Hopefully, this is a question relating to Mathematica, which I find virtually unreadable, and the Statistics package, which I am minimally familiar with, that someone can answer quickly.
Hence, could someone translate the following Mathematica code into Maple code? (The MmaTranslator failed at the 2nd line.)
func[x_] := 1/(1 + Sinh[2*x]*(Log[x])^2);
Distrib[x_, average_, var_] :=   PDF[NormalDistribution[average, var], 1.1*x - 0.1];
n = 10;
RV = RandomVariate[TruncatedDistribution[{0.8, 3}, NormalDistribution[1, 0.399]], n];
Int = 1/n Total[func[RV]/Distrib[RV, 1, 0.399]]*Integrate[Distrib[x, 1, 0.399], {x, 0.8, 3}]
hi , there is a simple expression ,
1D-input code:
3*G*(`Δγ`*H - `σy`(`Δγ`) + q)/(-q + `σy`(`Δγ`))^2;
and I want to simplify it like below ,but failed  ,
hope for the result:
3*G*`Δγ`*H/(q - `σy`(`Δγ`))^2 - 3*G/(q - `σy`(`Δγ`));
then  I'd like to use algsubs , but again  a error occurs.
1D-input :
algsubs(3*G*`Δγ`/(q - `σy`(`Δγ`)) = y, 3*G*`Δγ`*H/(q - `σy`(`Δγ`))^2 - 3*G/(q - `σy`(`Δγ`)));
hope for some suggestions . thanks!
I think I found another clitch in odetest.
dsolve gives correct solution to this first order ode with IC. But odetest does not verify that the solution is satisfied for the IC part, but only for the ode itself.
Below worksheet confirms the solution is also valid for the IC.   So why odetest does not give 0 for the IC part?
`The "Physics Updates" version in the MapleCloud is 1727. The version installed in this computer is 1725 created 2024, April 15, 17:29 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
libname;
ode:=x^2*diff(y(x),x)*cos(y(x))+1=0;
ic:=y(infinity)=Pi/3; #16/3*Pi;
sol:=dsolve([ode,ic]);
odetest(sol,[ode,ic])
x^2*(diff(y(x), x))*cos(y(x))+1 = 0
y(infinity) = (1/3)*Pi
y(x) = arcsin((1/2)*(3^(1/2)*x+2)/x)
[0, (1/3)*Pi]
#we see that odetest think the solution does not verify the IC. But it does
IC_eq:=Pi/3=limit(rhs(sol),x=infinity)
(1/3)*Pi = (1/3)*Pi
Download odetest_does_not_verfiy_correct_solution_maple_2024_april_18_2024.mw
I think what odetest did is not use limit when plugging in the values. That is why.
If we do not use limit, this is what happens:
IC_eq:=Pi/3=eval(rhs(sol),x=infinity)
And this explains the odetest output. It should have used limit.
ps. just in case also reported to Maplesoft support.
Hi, I am trying to illustrate the concept of solid areas, and I'm wondering if there's a way to easily develop them (representing each of their faces in two dimensions on the same plane) using Maple? Thank you for your help
SolidesDév.mw
Every last query I make in the AI Formula Assistant returns this message...
This happens even when I use a basic canned query shown in use-case examples (e.g., surface area, sphere).
I have accepted the Terms of Use.  Is there some other setting I need to enable? Thanks.
For the following program using dsolve to solved a differential equation with a sum of exponential inputs, the time required has a huge dependence on subtle difference in paramters.
For example, if Cl := 0.32, calculation time is 1.4 sec.    If Cl := 0.33,  calculation time is 39 sec.
Also, calculation time seems to have huge dependence  on whether or not I truncate M
Can someone please explain what is going on?
st := time();
N := 4;
T := 5.0/60;
M := 6905;
dose := t -> M*sum(Heaviside(t - 24*k/N)*exp((-t + 24*k/N)/T), k = 0 .. 2*N - 1);
Cl := 0.32;
deq := diff(C(t), t) = dose(t) - Cl*C(t);
sol := t -> rhs(dsolve({deq, C(0) = 0}));
p := plot(sol(t), t = 0 .. 48);
time() - st;
                             1.360
I tried to solve a Blasius problem (available in maple), but I have an error. How to solve this issue.
Download Shoot_Blasius_solution.mw
What might be the reason for the GUI loosing icons during a session? It looks like this
Mouse over let the icons reappear.
This problem is not new to me and only happens from time to tim
I have not found out under what conditions this happens.
The only thing I can say is that I didn't see it after restarting Maple.
And: Only the icons on the left-most disappear.
Everything under Windows 10
Has anyone seen the same thing?
Any idea how to fix this?
I'm trying derive the equation for a matching resistor pad.  In order for me to get a solution (eg for R2), I had to "manually" solve the one equation and then substitute the resulting value in the other.  Why doesn't solve do the same thing?
