ask Maple to solve it with no IC, then solve the constant myself and plug the constant back into the solution I get solution which does not verify any more.
I am not able to find why. Could someone spot the error in this? Please see worksheet below. I suspect the problem is when plugging back the constant of integration into the general solution, but have no idea now what it is. Clearly Maple did something much smarter than what I did by just plugging the constant back into the solution. May be need to specify what branch to use when plugging the constant back? but how do I know which one?
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1730 and is the same as the version installed in this computer, created 2024, April 17, 19:33 hours Pacific Time.`
ic:=y(1) = 1;
sol_no_IC:=dsolve(ode);
x*y(x)*(diff(y(x), x)) = (x+1)*(y(x)+1)
y(1) = 1
y(x) = -LambertW(-exp(-x-1)/(x*c__1))-1
sol_with_IC_direct:=dsolve([ode,ic]);
odetest(sol_with_IC_direct,[ode,ic]);
y(x) = -LambertW(-1, -2*exp(-x-1)/x)-1
[0, 0]
#this verifies Maple found correct constant also:
solve(rhs(sol_with_IC_direct)=rhs(sol_no_IC),c__1)
1/2
#now solve for constant of integration manually. This gives invalid solution. Why?
eq:= 1=limit(rhs(sol_no_IC),x=1);
1 = -LambertW(-exp(-2)/c__1)-1
PDEtools:-Solve(eq,c__1);
c__1 = 1/2
sol_with_ic:=eval(sol_no_IC,%)
y(x) = -LambertW(-2*exp(-x-1)/x)-1
odetest(sol_with_ic,[ode,ic]);
[0, 2+LambertW(-2*exp(-2))]
Download why_wrong_solution.mw
How to show that any Pythagorean triplet can be obtained from <3,4,5> ? Thank you.
Can we simplify this program?
#Génération Géométrique et Algébrique des triplets Pythagoriciens
with(geometry);
with(LinearAlgebra);
_EnvHorizomtalName = 'x';
_EnvVerticalName = 'y';
with(plottools);
P := point([0, 0], color = black, symbol = cross, symbolsize = 25);
Oo := point([1/2, 1/2], color = black, symbol = cross, symbolsize = 25);
A := point([1, 1/2], color = black, symbol = cross, symbolsize = 25);
c1 := circle([1/2, 1/2], 1/2, color = blue);
NULL;
PA := line([0, 0], [1, 1/2], color = red);
eqC := (x - 1/2)^2 + (y - 1/2)^2 = 1/4;
eqPA := y = 1/2*x;
sol := solve({eqC, eqPA}, {x, y});
t1 := textplot([0, 0, 'typeset'("P"), font = [Times, Bold, 14]], 'align' = 'above');
t2 := textplot([1, 1/2, 'typeset'("A"), font = [Times, Bold, 14]], 'align' = 'right');
t3 := textplot([1/5, 1/10, 'typeset'("A'"), font = [Times, Bold, 14]], 'align' = 'above');
A1 := point([1 - 1/5, 1/10], color = black, symbol = cross, symbolsize = 25);
diff(A, x) := point([1/5, 1/10], color = black, symbol = cross, symbolsize = 25);
t4 := textplot([1 - 1/5, 1/10, 'typeset'("A1"), font = [Times, Bold, 14]], 'align' = 'right');
A2 := point([1 - 1/5, 1 - 1/10], color = black, symbol = cross, symbolsize = 25);
t5 := textplot([1 - 1/5, 1 - 1/10, 'typeset'("A2"), font = [Times, Bold, 14]], 'align' = 'right');
A3 := point([1/5, 1 - 1/10], color = black, symbol = cross, symbolsize = 25);
t6 := textplot([1/5, 1 - 1/10, 'typeset'("A3"), font = [Times, Bold, 14]], 'align' = 'right');
poly := Matrix([[1/5, 1/10], [1 - 1/5, 1/10], [1 - 1/5, 1 - 1/10], [1/5, 1 - 1/10]], datatype = float);
pol := polygonplot(poly, color = blue, transparency = 0.95);
display(c1, P, Oo, A, PA, seq(A || i, i = 1 .. 3), seq(t || i, i = 1 .. 6), pol, scaling = constrained, axes = none, size = [600, 600]);
R1 := Transpose(<<1, -2, 2> | <2, -1, 2> | <2, -2, 3>>);
R2 := Transpose(<<1, 2, 2> | <2, 1, 2> | <2, 2, 3>>);
R3 := Transpose(<<-1, 2, 2> | <-2, 1, 2> | <-2, 2, 3>>);
V := <3, 4, 5>;
MatrixVectorMultiply(R1, V);
MatrixVectorMultiply(R2, V);
MatrixVectorMultiply(R3, V);
t1 := <2225, 3648, 4273>;
t2 := MatrixVectorMultiply(1/R1, t1);
t3 := MatrixVectorMultiply(1/R3, t2);
t4 := MatrixVectorMultiply(1/R2, t3);
t5 := MatrixVectorMultiply(1/R1, t4);
t6 := MatrixVectorMultiply(1/R3, t5);
MatrixVectorMultiply(MatrixMatrixMultiply(MatrixMatrixMultiply(MatrixMatrixMultiply(MatrixMatrixMultiply(R1, R3), R2), R1), R3), V);
% - t1;
NULL;
First 110 111 112 113 114 115 116 Last Page 112 of 2426