NULLeq1 := (R2+Rhi)*R1/(R1+R2+Rhi) = Rlo
eq2 := R1*Rlo/(R1+Rlo)+R2 = Rhi
R1sol := solve(eq2, R1)
-Rlo*(R2-Rhi)/(R2-Rhi+Rlo)
R2sol := solve(subs(R1 = R1sol, eq1), R2)
(Rhi^2-Rhi*Rlo)^(1/2), -(Rhi^2-Rhi*Rlo)^(1/2)
NULLeq1 := (R2+Rhi)*R1/(R1+R2+Rhi) = RloNULL
NULLeq2 := R1*Rlo/(R1+Rlo)+R2 = RhiNULL
s := `assuming`([solve({eq1, eq2}, {R1, R2})], [`and`(Rhi > 0, Rlo > 0)])
{R1 = RootOf((Rhi-Rlo)*_Z^2-Rhi)*Rlo, R2 = -(RootOf((Rhi-Rlo)*_Z^2-Rhi)*Rhi-RootOf((Rhi-Rlo)*_Z^2-Rhi)*Rlo-Rhi)/(RootOf((Rhi-Rlo)*_Z^2-Rhi)-1)}
Download for_help.mw
ras5_v1.mw
How can I  change eq13 to eq14 without using op command manually?
Thank you for your help in advance,
I want to solve a big system of equations. There are 32 equations and 32 variables. Furthermaore there are a few restrictions to 8 of those variables, for example 0<t, t<1. I put the restrictions into the set of equations I want to solve. Normaly its works quite well, but today, one of the solutions was t=-2.0000000000. But this does not fit to the inequalitys I gave into the programm. Why is that? Is there a diffrence if I mark a set of inequalitys as restrictions and put them as a further property into the solve command comparded to use those inequalitys as additional equations?
I am the administrator of Maple in my school, and all the students use Maple in part of their exams. Is it possible  to block the access to ChatGPT thru eg. the firewall or otherwise during exams.
The reason for this question is that the students must have access to some internet sources during exams, but definately not CharGPT.
Kind regards
Per Kirkegaard
Hello, I try to solve the equations of the odometric model with the Maple 2024 but I have not the answers as with the hands, can you help me to verify it ?
dsolve(diff(phi(t), t) = tan(10*t)/5)
dsolve(diff(x(t), t) = V*cos(ln(1 + tan(10*t)^2)/100))
dsolve(diff(y(t), t) = V*sin(ln(1 + tan(10*t)^2)/100))
Best regards, Edern Ollivier.
I noticed that Student:-ODEs:-ODESteps does not use the newer subscripted constant of integrations for solution of odes which looks much nicer.
Is there a way to make it use same constant of integrations as dsolve() does? Compare
This is on a worksheet using typesetting level extended. Worksheet is attached
`The "Physics Updates" version in the MapleCloud is 1724 and is the same as the version installed in this computer, created 2024, April 15, 17:29 hours Pacific Time.`
#to make Maple use the new constant of integrations. Is this still needed in Maple 2024?
dsolve(diff(y(x),x$9)=1,arbitraryconstants=subscripted):
pdsolve(diff(psi(x,t),x$9)=0,arbitraryfunctions=subscripted):
ode := diff(y(x), x$2) + 2*y(x) = 0;
Student:-ODEs:-ODESteps(ode,y(x));
ode := diff(y(x), x, x)+2*y(x) = 0
"[[,,"Let's solve"],[,,((&DifferentialD;)^2)/(&DifferentialD;x^2) y(x)+2 y(x)=0],["&bullet;",,"Highest derivative means the order of the ODE is" 2],[,,((&DifferentialD;)^2)/(&DifferentialD;x^2) y(x)],["&bullet;",,"Characteristic polynomial of ODE"],[,,r^2+2=0],["&bullet;",,"Use quadratic formula to solve for" r],[,,r=(0+/-([]))/2],["&bullet;",,"Roots of the characteristic polynomial"],[,,r=(-&ImaginaryI; sqrt(2),&ImaginaryI; sqrt(2))],["&bullet;",,"1st solution of the ODE"],[,,y[1](x)=cos(sqrt(2) x)],["&bullet;",,"2nd solution of the ODE"],[,,y[2](x)=sin(sqrt(2) x)],["&bullet;",,"General solution of the ODE"],[,,y(x)=C1 y[1](x)+C2 y[2](x)],["&bullet;",,"Substitute in solutions"],[,,y(x)=C1 cos(sqrt(2) x)+C2 sin(sqrt(2) x)]]"
#compare to this output
dsolve(ode,y(x));
y(x) = c__1*sin(2^(1/2)*x)+c__2*cos(2^(1/2)*x)
Download make_step_solution_use_new_constant_of_integration.mw
Hello Everyone;
I need to find the bifurcation point and further bifarcation diagram for the given model. But facing error. Can anybody help to do this? Can you refer some library for bifurcation analysis of ODE's? Code is attched. Thanks in Advance.
123.mw
C_m := 1.0; g_K := 36.0; I_inj := 0; g_L := .3; E_Na := 50.0; E_K := -77.0; E_L := -54.4
alpha_m := (.1*(V-25.0))/(1-exp(-(V-25.0)*(1/10))); beta_m := 4*exp(-V/(18.0)); alpha_h := 0.7e-1*exp(-V/(20.0)); beta_h := 1/(1+exp(-(V-30)*(1/10))); alpha_n := (0.1e-1*(V-10.0))/(1-exp(-(V-10.0)/(10.0))); beta_n := .125*exp(-V/(80.0)); I_Na := g_Na*m^3*h*(V-E_Na); I_K := g_K*n^4*(V-E_K); I_L := g_L*(V-E_L)
.125*exp(-0.1250000000e-1*V)
(1.1)
eq1 := (I_inj-I_Na-I_K-I_L)/C_m; m := alpha_m/(alpha_m+beta_m); n := alpha_n/(alpha_n+beta_n); h := alpha_h/(alpha_h+beta_h)
-16.32000000-1.000000000*g_Na*m^3*h*(V-50.0)-36.00000000*n^4*(V+77.0)-.3000000000*V
.1*(V-25.0)/((1-exp(-(1/10)*V+2.500000000))*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V)))
0.1e-1*(V-10.0)/((1-exp(-.1000000000*V+1.000000000))*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V)))
0.7e-1*exp(-0.5000000000e-1*V)/(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3)))
(1.2)
bif_eq1 := eq1 = 0;
-16.32000000-0.7000000000e-4*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))-0.3600000000e-6*(V-10.0)^4*(V+77.0)/((1-exp(-.1000000000*V+1.000000000))^4*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^4)-.3000000000*V = 0
bif_eq2 := diff( eq1, V) = 0;
-0.2100000000e-3*g_Na*(V-25.0)^2*exp(-0.5000000000e-1*V)*(V-50.0)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))+0.2100000000e-4*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)*exp(-(1/10)*V+2.500000000)/((1-exp(-(1/10)*V+2.500000000))^4*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))+0.2100000000e-3*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)*(.1/(1-exp(-(1/10)*V+2.500000000))-0.1000000000e-1*(V-25.0)*exp(-(1/10)*V+2.500000000)/(1-exp(-(1/10)*V+2.500000000))^2-.2222222222*exp(-0.5555555556e-1*V))/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^4*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))+0.3500000000e-5*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))+0.7000000000e-4*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)*(V-50.0)*(-0.3500000000e-2*exp(-0.5000000000e-1*V)+(1/10)*exp(-(1/10)*V+3)/(1+exp(-(1/10)*V+3))^2)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3)))^2)-0.7000000000e-4*g_Na*(V-25.0)^3*exp(-0.5000000000e-1*V)/((1-exp(-(1/10)*V+2.500000000))^3*(.1*(V-25.0)/(1-exp(-(1/10)*V+2.500000000))+4*exp(-0.5555555556e-1*V))^3*(0.7e-1*exp(-0.5000000000e-1*V)+1/(1+exp(-(1/10)*V+3))))-0.1440000000e-5*(V-10.0)^3*(V+77.0)/((1-exp(-.1000000000*V+1.000000000))^4*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^4)+0.1440000000e-6*(V-10.0)^4*(V+77.0)*exp(-.1000000000*V+1.000000000)/((1-exp(-.1000000000*V+1.000000000))^5*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^4)+0.1440000000e-5*(V-10.0)^4*(V+77.0)*(0.1e-1/(1-exp(-.1000000000*V+1.000000000))-0.1000000000e-2*(V-10.0)*exp(-.1000000000*V+1.000000000)/(1-exp(-.1000000000*V+1.000000000))^2-0.1562500000e-2*exp(-0.1250000000e-1*V))/((1-exp(-.1000000000*V+1.000000000))^4*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^5)-0.3600000000e-6*(V-10.0)^4/((1-exp(-.1000000000*V+1.000000000))^4*(0.1e-1*(V-10.0)/(1-exp(-.1000000000*V+1.000000000))+.125*exp(-0.1250000000e-1*V))^4)-.3000000000 = 0
bif_sol := solve({ bif_eq1,bif_eq2}, {V, g_Na});
as the solutions, which are then expressed as the points mu, y via
[Back to ODE Powertool Table of Contents]
First 112 113 114 115 116 117 118 Last Page 114 of 2426
